[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Hey.
Also komme ich mal zu meinem zweiten Problem.
Ich habe mir die GTX 470 AMP gegönnt.
Leider stehen die Schrauben zu Befestigung des Kühlers soweit hinten an der Karte hervor, dass die X-Fi Supreme nicht mehr in den PCIe 1x Slot passt.
Der andere PCIe 1x Slot wird vom Kühler verdekc tund ist somit auch nicht erreichbar.
Nun habe ich mir gedacht...PCIe ist ja Abwärtskompatibel...aber die Soundkarte wirl einfach in keinem anderen Slot außer dem PCIe 1x funtionieren.
Habe ich eigentlich Leistungseinbußen, wenn ich die GK in den unteren(zweiten= PCIe 16x packe?
Für andere Ideen bin ich natpürlich auch offen!
Grüße
neue Soundkarte gönnen,die Supreme ist eh nicht so der Hammer.
Hab mir die Xonar DX gegönnt,Supersound und nicht teuer.
Das war jetzt nicht so die Antwort auf die ich gehofft habe!
Die Soundqualität reicht mir :-) War vorher nen Onboardchip von Realtec gewohnt....von nem ziemlich altem Board :-)
Naja ich habe die GK jetzt erstma im unteren PCIe 2.0 16x untergebracht!
Im Manual stand zwar, das man sie aus Perfomancegründen besser in den oberen stecken soll aber was solls.
Hab mit beidem Varinaten Furmark und Vantage laufen lassen.....und das tut sich ungefähr nöx :-)
GoGoGo
Ich habe ja gehofft, dass es irgendeine Bioseinstellung gibt....
Jow!!
ist halt nur bisl Schade, da die GK jetzt nicht mehr voll im Luftstrom von meinem Seitenlüfter ist!!!
Wie ist das denn nun generell mit der Abwärtskompatibilität.
Eigentlich müsste eine PCIe 1x Soundkarte doch in allen PCIe Slots funktionieren oder?
Da liegst du völlig richtig.
Jo.
Ich habe das Problem jetzt nicht ganz so suptil gelöst!
Da die X Fi in keinm (!) außer der obersten (!) Slots funtionieren wollte, habe ich jetzt einfach die Abdeckung entfernt!
Karte passt rein....leigt im Luftstrom...und ich habe Sound :-)
hallo , wo kann ich denn im Bios den Turbo Mode / Turbo Boost für die CPU abstellen ? ich finde nur die Speed Step funktion , aber nicht Turbo Boost , aktuellste Bios ist drauf
was genau muss ich einstellen damit nur der Turbo Mode deaktiviert ist ?
Wenn ich es noch richtig im Kopf habe, ist die Turbo Funktion bei bestimmten (OC) Einstellungen nicht mehr verfügbar und wird auch nicht angezeigt.
Solltest alles auf Standart gestellt haben, solltet du diese Funktion bei CPU FEATURES oder im OC Menü finden!
hmm der Turbo Modus ist aber trotz oc aktiviert wie ich in Win7 und CPUZ64 sehen kann
werde mal Standard laden und sehn ob ich es finde , danke erstmal
@stokit,
kannst du bitte ein screenshot von GPU-Z posten wenn du deine karte in zweiten PCI-E eingebaut hast ?
Ich brauche auch meinen zweiten (PCI-E 1x) slot für einen USB 3.0 kontroller karte und bin am überlegen meine grafikkarte ein slot runter schieben.
Möchte wiesen ob die grafikkarte in zweiten slot mit x16 oder x8 interface läuft.
Ich glaube das wurde schonmal diskutiert und als Resultat kam heraus das die Graka nur mit 8 Lanes betrieben wurde.
hab schon selbst probiert. läuft mit 8x aber viel unterschied bei performance gibt es nicht. bei vantage macht es 100 punkte weniger und bei games merke ich absolut nix.
Hi Leute.
Ich habe leider ein Problem mit dem Board und brauch Hilfe von den MIIIF Experten.
