[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
Danke für die schnelle Antwort.
Schade hätte nämlich noch ein paar fragen
außerdem gibt es hier ja auch noch andere Leute die Fragen beantworten können ;)
Lol hab die selbe Tastatur.
die gleiche vielleicht ... die selbe wohl eher nicht. :d
Wenn nein welches NT bietet diesen Anschluss will alles neu Aufbauen.
es gibt auch Adapter mit denen man zwei 4-Pol IDE zu einem 6-Pol PCIe verbinden kann.
Generell bieten (fast) alle neuen Netzteile diese Anschlüsse, da sie für fast alle aktuellen Grakas benötigt werden. ;)
Re: ASUS Maximus V Extreme R.O.G + Mini Review? (Z77)
So nach 2Wochen testen kann ich sagen das das Board das Geld nicht wert ist, gerade im Bezug auf OC, die Features wären nicht schlecht wenn sie funktionieren würden, und an Spannungen brauch es mehr wie ein asrock formula und ein m5gene aus eigenem Haus.
Das Board soll für overclocker sein, das ich nicht lache, jedes andere Board kann das was ein extreme kann und manche sogar besser, und kosten über 100€ weniger.
Also mein Fazit ist, für overclocker ungeeignet.
Gesendet von meinem GT-I9300 mit der Hardwareluxx App
Jedem das seine, aber ungeeignet für Overclocker ist es ganz sicher nicht ;)
Welche Features funktionieren denn nicht?
Dafür muss beim M5E nicht die Switching Frequenz des PWM Controllers deutlich angehoben werden, um bestimmte CPU-Taktergebnisse zu erreichen (wie beim OCF*) und man kann die Systemspannungen getrennt konfigurieren, statt diese wie beim M5G gemeinsam anheben zu müssen. Abgesehen davon bezweifele ich, dass "jedes andere Board kann das was ein extreme kann", basierend auf meinen eigenen Erfahrungen mit einigen ASRock (E4, E6) und MSI (GD80, Mpower) Modellen. Keines davon konnte dem M5E auch nur annähernd das Wasser reichen, wenn es um die OC-Funktionalität ging (Funktionsumfang, Anzahl Parameter, Granularität der einstellbaren Werte, Handling). Versuch doch bitte objektiv zu bleiben, sonst hat eine Aussage wie diese keinen Wert...
*warum das notwendig ist, kann man sich ja denken
Ich bin so objektiv wie ich es sein kann, habe jetzt auch schon jede Menge z77 Bretter da geht vom M5g,Asrock Formular, Gigabyte ud 5h,ud3,ASROCK 9,
und ich denke für das Geld was man für das Brett hinlegt ist es nicht gerechtfertigt, gerade bezogen auf OC, das selbe habe ich auch zum asrock 9 gesagt, wo kann ich was besser einstellen um bessere Werte zu erreichen? Bis jetzt komm ich nicht annähernd an die Werte eines oc formula, was OC betrifft, kannst auch sagen hab keine Ahnung, meine Meinung ändere ich nicht.
Vielleicht bin ich aber auch zu blöd um mit nem Asus richtig zu takten, kannst mir ja gerne Nachhilfe geben, lasse mich gerne vom Gegenteil überzeugen.
Wieso kommst du drauf das man die systemspanung beim M5g nicht separat einstellen kann? Das kann man doch, hast du das M5G Gehabt?
Fand das M5G für OC besser wie das M5E
Und warum muss man beim OCF die switching Frequenz anheben, habe ich nicht gebraucht?
OC key funktioniert nicht mit meiner Tastatur, Bluetooth Funktion funktioniert nicht für oc, und so weiter.
