[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
Toll , und dann wundern se sich wegen Retouren...Bei mir war es ja so das 1,5V angegeben aber 1,65V auf den Modulen steht . Im Nachhinein ist es aber gut so , das ist jetzt das dritte Kit seit Dez. die beiden anderen waren beide defekt , allerdings liefen se erst ne Zeit , dann kamen die Störungen . Entweder hab ich 2xPech gehabt oder ( was ich eher glaube ) das Board gibt zuviel Saft , hab den Ram jetzt auf 2000@1,45V laufen und hoffe das er nu länger hält : )
Ich hatte aber das gleiche Problem, erst läuft der Recher bestens und einen Tag später geht garnix mehr...
Mit 4x memtest64 und einem modul im Slot A2 läuft er jetzt seit fast 45 Minuten fehlerfrei, werde später mal das andere Modul testen.
Danach mal beide zusammen.
Vllt hat das X.M.P. was gebracht...
Werde aber wohl doch den Ram wechseln, hab keine lust auf Experimente...
Ja, hast recht. Hatte ein ähnliches Problem und hab auch Memtest und alle möglichen Programme durchlaufen lassen, haben nix gefunden. Hab mich da bestimmt an die 3-4 Wochen immer mal wieder rum geärgert, bis ich dann mal den Ram getauscht habe wo ich Zeit hatte. Ist wohl doch immer noch die größte Fehlerquelle.
Für mich macht es bisher den Eindruck das man auch bei nicht OC alle V Werte fixen sollte ( hab diesmal bei Aktuell 4GHz auf Offset verzichtet und auf 1,130V gestellt ) . MfG
Nabend,
Das Corsair Kit ist eingebaut und läuft bis jetzt bestens. Ich werde die GeIL Module mal behalten, die liefen ja jetzt auch und man kann ja nie wissen wann man nochmal welche braucht...
Besten Dank für eure Hilfe!
Gruß Markus
Wollte nur mal eine meldung bezügl. Des RAMs geben. Die G.Skill RipJaws 16GB DDR3 1600er Kit läuft einwandfrei und wird auch ohne XMP richtig erkannt.
~> F3-12800CL9Q-16GBRL
Hallo, ich bin (fast) neu hier.
Ich habe mich durch einige Seiten durchgelesen, muss aber gestehen, bin dann nach hier hinten 'gehüpft'.
Ich plane mir gerade ein neues System zusammen (keine Games) und habe mich (zur Zeit) auf ein P8Z77-V Premium 'eingeschossen'
1. Bei meiner RAM Suche ist mir ein RAM aufgefallen, bei dem der Hersteller folgendes schreibt und der bisher nicht in der Liste am Anfang dieses Threads steht:
Guaranteed-compatible with the ASUS*P8Z77-V PREMIUM
Es geht um den 1.35V BLS4C8G3D1609ES2LX0B Crucial Ballistix Sport VLP (Very Low Profile)
Er scheint eine Art kleiner Bruder vom im 'Vorstellungspost' gelisteten Crucial Ballistix Sport zu sein (= ohne VLP).
Was ihn ev. für ein paar Leute hier zwecks CPU-Kühlern.... interessant machen könnte ist z.B. die Bauhöhe (und / oder die Voltzahl für ein 8GB Modul?):
lt. Geizhals:
1.35V-1.50V • Bauhöhe: 18.75mm (very low profile)
lt. Hersteller:
Specs: DDR3 PC3-12800 • 9-9-9-24 • Unbuffered • NON-ECC • DDR3-1600 • 1.35V • 1024Meg x 64 • Low Profile
2. Ansonsten ist mir bei der pdf mit dem Vergleich der verschiedenen Mainboards etwas aufgefallen:
ein in meinen Augen ein großer Unterschied zu den anderen Asus Boards ist folgender:
der Marvel controler des Premiums gehört zu der 92xx Baureihe
Zitat aus dem Netz (habe leider vergessen wo das vorkam, vermutlich im Adobe board)
Only the 88SE9130, 88SE9220, 88SE9230 series Marvell controllers support TRIM. (The 88SE9130 is still to be avoided though as it will most likely have the stuttering issue, as it's still based on the older 91xx designs.)
Wenn ich mich richtig erinnere, hatte es etwas mit 2 lanes / dual usw zu tun.
