[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
ich habe mir ein Asus Maximus V Extreme gekauft und wollte meinen
Thermalright Archon SB-E X2 weiter nutzen nun musste ich leider feststellen das
ich die Garfikkarte nicht in den PCIe Slot 1 einbauen kann da der Kühler zu groß ist.
ich muss auch auf die länge des Kühler achten da ich sonst meine 4x8GB G.Skill Sniper nicht nutzen kann ein Riegel 42mm hoch
Welche top alternative gibt es als CPU Kühler damit ich den ersten PCIe Slot nutzen kann um mein Sli-System zu verbauen
Preis bis 100 € lieber weniger;)
Danke im Voraus
JP
Hilfe
Hilfe bitte ich habe kein PLAN ich suche nur einen Kühler der den 1. PCIe Slot nicht verdeckt und die vier Ram-Bänke :(
Du kannst zum Beispiel die Featuresuche des Preisvergleichs nutzen und so die Breite des Kühlers beschränken/eingrenzen. Ich nehme mal an, das fast jeder Towerkühler mit 120mm Lüfter(n) problemlos passt. Ich habe ja den Frio verwendet, der mit zwei Lüftern aber die Speicherbänke teilweise überlagert und auch relativ breit ist. Wenn du da also komplett auf Nummer sicher gehen willst (Breite & Tiefe), dann fallen viele der High End Kühler weg. Der Thermalright HR-02 Macho 120 ist zwar nicht unbedingt High End, sollte dafür aber keine Platzprobleme bereiten. Wenn dir das zu wenig Performance ist, gibt es da auch noch die AIO-Wasserloops, von Corsair oder NZXT. Das sind eigentlich für solche Fälle recht praktische Lösungen, sofern die den Platz im Gehäuse hast...
Einfach mal selbst nachmessen, wie breit der Kühler in deinem Fall sein darf und vielleicht selbst noch mal im Preisvergleich umsehen.
HI,
ich denke ich brauche einen guten 120mm breiten ca. 110mm langen und max. 170mm hohen Kühler
ich muss auch auf die länge achten da ich sonst meine 4x8GB G.Skill Sniper nicht nutzen kann ein Riegel 42mm hoch
ich habe auch schon über eine Kompaktwasserkühlung nachgedacht nur welche und wie schaut das aus mit Wartung und Haltbarkeit und Zuverlässigkeit aus
Gehäuse: Thermaltake Overseer RX-I Big Tower
Warten musst du die AIO Lösungen gar nicht, sie sind per Definition wartungsfrei. Die Haltbarkeit wird vermutlich durch die MTBF der Pumpe vorgegeben (ohne Gewähr). Du kannst dich ja dazu selbst mal umsehen, wir haben hier im Forum einige Threads zu diesem Thema. Oder Frag direkt die Experten im Wakü-Quatsch-Thread (LINK). Die Wahl des richtigen Modells hängt auch davon ab, welche Möglichkeiten dein Gehäuse für den Radiator bietet. Von 1x120, 1x140, 2x120, 2x140 gibt es eigentlich alles. Beliebte Modelle wären im Moment, je nach Größe zum Beispiel die Corsair H80i (1x120) + H100i (2x120) und die NZXT Kraken X40 (1x140) + X60 (2x140).
Mhhh..irgendwie kann ich mich mit dem UEFI Bios nicht anfreunden!
Kann ich die integr. iGPU meines i5-3750K nicht komplett abschalten? Bios: steht nur Auswahl iGPU / PCI-E / Auto
Wie stelle ich nur den Multi ein das " nur " die CPU höher getaktet wird alles andere aber gleich bleibt bei max. 1,2V CPU Spannung?
CPU LEVEL UP taktet alles hoch!
LOAD Gamers OC Profile knallt die Spannungen auch ganz schön hoch bzw. die Mhz des RAM Speichers!
geht bei mir ohne Probleme mit bios 1604
Danke für die Rückmeldung!
Habe Acronis erstmal gelöscht und EaseUS installiert (mit nem coupon code kommt man da sehr günstig dran).