Ich hatte bisher 2x2GB Arbeitsspeicher auf A1+B1 gesteckt. Memtest, LinX, Prime, etc. liefen anstandslos.
Nun habe ich mir nochmals 2x2GB von demselben RAM gekauft und auf A2+B2 gesteckt. Memtest brachte sofort Fehler. Daraufhin habe ich alle möglichen Steckszenarien durchgemacht und dabei festgestellt, dass es Fehler gibt, sobald ein Riegel (egal welcher) in Bank A2 steckt.
Die Fehler treten aber nur im übertakteten Zustand auf. Wenn ich die Setup-Defaults auswähle und das XMP Profil auswähle läuft Memtest fehlerfrei.
Was kann ich nun tun, um den RAM auf Bank A1 doch zum Laufen zu bringen?
Grüße
Habe IMC und DRAM Voltage erhöht. Hat nichts gebracht.
Sollte ich die VCore erhöhen?
Meine Settings:
Code:
Ai Overclock Tuner                 Manual
OC From CPU Level Up            Auto
OC From Memory Level Up            Auto
CPU Ratio Setting                20
> CPU-Konfiguration
    C1E Support                        Aktiviert
    Hardware Prefetcher                Aktiviert
    Adjacent Cache Line Prefetcher    Aktiviert
    Max CPUID Value Limit            Deaktiviert
    Intel(R) Virtualization Tech    Aktiviert
    CPU-TM-Funktion                    Aktiviert
    Execute-Disable Bit Capability    Aktiviert
    *Active Processor Core            All
    A20M                            Deaktiviert
    *Intel(R) SpeedStep(TM) Techno    Aktiviert
    Intel(R) C-State Tech            Aktiviert
    C State package limit setting    C6
BCLK Frequency                    200
PCIE Frequency                    100
DRAM Frequency                    DDR3-1600 MHz
QPI Frequency                    6407 MHz
Start auto tuning
OC Tuner                        Turbo Profile
> DRAM Timing Control
    DRAM CAS# Latency                8
    DRAM RAS# to CAS# Delay            8
    DRAM RAS# PRE Time                8
    DRAM RAS# ACT Time                24
    DRAM Timing Mode                1N
CPU Clock Amplitude                Auto
PCH Clock Amplitude                Auto
CPU Clock Skew                    Auto
PCH Clock Skew                    Auto
Extreme OV                         Deaktiviert
LN2 Mode                        Deaktiviert
Full Phase Control                 Full Phase
Load-Line Calibration            Aktiviert
CPU Voltage Mode                VID
CPU Voltage                     1,3125 (je nach CPU)
CPU PLL Voltage                 1,80200
IMC Voltage                        1,25875 (je nach RAM)
PCH Voltage                        1,08650
DRAM Voltage                    1,65625
DRAM Data REF Voltage on CHA    Auto
DRAM CTRL REF Voltage on CHA    Auto
DRAM Data REF Voltage on CHB    Auto
DRAM CTRL REF Voltage on CHB    Auto
Spread Spectrum Control
CPU Spread Spectrum             Deaktiviert
PCIE Spread Spectrum            Auto
> ASUS O.C. Profile
Erweitert
    > Chipsatz
        > Uncore Configuration
            Memory Remap Feature    Aktiviert
    > Onboard-Konfiguration
        J-Micron Controller 01        Deaktiviert
        J-Micron Controller 02        Aktiviert
...komisch ist doch, dass es nur mit Bank A2 Probleme gibt.
Ich hab die DRAM Timings momentan auf Auto (non-OC Settings). Da sind momentan 2T eingestellt. Vielleicht ist das der entscheidende Hinweis :)
Allerdings sind die Timings bei 9-9-9-24 (statt 8-8-8-24).
Ich werde es testen und berichten, danke.
Aber ich kann ja kein XMP und manuelle OC gleichzeitg anwählen...von daher für mich eher unbrauchbar, da ich übertakten will.