Bei Marvel heißen die Teile 88SE92xx
http://www.marvell.com/storage/system-solutions/assets/Marvell-88SE92xx-Product-Brief.pdf
http://www.marvell.com/storage/syst.../assets/Marvell-HyperDuo-Technology-Brief.pdf
Controller aus der Serie 92xx konnte ich bisher on-board in Kombination mit Z77 nur auf dem Asus P8Z77-V Premium finden - einer der Gründe, warum ich mich zur Zeit so sehr für das Board interessiere. Mit X79 Chipsatz ist einer aus der Serie - wenn ich mich nicht täusche - auf einem AsRock Extreme irgendwas.
3. Rein Neugier halber, benutzt hier jemand das Premium speziell für Adobe After Effects / Premiere Pro / .... und könnte mir seinen / ihren Eindruck weitergeben?
Wenn Du gerade erst planst: warum nicht auf Haswell warten?
Eigentlich bräuchte ich meinen PC vor dem September. Vielleicht.
Klingt 'entschlossen'? => ich schneide / bearbeite u.a. ehrenamtlich für Jugendliche und weiss vorab nie, was auf mich zukommt => weder, welcher Dateityp noch welcher zusätzlicher Aufwand / Nachbearbeitung noch dazukommt. Reines Schneiden ging noch mit einem simpleren Programm, ich stelle aber eigentlich auch aus anderen Gründen gerade auf Adobe um.
Ich bin aber trotz dem Interesse an der Premium auf der Jagd nach Haswell-Details.
Ich will erst einmal wissen, was eigentlich zur Zeit machbar ist und per Haswell als neue Standards dazu kommen bzw habe Vorstellungen bzgl. des Aufrüstens in Schritten, die entweder nicht kostengünstig mit den Meisten der besseren Mainboards von heute machbar sind oder auch mit späteren selbst hohen Kostenaufwand nicht erreichbar sind. Klar, da hoffe ich auch auf Haswellboards.
Über Haswell/-Chipsätze habe ich noch nicht genügend Details herausgefunden, um mit einem Vergleich anfangen zu können, die meiner Denkweise entspricht.
Irgendwie glaube ich auch (noch) nicht, dass mein Endziel mit einem Haswellboard erkennbar günstiger wird, diverse Bauteile kosten 'richtig' Geld.
Z.B. 'nicht-reine-Software-Controller', die auch noch auf dem aktuellen Stand sind (3.0,...) werden vermutlich auch die nächsten 2 Jahre nicht wirklich mit den Preisen 'runter gehen, oder? On board sind meist nicht TRIM fähig oder arbeiten ungenau oder nur lahm oder einfach....
Thunderbolt als 20GB kommt soweit ich weiss nicht vor 2014/2015, also nützt mir da auch Haswell vermutlich nicht viel => Spezifikationen noch nicht gefunden, lt.Intel soll die neue Version aber abwärts kompatibel sein. Weiß nur noch nicht, ob die auch den Weg anders herum meinen = neues Gerät an 'alten' PC anschließbar.
Endziel ist u.a. 2x 6GB-SSD RAIDs mit TRIM... plus 'Datengrab' HDD.
Als Controller Nachrüstkarte, die auch PCI 3.0 kann müsste ich bei normalen Mainboards z.B. nach der Adaptec mit den Nummer 7xxx schauen. Die können weit mehr wie ich benötige und kosten dann 350 - 900 Euro. Und brauchen einen Steckplatz. RAID extern will ich nicht.
Falls es einen Haswell-Chipsatz geben wird, der das anbietet => großer Pluspunkt. Dann dürfte es ein paar mainboards mehr geben, die das dann auch anbieten. Die Premium kann es theoretisch jetzt schon schon. Ich habe nur noch niemenden gefunden (keinen Post oder per google oder....), der/die eine Premium besitzt und sowas probiert hat = es fehlt mir noch die Anwenderbestätigung.
Meine Befürchtung ist, dass so ein Asus-Haswellboard auch nicht mit der ersten Welle der Mainboards veröffentlicht wird. Und 2014 ist mir definitiv zu spät. Plus würde ich auch gerne erst ein paar Anwenderreaktionen hören, was aber - siehe Premium - nicht ganz einfach zu sein scheint. Bei den 'Adoblern' scheinen die meisten 'Selberzusammensteller' das Geld für 6-Kern Systeme zu haben.
