[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
Ich überlege ob ich meine GTX770 SC Titan cooled gegen eine GTX780 tauschen soll.....
Bei BF3 auf Ultra kann ich die 60fps nicht halten:)
Was hält der PCH/PLX eigentlich so an Temps aus ? Hab grad 3 Grakas drinne und verbrenn mir die Finger dran. 65° laut Sensor.
Hehe, da haben wir wohl ein Timingproblem :fresse2:
Aber meine bessere Hälfte wirft sonst vielleicht mal ein zwei Rechner aus dem Fenster, also lasse ich es nicht darauf ankommen^^
Hallo Zusammen,
ich bin dabei, mir meinen neuen PC zusammenzubauen. Jetzt habe ich zum ersten Mal ein modulares Netzteil (Seasonic Platinum 760W).
Der netzteilseitige Anschluß des beigelegten 24Pin MB Kabels verfügt über einen zusätzlichen 8Pin Kabelstrang welcher im Netzteil gesondert eingesteckt wird. Soweit so gut... Nun ist aber laut MB Handbuch ein weiterer 4 oder 6 oder 8Pin Stromanschluß erforderlich welcher auf dem Boardlayout ebenfalls mit 1 beziffert ist. Ich bin jetzt allerdings ratlos, ob ich den ebenfalls benötige, da ich ja schon den erstgenannten, zusätzlichen 8Pin Stecker verwendet habe... Ihr werdet über so eine Anfängerfrage sicherlich lachen, aber ich möchte mir nichts zerschießen... Es wäre toll, wenn Ihr mir hier weiterhelfen könntet !
Falls du den rot eingekreisten meinst. Ja muss angeschlossen werden. Bei meinem Netzteil ist es ein zusätzlicher 8-Pin. Sprich 24 Pin Anschluß vorn aufs Board und den 8-Pin so wie ich eingezeichnet habe.
Hallo AK511,
1000 Dank für Deine schnelle Antwort ;)
OK, das zweite Kabel wird in jedem Fall benötigt - verstanden! Ich habe jetzt die auf dem Foto zu sehenden linken beiden M/B Anschlüsse mit dem 24Pin Mainboard Kabel verbunden, (den oben zu sehenden 18 Poligen und den darunter liegenden 10 poligen.) sea11s.jpg
Für den von Dir eingekreisden Anschluß benötige ich also nun noch ein weiteres CPU/PCI-E Kabel.
Ich hatte nur Angst, zu viel Strom zuzuführen - deswegen meine genaue Nachfrage.
Einen schönen Abend an Alle !
Hallo AK511,
OK, das zweite Kabel wird in jedem Fall benötigt - verstanden! Ich habe jetzt die auf dem Foto zu sehenden linken beiden M/B Anschlüsse mit dem 24Pin Mainboard Kabel verbunden, (den oben zu sehenden 18 Poligen und den darunter liegenden 10 poligen.) Anhang anzeigen 244694
Wie es von deinem Netzteil her aussieht mit den Anschlüssen weiß ich nicht. Wie gesagt ich habe einen vollwertigen 24 Pin dran und den zusätzlichen 8 Pin
Ich habe jetzt die auf dem Foto zu sehenden linken beiden M/B Anschlüsse mit dem 24Pin Mainboard Kabel verbunden... Für den von Dir eingekreisden Anschluß benötige ich also nun noch ein weiteres CPU/PCI-E Kabel.
Du brauchst nur einen der beiden CPU-Anschlüsse verbinden, der zweite ist optional.
Das ist nicht richtig. Auch bei einem 3 Way Setup ist der zweite CPU-Anschluss optional. Um die Versorgung der PEG zu stabilisieren gibt es einen eigenen Anschluss EZ_PLUG_1, welcher laut Handbuch für 4 Way Setups verwendet werden soll(te).
@emissary42: Hast natürlich Recht! :d .....war noch zu früh für mich...
Passt schon, aber vielleicht hast du dem einen oder anderen kurz Angst gemacht^^
Dachte hast mit Brutus getauscht ?
Hab mich schon gefreut meine Perle noch auf dem OCF zu sehen von ihm :(
Habe noch mal eine Frage an Euch...
Ich habe mir eine PCI-Express SSD zugelegt, jetzt werde ich im Handbuch aber nicht so richtig schlau wo ich diese jetzt einstecken soll...
Ich habe im ersten Slot (PCIe 3.0/2.0 x16/x8_1) meine Geforce GTX 680 stecken, im fünften Slot (PCIe 2.0/1.1 x4_1) meine Soundkarte stecken. Wo kann ich denn nun die PCIe-SSD hineinstecken, möglichst ohne was anderes auszubremsen? Nach der SLI-Tabelle im Handbuch müsste die SSD sicherlich in Slot 2B, oder? Aber dadurch wäre die Grafikkarte in Slot 1 nur noch mit 8 Lanes angebunden... Werde ich da mit einer IvyBrige CPU Leistungseinbrüche haben?
Danke schon mal für eure Hilfe ;-)
Wenn du dir die Tabelle aus dem ersten Beitrag ansiehst, dann musst du dies wie ein 2 Way Setup behandeln. Sofern du deine Soundkarte auch im PCIe x4 Slot betreiben kannst, kannst du dir aussuchen, ob du die Grafikkarte weiterhin mit 16 Lanes über den PLX (PEG_2A & beliebiger Slot für die SSD), oder mit 8 nativen Lanes von der CPU versorgen willst (PEG_1 & PEG_2B). Ich würde dir raten, es erst mal mit der nativen Variante auszuprobieren...
Habe die SSD jetzt mal im PEG_2B verbaut, die Grafikkarte läuft jetzt natürlich nur noch mit 8 Lanes, aber es ist kein Unterschied bemerkbar. Habe mal 3DMark drüberlaufen lassen, der Unterschied ist zu vernachlässigen...
Da es sich um die RAIDR Express SSD von ASUS handelt wollte ich mal fragen: Hat die noch jemand auf dem MVE verbaut? Auf der Karte befindet sich ja ein sogenannter "Duo-Switch". Nach den CSM-Einstellungen im BIOS habe ich die Karte im Legacy-Mode zum laufen bekommen, im UEFI-Mode bootet das Board natürlich wesentlich schneller, nur wird die Karte erst gar nicht erkannt :(
Nur so aus dem Bauch heraus:
UEFI/Legacy Boot [Enable both UEFI and Legacy]
PCI ROM Priority [EFI compatible ROM]
Boot from PCIe/PCI Expansion Devices [UEFI driver first]
Wenn die Karte dann im UEFI angezeigt wird, solltest du sie nur noch in der Bootreihenfolge hinzufügen müssen.
Danke, das werde ich mal ausprobieren... Alles was ich bisher gefunden hatte war, das ich unter den CSM-Einstellungen die Einstellung für externe Geräte ändern sollte ;-)
Hat denn überhaupt jemand Probleme mit dieser System Stability?^^