Wenn alle Stricke reißen hol ich mir halt 2x4GB Domis...
Hmm...man muss doch in den BIOS Einstellungen "Ai Overclock Tuner" auf "Manuel" setzen. Danach kann man kein XMP mehr anwählen, oder täusche ich mich da.
Vielleicht hat auch das Board n Schuss mit der A2 Bank.
Also irgendwas stimmt bei mir nicht.
CPU-Z zeigt die beiden Kits mit unterschiedlicher Geschwindigkeit an.
Siehe DIMM 1+3, DIMM 2+4...
Wie kann das sein?
Code:
CPU-Z
Binaries
CPU-Z version    1.54
Processors
Number of processors    1
Number of threads    4
APICs
Processor 0
     -- Core 0
         -- Thread 0    0
     -- Core 1
         -- Thread 0    2
     -- Core 2
         -- Thread 0    4
     -- Core 3
         -- Thread 0    6
Processors Information
Processor 1    ID = 0
     Number of cores    4 (max 8)
     Number of threads    4 (max 16)
     Name    Intel Core i5 750
     Codename    Lynnfield
     Specification    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
     Package (platform ID)    Socket 1156 LGA (0x1)
     CPUID    6.E.5
     Extended CPUID    6.1E
     Core Stepping    B1
     Technology    45 nm
     Core Speed    1805.9 MHz
     Multiplier x FSB    9.0 x 200.7 MHz
     Rated Bus speed    3210.4 MHz
     Stock frequency    2666 MHz
     Instructions sets    MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
     L1 Data cache    4 x 32 KBytes, 8-way set associative, 64-byte line size
     L1 Instruction cache    4 x 32 KBytes, 4-way set associative, 64-byte line size
     L2 cache    4 x 256 KBytes, 8-way set associative, 64-byte line size
     L3 cache    8 MBytes, 16-way set associative, 64-byte line size
     FID/VID Control    yes
     Turbo Mode    supported, disabled
     Max non-turbo ratio    20x
     Max turbo ratio    24x
     Max efficiency ratio    9x
     TDP Limit    95 Watts
     TDC Limit    89 Amps
     Core TDP    89 Watts
     Uncore TDP    6 Watts
     Power @ 9x    14 Watts
     Power @ 10x    17 Watts
     Power @ 11x    20 Watts
     Power @ 12x    25 Watts
     Power @ 13x    30 Watts
     Power @ 14x    36 Watts
     Power @ 15x    43 Watts
     Power @ 16x    51 Watts
     Power @ 17x    60 Watts
     Power @ 18x    70 Watts
     Power @ 19x    82 Watts
     Power @ 20x    95 Watts
     Max bus number    255
     Attached device    PCI device at bus 255, device 2, function 1
     Attached device    PCI device at bus 255, device 3, function 4
Chipset
Northbridge    Intel DMI Host Bridge rev. 11
Southbridge    Intel P55 rev. 05
Graphic Interface    PCI-Express
PCI-E Link Width    x16
PCI-E Max Link Width    x16
Memory Type    DDR3
Memory Size    8192 MBytes
Channels    Dual
Memory Frequency    802.6 MHz (2:8)
CAS# latency (CL)    9.0
RAS# to CAS# delay (tRCD)    9
RAS# Precharge (tRP)    9
Cycle Time (tRAS)    24
Row Refresh Cycle Time (tRFC)    89
Command Rate (CR)    2T
Uncore Frequency    3210.4 MHz
Memory SPD
DIMM #    1
     SMBus address    0x50
     Memory type    DDR3
     Module format    UDIMM
     Manufacturer (ID)    Corsair (7F7F9E0000000000)
     Size    2048 MBytes
     Max bandwidth    PC3-10700H (667 MHz)
     Part number    CMD4GX3M2A1600C8
     Manufacturing date    Week 20/Year 09
     Number of banks    8
     Nominal Voltage    1.50 Volts
     EPP    no
     XMP    yes
     XMP revision    1.2
JEDEC timings table    CL-tRCD-tRP-tRAS-tRC @ frequency
     JEDEC #1    6.0-6-6-16-23 @ 444 MHz
     JEDEC #2    8.0-8-8-22-30 @ 592 MHz
     JEDEC #3    9.0-9-9-24-34 @ 666 MHz
XMP profile    XMP-1600
     Specification    PC3-12800
     Voltage level    1.650 Volts
