[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Komplett zu vernachlässigen! Die Wirkung nimmt mit jeder DDR-Generation ab.
Hat mir der Corsair Support auch gesagt :)
@sarge07
Also LinX lässt die CPU nochmal deutlich mehr glühen als Prime. Also ich musste gestern feststellen dass alle Kerne bei LinX über 70° hatten...CPU Lüfter @ 80%.
Das ist schon heftig, aber das bekommst du ja mit keiner normalen Anwendung hin und daher bin ich zufrieden mit dem Zali :)
@sarge07
hm mag sein, aber die games belasten die cpu nicht so sehr. ich finde die beste methode für oc, sind die games. weil da wird nicht nur die cpu belastet... sondern auch imc/sb/pci-E und die soundkarte. ich hatte schonmal oc prime stabil aber codwaw und mw2 und nfs-shift liefen nicht fehlerfrei. deshalb verlasse ich mich nicht so sehr auf solche tools. aber als erstes teste ich mit prime und dann games die das system viel belasten :)
kann mir mal einer die ganzen Spannungen im Bios erklären für was die zuständig sind ?
habe nix im Thread gefunden .bis auf CPU und Ram die sind klar .
auch über google habe ich nichts hilfreiches gefunden .
vielen Dank schonmal
kann mir jemenad bezüglich meiner frage #122 was sagen
Hat schon jemand längere erfahrungen mit dem 2001 Bios? Ich überlege ob ich vielleicht von 1607 auf 2001 updaten soll. Vielleicht bekomme ich ein Stück Vcore weniger, da meine jetzige CPU ein wenig zickt.
ich habe das bios 2001 seit erscheinung darauf und habe keine probleme mit dem board. in sachen oc läuft in moment mein sys mit 167x21 mit eist und c6 wunderbar. meine rams fahren auch mit 2000mhz.
bin vollkommen mit dem bios zufrieden :)
hab mein i5 750 auf 3,7 ghz stable mit kingston hyperx 8 gb 1600mhz laufen und ist stable und top aber c6 willer irgendwie nicht ;)
Aber sonst ist das 2001 top keine anderen probleme
und die tage kommt meine msi gtx 470 soc :d
Bei 200 BLCK und 22er Multi, muss da die IMC noch angehoben werden? Oder reicht die IMC vom 20x200
Hab das BIOS 2001 seit ich zusätzlich 4GB RAM verbaut habe...läuuft mit 20x200 (und all den anderen Specs von meiner BIOS 1607 Konfig) einwandfrei und stabil.
Allerdings habe ich nicht mehr versucht irgendwelche Spannung abzusenken. Lediglich die RAM Timings habe ich entspannen müssen.
Mhh OK, werde dann mal das 2001 flashen. Vielleicht hilft es ja die eine oder andere Spannung zu senken. Obwohl die 1,152 IMC niedrig genug ist für 180 BLCK ;)
@PitBull
Sag uns halt Bescheid, ob Du das 2001 besser findest. Bin auch am überlegen, ob ich updaten soll.
Das sind alles sehr niedrige Werte. 4GHz unter 1,3V sind imho relativ selten. Was willst du also mehr!? :)
@PitBull
mach Dir keinen Kopf. Du hast eh einen guten 860er erwischt.
Meiner macht: 3,6Ghz 1,19v, 3,8Ghz 1,28v und die 4Ghz erst mit 1,33v Stabil.
Bin trotzdem zufrieden und hab bei 3,8Ghz genug Power für alles.
@ PitBull
Wieviel vCore braucht der 870er nun für 4Ghz ?
Oder bist du noch am Ausloten ?
kann mir jemand die lochabstände der spawa kühler geben
@ PitBull
1,296 :( bleibt aber durch die hohe VID kühl.
@PitBull
Mein alter i860 brauchte 1,176v für 3,6Ghz 1,240 für 3,8Ghz und ca. 1,312v für 4Ghz
Den I7 870 habe ich gekauft mit der Info das er 4Ghz mit 1,232v macht. Wie man sieht ist es fast 0,7v mehr
Es gibt viele, die 4Ghz einstellen und nicht testen, ob es stabil ist. Da wird dann mal Super-Pi laufen gelassen und das war es dann.
Was auch sein kann, dass HT für 4Ghz deaktiviert war.
Ein I7-870 mit HT an 4Ghz und 1,23V Vcore ist wohl schwer zu finden.
So jetzt habe ich meine Gigabyte gtx 470 super teil nur hat das direkt mein soundtreiber gekickt o_O
So nun zur frage welcher treiber nehme ich für die soundkarte die dabei ist? weil aktuell ist kein wirklich aktueller treiber bei asus vertreten auserdem via? dachte xfi ist creative?
der windows treiber den er genommen hat verursacht das irgendwie "mp3s" okay sind im 5.1 headset aber z.b. Granaten und andere explosionen dumpf und irgendwie falsch anhören auch ts ist irgendwie "fremd".
hoffentlich könnt ihr mir helfen.
lg exelzur
ich kann dir nur sagen welche soundtreiber versionen sind die aktuellste.
Via sound treiber...
ftp://ftp.asus.com/pub/ASUS/misc/audio/VIA_Audio_V6018500_XpVistaWin7.zip
XF-I treiber...
ftp://ftp.asus.com/pub/ASUS/misc/utils/SB_XFi_V10_R19_XpVistaWin7.zip
ich hoffe damit ist dein sound problem weg :)
ps,
nvidia kickt keinen sound treiber. der hat eventuell dein audio gerät auf nvidia umgestellt. du kannst wieder umstellen. entweder über nvidia eigenschaften oder über systemsteuerung oder direkt durch rechtsklick auf Lautsprecher symbol auf der taskleiste und dort wählst du ein anderes audio gerät als standard.
gibt es eine aktuelle übersicht der aktuellen treiber? weil die asus seite gibt ja nicht gerade die aktuellsten ;).
bzw. gibt es eine komponenten übersicht nach was ich suchen muss ;D
Hi zusammen.
Kurze Frage zur Speicherkontroller-Config:
Ich habe 2x Samsung SPF3 HDDs...dazu gesellen sich demnächst ein oder zwei SSDs.
Momentan hängen die Samsungs im RAID0 allein am P55 Controller.
Wenn jetz die SSD(s) hinzukommen, will ich diese dann exklusiv am P55 Controller betreiben.
Macht es Sinn (performancetechnisch) die normalen Samsung Platten im RAID1 an den JMB363 zu hängen?!
Hat das jemand mal gebenched!?
Hi
Ich habe gerade mal eine Frage.
Habt ihr vlt Stabilitätsprobleme mit Corsair Dominator GTs?
Genauer gesagt die 1600er mit CL7 Latenzen?
mfg Ceres