Warum sollte ich das behaupten? Du hast dir mit dem M5E offenbar nicht sehr viel Zeit gelassen und bist daher zum Fazit gekommen, dass du mit dem OCF besser zurecht kommst. Das ist vollkommen in Ordnung so. Ich habe nicht vor dich umzustimmen oder dir "Nachhilfe" zu geben. Aber zu behaupten das M5E wäre "für overclocker ungeeignet" - Das kann ich beim besten Willen nicht nachvollziehen, zumal es ja auch von Overclockern auf der ganzen Welt genutzt wird. Andererseits ist "jedes andere Board kann das was ein extreme kann" zwar ein schöner Gedanke, aber irgendwie auch realitätsfremd, weil es schon angefangen mit der Ausstattung kaum ein vergleichbares Modell am Markt gibt. Die umfangreichen Möglichkeiten im UEFI, angefangen mit den einstellbaren Spannungen in 0.005v und 0.00625v Schritten* bis hin zu den 35 vorhandenen Speichertimings, sind keinesfalls Standard. So sind einige dieser Timings bei den ASRock Extreme Modellen nicht vorhanden und die Besitzer haben dadurch Probleme zum Beispiel Samsung Green jenseits von DDR3-2200 zu übertakten (siehe Samsung Sammelthread).
*Frage mal einen Gigabyte Z77-D3H oder Z77N-WiFi Besitzer danach.
Du hast es vielleicht nicht gebraucht, bei allen anderen im Sammelthread ist es aber offenbar Standard und wird auch regelmäßig als Empfehlung gegeben, wenn jemand Stabilitätsprobleme in Prime/LinX hat. Da du den Sammelthread vermutlich aktiv verfolgst, weist du bereits, dass das OCF auch so seine offenen Baustellen hat mit denen sich zum Beispiel Punk Sods und nfszocker im Moment herumschlagen. Das sollte aber kein Grund sein, es direkt pauschal als "unbrauchbar" zum übertakten zu erklären :)
Du wolltest den OC Key an einer Tastatur mit integriertem USB-Hub nutzen? Dies ist auf Grund der Funktionsweise des Tools nicht möglich und steht so auch im Handbuch.
Welches Problem hattest du mit der Bluetooth Funktion beim übertakten?
Oje, eine Schlacht um das kalte Buffet. :asthanos:
Es stimmt, das wir uns beim Ram OC bei bestimmten Chips etwas mehr Support wünschen würden, mit den bisherigen UEFI's ist bei manchen Kits echt nichts zu reißen beim Z77OCF und der Support seitens ASRock/Nick Shih ist zur Zeit unter aller Kanone. Muss nicht sein, so was. Allerdings laufen wiederum viele aktuelle Kits sehr gut drauf, wie die CDP oder TridentX.
Das mit der Erhöhung Power der Switching Frequency ist eher im Ausnahmefall und bei 5GHz und mehr CPU Takt angebracht, ich persönlich habe das noch nicht gebraucht. Allerdings habe ich dies einmal zur Stabilisierung von 5GHz CPU Takt empfohlen.
Ansonsten würde ich sagen, beide Mb. haben ihre Vor- und Nachteile und wenn ich wieder auf 3fach SLI gesetzt hätte wie bei meinem ehemaligen MIVE, hätte ich eher ein M5E gekauft. So ist es eben ein Z77OCF geworden und bin mit dem Board an sich sehr zufrieden. Beim M5E liegt der Vorteil meiner Meinung nach eher im SLI/Crossfire Betrieb und den zusätzlichen Features. Man kauft halt das, was passt und gut ist.
*Fertig* ;)
Heinrich
Da hab ich mich wohl falsch ausgedrückt, man kann es zum takten nehmen, aber für ein über 300euro brett extra für Übertakter stell ich andere ansprüche wie an ein 08/15 board.
Und wenn ein OCF und M5G besser zu takten ist als ein M5E da kann doch was nicht stimmen, was nützen mir die ganzen feinen Einstellungen, wenn am Ende nichts dabei rauskommt.
Ja jedes Board hat seine Problem auch das OCF, aber die Eierlegende Wollmilchsau gibt es noch nicht, aber wenn ein Board für Overclocker angepriessen wird, sollte es auch dafür was können, was andere nicht können und bei dem Preis schon allemal.
Punksods und nfzocker nörgeln aber auch auf hohem Niveau, da kann das M5E nicht mithalten.