     Min Cycle time    1.250 ns (800 MHz)
     Min tRP    10.00 ns
     Min tRCD    10.00 ns
     Min tWR    15.00 ns
     Min tRAS    30.00 ns
     Min tRC    50.63 ns
     Min tRFC    110.00 ns
     Min tRTP    7.50 ns
     Min tRRD    7.50 ns
     Command Rate    2T
XMP timings table    CL-tRCD-tRP-tRAS-tRC-CR @ frequency (voltage)
     XMP #1    6.0-6-6-18-31-2T @ 600 MHz (1.650 Volts)
     XMP #2    8.0-8-8-24-41-2T @ 800 MHz (1.650 Volts)
DIMM #    2
     SMBus address    0x51
     Memory type    DDR3
     Module format    UDIMM
     Size    2048 MBytes
     Number of banks    8
     EPP    no
     XMP    yes
     XMP revision    1.2
     Min tRP    10.00 ns
     Min tRCD    10.00 ns
     Min tWR    15.00 ns
     Min tRAS    30.00 ns
     Min tRC    50.63 ns
     Min tRFC    110.00 ns
     Min tRTP    7.50 ns
     Min tRRD    7.50 ns
     Command Rate    2T
DIMM #    3
     SMBus address    0x52
     Memory type    DDR3
     Module format    UDIMM
     Size    2048 MBytes
     Number of banks    8
     EPP    no
     XMP    yes
     XMP revision    1.2
     Min tRP    10.00 ns
     Min tRCD    10.00 ns
     Min tWR    15.00 ns
     Min tRAS    30.00 ns
     Min tRC    50.63 ns
     Min tRFC    110.00 ns
     Min tRTP    7.50 ns
     Min tRRD    7.50 ns
     Command Rate    2T
DIMM #    4
     SMBus address    0x53
     Memory type    DDR3
     Module format    UDIMM
     Size    2048 MBytes
     Number of banks    8
     EPP    no
     XMP    yes
     XMP revision    1.2
     Min tRP    10.00 ns
     Min tRCD    10.00 ns
     Min tWR    15.00 ns
     Min tRAS    30.00 ns
     Min tRC    50.63 ns
     Min tRFC    110.00 ns
     Min tRTP    7.50 ns
     Min tRRD    7.50 ns
     Command Rate    2T
Monitoring
Mainboard Model    Maximus III Formula (0x000006D5 - 0x737EC7E1)
LPCIO
LPCIO Vendor    Winbond
LPCIO Model    W83667HG-A
LPCIO Vendor ID    0x5CA3
LPCIO Chip ID    0xB3
LPCIO Revision ID    0x53
Hardware Monitors
Hardware monitor    Winbond W83627DHG
     Voltage 0    1.31 Volts [0xA4] (CPU VCORE)
     Voltage 1    1.77 Volts [0xDD] (VIN1)
     Voltage 2    3.34 Volts [0xD1] (+3.3V)
     Voltage 3    5.02 Volts [0xD1] (+5V)
     Voltage 4    11.99 Volts [0xD7] (+12V)
     Voltage 6    0.86 Volts [0x6B] (VIN6)
     Temperature 0    18°C (64°F) [0x12] (SYSTIN)
     Temperature 1    19°C (65°F) [0x25] (CPUTIN)
     Temperature 2    34°C (93°F) [0x44] (AUXTIN)
Hardware monitor    Analog Device ASP0800
     Current 0    24.13 Amps [0x304] (CPU)
     Power 0    31.75 W [0x3F8] (CPU)
     Current 0    24.38 Amps [0x30C] (CPU)
     Power 0    32.06 W [0x201] (CPU)
Hardware monitor    Intel Core i5 750
     Power 0    14.11 W (Processor)
     Temperature 0    28°C (82°F) [0x47] (Core #0)
     Temperature 1    26°C (78°F) [0x49] (Core #1)
     Temperature 2    30°C (86°F) [0x45] (Core #2)
     Temperature 3    26°C (78°F) [0x49] (Core #3)
PCI Devices
Description    Host Bridge
Location    bus 0 (0x00), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0xD131
     Revision ID    0x11
Description    PCI to PCI Bridge
Location    bus 0 (0x00), device 3 (0x03), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0xD138
     Revision ID    0x11
Description    System Device
Location    bus 0 (0x00), device 8 (0x08), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0xD155
     Revision ID    0x11
Location    bus 0 (0x00), device 8 (0x08), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0xD156
     Revision ID    0x11
Location    bus 0 (0x00), device 8 (0x08), function 2 (0x02)
