[Sammelthread] ASRocks Fatal1ty P67 Professional
image.php
[/url]http://[/IMG]
  1. ASRock > Produkte > Fatal1ty P67 Professional
    *] Preise und Verfügbarkeit
    ASRock Fatal1ty P67 Professional, P67 (B3) (dual PC3-10667U DDR3) | Geizhals.at Deutschland
    ASRock Fatal1ty P67 Professional Sockel 1155 Mainboard: Mainboard Preisvergleich - Preise bei idealo.de
  2. Spezifikationen
    Sockel
    1155 Sandy Bridge​
    Prozessor
    Intel® Core™ i7-2600K/2600​
    Intel® Core™ i5-2300-2500/2500K​
    Intel® Core™i3-2100-2120​
    Chipsatz
    Intel® P67 Express​
    Steckplätze
    2x PCI 32 Bit Steckplätze
    32 Bit 5 Volt 33 Mhz
    2x PCIe 2.0 x1
    3x PCIe 2.0 x16 /1x16 oder 2 x8/x8 ; PCIE5: x4​
    BIOS
    64Mb AMI UEFI Legal BIOS with GUI support
    - Supports "Plug and Play"
    - ACPI 1.1 Compliance Wake Up Events
    - Supports jumperfree
    - SMBIOS 2.3.1 Support
    - DRAM, PCH, CPU PLL, VTT, VCCSA Voltage Multi-adjustment
    Arbeitsspeicher
    Dual Channel DDR3 memory technology
    4 x DDR3 DIMM slots Max. 32GB
    Supports DDR3 2133(OC)/1866(OC)/1600/1333/1066 non-ECC, un-buffered memory​
    Supports Intel® Extreme Memory Profile (XMP)​
    Audio
    7.1 CH HD Audio with Content Protection (Realtek ALC892 Audio Codec)
    - Premium Blu-ray audio support
    - Supports THX TruStudio PRO™​
    LAN
    - PCIE x1 Gigabit LAN 10/100/1000 Mb/s
    - Realtek RTL8111E
    - Supports Wake-On-LAN
    - Supports LAN Cable Detection
    - Supports Energy Efficient Ethernet 802.3az
    - Supports Dual LAN with Teaming function​
    SATA3
    2 x SATA3 6.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and "Hot Plug" functions
    - 4 x SATA3 6.0 Gb/s connectors by Marvell SE9120, support NCQ, AHCI and "Hot Plug" functions (SATA3_M4 connector is shared with eSATA3 port)​
    USB 3.0
    - 4 x Rear USB 3.0 ports by Etron EJ168A, support USB 1.0/2.0/3.0 up to 5Gb/s
    - 1 x Front USB 3.0 header (supports 2 USB 3.0 ports) by Etron EJ168A, supports USB 1.0/2.0/3.0 up to 5Gb/s
    - 4 x SATA2 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 10, RAID 5 and Intel® Rapid Storage), NCQ, AHCI and Hot Plug functions​
    Anschlüsse Board
    - 6 x SATA3 6.0 Gb/s connectors
    - 1 x ATA133 IDE connector (supports 2 x IDE devices)
    - 1 x Floppy connector
    - 1 x IR header
    - 1 x COM port header
    - 1 x HDMI_SPDIF header
    - 1 x IEEE 1394 header
    - 1 x Power LED header
    - CPU/Chassis/Power FAN connector
    - 24 pin ATX power connector
    - 8 pin 12V power connector
    - CD in header
    - Front panel audio connector
    - 4 x USB 2.0 headers (support 8 USB 2.0 ports)
    - 1 x USB 3.0 header (supports 2 USB 3.0 ports)
    - 1 x Dr. Debug with LED​
    Anschlüsse ATX-Blende
    - 1 x PS/2 Mouse Port
    - 1 x PS/2 Keyboard Port
    - 1 x Coaxial SPDIF Out Port
    - 1 x Optical SPDIF Out Port
    - 3 x Ready-to-Use USB 2.0 Ports
    - 1 x Fatal1ty Mouse Port (USB 2.0)
    - 1 x eSATA3 Connector
    - 4 x Ready-to-Use USB 3.0 Ports
    - 2 x RJ-45 LAN Ports with LED (ACT/LINK LED and SPEED LED)
    - 1 x IEEE 1394 Port
    - 1 x Clear CMOS Switch with LED
    - HD Audio Jack: Side Speaker / Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone​
    Mitgeliefertes Zubehör
    1 x SLI_Bridge
    1 x Drivers and Utilities CD
    1 x Front USB 3.0 Panel mit Aufnahme für 1.SSD !!
    1 x Rear USB 3.0 Bracket , einfach nur umschrauben !
    1 x Floppy/ATA 133 Kabel
    6 x SATA Data Kabel
    2 x SATA 1 to 1 Powerkabel​
  3. Bilder uneingebaut und eingebaut
  4. Bilder Bios Übersicht
  5. Bilder Bios OC Tweaker und Advanced
  6. RAM Liste
    ASRock > Produkte > Fatal1ty P67 Professional > Speicher Support Liste
  7. Getesteter Ram
    Corsair XMS3 DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CMX8GX3M2A1600C9) | Geizhals.at Deutschland
    G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL)
    Corsair XMS3 DIMM Kit 8GB PC3-16000U CL9-10-9-27 (DDR3-2000) (CMX8GX3M2A2000C9)
    Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-16000U CL8-9-8-24 (DDR3-2000) (CMT4GX3M2A2000C8)
    G.Skill ECO DIMM Kit 4GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7D-4GBECO)
  8. Download BIOS + Treiber
    ASRock > Produkte > Fatal1ty P67 Professional > Download
    Rest kommt nocht
    MfG
1.80 ??
