[Sammelthread] Asus Maximus V Formula (Z77)
WIP
Willkommen im Asus Maximus V Formula Sammelthread
Asus Maximus V Formula bei Geizhals.at
Bilder
Spezifikationen
Specifications
CPU Intel® Socket 1155 for 3rd/2nd Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors*
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0*
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
* Refer to ASUS for CPU support list
Chipset Intel® Z77
Memory 4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.*
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic Integrated Graphics Processor*
Multi-VGA output support : HDMI/DisplayPort ports*
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support Supports NVIDIA® SLI™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports AMD CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *1
Expansion Slots 3 x PCIe 3.0/2.0 x16 (x16 or dual x8 or x8/x4/x4) *2
1 x PCIe 2.0 x4*
3 x PCIe 2.0 x1*
1 x mini-PCIe 2.0 x1 *3
Storage Intel® Z77 chipset :*
2 x SATA 6Gb/s port(s), red
2 x SATA 3Gb/s port(s), black
1 x eSATA 3Gb/s port(s), red
1 x mini-SATA 3Gb/s port(s) , black
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *4
ASMedia® PCIe SATA controller : *5
4 x SATA 6Gb/s port(s), red
LAN Intel®, 1 x Gigabit LAN Controller(s)
Wireless Data Network Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth Bluetooth V4.0
Bluetooth V3.0+HS
Audio SupremeFX IV built-in 7.1-Channel High Definition Audio CODEC*
- Output Signal-to-Noise Ratio (A-Weighted): 110 dB
- Output THD+N at 1kHz: 95 dB
- TI 6120A2 high fidelity headphone amplifier
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- SupremeFX Shielding™ Technology
- ELNA premium audio capacitors
- 1500 uF Audio Power Capacitor
- Blu-ray audio layer Content Protection*
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports Intel® Z77 chipset :*
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
8 x USB 2.0 port(s) (4 at back panel, black+white, 4 at mid-board)
ASMedia® USB 3.0 controller :*
2 x USB 3.0 port(s) (2 at back panel, blue)
Overclocking Features mPCIe Combo™ (mPCIe/mSATA combo card)
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Slow Mode
- LN2 Mode
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
GameFirst II
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS TurboV EVO :
- CPU Level Up
ASUS EPU :
- EPU*
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send*
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3*
- ASUS EZ Flash 2*
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM*
- ASUS Q-Connector
Back I/O Ports 1 x DisplayPort
1 x HDMI
1 x eSATA 3Gb/s
1 x LAN (RJ45) port(s)
4 x USB 3.0*
4 x USB 2.0*
1 x Optical S/PDIF out
1 x Optical S/PDIF in
5 x Audio jack(s)
1 x Clear CMOS button(s)
1 x ROG Connect On/ Off switch(es)
Internal I/O Ports 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)*
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
2 x CPU Fan connector(s) (4 -pin)
3 x Chassis Fan connector(s) (4 -pin)
3 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x 4-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)*
1 x Slow Mode switch(es)
8 x ProbeIt Measurement Points
3 x Thermal sensor connector(s)
1 x LN2 Mode header(s)
1 x EZ Plug connector(s) (4-pin Molex power connector)
1 x Power-on button(s)
1 x Reset button(s)
1 x Go Button(s)
1 x mPCIe Combo header(s)
Accessories User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)*
1 x ROG Connect cable(s)
1 x 12 in 1 ROG Cable Label(s)
1 x mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
1 x 2-in-1 RF Cable(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability WfM2.0, DMI2.0, WOL by PME, PXE
Support Disc Drivers
Kaspersky® Anti-Virus
DAEMON Tools Pro Standard
GameFirst II
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form Factor Extended ATX Form Factor*
12 inch x 10.1 inch ( 30.5 cm x 25.7 cm )
Note *1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2-1: PCIe 3.0 speed is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*2-2: x8/x4/x4 mode is supported by Intel® 3rd generation Ivy Bridge Core™ Processors.
*3-1: The mPCIe 2.0 x1 slot is located on mPCIe Combo™ expansion card.
*3-2: The mini-PCIe slot is pre-installed with an Wi-Fi/Bluetooth module.
*4: Supports on Intel® Core™ processor family with Windows® 7 operating systems.
*5: These SATA ports are for data hard drives only.
Downloads
BIOS, Drivers, ETC.
passende CPU Kühler
Luftkühler:
teilt mir eure Konfigs mit...