Und zum OC Key: Asus preist das an als tolles Feature nur schreiben sie nicht dazu das das nur mit bestimmten Tastaturen geht, weder auf der Homepage noch auf der Verpackung, erst wenn man es gekauft hat findet man das im Handbuch, na tolle wurst 330 euro und ich muß noch ne tastatur kaufen die Asus genehm ist.
Und das mit den Samsung Speicher kann auch auf dem M5E so passieren ,vieleicht nicht mit Samsung aber mit anderem Speicher, aber gerade was Speicher betrifft bin ich vom Asus auch entäuscht, läuft auch nicht rund, aber das nur nebenbei, da haben ja alle mit zu kämpfen siehe Gigabyte, da sind Asrock und Asus noch sehr gut.
Auf dem M5G liefen meine CPU und Speicher runder als wie auf dem M5E, und dies kostet weniger als die Hälfte.
Und die Features für Overclocker wie OC Key sind nur bestimmt einsetzbar, siehe oben.
---------- Post added at 16:26 ---------- Previous post was at 16:13 ----------
*Fertig* ;)
Heinrich
Hi Heinrich,
da hast du recht ausser das es 3fach sli kann, hat es sonst keine vorzüge für Übertakter.
Will auch keine große Welle draus machen, aber kritik sollte man schon abkönnen, und für das Geld das Asus dafür verlangt finde ich es halt komplett übertrieben.
Wer kein 3fach SLI braucht ist mit dem M5G besser bedient für OC als mit dem M5E, und nur darum geht es mir, habe meine persönliche Meinung zu dem Board gepostet mehr nicht.
Und wenn man dann sein Board verteidigt kann ich das auch verstehen, denn wenn man über 300 taken für ein Brett ausgibt und dann gesagt bekommt das es im OC bereich nichtmal kleinere Boards in den Schatten stellt ist das natürlich nicht so schön, da hätte man schön sparen können und ist bissle angep...
Ansonsten jedem das seine, es ist kein schlechtes Board das hab ich nie behauptet, es hat alles was man braucht, nur zum Overcklocken gibt es bessere und günstigere Modelle aus dem eigenen Haus und von anderen Herstellern, meiner Meinung nach.
Man merkt dem M5E wohl an das Shamino vermutlich längst mit der Entwickelung der 1150 Boards beschäftigt ist.
Beim M5G hatte er viel Zeit in immer neue Bios Versionen investieren können da vermutlich das Design der ATX Boards noch nicht abgeschlossen war.
Sicher gibt es auch noch andere Entwickler aber am Feinschliff der Biose ist nun mal der Meister maßgeblich beteiligt. ;)
Das es deinen Ansprüchen nicht genügt kann ich mir schon eher vorstellen. Gerade wenn du glaubst 300,- Euro hauptsächlich für eine bessere Übertaktbarkeit im Vergleich zu den kleineren ROG Modellen oder dem OCF bezahlt zu haben. Denn das ist freilich weder beim M5E noch beim E9 oder E11 der Fall. Vor allem beim E11 wirst du, vergleichbar mit dem ASUS P8Z77-V Premium, hauptsächlich die sehr spezielle Ausstattung teuer bezahlen. Das M5E hat eben noch mehr zu bieten, als "nur" seine umfangreichen OC Features und die zahlreichen PCIe 3.0 Slots/Switches (selbst die brauchst du offenbar ja nicht). So bin ich persönlich zum Beispiel sogar auf den integrierten Thunderbolt Controller angewiesen...
Wer ein puristisches OC Mainboard sucht, sollte sich ganz sicher kein E11, UP7 oder M5E kaufen. Da sind wir uns alle einig, glaube ich.
Das ist nicht richtig. Der Hinweis findet sich auch im PDF Handbuch, dass bereits vor Auslieferung der ersten Mainboards selbst auf den ASUS Server zum Download verfügbar war und auch nach wie vor ist.