Common header
     Vendor ID    0x8086
     Model ID    0xD157
     Revision ID    0x11
Location    bus 0 (0x00), device 8 (0x08), function 3 (0x03)
Common header
     Vendor ID    0x8086
     Model ID    0xD158
     Revision ID    0x11
Location    bus 0 (0x00), device 16 (0x10), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0xD150
     Revision ID    0x11
Location    bus 0 (0x00), device 16 (0x10), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0xD151
     Revision ID    0x11
Description    USB 2.0 Controller (EHCI)
Location    bus 0 (0x00), device 26 (0x1A), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x3B3C
     Revision ID    0x05
Description    Multimedia device
Location    bus 0 (0x00), device 27 (0x1B), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x3B56
     Revision ID    0x05
Location    bus 0 (0x00), device 28 (0x1C), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x3B42
     Revision ID    0x05
Location    bus 0 (0x00), device 28 (0x1C), function 4 (0x04)
Common header
     Vendor ID    0x8086
     Model ID    0x3B4A
     Revision ID    0x05
Location    bus 0 (0x00), device 28 (0x1C), function 5 (0x05)
Common header
     Vendor ID    0x8086
     Model ID    0x3B4C
     Revision ID    0x05
Location    bus 0 (0x00), device 28 (0x1C), function 6 (0x06)
Common header
     Vendor ID    0x8086
     Model ID    0x3B4E
     Revision ID    0x05
Location    bus 0 (0x00), device 28 (0x1C), function 7 (0x07)
Common header
     Vendor ID    0x8086
     Model ID    0x3B50
     Revision ID    0x05
Location    bus 0 (0x00), device 29 (0x1D), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x3B34
     Revision ID    0x05
Location    bus 0 (0x00), device 30 (0x1E), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x244E
     Revision ID    0xA5
Description    PCI to ISA Bridge
Location    bus 0 (0x00), device 31 (0x1F), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x3B02
     Revision ID    0x05
Description    RAID Controller
Location    bus 0 (0x00), device 31 (0x1F), function 2 (0x02)
Common header
     Vendor ID    0x8086
     Model ID    0x2822
     Revision ID    0x05
Description    SMBus Controller
Location    bus 0 (0x00), device 31 (0x1F), function 3 (0x03)
Common header
     Vendor ID    0x8086
     Model ID    0x3B30
     Revision ID    0x05
Description    VGA Controller
Location    bus 1 (0x01), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID    0x1002
     Model ID    0x6899
     Revision ID    0x00
Location    bus 1 (0x01), device 0 (0x00), function 1 (0x01)
Common header
     Vendor ID    0x1002
     Model ID    0xAA50
     Revision ID    0x00
Description    IDE Controller
Location    bus 2 (0x02), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID    0x197B
     Model ID    0x2363
     Revision ID    0x03
Description    Ethernet Controller
Location    bus 7 (0x07), device 4 (0x04), function 0 (0x00)
Common header
     Vendor ID    0x10EC
     Model ID    0x8167
     Revision ID    0x10
Location    bus 255 (0xFF), device 0 (0x00), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x2C51
     Revision ID    0x04
Location    bus 255 (0xFF), device 0 (0x00), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0x2C81
     Revision ID    0x04
Location    bus 255 (0xFF), device 2 (0x02), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x2C90
     Revision ID    0x04
Location    bus 255 (0xFF), device 2 (0x02), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0x2C91
     Revision ID    0x04
