[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
Hi ich hab Win8 und defrag gibts da ja nicht mehr sondern Optimieren wie ihr sicher alle wisst.
Bei Optimieren löst bei SSDs den Trimbefehl aus.
Seit dem ich das neue Bios darauf hab ist das optimieren bei der SSD ausgegraut.
Ist das bei euch auch so?
OK danke wird sich meine Frau freuen.
Hi Wotan hast jetzt gewechselt?
- - - Updated - - -
@labview
fino a quando si riesce ad aggiornare il bios che
Molte grazie e ortografia non importa
Greats Marc
hallo :)
ok Jungs, ich habe all das BIOS und Changelog aktualisiert
Achtung
Aktualisieren Sie den BIOS nicht, wenn es in OC ist, immer default.
Warum nicht mit OC???
Macht das Probleme und ist dass auch beim alten Bios so?
Update des BIOS in OC ist sehr gefährlich wenn Ihr PC ist nicht stabil.
Macht ja auch sinn man muss ja mach denn Update sowieso alles neu einstellen.
Hi Labview du bist der Beste.
Nur aus Neugier welches OROM hast du benutzt das orginale oder das Raid0 Modifizierte?
Ich muss sagen deine Site wird immer besser und besser
Gruß Marc
Bei mir auch ohne Probleme mit der neuen Mod UEFI Version.
Nochmals danke am labview.
@labview
Bitte dann auch für das Mainboard meiner Frau, ASRock Z68 Professional Gen3
http://www.mdclab.it/BIOS-TEMP/FP-P67-Trim.zip
hallo Jungs, Ich stellte die Beta-BIOS mit dem Modul mod (für P67)
Ich brauche ein Meerschweinchen mit RAID 0 SSD
- - - Updated - - -
to verify the TRIM:
open prompt command to administrator and paste: fsutil behavior query disabledeletenotify
Result = 0 (trim active), 1 (trim don't active)
to force the boot: fsutil behavior set disabledeletenotify 0
Hi this time in english
Hi Labview Bios is running and Trim is activ.
But the Method with "fsutil behavior query disabledeletenotify" is not right. it only says that Windows can use Trim or not.
If you have Win8 you can test it with Disk optimize if that option is there means Trim is runnig.
With Win7 you can use a tool called Trimcheck http://files.thecybershadow.net/trimcheck/trimcheck-0.7.exe
But TRIM IS RUNNIG MEGAAAAAAAAAAAA
Thank you very much
@labview
Thank you very much
Ops... Sorry for my instructions... :)
I have updated the my web site with the new BIOS
enjoy! :xmas:
“64bit Intel RSTe AHCI & RAID drivers v13.5.0.1056 mod by Fernando.rar”
Link
Hi hat noch wer das Board oder sind alle außer mir schon umgestiegen?
Ich habe seit heute das ASRock Z97 Professional. Ich hoffe das labview dafür auch Mod Bios produziert
Nur meine Frau hat noch ihr ASRock Z68 Professional Gen3