Wasserkühler:
Heatkiller 3.0 LC/LT, Copper, Black Nickel/Chrome
XSPC Raystorm
Passender Schlauch:
Primochill Schlauch PrimoFlex Pro 16/10 (3/8"ID) Clear
RAM
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133)
Patriot Viper 3 PC3-17000 2133 Mhz (2x4 Gb)
G.Skill Ripjaw Z F3 -17000CL9Q-16GBZH (4x4 Gb)
G.Skill Ripjaw X F3- 17000CL9Q-4GBXMD (2x4GB, 2 Kits in Vollbetückung laufen auch !)
More to come...
Kann die Erfahrung von Ironage mit Hardwareversand bestätigen. Ich musste das R4E damals innerhalb von 6 Monaten zweimal reklamieren.
Lief alles über Hardwareversand problemlos und recht schnell ab.
Da normalerweise komplett ausgetauscht wird (waren bei mir sogar beide Male fabrikneue Boards), musst Du das Board mit allem Drum und Dran einschicken.
Wenn was fehlt, kann es sein, dass Du aufgefordert wirst das nahczureichen, was den ganzen Prozess evtl. enorm verzögert.
Auch die ganzen Kabel? Weiss gar nicht mehr was da alles dabei war, naja zur halt in die Anleitung schauen, da sollte es ja drinstehen oder?
So auch wenn ich mir jetzt spott von euch anhören muss ist es mir wert! :d
Grade als ich mein Board für den Versand vorbereiten wollte sah ich das die Pins in einer ecke leicht verzogen waren.
Schön vorsichtig wieder alles in original zustand gedrückt und ZACK 16 Lanes :d
Also siehe da niemals aufgeben alles in betracht ziehen ich bin so verdammt happy :P
Aber.. Ich frage mich ob es schon vorher war weil ich eigentlich bei sowas immer zu übervorsichtig bin. Danke an alle für die Hilfestellung :)
Ganz ehrlich? Ich hätte ungern mein Prozzi abgegeben er läuft super stabil auf 5 ghz und frisst dabei wenig an Spannung :)
Jau die Vom CPU Sockel. wenn du von oben drauf guckst links in der ecke waren ein paar Pins leicht verzogen.
Find ich schon geil das war damals undenkbar nen CPU mit verbogenen Pins zu betreiben. ES LEBE DIE ZUKUNFT :P
Es gab hier im Luxx mal jemanden der hat abgebrochene Pins von Athlon64-CPUs wieder angelötet so das die CPUs wieder funktionierten. Weiß aber nicht mehr wer das war.
hab da ein kleines Problem mit meinem M5F.
Seit einiger Zeit zeigt mir die AI Suite, in unregelmäßiger Folge, Warnmeldungen über Spannungsschwankungen an. Die sich auf alle Bereiche der Stromversorgung beziehen. 3,3; 5 und 12 Volt
Da meldet die AI Suite z.B. das bei 12 Volt nur eine Spannung von 0.5 Volt oder auch 0,0 Volt anliegt oder bei 5 Volt eine Spannung von 0,0 anliegt. usw. usw.
Ich habe diese Meldungen bisher ignoriert da der PC ohne Abstürze weiter lief. Doch seit ein paar Tagen musste ich feststellen das mein PC sich wären des Betriebes immer mal wieder einen "Warmstart" gönnt.
Dies geschah beim Zocken von Crysis 2 oder beim Surfen im I-Net.
Board, Software (ASUS AI Suite) oder doch das NT? Wer oder was verursacht mir hier das Problem?
M5F @4600Mhz und die Graka Palit GTX670 Jetstream @1163Mhz; der PC ist komplett unter Wakü; Prime ist stabil (12h)
Netzteil ist Seasonic Platinum 1000W
Hi Leutz,
wie läuft denn das aktuelle btw. neue Bios? :)
schon alle hier aktualisiert und gibt es was neues?
LG
@Blau Bear
Diese Fehlmeldungen kenne ich von Asus Probe I/II (Teil der AI Suite) seit Jahren, weshalb diese Komponente bei mir grundsätzlich nicht mehr installiert wird.
Jenachdem, wie die Grenzwerte im Bios evtl. eingestellt sind, kann so eine Fehlmeldung durchaus dazu führen, dass das system meint, sich schützen zu müssen
und z.B. restartet.
@Watercoolio
Gerade aufgespielt, läuft bis jetzt wunderbar. Hab bis jetzt nix neues gefunden, aber auch nicht wirklich groß gesucht.
Gibt es eigentlich eine Möglichkeit die Beleuchtung vom Board zu regeln?