Das Problem ist, mein Desktop ist mindestens 7 Jahre alt und war nie auf Video ausgelegt und mein 2 Jahre altes Notebook, das eigentlich Video kann, kann nicht die rechenintensiven Dateiarten bzw erfüllt nicht die Mindestanforderungen von Adobe, die lt. Anwendern in diversen Details sowieso 'ein Witz' sind, da mit denen ganze Programmteile nicht gehen
=> die Anwender empfehlen mindestens 6-Kern (für AE und PP), 64 GB RAM (für AE), ab 4GB vRAM (für PP), 3 RAIDs (OS/Programme = erster RAID, Pagefile, media cache, renders = 2. RAID, Media, exports,.... = 3. RAID, hier HDD) = in Kombi mit 3.0 gar nicht mal so einfach zusammenzustellen und viel zu teuer für mich.
Ich möchte am Liebsten erst einmal eine Art Backbone mit Thunderbolt jetzt oder nachrüstbar und SSD 250/256 für OS / Adobe.... und die restlichen SSDs... später so dazu kaufen, wie wieder Geld da ist.
Endziel 4 x 6GB/s SSDs und 2 x SATA III HDDs intern. 2 stabile RAIDs mit 3.0 'haben' zu reichen. 32GB RAM mit max. 1.5V, 3770/3770K.... Plus Sound und Brenner.... Eine vernünftige und leise CUDA-GPU, die später ev. 'vermehrt' wird. Transportabel = Midi- bis Big-Tower kein Problem, aber was die da teilweise haben!?!?!?
Also Netzteil mit dem max Endziel berechnen... nach genügend und passenden Anschlüssen schauen (speziell bei PCIe können nicht alle PSUs mithalten, auch nicht bei den teuren) ... es würde eigentlich schon gehen, hence my interest an der Premium. Nur nicht gerade 'günstig'
Sobald ich mehr über Haswell herausfinde und erste Preise sehe.... fällt die Entscheidung - vorzugsweise Premium, da ich die Kiste eigentlich in gut 1 Monat brauchen könnte.
Schrauben könnte ich selber, nur von BIOS/RAID habe ich keine Ahnung.... Recherche ....
Was würdest Du machen, schon loslegen, da man es kaum noch erwarten kann,noch ca. 1 Monat warten, bis mal endlich mehr Details bekannt werden und sich dann entscheiden oder 'bibbernd' auf den September warten? Nicht zu vergessen, das entspricht meinem PC Bestand :wut: (keine blue screens, aber er neeerrrrrvvvvttt, weil so langsam usw)
Gibt neue Biose Version 1908. Für das P8Z77-V hier. Für das P8Z77-V Pro hier, ein paar andere sind auch noch dabei, das Deluxe fehlt noch.
Hab ich gestern schon gelesen, hoffentlich ist das besser als die Version davor, die soll ja ziemlicher Mist gewesen sein mit lauter Fehlern, warum ich auch davon abgesehen hatte.
@ WoasNed:
Du hast ja schon sehr genaue Vorstellung von dem System. Wenn Du der Meinung bist, sowas anzustreben, dann hab ich nur noch zwei Anmerkungen.
Ich persönlich würde einem Raidgespann nicht trauen, erst recht nicht, wenn man womöglich wieder 5 Jahre oder länger mit dem System arbeiten will. Lieber auf professionelle SSDs setzen und auf die letzten mb Durchsatz verzichten als die Ausfallwahrscheinlichkeit durch Raid mehr als verdoppeln.
Das zweite gehört dazu:wenn schon neues System, dann auch die neuen Features und die gesteigerte Leistung und Effizienz der neuen Generation mitnehmen. Zumal ich davon ausgehe, dass die Lösungen schon im Juni und nicht erst im September zu haben sein werden.
Hallo zusammen,
ich habe leider ein Problem mit meinem P8Z77 V-Pro. Also zumindest nehme ich an, dass es das Board ist. Und zwar schmiert der Rechner mehrmals täglich (bis zu 10 mal) ab. Entweder er bleibt einfach hängen oder er geht einfach aus und lässt sich dann nicht mehr einschalten (hilft nur Kabel ziehen). Letzteres passiert zu 90%. Habe mittlerweile das Netzteil getauscht, mit memtest86 + den Speicher getestet, Speichertimings heruntergesetzt, neustes BIOS aufgespielt und auch mal mit jedem Riegel einzeln das System laufen lassen. Dachte am Anfang es liegt an Windows 8 und habe Windows 7 nochmal aufgespielt, doch mit dem gleichen Ergebnis.
Also das System habe ich seit August und seit November macht es diese Probleme. Vielleicht weiß ja von euch jemand was.
Probe 2 zeigt mir öfter: CPU Temperaturen von unter 0° Grad; 12 V im Negativenbereich oder eine negative VCore (allerdings läuft auch AIDA64 was ja zu diesem Problem führen soll)
System ist nicht OC.