Abgesehen davon: OC Key funktioniert bei mir genau wie von ASUS beworben. Zum Glück muss man auch nicht mehr per Jumper zwischen der Eingabe umschalten (wie beim R4E), sondern darf dafür nun eine Tastenkombination verwenden. Ich kann es allerdings im Alltag nicht nutzen, weil ich aus beruflichen Gründen einen DisplayPort-basierten Desktop KVM mit eigener USB-Konsole verwende. Das ist natürlich sehr speziell und vermutlich gibt es im ganzen Hardwareluxx keinen zweiten Nutzer mit so exotischer Peripherie. Aber daraus mache ich ASUS ganz sicher keinen Vorwurf, zumal ich, wie die meisten professionelleren Übertakter, eine 08/15 Tastatur zum Benchen anstöpseln könnte.
Mit welchen Chips hattest du denn Probleme?
Hier im Thread hattest du bisher nichts geschrieben dazu...
Habe mit meinen machs sowie mit meinen corsair Probleme, laufen nicht so wie auf dem OCF und m5g, ausserdem wenn ich denn Speicher wechsle muss ich erst mal das Board stromlosmachen, die Batterie raus nehmen und erst dann erkennt er den anderen Speicher, ansonsten gibt es einen 55 fehlercode, und das Board startet nicht, soviel trouble hatte ich bei den anderen Boards nicht beim Speicher Wechsel. Selbst wenn ich default setting geladen habe und cmos clear gemacht habe will er beim Speicher wechsel nicht booten, hilft nur Batterie raus.
Und du kannst das Board verteidigen wie du willst, oc technisch ist es nicht der Bringer, die anderen Sachen sind ja gut wenn man sie braucht und da kann man auch das Geld bezahlen, aber nicht wenn man mit oc wirbt.
Das selbe habe ich beim asrock e9 gesagt, wenn man damit wirbt das es für oc geeignet und das heraushebt, ist und dann noch für extreme oc, dann soll es auch das können.
Und warum wechseln so viele Profi. Ocer zum OCF, die vorher das M5E hatten.
Habe mich mit ein paar Leuten bei hwbot unterhalten, da sind einige umgesattelt sogar welche die gesp... werden.
Ist egal, ist für mich als clocker nicht der Bringer, und wenn du meinst es ist Top, dann ist das für dich okay, für mich nicht. Und ich werde auch nicht gesponsert damit ich was darstelle was nicht ist.
Und zum Thema oc key wenn das so ist das es in PDF Format schon zu haben war liest du das komplette manuell, bevor du ein Board kaufst?
Egal du findest das Board gut, ich finde es Grotten schlecht für OCler, hast du mal jenseits der 5,8 GHz gebencht?
Es ist ein gutes Board nochmal, aber nur bedingt für oc geeignet, meiner Meinung nach.
Das habe ich noch nie bei meinem M5E machen müssen und ich habe schon an die 50 Kits darauf getestet. Nun bin ich mir nicht mehr sicher, ob mit deinem Mainboard tatsächlich alles in Ordnung war :/
Das mache ich tatsächlich. Aber darum ging es hier ja nicht? Man konnte es vor dem Kauf lesen, eventuell sogar in dem einen oder anderen Review... auf deine Nachfrage dazu hier im Thread, hat dir steini81 auch direkt geantwortet.
Muss ich Extreme OC betreiben, bevor ich eine Meinung zum Thema haben darf? Meine Hardware ist mir ehrlich gesagt zu schade dafür, deshalb muss ich an der Stelle leider passen.
Das M5E ist also nicht das Richtige für dich. Dann viel Spaß mit dem OCF oder M5G!?
Hi Emi!
Das Asus, vollkommen egal, ob das M5G oder M5E, kommt nicht annährend drann, an das, was OC formula und kann und das, ist der Fakt.
Davon abgesehen, das Asus M5E kann gar nichts, das M5G hat die gleiche spannungsversorgung und kann deutlich mehr, als das M5E.
Egal, ob das Formula oder M5E, diese können, für das das Geld, nicht wirklich viel, das M5G ist für die PL Ver. Klasse.:wink:
Emi, wollte dich nicht angreifen auch nicht mit extreme oc, nur hälst du Asus die Stange was ich nicht verstehe, und machst ausagen zu Sachen die du selbst noch nicht getestet hast, und vom höheren sagen. Ich rede nur von Sachen die ich auch selbst getestet habe.
