[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
Scheint am 1PCIE-Slot zu liegen.
wenn ich die Graphikkarte rausnehme läuft er.
Alles ein bisschen strange.
Was haltet ihr davon, mal mit dem Pinselchen und Alkohol versuchen, den PCI-Slot zu reinigen?
Mit dem Umbau auf den PCi-Slot zwei ist das so eine Sache wegen der Wakü.
Bios ist immer noch das alte 1309
Ja,
Steht auch in Post 501.
Nur wundere ich mich, wieso die Kiste nach dem Trocknen wieder 3 Tage anstandslos lief.
Also ich kann euch nur raten, die Schläuche, egal welche, mit Schlauchschellen festzuziehen!!
hast schon getestet ob deine karte im 2 PCI slot läuft ??? nicht das die nun nen schuss ab hat.... vielleicht hast es nicht richtig getrocknet
Genau das ist ja das Problem....Schläuche umstecken...alles ein bisschen viel Arbeit.
na dann viel glück, hoffe für dich das es dann wieder funzt.....
mir ist das aber auch schon passiert,vor 3 wochen, als ich nen anderen cpu kühler testen wollte war ein anschluss undich und alles runter gesabbert über slots und bios chip "schreck" hab dann alles trocken gelegt und mit druckluft die slots ausgepustet und ist glücklicherweise nüscht passiert.......
Und für das Maximus 5 Gene btw auch ... und das ist schlechter was den Speicher angeht ... scheint aber etwas weniger VCore zu benötigen.
Mit welchen Chips getestet? Dann würde ich das fürs M5E auch gleich mal verifizieren und wir brauchen wir nur noch jemanden fürs M5F^^
Ich kann es bei meinen HCH9 auch mit CL8 mal gegen prüfen, dafür brauche ich keinen Wunder-IMC =)
Vielleicht bin ich ein wenig spät aber gibt es schon Erfahrungen zum BIOS 14 im Vergleich zum 13? Frage mich ob ich's drauf machen soll
im Rog Forum habe ich gelesen das einer den Multi nicht mehr einstellen konnte nach dem der den 14er bios aufgespielt hatte
selbst als er den 13er Bios wieder geflasht hat .....
da mit dem 13er bei mir alles rund läuft im moment werd ich erstmal abwarten und das 14er noch nicht draufmachen ...
@all,
Kiste läuft wieder wie sie soll.
Die Ursache war wirklich der PCI-Slot.
Habe ihn mit Alkohol und einer Zahnbürste gereinigt, anschließend mit Druckluft ausgeblasen.
Danke für eure Tipps.
LOL mit dr Zahnbürste hehe
na super.............
bin gerade am 1408 bios testen irgendwie läuft meine kiste nimma stabil mit den vorrigen werten.....
brauch irgendwie mehr saft.........
Bin auch gerade am Bios testen.
brauche allerding beim Offset-mode + 1,1 mehr.
d.h. 0,1 weniger als vorher. ist soweit also zu empfehlen
Auf 4800 GHz
Werde demnächst noch ein bisschen dran schrauben, aber insgesamt 1.26 V sind für diese Geschwindigkeit
absolut ok. Temps gehen nie über 42 Grad. (Wakü)
Was mir tierisch auf den Geist geht ist das meine Tastatur ( 3 Stück ausprobiert) nur sporadisch erkannt wird beim Booten.
Hab schon auf Full inialisation gestellt anstatt partial, ist auch schon besser geworden aber dennoch öfter keine tastaturerkennung. Maus immer.
Ärgerlich wenn man mal ins BIOS will und sie grad da nicht erkannt wird
das is doof das hatte ich aber auch schonmal das die maus im desktop nicht mehr funktioniert hat,dann muß ich einmal umstecken dann gehts wieder .........
Das Problem mit der Tastatur hab ich auch ab und an. Scheint nicht genug Saft zu geben..
Gesendet von meinem Galaxy Nexus mit der Hardwareluxx App
wo habt ihr maus und tastatur angeschlossen ... ich hab noch ne etwas ältere logitech G5 (M-UAH113A, die mit der blau marmorierten oberfläche) und nen logitech internet navigator keyboard (Y-BF37)
keyboard steht 5V 75mA auf der rückseite
mouse steht 5V 100mA auf der rückseite
hab beide angeschlossen an den beiden ganz oben rechts befindlichen usb 2.0 anschlüssen, das keyboard dabei ganz rechts am io-panel und maus dann direkt links davon
und hatte im bios damit noch keine probleme und soweit ich mich erinnern kann auch nicht am windows logon und danach sowieso nicht ... außer das im windows die setpoint software öfter mal rumzickt und es für die tastatur leider nix für windows 7 gibt bzgl. der ganzen zusatztasten
wo ich aber probleme hatte war im uefi windows ... da kam maus und tastatur teilweise nur sehr verzögert am windows logon an ... d.h. beides hat etwas gebraucht bis es mit strom versorgt wurde ... warum auch immer ...
Ich hab ne Hama 08/15 Tastatur. Am USB 2.0 Port, für sowas verschwende ich keinen 3.0.
Ist auch nur sehr sporadisch, einer von 30-40 Neustarts, wo die Tastatur nicht erkannt wird, deshalb mach ich mir da drum keine Platte.
Wenns bei mir so wäre wär's mir auch egal aber bei mir ist es exact nach jedem Neustart. Bleibt beim Booten hängen mit postcode das kein Keyboard da ist.
1000% geht es aber dann beim softreset, und das mit dem Saft dachte ich auch da ich ne G 15 habe mit Display usw. Aber auch zwei andere 0815 tastaturen( Cherry/ logitech) machen genau das gleiche, und ich hab schon alle Ports durchprobiert. Naja weiß ja wie ich damit umgehe. Maus work komischerweise immer erkannt ( sehe es am leuchten( logi G9x))
Besser als beim GB Board wo ich permanent umstecken musste das was passiert.
Was aber wohl alle boards haben ist ne Inkompatibilität mit dem corsair HS1 headset. Am USB 3.0 kratzt das Ding mächtig im Klang, am 2.0 alles ok
@ beide: Windows 7 normal oder im uefi modus installiert? weil ich hatte die probleme nur im uefi modus ... da es da aber auch andere probleme gab (gleich installiert wie non-uefi-modus) wie z.b. group policy service funktionierte nicht, firewall settings dialoge öffneten sich nicht, ... hab ich nochmal neu im non-uefi-modus installiert - auch wieder auf die gleiche weise wie davor im non-uefi-modus und uefi-modus installiert (also was updates, hardware usw. anbelangt) und seither keine probleme mehr
