Build 717 (02/05/14, Junior Member+) - 1.4 GB
Next-Gen:
* XB1: Added rich presence stats, enumerations and a test achievement and its test stat to the game configuration.
* PS4: Added common dialog initialize
* PS4: Revised invitation accept from within a race.
* PS4: Adds support for clearing texture on first 'BeginFrame'.
Render:
* Setting of SkipBonnetCamEnvmap flag corrected in CMaterialSpec::_CreateFromBinaryFile
* Increase in particle pool size.
* Tried to reduce shimmer on vertical poles by increasing width and removing normal/env/spec powers
Online/Multiplayer:
* Updated events data to latest version.
GUI:
* Adding number of turns and track description to load screen.
* Links for number of terms and track desc in loading screen
* Post-race Results screen updated
Career:
* Career Championships: Pro Kart Championship, first release.
* Career Championships: Pro Kart UK Nationals, first release.
* Career Championships: Rookie Kart Championship, first release.
* Career Championships: Rookie Kart UK Nationals, first release.
* Career Championships: Formula Rookie World Championship, first release.
* Career Championships: Formula Rookie American Challenge, first release.
* Career Championships: Formula Rookie British Challenge, first release.
* Career Championships: Formula Rookie German Challenge, first release.
* Career Championships: Formula Rookie Euro Trophy, new rounds and round detail updates.
Penalties:
* Fixed bug where yellow flag for collision would still be shown, even when the flags were turned off in the main menu
Crowds:
* Rain male and female
Pitstops/AI:
* Update "simulate" code, now uses the AI "skill" value to affect the results
* Optimised TrackOverview usage
* Added simple access micro timers in physics
* Remove mDriverDetails from PhysicsParticipantInfo
* Added mSkill to PhysicsParticipantInfo
* Set PhysicsParticipantInfo's mSkill from driver skills
Physics:
* Ariel Atoms: AI tire and suspension model tweaks
Tracks:
* Brands Hatch: Continued polish pass, fixes to the grass broad mapping,  swapped to new_ground for the main grass to test speed improvements ,  added full set of motorbike grid spots , fixes for line mipping in the  pits, special scenes for Indy foliage checked in, HW instances removed  from Indy layout since not needed, 86 3D static instances trees removed  from Indy since not needed around GP, and highres 3D trees replaced by  new optimized 3D instances, new optimized 3D trees added to the instance  pool - trianglecount between the instances 997 to 1135 triangles -  WIP!, crowds - updated crowds placement, Started the track material  polish pass - new tarmac for main track and for pitlane , new concrete  and detailing along pitlane , new pitbox markings , new white lines in  pits , fixed missing wall at the end of the pit building on the right ,  fixed CSM issues along pits , CSM fix at Druids , new skybox with  brightness fix.
* Loire: Added latest stuff from DaveF, Jan and Tomas.. tyrewalls updated
* Silverstone: Fixed xmls so they all have latest placement and include correct links to tyre only xmls which had been broken
Vehicles:
* Vehicle Damage: Went one step back higher on crumple damage multipliers, modified componentdamage for more durable parts
* Ginetta G55 GT3: LODC added, LODD optimized, misc. bug fixing and drawcall reduction
* Pagani Zonda Cinque: Misc texture update. Added belts for LODA.
* RUF CTR3: Added cockpit animations and damage modifiers, adjusted cockpit exposure, added shiftgaiter name
* Mercedes SLS GT3: Damage and tire shape modifications
Known issues:
- Replays in MP: Not working as they should
- P2P Tracks: Don't press return to pitbox
- JIP: Stop&Go Penalty might be given during the JIP sessions
- Replays will only work with your first race. If you quit and start a new session, all participants will be stuck on the grid.
- GT40 present some visual issues (misaligned window)
- California Highway: Broken AIW and track percentages, might have poor performance or be unable to move.
- Tyres blowing out after a few seconds of driving (inconsistent).
- Qualifying sometimes starting on the grid and the AI not moving (inconsistent).
- Shifting animations are not working in the Mercedes SLS GT3.
- Player loses control of the car after accessing the Setup and Strategy.