Aber genug jetzt, für mich ist das Thema erledigt.
Passt schon Jungs. Ich versteh schon wie ihr das meint und habe das nicht persönlich genommen.
Wer meine Threads schon eine Weile verfolgt, dem ist vermutlich bekannt, dass ich eigentlich nicht der größte ASUS Fan bin und mich mit Kritik generell nicht zurück halte. Tatsächlich hätte ich mich normalerweise eher bei Gigabyte oder MSI umgesehen, aber das UP7 ist total an mir vorbei entwickelt wurden und mit dem Mpower kam ich nicht zurecht. Dem OCF fehlt leider der DisplayPort für meinen KVM, weshalb es nicht in Frage kam. Das M5G war tatsächlich in meiner engeren Auswahl, wurde dann aber zugunsten der Möglichkeit eines integrierten Thunderbolt Controllers verworfen. So ist das M5E dann tatsächlich mein erstes ROG Modell geworden und vielleicht auch schon mein letztes. Es ist sicher nicht perfekt und ganz bestimmt kein Schnäppchen, aber - meiner Meinung nach - nicht so schlecht, wie es hier teilweise dargestellt wurde. Auch wenn ich das nicht so professionell angehe, wie manch anderer hier, konnte ich mich damit trotzdem problemlos durch meine Speicher-Kits fressen und hatte noch nie ein Mainboard, dass sich dabei so gutmütig verhalten hat. Weder musste ich wie donkel bei seinem Exemplar jemals die Batterie entfernen, noch hatte ich Probleme in kürzester Zeit an die Grenzen meiner, inzwischen drei - leider alle recht bescheidenen, 3570K zu gelangen. Zusätzlich diente es dank seiner Ausstattung in den letzten Wochen als Ersatz in unserer Entwicklungsumgebung, nachdem mir mehrfach andere Modelle, aus noch unbekannter Ursache, darin komplett verstorben sind *grml*
Mein Fazit ist daher: Wenn ich noch mal Geld in diese Plattform investieren würde, dann vermutlich eher in einen 3770K als in ein anderes Mainboard (das gesuchte UP5 TH ist der geplante Ersatz fürs Labor).
Nun also weiter im Sammelthread, mit dem normalen Tagesgeschäft :wink:
Nutzt jemand Acronis True Image 2013 !?
Ich habe hier Probleme unter laufendem Windows ein Recovery zu starten - normalerweise bootet er neu und lädt den Acronis Bootloader.
Bei mir ist es aber so das nach dem Boot jedes mal Windows 8 wieder geladen wird!?
Wenn ich in die Bios Optionen gehe ist auch der Acronis Bootloader als erstes in der Reihenfolge zum booten eingestellt...
was läuft da falsch!?
Edit:
eigentlich hat das sonst funktioniert ob es vielleicht mit dem letzten Bios Update zusammenhängt?
Wo kann ich denn die integr. GPU in meinem i5-3570K ausstellen?
Hallo Jungs...
Aktuell nutze ich das 22er BIOS. Dieses hat die Intel ROM Version 11.0.0.1339.
Wisst Ihr ob bzw. wie man das Intel ROM updaten kann?
Inzwischen gibt es ja das 11.6.0.1702...
Edit:
geht bei mir ohne Probleme mit bios 1604
Für die Liste:
Geil EVO Leggera Series 1866Mhz CL9 sind komplett stabil. Der Noctua NH D14 ist sehr groß und passt wegen der Lüfterhalteklammern nicht weil das PCB bzw. die Backplate der Graka im ersten Slot diese Klammern berührt.
Entfernt man diese Klammern aber, und ersetzt sie einfach mit Kabelbindern oder Draht die man nicht seitlich am lüfter führt sondern oben und unten benutzt um die Lüfter zu befestigen klappt alles. Man hat dann ca. 3-4mm zwischen Graka und Kühler Platz.