Edit: ich denke aber, dass es bei mir an der Laufwerksbootreihenfolge lag.
Diese Möglichkeit ist nicht in allen BIOS Versionen vorhanden.
CPU Ratio und CPU Spannung manuell eingeben. Die OC-Automatiken einfach links liegen lassen.
Mein OC Formula ist aus der RMA zurück, das wars dann hier, das M5E werd ich verkaufen.
Danke für die Unterstützung.
Hier mal ein Wert wo das M5E nie drangekommen wäre, für die 4,5 brauchte das M5E 1,180V
Das lässt sich leider schwer nachvollziehen, ohne die CPU selbst getestet zu haben auf beiden Mainboards.
Ich glaube immer noch, dass mit deinem M5E etwas nicht gestimmt hat (deiner Beschreibung nach).
Wie auch immer, das Thema Asus hat sich erledigt, nachdem ich auch noch mit dem Support kontakt hatte.
gruß
AW: ASUS Maximus V Extreme R.O.G + Mini Review? (Z77)
Mein 3570K braucht für die 4,5ghz 1,168V auf dem M5E.
Ohne WEHA Fehler komm ich auch noch eine Stufe weiter runter mit der Vcore, aber sobald es bei mir Prime stable ist gebe ich noch eine Stufe drauf als 24/7 setting.
Ich mache das immer über offset.
Also in deinem Fall den Multi auf 40 und mal mit offset -0,010 anfangen.
Mit Prime auf Stabilität testen und sollte alles ohne Fehler durchlaufen kannst du mit dem offset weiter runter gehen (-0,015, -0,020, usw.).
Sollten Fehler auftreten dann mit dem offset wider eine Stufe rauf.
Die Stromsparmodi und EIST sollten aktiviert sein.
Hallo! Habe das auch schon im Mainbord-Bereich gepostet, aber vielleicht wird mir hier eher geholfen...
Ich hoffe mal ihr könnt mir weiterhelfen...
Mein Computer startet nach dem ich Windows heruntergefahren hab nach paar Sekunden neu, das einzige was hilft, ist den Schalter am Netzteil umzulegen, damit er aus bleibt, oder den PC in Windows durch drücken des Power-Knopfs "abzuwürgen"...
Nun habe ich mich schon durch einige Foren durchgelesen, aber ich bekomme das Problem nicht gelöst.
Was ich bisher versucht habe:
- Den PC in den Ruhezustand geschickt. Das klappt auch nicht, er wacht direkt wieder auf...
- BIOS zurückgesetzt
- Wake On LAN mal abgeschaltet
Habt ihr sonst noch eine Idee? Ich habe jetzt alles auf Standardwerten, also nichts übertaktet. Das Phänomen trat 2 Tage nachdem ich eine GeForce 680 verbaut hatte das erste mal auf...
Hier mal mein System:
ASUS Maximus V Extreme mit neustem BIOS
i7 3770k
Corsair Dominator GT 8GB
Corsair AX860i Netzteil
Die Geforce 680 ist auch von ASUS
Danke schon mal ;-)
Hast du unmittelbar vor dem ersten Auftreten irgendwelche Änderungen (Software) am System vorgenommen?
Kannst du die GTX680 eventuell noch mal ausbauen und testen ob das Problem es nur mit der Grafikkarte auftritt?
Alternativ: Geh mal testweise auf ein älteres BIOS zurück, eventuell versuch es mit der 0704.
Edit: und ggf die EuP Funktion aktivieren
Hallo!
Nein, das Problem trat von heute auf morgen auf...
Ich habe zwischenzeitlich auch mal Windows 7 neu installiert, habe auf das zweite BIOS gewechselt (ich meine 0604 wäre das gewesen) und habe mal sämtliche Karten nacheinander ausgebaut... Bringt alles keine Besserung.
EuP Funktion? Kannst Du mir das genauer erklären?
Edit: EuP habe ich mal aktiviert, hat aber bei frisch installiertem Windows keine Besserung gebracht
Edit 2: Sämtliche OnBoard Geräte habe ich eben auch mal deaktiviert, bringt ebenfalls nichts...