Location    bus 255 (0xFF), device 3 (0x03), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x2C98
     Revision ID    0x04
Location    bus 255 (0xFF), device 3 (0x03), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0x2C99
     Revision ID    0x04
Location    bus 255 (0xFF), device 3 (0x03), function 4 (0x04)
Common header
     Vendor ID    0x8086
     Model ID    0x2C9C
     Revision ID    0x04
Location    bus 255 (0xFF), device 4 (0x04), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x2CA0
     Revision ID    0x04
Location    bus 255 (0xFF), device 4 (0x04), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0x2CA1
     Revision ID    0x04
Location    bus 255 (0xFF), device 4 (0x04), function 2 (0x02)
Common header
     Vendor ID    0x8086
     Model ID    0x2CA2
     Revision ID    0x04
Location    bus 255 (0xFF), device 4 (0x04), function 3 (0x03)
Common header
     Vendor ID    0x8086
     Model ID    0x2CA3
     Revision ID    0x04
Location    bus 255 (0xFF), device 5 (0x05), function 0 (0x00)
Common header
     Vendor ID    0x8086
     Model ID    0x2CA8
     Revision ID    0x04
Location    bus 255 (0xFF), device 5 (0x05), function 1 (0x01)
Common header
     Vendor ID    0x8086
     Model ID    0x2CA9
     Revision ID    0x04
Location    bus 255 (0xFF), device 5 (0x05), function 2 (0x02)
Common header
     Vendor ID    0x8086
     Model ID    0x2CAA
     Revision ID    0x04
Location    bus 255 (0xFF), device 5 (0x05), function 3 (0x03)
Common header
     Vendor ID    0x8086
     Model ID    0x2CAB
     Revision ID    0x04
DMI
DMI BIOS
     vendor    American Megatrends Inc.
     version    1607
     date    03/26/2010
DMI System Information
     manufacturer    System manufacturer
     product    System Product Name
     version    System Version
     serial    System Serial Number
     UUID    E056001E-8C0000AD-40E990E6-BA2EDA97
DMI Baseboard
     vendor    ASUSTeK Computer INC.
     model    Maximus III Formula
     revision    Rev 1.xx
     serial    101600370000337
DMI System Enclosure
     manufacturer    Chassis Manufacture
     chassis type    Desktop
     chassis serial    Chassis Serial Number
DMI Processor
     manufacturer    Intel
     model    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
     clock speed    4013.0 MHz
     FSB speed    200.0 MHz
     multiplier    20.0x
DMI Memory Controller
     correction    64-bit ECC
     Max module size    2048 MBytes
DMI Memory Module
     designation    DIMM0
     size    2048 MBytes (double bank)
DMI Memory Module
     designation    DIMM1
DMI Memory Module
     designation    DIMM2
DMI Memory Module
     designation    DIMM3
DMI Port Connector
     designation    PS/2 Keyboard (internal)
     designation    PS/2 Keyboard (external)
     port type    Keyboard Port
     connector    PS/2
DMI Port Connector
     designation    USB9_10 (internal)
     designation    USB9_10 (external)
     port type    USB
     connector    Access Bus (USB)
DMI Port Connector
     designation    USB11_12 (internal)
     designation    USB11_12 (external)
     port type    USB
DMI Port Connector
     designation    USB13_14 (internal)
     designation    USB13_14 (external)
     port type    USB
DMI Port Connector
     designation    GbE LAN (internal)
     designation    GbE LAN (external)
     port type    Network Port
     connector    RJ-45
DMI Port Connector
     designation    SATA6 (internal)
     designation    SATA6 (external)
DMI Port Connector
     designation    SATA1 (internal)
DMI Port Connector
     designation    SATA2 (internal)
DMI Port Connector
