[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
Naja, die Temps wo dort herrschen sind aber lang nicht so schnell im kritischen Bereich. Das meine ich eigentlich damit. Ob ein Wandler nun ,60 oder 80 grad hat doch glaub egal oder?
Kann man Paste nehmen oder zu gefährlich wegen Höhenunterschied?
Wenn ich mit Hotkey aufs OSD wechseln will und Keyboard umschalte passiert irgendwie nix bzw. schaltet kurz um aber wirft mich dann nach 3sec. wieder zurück aufs Windows.
Liegt des an meiner Anansi ?
Wenn deine Tastatur einen integrierten USB Port hat dann funktioniert der OC Key nicht.
hi.bin der neue^^
suche lange leute die das mobo haben.ich habe ein paar probleme.
nach tagelangem studium des handbuches und onkel google fragen,weis ich immer noch nicht alles.
hab etliche mobos gesehen,aber das maximus v formula,macht mich wahnsinnig.
mein 3570-k läuft mit 4,6ghz im alltag.
offset ist an,klappt auch schön.desktop 1,6ghz.aber..........
ich kann beim offset keine 0,005v runter gehen.dann hab ich beim desktopstart 0,9v,und komme nicht über das "willkommen" hinaus.
ist ja nicht schlimm.spannung offset auto,dann klappts.
das problem: ich habe bei 4,6ghz bis zu 1,38volt anliegen.
ich versuche seit monaten rauszufinden,wie ich unter last die 1,38v auf ca 1,25v senken kann.
welche der 425 einstellmöglichkeiten ist die vcore?!
diese vccsa,vcc-irgendwas,bringen mich durcheinander.
also,wie stelle ich den vcore unter last ein!?
problem 2:
so alle 1-2 tage,geht mein pc einfach so aus.
klack...dunkel.
beim film schaun,desktop,surfen,oder zocken.
tagelang ruhe,irgendwann...klack,kiste dunkel.
nt war ein corsair hx 650 pro.
wurde getauscht,gegen ein corsair hx 850 pro (wegen neue gtx 780 hydro copper)
problem taucht immer noch auf.gestern erst:kippe geraucht,komm ins zimmer,tft..kein signal.kiste dunkel...kotz.
in der ereignisanzeige finde ich : pc wurde unerwartet runtergefahren.
beim neustart bekomme ich auch die meldung:windows normal starten/abgesicherter modus bla bla.
wenn einer ne lösung hat,tips,oder andere lösungswege,schreibt...
ps:ihr habt auch den kleinen switch auf dem mobo "slow-mode" auf aus stehen,oder?!:d sagt ja!
Hmm hab ich dass ? :d gehen also nur normale alte Tastaturen dran oder?
Es gehen auch nagelneue Modelle, solange sie keinen USB Hub besitzen. Denn sonst schlägt die Low Level Enumeration des OC-Key über das USB Protokoll fehl.
das problem: ich habe bei 4,6ghz bis zu 1,38volt anliegen. ich versuche seit monaten rauszufinden,wie ich unter last die 1,38v auf ca 1,25v senken kann. welche der 425 einstellmöglichkeiten ist die vcore?!
CPU Spannung: CPU Voltage, entweder als fixer Wert oder mit Offset
CPU Last Spannung: zusätzlich beeinflusst durch die CPU Load-line Calibration* (LLC) --> könntest du mal von AUTO auf Normal stellen (oder die anderen Möglicheiten durchprobieren)
*findest du im UEFI bei Extreme Tweaker \ DIGI+ Power Control
so alle 1-2 tage,geht mein pc einfach so aus. klack...dunkel. beim film schaun,desktop,surfen,oder zocken.
Würde da auch zuerst auf das Netzteil tippen. Könnte auch an anderen Komponenten liegen, ist aber schwer zu sagen ohne das System und die Komponenten zu kennen. Hast du dieses Problem auch, wenn du nicht übertaktest?
Slow und LN2 Mode lass mal besser deaktiviert.
Übrigens ist das der Sammelthread zum Maximus V Extreme, das Formula hat einen eigenen:
http://www.hardwareluxx.de/community/f219/asus-maximus-v-formula-z77-909945.html
:wink:
hmm an was liegts dann. Glaub des Anansi hat kein USB Hub. Wenn ich umschalte macht Windows auch kurz "babim" und dann nach 3sec. wieder "babam" :fresse: ihr wisst was ich meine ... wenn man Laufwerk anschließt etc.
Du könntest mal bei Razer nachfragen, ob das ein bekanntes Problem ist und eine Firmware Fix in Arbeit... oder dich in ähnlicher Weise an den ASUS Support wenden.
