[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
Ich bin bei 4,5 GHz bei 1,34V VCore. RAM hab ich nicht übertaktet. Ob die hohe VCore durch den vielen RAM bedingt ist weiß ich wirklich nicht
Dann nehm doch einfach zwei Riegel raus. Ich habe 2x8 GB drin.
Wie sehen denn deine Temperaturen aus?
[/QUOTE]
Was würde es denn bringen? Ich lass es ja eh mit 32 laufen, ob ich nun weiß ob es mit 2 Riegeln weniger Spannung braucht oder nicht.
Meine Temperaturen sind im Rahmen, so um die 70° - Hab aber auch ne sehr gute Wakü
also mein 3570K brauch auch 1,3V für die 4,5GHz ...... und 4,7GHz erreeiche ich nur mit ca 1,4V hab wohl eher ne schlechte erwischt
allerdings habe ich es immer mit 4 riegel probiert , gerade habe ich nur 2 drin kann ja mal testen ob er nun weniger brauch für die 4,7GHz
zur Info,
ich hab 4 mal 4GB Corsair Vengeance 1600er 9-9-9-24er drin. Die laufen netmal auf 1866 dauerhaft stabil. Ich habs mit den Werten aus
dem Hardwareluxx-Test versucht (auch entschärft auf 11-13-12-30-2T). Nach rund 1h bricht prime ab, mit 1600 läuft auch 8h durch.
Also 2000+ mit den Dingern grenzt wohl an ein Wunder.
Kein Kit läuft exakt wie das Andere. Bei den Review-Samples sollte man außerdem im Hinterkopf haben, dass die zum Teil sicherlich auch "Cherry-picked" sind.
Salve,
einmal eine Frage an die Experten: können diese Daten stimmen?
deine ersten screens sahen ja nicht so gut aus ???? das Bios scheint doch gut zu sein ....
wieviel LLC haste eingestellt ???
na dann haste wohl ne gute CPU erwischt ...... warum waren den deine ersten screens nicht so gut , da war ja dein verdacht das du mehr Vcore brauchst ......
Also im Standby sollte der Motor nicht brummen. Damit ein Motor brummt muss er laufen.
Könnte ein elektrisches Bauteil im NT sein, was bei Standby noch Strom führt ( also Kondensator oder ähnliches )
Und soll ich was unternehmen oder kann ichs ignorieren? Nicht, dass mir das Seasonic irgendwann um die Ohren fliegt. Könnte es auch am Stromnetz / Hausverkabelung liegen?
also am stromnetz /hausverkabelung kanns nicht liegen ....... wenns störend ist oder nervig tausche doch das netzteil um wenn du noch garantie hast
Nö mir isses eigentlich egal, will nur wissen, ob das gefährlich sein könnte, ansonsten würde ichs ignorieren weil es alles super läuft. :)
Klar kann es irgendwann mal kaputt gehen. Das kann dir aber auch ohne Brummen passieren.
Also ist das Brummen :wayne: oder ist es ein Zeichen dafür, dass es schneller kaputtgehen könnte?
Nochmals,
wenn du sicher bist, dass es das Netzteil ist, dann geb es zurück, wenn du noch Garantie darauf hast.
Andernfalls reinige es mit Druckluft und schaue, ob es besser wird. Montiere ebenfalls eventuell einen neuen Lüfter.
Im Übrigen:
Wenn ein Netzteil über den "Jordan geht", dann können Spannungsspitzen entstehen, die die übrige Hardware ebenfalls nicht überlebt.
Merke: Können heißt nicht Müssen
würde das netzteil auch schleunigst tauschen (wenn es wirklich das netzteil ist) ... lieber den aufwand ein netzteil zu tauschen oder sogar zu erneuern als damit riskieren die restliche hardware zu beschädigen ...
Dann muss ich nochmal untersuchen, ob es wirklich vom NT kommt, Danke. Und wie geschrieben: Klar hab ich noch Garantie drauf, das Ding ist erst seit einem Monat verbaut. Aufschrauben werde ich es aber nicht, da müsste ich nämlich das Garantiesiegel durchbrechen. Dann lieber über Seasonic tauschen lassen, die haben ja Premium-Service laut Madz, aber erstmal sicherstellen, dass es auch wirklich vom NT kommt.
P.S.: Im Betrieb habe ich aber kein Brummen o.ä., das ist echt nur so, wenn es ausgeschaltet ist und dann ab und zu.
also ich würde auch die Finger davon lassen im PCGH war erst kürzlich ein Bericht das ein 16jähriger junge in Amerika daran gestorben ist weil er an einem Netzteil rumgebastelt hat..... Ausbauen umtauschen und gut is .
Ich hab auch schonmal eine vom Netzteil gewischt bekommen, das ist kein Spaß! Sollte man nur machen, wenn man Ahnung davon hat, ich hab meine Lektion gelernt :fresse:
Es passiert nichts, wenn man das grüne Kabel kurz mit dem schwarzen Kabel daneben (links oder rechts ist egal) verbindet/kurzschließt.
Netzstecker vorher ziehen. Läßt man den Netzstecker drin, dann läuft das Netzteil an. Will man dagegen das Netzteil länger laufen lassen, dann
sollte man einen Verbraucher dazwischenschalten.
gibts z.b hier für kleines Geld:
http://www.ebay.at/itm/Neu-PC-20-24...098831826?pt=PC_Netzteile&hash=item3a76a81bd2
@Lajocy: Auf was beziehst Du Dich? :hmm: Meinst das Überbrücken eines NTs?
Ja, eigentlich schon.
Will dir nur helfen, dein Netzteil zu testen. Ich würde das Teil abklemmen vom Motherboard, anlaufen lassen, ausschalten,
und dann hören: brummt oder brummt nicht...??!