Das ist aber schon sehr alt oder ?
Ich würde auf jeden fall ein Bios Update machen und dann schauen ob es geht.
Edit:
Der Code 97 bedeutet: Console Output devices connect.
Das heißt das er keine Grafikkarte findet
Sitzt Sie richtig im Sockel ?
Oder in welchem Sitzt Sie denn?
Gibt ja 3 Stück.
Von Oben ?
Und ich würde mal ein Update vom Bios machen.
@Lord Wotan
Hi kleine frage hast du noch die aktualisiert Bios-datei von der 3.21 ohne das BF logo?
Da ja pctreiber.net nicht mehr exisitent ist komm ich nicht mehr ran und ich müsste mein Bios flashen.
hm jetzt meldet mir gpuz, dass dass die graka mit pcie 1.1 läuft.. ist ne 3.0 karte sollte sie dann nicht mit 2.0 laufen oder ist das ein anzeigenfehler? o_O
mache mal Aktivitäten mit der Karte. Denn bei GPUZ schaltet ganz normal die Karte nach kurzer Zeit in Energiesparmodus PCIe x1. Bei Aktivitäten muss sie aber in Modus x2.0 schalten. x3.0 Unterstützt der P67Chipsatz nicht.
@Dracal2002
Mail mit Anlage ist raus.
Ist wohl ein Anzeigefehler da die ATI wohl Stromsparmodi hat und nutzt.
Ist bei meinen beiden GTX 570 auch so.
kein Problem.
jemand noch die einstellung für die wattzahlen zum ocen eines i7 2600k?
musste man doch was einstellen bei den power consumption etc?
besser fixed oder offset?
edit: so hab nun 42er multi und 1,18V für 2 stunden custom am rennen ohne fehler.
aber mein busclk ist nur bei 99,8mhz, daraus ergeben sich keine vollen 4200mhz.
jemand ne ahnung wie der hoch geht? 100mhz is ja eingestellt im bios
Ich muss auch 100.1 einstellen um 100 zu erhalten.
Ich mach offset denn warum soll die cpu im Idle volle Vcore bekommen
offset geht ja von der vid der cpu aus, richtig?
laut cpu-z habe ich ne vid von 1,334V bei meinem i7.
ergo muss der offset ja doch direkt -0,15v eingestellt werden? rein theoretisch..
Wenn ihr nen gleichmäßigen Bus Speed/BCLK haben wollt, stellt mal den Spread Spectrum von Auto auf Disabled.
@marques
offset hat nichts mit der VID zu tun zumindest wäre das jetzt neu für mich. Über den Offset kannst du halt den niedriegsten vcore Wert ermitteln wobei dein System auch in den IDLE taktet. Beim festeingestellen Wert stehen halt die volle GHz an. Der LLC Wert spielt da auch noch ne Rolle ;)
@marques
achso.
ja ok. so war das.
heißt im idle könnte das zu instabilitäten führen?
achso.
ja ok. so war das.
ja das gibt es sogar das die CPu unter volllast Stabil läuft aber wenn sie in den IDLE taktet kann es sein das die dann anliegende vcore zu wenig ist.
LLC Wert 5, offset muss man einfach probieren wie weit man runter gehen kann. Vcore mit Prime95 ausloten.
könnte es sein das ich bei 4x4gb rambestückung die spannung vom board auch bissl hochsetzen muss?
selbst mit enormer vcore bekomme ich das teil nicht stabil getaktet...
ja die Boardspannung wirst du erhöhen müssen...
wie hoch hast du sie gehabt?
bin jetzt erstmal ne woche auf messe in stuttgart...danach probiere ich bissl was. 4,5ghz sollte ja machbar sein
Hi Leute muss mich jetzt mal dumm einfragen.
Ich hab mir gestern eine UEFI-fähige Grafikkarte bestellt. Muss ich jetzt nur noch auf Ultrafastboot stellen und gut ist, oder ist da noch mehr?
Denn ich lese immer was von CSM aber ich finde diese Option bei mir im Bios/Uefi nicht.
PS ich nutze das selbe angepasste Bios wie Wotan 3.21a
Gruß Marc
Ich habe zwar keine GOP Karte würde aber sagen das du auf Ultrafastboot stellen musst, wenn deine Karte eine GOP UEFI Firmware hat.
Du musst dir aber sicher sein das die Karte auch wirklich eine GOP UEFI Firmware hat.
Zu deiner Frage nach CSM. Dieses Menü verschwindet wenn du Fastboot ausgewält hast.
So hab endlich das richtige Bios bekommen.
Laut Win8 Startzeit: 6.3 Sekunden
Einfach geil PC einschalten auf den Stuhl setzen und anfangen mit der Arbeit.
Also läuft Ultra Fast Boot bei dir jetzt mit GOP Karte
Ja Ultra Fast Boot mit "externer" Grafikkarte.
Bin jetzt aber spontan auf eine MSI GTX 770 TF umgestiegen, wobei aber Ultrafastboot auch mit der Gigabyte ging.