Bisher hatte ich damit noch keine Probleme, aber es gibt wohl noch ein paar andere exotische Tastaturen die sich aus verschiedenen Gründen problematisch verhalten können (zum Beispiel wenn aus dem internem Speicher der Tastatur automatisch der Treiber installiert wird, das hatten wir hier schon am KVM^^).
Boah jetzt hab ich ne Stunde rumgemacht weil mein 3d nicht mehr ging. Jetzt kam mir mal die Idee das vielleicht am OC Key liegen könnte :fresse:
Hallo Leute kann mir einer verraten wie mann die Power Limit Control einstelt.Ich erhoffe mir einen kleinen Leistungsschub.
Die Limits selbst anzuheben, bringt dir erst mal gar keine Leistung. Das kann nur notwendig werden, wenn du beim übertakten durch diese begrenzt wirst.
Achso oke supper danke was könnte mir einen wintzigen leistungsschub bringen ohne zu übertackten was für möglich keiten habe ich.
Woher soll die Leistung kommen, wenn du nichts übertakten willst?
Du könntest du Speichertimings optimieren, oder an deinem Betriebssystem und an den Treibern herum schrauben... aber sonst, dürfte das schwierig werden.
Wie kann mann die Speichertiming optimieren.Ich nicht so viel erfahrung in Timings.
Ob bei den Timings überhaupt noch Luft ist hängt vom Speicher ab. Da du nicht übertakten willst, kommt ja ein anderer Speicherteiler schon nicht in Frage *G*
Das Thema selbst ist sehr komplex und ich fühle mich jetzt auch nicht in der Lage, hier ein allgemeines Tutorial dazu zu schreiben. Wenn du mal mit ein paar Informationen zu deinem System und Settings heraus rückst, kann ich dir aber eventuell ein paar Tips geben. Wichtiger wäre aber: Was versprichst du dir eigentlich davon? Also welchen Nutzen? Nur ein kleiner Teil von Anwendungen reagiert überhaupt direkt mit Leistungsgewinnen auf solche Speichertweaks...
OOOO ENTSCHULDIGUNG
Mein Sys:
Maximus V Extream
CPU 3770K Turbo Max 3900 MHZ Syncronisiert alle 4 Kerne Boost 3900 CPU Wakü
NT Enermax 1500 Watt
KFA2 GTX 680 2GB
2xSSD OC Vertex 4
2400 Riegel mit standart 1.65 V
Was für Riegel genau? Alle 2400er Module brauchen 1.65V, das grenzt es also nicht unbedingt ein^^
Zeig mal einen Memtweak Screen von den Timings und einen Aida64 Membench von den Durchsätzen und Timings.
Sind also Samsung Module. Da geht bei den Haupttimings vermutlich nicht mehr viel, eventuell 10-11-11-21 1T. Aber das M5E besitzt auch integrierte Profile für diese Samsung Chips (Tight & Medium). Eventuell ist die Performance damit etwas besser, als mit dem XMP. Jedoch ist das keine Sache von Schalter umlegen fertig, da gehört schon etwas Handarbeit dazu...
Wie sehen denn deine Durchsätze in Aida64 (3.00) aus?
Jo ich denke auch.Ich hatte ja ein MSI das gröste der 1155 Sockel.Aber das wahr ned grad supper von UEFI Settings.Noch eine kleine frage was würdest du einsten 100:100 oder 100:133 was wer besser.Die im Asus Support konnten mir ned mahl sagen was besser ist.
Das Board wählt automatisch die richtige Einstellung für den jeweiligen Speicherteiler (manche Teiler brauchen den 100er und andere 133er Strap). Wenn du diesen manuell umstellst, siehst du das sofort an der Auswahlmöglichkeit bei den Teilern.
Kannt du mir mahl ein Bild zeigen wie das bei dier aussieht.Das ich ein mahl eine vorstellung bekomme.
Wenn du mir jetzt noch sagst, was du eigentlich meinst?
Aida64:
Ich bin zu dum ich raf das nicht ganz.Ich muss mir das mahl genau anschaun.Ich schreibe dier dann.
Du kannst am Speicher eh einstellen was Du willst oder auch übertakten, Du wirst da keinen wirklichen Leistungsschub feststellen (außer Du lässt'n benchmark laufen).
Übertakte die CPU und die Grafikkarte, da merkst auch was von (Grafikkarte natürlich nur wenn Du auch vor hast zu zocken).
Mein Sys:
Maximus V Extream
KFA2 GTX 680 2GB
2xSSD OC Vertex 4
krasse Kombi ... hast Du Dir das Netzteil selber ausgesucht, oder hat dir das Jemand so empfohlen oder sogar in der Kombi verkauft? Das ist leicht überdimensioniert ... oder sind das vier KFA2 GTX680? ;)