Im Bios gibt es ja nur an und aus, auf an leuchtet es aber auch wenn der Pc runter gefahren ist, bleibt nur das Netzteil aus zu schalten, ist aber auch nicht so das wahre...
Hab ich da was übersehen oder lässt sich da sonst nix ändern?
@Bin2good
gut dann werde ich die Suite neu installieren und dann ohne "Probe"
eine Frage zur CPU Spannung hätte ich da noch.
Ist es normal das bei "CPU VID" die Spannung schwankt? bei mir schwankt sie zwischen 1,216 Volt bis 1,313 Volt.
Sie wird über AIDA64 ausgelesen und auf meinem Logitech G510 angezeigt.
Die ai suite spinnt bei mir auch n bissl mit den spannungen rum, ich hab dann einfach die spannungen auf ignor gestellt und gut. Da bei mir auch aida im hintergrund läuft, denk ich kriegen sich die zwei programme in die haare.
Gesendet mit Galaxy Tab2 10.1
ai suite ist der größte schrott und das seit jahren ... gibt paar anleitungen im internet wie du die wieder loswirst ... ist mit aufwand verbunden ... ein einfaches deinstallieren reicht nicht, da bleibt jede menge schrott im system zurück (services und so ...)
am besten: komplett neu installieren oder backup einspielen von vor der ai suite installation (sofern du sowas hast)
unmotivierte reboots: lass memtest86+ mal laufen, und zwar erstmal mit der aktuellen ram-bestückung und mindestens 2 durchläufe ... hatte dasselbe problem bei meinem system, sporadisch, hatte nichts mit der auslastung zu tun ... war ein speicherriegel kaputt
Mein Board geht : " Return to sender" .
Ich hatte alles eingebaut und gestartet kam ins Bios/Uefi er hat auch alles erkannt sogar den Speicher .
Dann habe ich das XMP Profil geladen und F10 ( Save&Quit ) gedrückt und er wollte nicht mehr starten.
Beim Board leuchtet "Power , Reset und hinten CmosClear + der Leuchtkram. Aber er will einfach nicht starten.
Dann habe ich eine sehr nervige Ein- und AusbauSession gehabt (2 Verschiedene Netzteile probiert , 3verschiedene RamKits probiert , 2 GraKas probiert ,Festplatte gewechselt halt alles was ich da hatte um Fehler auszuschliessen ) . Bios Reset natürlich auch.
Asus Support angerufen alles aufgezählt was ich gemacht habe kam der Tipp Ich sollte doch zusätzlich zum 8Pin EPS auch den 4Pin EPS ranmachen.
Ging aber auch net . Hätte mich auch gewundert.
Naja geht halt Board und CPU ( habe kein Austauschboard und CPU zur Verfügung ) zurück und es heißt warten und dann später Hoffen. Bin mal gespannt da ich das Cashback-Formular ausgefüllt habe aber halt mit der S/N von dem Board was jetzt in die RMA geht.
Naja dann läuft halt erstmal wieder der Quasi-Urahn vom Maximus Formula V weiter das Maximus Extreme.
*mfg JPR :banana:
So sah es eingebaut aus ( vor der Feinarbeit Kabel usw.) :
Mann Mann ich will mir gerade auch Asus Maximus V Formula (Z77) oder Rampage zu legen da kriegt man ja richtig Angst wenn man hier mit liest.
Ging mir ähnlich. Aber als ich alles drin hatte und gestartet hatte und im Bios wirklich alles erkannt wurde war ich froh. Aber halt zu früh gefreut. Aber das Rampage is So.2011 .
Aber innerhalb des gleichen Sockels umrüsten ? So. 2011 kostet halt "ein wenig mehr" aber man kann sich sicher sein das noch gegen Herbst die Ivys kommen. Hatte das auch überlegt das Rampage IV Extreme + 3930K aber das wären dann auch gut 850€ und das war mir zu heftig. Da kriege ich auf So.1155 Board + CPU + Ram + SSD für.
Hi Leutz,
LG
ich hatte das neue schon mal drauf. :(
habs gleich wieder runter geschmissen. geht ja gar nicht!
wenn ich die OC-Werte vom 1408 auf das 1604 einstelle hab ich nur Loops.
kommt nur bis zum RAM und dann Re-start.
neues ist nicht immer gut
und bei mir hat sich gestern der pc einfach abgeschalten, einschalten ging nimmer, musste strom wegnehmen, dann startete er wieder :confused:
@Bin2good
Ich drück Dir mal die Daumen, dass es ohne Probe klappt.
