[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Hatte Probleme mit Intel(R) C-State Tech an den Rechner stabil zu bekommen. Bekam Bluescreens oder der ist beim Windows Start hängen geblieben.
Weiss es nicht genau, aber bin der Meinung, dass das Bios beim takten automatisch C-State deaktiviert (keine Lust das jetzt zu testen).
Jetzt mit C-State aus benutze ich Speedstep und VCore Offset um den Takt und die Spannung im Idle zu senken.
einen Bios Reset haste schon gemacht ? ich würde mal den NT Stecker ziehn und die Batterie rausnehmen , 5 min. warten , alles wieder anstöpseln und dann die Setup Defaults laden . zumindest das Prob mit den unterschiedlichen Geschwindigkeiten sollte dann weg sein
Hab ich eben gemacht. Habe dann noch das BIOS 2001 aufgespielt.
CPU-Z zeigt mir immer noch 667MHz max. Bandbreite an.
Hat jemand ne Idee wo der Fehler liegen könnte!?
Anbei seht ihr die CPU-Z und Everest Werte.
das cpu-z dir 667mhz zeigt, liegt daran das das bios des rames so programmiert worde. bei mir ist auch so. das machen die ram hersteller absichtig. aber wie ich aus deinem shot sehe laufen die rams mit 1600mhz.
wo ist das problem ?
So wie ich das mal gelesen habe kommt das davon das diese Rams in wirklichkeit nach Jedec maximal nur 667 MHz können, der Hersteller diese aber bei bestimmten Timings auf einen schnelleren Standart getestet hat und dies dann XMP Profil nennt.
nein, 667mhz ist SPD programmierung damit auf den mainboards problemlos erkannt werden und einwandfrei funktionieren. alles was über 1333mhz geht, wird als oc ram bezeichnet und man muss die taktung und timing manuel einstellen. XMP,s sind nur vorprogrammierte profile. eigentlich für noobs gedacht die nicht mit bios einstellungen klar kommen :)
Die tatsächliche geschwindigkeit kann man von der ram bezeichnung erkennen. zB PC3-10700 usw. die mhz zahl dahinter ist SPD programmierung. man kann auch selbst die spd taktung mit geeigneten ram tools ändern. ist aber nicht empfehlenswert und dabei verliert man die garantie.
Ausgezeichneter Thread! ;)
Werde es mir auf jedem Fall kaufen, bin mir aber noch unschlüssig welche CPU & Ram ich verbauen soll!
Was haltet ihr von der CPU: Core(TM) i7-860 Prozessor (FC-LGA4, "Lynnfield")
+ Zalman CNPS 9900A?
Und was empfiehlt Ihr für Ram, also 4 GB sollten es schon mal sein!
Möchte aber für alles inkl. Board nicht mehr als 600 - 650 Euro ausgeben!
LG
Vandit
also G.Skill RipJaws laufen einwandfrei mit dem Board , und die genannte CPU ist auch ok , hab ich selbst
gute entscheidung!
hol dir am besten corsair dominator
die 2000 cl8 mit 4gb gibts für gute 100 €
cpu kommt drauf an was du machen willst, ob 4 oder 8 kerne ist anwendungsabhängig
Danke Euch beiden für die schnelle Antwort!
Also das Board, den Core(TM) i7-860 Prozessor (FC-LGA4, "Lynnfield")
+ Zalman CNPS 9900A Kühler werde ich mir schon mal kaufen!
Aber der Arbeitsspeicher!
Was hat das eigentlich mit den Latenzzeiten auf sich?
G.Skill RipJaws
Corsair Dominator GT
Die sind ja bei beiden Ram´s völlig unterschiedlich!
ich würde auch G-Skill empfehlen. da sie mit dem board getestet worden und 100% einwandfrei funktionieren. Bei dem CPU Kühler wenn du übertakten willst, lieber Zalman 9900MAX nehmen. will ich mir auch holen. aber 9900A ist auch sehr gut :)
oder das hier lesen...
Zalman stellt CPU-Kühler mit
@sarge07
Danke für den Tip! habe Ihn mir gleich in blau mitbestellt! :)
@Stefan 008, TobiasAlt
Habe mich jetzt also so entschieden:
1. S1156 ASUS Maximus III Formula GSAF e 4D3 P55 (168,94 Euro)
2. Core S1156 i7-860 BOX 4x2,80Ghz DMI2.5GT/s 8MB-L3 512KB-L2 (224,08 Euro)
3. DDR3 4096MB 2x2 PC1333 G.Skill RipJaws CL7-7-7-21 (74,28 Euro)
5. Zalman CNPS9900 MAX blau (67,50 Euro)
Gesamt: 534,8 Euro
Dank PreisSuchmaschine bleibe ich noch unter dem was ich mir eigentlich als Grenze gesetzt hatte!:heuldoch:
...Hoffe nur das ich alles in meinem Alienware Area-51 5500 Tower verbaut bekomme!
Hey Leute. Danke für die Infos. Ich habe mich wohl an den falschen CPU-Z Werten aufgehängt.
Ich habe die Timings jetzt auf 9-9-9-24 2T und Memtest sowie LinX laufen nun anstandslos. Werde noch ein wenig testen und versuchen die Timings noch ein wenig zu straffen. Ist diese leichte entschärfung der Timings überhaupt relevant oder zu vernachlässigen?!
Will mir auch den neuen Zalman holen. Hoffe der bringts :)
Weils geil aussieht und die Kühlleistung ganz gut ist. Klar gibts bessere, aber der Zalman ist ein echtes Schmuckstück :p
Zu dem MIIIF hätte aber der rote Zalman wesentlich besser gepasst, wo doch die RipJaws auch schwarz/rot sein sollten...
Bei Computerbase ist auch einer in rot abgebildet...
Ich sehe gerade, den gibts mit roter & blauer LED.
ich will mir auch den mit roten LED holen weil gut zu dem board und zukunftigen maximus boards passt :)
Vandit@
gute auswahl :)
ich hoffe nur du hast noch ein gutes netzteil daheim :)
Lamagra-x@
freud mich dass die infos geholfen haben :)
@sarge07
Ich seh du hast denselben CPU Kühler wie ich. Wie heiß wird deine CPU wenn du LinX (25 runs) machst!? Und wie hoch hast du deine CPU getaktet?
Grüße
Komplett zu vernachlässigen! Die Wirkung nimmt mit jeder DDR-Generation ab.
LaMagra-X@
im sommer fahre ich mit standard takt und in winter mit ca 3600mhz. in moment habe ich mit oc bei last max temp mit prime 55°-59°. LinX kenn ich nicht ! ich höffe mit Zalman 9900Max habe ich 10°c weniger :)
Vandit@
dein netzteil reich vollkommen. was willst du mit 1000watt netzteil :) es sei denn du willst 2 oder 3x GTX480 brauen ;) dann kommt ein 1000watt netzteil in frage.