Oh, Shit! Deine letzte Antwort habe ich komplett übersehen. Die nächsten Schritte wären bei mir Windows neu aufsetzen und anderes Netzteil testen gewesen :/
Ich hab mein M5E mal wieder kurz raus geholt, da ich für einen anderen User zwei Kits testen "durfte". Es war auch noch etwas Zeit für einen meiner eigenen Neuzugänge:
Corsair Dominator GT CMT4GX3M2A2000C8 @ DDR3-2302 CL7-10-7-27 1T 1.678v
Kein Problem ;-)
Windows neu aufsetzen habe ich getan, hat nichts gebracht.
Anderer Arbeitsspeicher hat auch nichts gebracht.
Habe mal ein uralt-Netzteil mit 350 Watt und 20 poligem ATX-Stecker drangehangen, damit funktionierte es dann. Mein Corsair AX860i kommt die Tage aus der RMA zurück, mal sehn ob die einen Fehler gefunden haben... Obwohl Corsair auf das Board tippt.
Drücke dir auf jeden Fall die Daumen. Eigentlich sind gerade die Corsair AX-i Modelle ja auch wirklich spitzen Netzteile :)
Welcher RAM ist empfehlenswert wenn ich meine jetzigen DDR3 4x4 GB Corsair Vengeance 1600 Mhz aufrüsten möchte der noch halbwegs " günstig" ist! Mehr RAM-Takt sollte schon sein bei 1,5V!
gruß
dirk
Ich finde die G.Skill F3-1866C9Q-32GXM bieten eine recht vernünftige Mischung aus Leistung / Preis.
Dazu kommt, dass sie von G.Skill auch auf dem M5E getestet wurden:
G.SKILL- RipjawsX F3-1866C9Q-32GXM
Falls dir die Farbe wichtiger ist, als die Timings, gilt das auch für die F3-1866C10Q-32GXL (rot), die F3-14900CL10Q-32GBZL (rot) und die F3-1866C10Q-32GSR (schwarz).
Very Thanks! Ja farbe ist auch wichtig!:)
Geht noch ein bisserl mehr Mhz ? gerade BF3 soll ja auf mehr RAM Takt ansprechen! Ist halt mein Favorite Game!
Klar geht das auch mit mehr Takt, zum Beispiel gibt es bei Caseking gerade
Caseking.de » Team Group Xtreem Series DDR3-2133 CL11 32GB Kit
und sonst natürlich auch
G.SKILL - RipjawsZ F3-2133C11Q-32GZL (da steht das M5E ebenfalls auf der Comp-Liste)
Wenn du was schnelleres willst, gibt es auch noch die F3-2133C9Q-32GXH. Das sind allerdings 1.50-1.60v Module.
Meine Favoriten wären die TridentX F3-2133C9Q-32GTX. Das ist eigentlich ein 1.60v Kit, wenn sie so gut gehen, wie andere TridentX Modelle, dann lassen sie sich aber vermutlich gut undervolten.
ufff... aber über 200 € für RAM heutzutage ist schon ne Hausnummer!
Very Thanks!
Da die Preise im Moment eher steigen als sinken und das alles andere als Mainstream Kits sind, muss man das in Kauf nehmen ;)
2400er Kits gibt es dann nur noch mit Spezifikationen von 1.65v, auch wenn einige davon sicherlich auch mit weniger laufen...
Müßte nicht langsam wieder einmal eine BIOS Aktualisierung kommen ? Die letzte ist ja schon von Anfang Januar...
Hast du ein konkretes Problem, dass sich mit keiner der existierenden BIOS Versionen lösen lässt?
Hast du schon Kontakt zum ASUS Support aufgenommen und dein Problem geschildert?
Ein Hersteller wird nicht "aus Prinzip" in einem monatlichen Rhythmus neue Versionen entwickeln, da dies Kosten verursacht.
Wenn du Probleme mit eine der aktuellen Versionen hast, dann versuche es mal mit der 0704.