Die Reboots können natürlich auch anderweitig verursacht werden.
Dass der Vid- Wert schwankt ist normal, da er lastabhängig errechnet wird.
@bin2good
hab die BIOS-Funktion=> "Anti Surge Unterstützung" abgeschaltet
da diese ja zur Überwachung der Ober- und Unterspannung dient und bei möglichen Vorkommnissen den PC abschaltet.
Bei mir haben gerade die Gehäuselüfter die am Board hängen extrem hochgedreht nachdem ich eine CD eingelegt hab :hmm:
Ging ca. 2-3 Min.
War eigentlich Grundlos da die Temperaturen alle normal waren, Board ca. 30° CPU 39°
Sehe da auch keine Logischen Grund warum das durchs einlegen einer CD ausgelöst wird.
Scheint am neuen Bios zu liegen, ist mir vorher nie aufgefallen.
bei so einem "high end" board fragt man sich schon was das alles soll mit den ganzen problemen ... noch mehr wenn man auf den rechner angewiesen ist (arbeitsmittel) und dieses topic hier im hinterkopf hat und ständig "betet" das man nicht auch zu den leuten gehört die probleme haben/bekommen ...
tuning boards zicken immer rum...... genau so wie ein rennwagen
also mein brett läuft stabil und wenn man den pc als arbeitsmittel gebraucht dann sollte man zu einem soliden brett greifen das nur auf stabilen betrieb ausgelegt ist und nicht aufs tunen........
Hab meins erst gar nicht verbaut, die Verarbeitung war so schlecht gewesen das ich es gleich wieder zurückgeschickt hab.
Wenn ich das hier alles so lese, schade drum, hätte ein gutes Board werden können.
Also mein Board läuft stabil. Hab mein Problem mit den 8 lanes statt 16 lösen können als ich meine Sockel Pins grade gebogen habe.
Ansonst schnurrt mein PC *Urlaub sei dank* so 10+ Stunden am Tag. Alles wurde am 8. Dez. Im betrieb genommen und konnte sofort Starten.
Soviel dazu ich nutze die Gelegenheit hier mal da sich viele hier verlaufen mit ner Wasserkühlung :P
Ich hab momentan diesen http://www.pcdistrict.com/modules/productcatalog/product_images/150250-nox-coolbay-devil-7435.jpg kann man sich da ne gescheite Wasser Kühlung einbauen oder sagt ihr ne lieber nicht? Welchen Tower könnte ihr Empfehlen?
bis auf mein ram-problem wo am ende einer von 4 riegeln sich als fehlerhaft rausgestellt hat hab ich sonst eigentlich auch keine probleme ... aber imo sollte grad ein overclocking board wenigstens mit standardsettings absolut 100% stabil laufen und man nicht massig von problemen lesen müssen ... vor allem wenn es sich um ein so teures board handelt ...
die aussage von razzorone diesbezüglich halte ich also für sehr - keine ahnung wie ich es ausdrücken soll - ...
und auch die ai suite ... gibts ja nun schon seit 10 jahren ... und damals war die schon ziemlich unbeliebt ... und nach nun etwa 10 jahren sollte man meinen dass die software stabil läuft und nicht alles mögliche an mist veranstaltet und nicht richtig funktioniert ... spricht nicht gerade für asus
sonst bin ich aber soweit glücklich mit meinem board und hoffe dass es einfach läuft ...
habe ich befürchtet, :) war bisher bei Asus Boards & Bios immer so,
das nach den ganzen Updates, die Werte nicht mehr stabil waren. ;)
bei meinem CHIV mußte ich mit dem vorletzten Bios meine ich, auf
einmal viel mehr Spannung nach'm Update geben. :fresse:
also weiterhin das Prob. mit UEFI Bios existent...
Daher habe ich bei diesem Board bisher noch kein OC eingestellt,
warte auf ein stabiles & zuverlässiges Bios, der Rechner ist aktuell
auch so schon sehr schnell mit dem Corei7-3770 unterwegs. ;)
Hi Boardi05,
hab ähnliche probs letztens gehabt, bisher hat immer kurz Strom wegnehmen geholfen. ;)
LG
Hi Boardi05,
LG
Mir isses bisher einmal passiert, ich hab auch schon n verdacht, ich glaub der PC wollte gerade in dem moment ins stanby...
Ansonsten läuft alles stabil, explorer.exe stürtzt seit dem deinstall von office 2013 auch nimmer ab, von der AISuite hab ich nur Fanexpert installiert, läuft echt super, bin mit der luffisteuerung echt zufrieden.