     designation    SATA3 (internal)
DMI Port Connector
     designation    SATA4 (internal)
DMI Port Connector
     designation    SATA5 (internal)
DMI Port Connector
     designation    USB1_2 (internal)
     port type    USB
DMI Port Connector
     designation    USB3_4 (internal)
     port type    USB
DMI Port Connector
     designation    USB5_6 (internal)
     port type    USB
DMI Port Connector
     designation    USB7_8 (internal)
     port type    USB
DMI Port Connector
     designation    IE1394_2 (internal)
     port type    Firewire (IEEE P1394)
     connector    IEEE 1394
DMI Port Connector
     designation    AAFP (internal)
     port type    Audio Port
     connector    Mini Jack (headphones)
DMI Port Connector
     designation    CPU_FAN (internal)
DMI Port Connector
     designation    CHA_FAN1 (internal)
DMI Port Connector
     designation    PWR_FAN (internal)
DMI Port Connector
     designation    CHA_FAN2 (internal)
DMI Port Connector
     designation    CHA_FAN3 (internal)
DMI Port Connector
     designation    OPT_FAN1 (internal)
DMI Port Connector
     designation    OPT_FAN2 (internal)
DMI Port Connector
     designation    OPT_FAN3 (internal)
DMI Port Connector
     designation    SATA_E1 (internal)
DMI Port Connector
     designation    SATA_E2 (internal)
DMI Port Connector
     designation    SATA_ODD1 (internal)
DMI Port Connector
     designation    SATA_ODD2 (internal)
DMI Port Connector
     designation    F_ESATA (internal)
DMI Extension Slot
     designation    PCIEX16_1
     type    A5
     width    32 bits
     populated    yes
DMI Extension Slot
     designation    PCIEX1_1
     type    A5
     width    32 bits
     populated    no
DMI Extension Slot
     designation    PCIEX1_2
     type    A5
     width    32 bits
     populated    no
DMI Extension Slot
     designation    PCIEX16_2
     type    A5
     width    32 bits
     populated    no
DMI Extension Slot
     designation    PCI1
     type    PCI
     width    32 bits
     populated    no
DMI Extension Slot
     designation    PCIEX16_3
     type    A5
     width    32 bits
     populated    no
DMI Extension Slot
     designation    PCI2
     type    PCI
     width    32 bits
     populated    no
DMI OEM Strings
     string[0]    To Be Filled By O.E.M.
     string[1]    To Be Filled By O.E.M.
     string[2]    To Be Filled By O.E.M.
     string[3]    To Be Filled By O.E.M.
DMI Physical Memory Array
     location    Motherboard
     usage    System Memory
     correction    None
     max capacity    4096 MBytes
     max# of devices    4
DMI Memory Device
     designation    DIMM0
     format    DIMM
     type    DDR
     total width    72 bits
     data width    64 bits
     size    2048 MBytes
DMI Memory Device
     designation    DIMM1
     format    DIMM
     type    DDR
     total width    72 bits
     data width    64 bits
     size    2048 MBytes
DMI Memory Device
     designation    DIMM2
     format    DIMM
     type    DDR
     total width    72 bits
     data width    64 bits
     size    2048 MBytes
DMI Memory Device
     designation    DIMM3
     format    DIMM
     type    DDR
     total width    72 bits
     data width    64 bits
     size    2048 MBytes
Graphics
Number of adapters    0
Graphic APIs
Display Adapters
Software
Windows Version    Microsoft Windows 7 (6.1) (Build 7600)
DirectX Version    11.0
Weiß nicht, ob es bei Deinem RAM Problem hilft, aber wenn man taktet, schaltet man die Intel(R) C-State Tech aus.
Hatte bei mir massiv Probleme, wenn ich die eingeschaltet lasse.