Wer hier Angst hat, dass was passiert, einfach ein Kartonstück in ESD - Sackerl stecken und dazwischen schieben. Klappt tadellos, obwohl ich selber es ja nicht brauche weil ich weiß dass da nichts passieren wird ;)
Nun gut, habe jetzt nur eine kleine Frage zu dem mPCIe Combo Kärtchen. Und zwar steht im Eventlog ständig was von WLAN Auto Config. Das nervt tierisch. WLAN ist aber im BIOS deaktiviert und das Gerät aus dem Geräte Manager entfernt. Jemand eine Idee was das ist und wie man das abstellen kann?
Welches der Kits genau? EVO Leggera 1866 CL9 in DDR3 240pin Preisvergleich | Geizhals Deutschland
Der NHD14 ist also Grundsätzlich kompatibel, ragt aber an den ersten PEG. Hättest du ihn eventuell gedreht ohne diese Probleme verbauen können?
Hast du die WLAN/BT Suite für das Board dann überhaupt installiert? Wenn nicht, dann deaktiviere doch mal den WLAN Konfigurationsdienst in Windows selbst. Eventuell haben sich die Eventlog-Einträge damit dann erledigt (und das Board kann gar nichts dafür).
Das erste gleich: 16GB betehend aus 2x8GB Riegel. Wie gesagt läuft super.
Hab den Kühler nicht gedreht, aber ich denke mal dass einer der 2 Lüfter (der letztere) über den ersten PCIe Block ragen würde. Ohne lüfter könnte es gehen.
Das Board hat glaub ich eh nichts, ist sicher ein Software Problem. Ich hab diese ASUS Suite II installiert. das sollte eig. alles dabei sein. Bluetooth wird rochtig erkannt und funktioniert auch. Wenn ich das WLAN im BIOS aktiviert lasse, dann kommen noch mehr Einträge im Log. die nennen sich dann WLAN tray, was auch immer das wieder zu bedeuten hat. Ich probier deinen Vorschlag mal aus und schaue obs hilft ;)
Ich installiere nie blind alle Software von einer Hersteller CD. Wenn du die komplette WLAN/BT Suite mit installiert hast, dann kannst du die jeweiligen Anwedungen unter Umständen aus dem Autostart (Reg/Run) entfernen oder auch über die Systemsteuerung wieder runter schmeissen. Versuch macht kluch ;)
Also gedreht mit einem Lüfter mittig würde der NH-D14 passen? Dann nehme ich das so in den ersten Beitrag auf.
Edit: Den Hinweis zu den Lüfterklammern war bereits drin :fresse:
Ja ich hab ja nicht alles installiert :P
Nur die Treiber und die Suite :)
Hab jetzt den Dienst deaktiviert und es funktioniert tadellos. Vielen Dank hab keine Einträge mehr.
Der Lüfter sollte normal passen wenn man statt den Klammern was anderes zum Befestigen nimmt. Gedreht sollte es auch passen aber sicher bin ich mir nicht. Habs wie gesagt noch nicht probiert, man müsste das noch mal genau austesten um sicher zu sein.
Aso das mit den Klammern wurde schon geschrieben? Ich hab ein paar Seiten übersprungen weil ich lesefaul war und da wirds auf irgendeiner Seite gestanden haben! Na macht ja nix ;)
Prima, dass es mit dem Dienst sofort geklappt hat.
Der Hinweis mit den Klammern war im ersten Beitrag in der Kühlerliste selbst schon verlinkt :)
ich habe mir ein Asus Maximus V Extreme gekauft und wollte meinen
Thermalright Archon SB-E X2 weiter nutzen nun musste ich leider feststellen das
ich die Garfikkarte nicht in den PCIe Slot 1 einbauen kann da der Kühler zu groß ist.
ich muss auch auf die länge des Kühler achten da ich sonst meine 4x8GB G.Skill Sniper nicht nutzen kann ein Riegel 42mm hoch
Welche top alternative gibt es als CPU Kühler damit ich den ersten PCIe Slot nutzen kann um mein Sli-System zu verbauen
Preis bis 100 € lieber weniger;)
Danke im Voraus
JP
Hilfe
Habt ihr eine Idee wo ich weitere Temperatur Sensoren und die Sub - Zero Kabel herbekomme?