I7 3770K
4x Corsair Vengeance CMZ16GX3M4A2133C11 (16GB Kit)
Netzteil Corsair HX850
BIOS 1805 (werde aber gleich das 1908 mal aufspielen)
Windows 8 PRO
Treiber alle aktuell
Danke schon mal für eure Hilfe.
MFG
@colonel302
Speicher oder Netzteil, was anderes kommt eigentlich nicht in Frage, wenn nicht übertaktet. Hast du beides mal getauscht bzw. hast du die Möglichkeit dazu? Sonst noch andere Karten drin, was für Platten bzw. SSDs?
Grüße
Moin Trill,
also Netzteil habe ich bereits getauscht. RAM getestet mit Memtestx86+. Was mich stutzig macht und Ram ausschließen lässt ist, dass ich den PC erst wieder einschalten kann wenn ich das Kaltgerätekabel ziehe. Aus dem Grunde hab ich mir auch das Corsair geholt. Festplatten sind drin eine OCZ Vertex 4 128GB (SSD), OCZ Agility 3 60GB (SSD), Seagate 3 TB und ne Samsung 1 TB. Übertaktet ist der Rechner nicht. Und andere Karten keine außer einer MSI GTX 560Ti. Achja und ANTI-Surge habe ich auch deaktiviert. Hatten ja auch einige hier das Problem.
MFG
So ein Phänomen hatte ich auch mal... damals war es ein Kurzschluss... Vorschlag: Board ausbauen, auf eine antistatische Matte legen (ggf. die Tüte wo das Board drinne war) und den Rechner ohne Gehäuse betreiben. Sollte es dann stabil laufen könnte es sein, das die Lackierung des Boardes ein Schaden hat und ein Kurzschluss verursacht.
Cu.
Moin Trill,
MFG
Smile, also das Verhalten, dass du das Kabel ziehen musst, schließt nicht aus, dass es doch am RAM liegt. Das kannst du dir im Übrigen sparen, wenn du einen Netzschalter am Netzteil hast. Es reicht diesen umzulegen und für ca. 10 - 15 Sekunden die Powertaste zu drücken, damit die Elkos auf dem Board den Strom verlieren, dann startet es auch direkt wieder neu. Dass das Board nicht direkt wieder neu startet ist auch nur ein Schutz, zeigt aber, das du ein Problem mit dem RAM oder Netzteil hast.
Meine 1866er Corsair Vengeance wollten auf dem P8Z77-V auch nicht richtig und haben lustige Phänomene gezeigt. Memtestx86 bringt leider für diese Arte von Problemen keine Gewissheit. Ich nutzte vier 8GB Module G.Skill F3-1866C10D-16GAB, laufen perfekt! Ich tippe auf den RAM, an deiner Stelle bestelle dir mal testweise von Asus für dieses Board zertifizierte RAMs aus der Liste und teste.
Und vor allem lasse diese unnötigen Frequenzen weg, Ivy Bridge ist max. für 1600er Module freigegeben, mehr nicht, alles anderen bringt meist nur Ärger. 1866er ist ein guter Mittelweg, der meist noch ohne Probleme geht, RAM mit mehr Takt ist totaler Blödsinn!
Grüße
Trill
Netzschalter habe ich. Aber meistens keine Lust 10 Sekunden auf den Powertaster zu drücken. ;-) Kabel ziehen geht schneller. Hab den RAM auch auf 1333 bzw 1600 laufen lassen. Brachte leider auch nix. Aber jetzt neuen RAM kaufen und dann hinterher besteht das Problem immer noch wäre ärgerlich. Zumal das System ja auch mal stabil lief. :-/ Aber das ich das System wegen RAM reseten muss? Dachte das liegt daran, dass Probleme mit der Spannungsversorgung vorliegen? Unter RAM Probleme sehe ich z.B. das Einfrieren des Systems.
Hat schon jemand die neue Bios Version draufgehauen?
Läuft die gut oder gibt es iwelche Probleme?
@Colonel: Ich würde auch sagen das es durchaus am Ram liegen kann. Am besten mal noch ein Kit bestellen und dann einfach ausprobieren ob sich was gebessert hat.
Wenn nicht kannst du den Ram ja danach wieder zurückschicken. Und dann würd ich auch das MB einschicken, auch wenn du dann sehr lange warten musst.
Hast du denn zwischendurch iwas geändert, wonach dann das Problem aufgetreten ist?
Du hast keine Lust 10 Sekunden die Powertaste zu drücken kriechst aber hinter den Rechner um das Kabel zu ziehen, is klar soweit! ;) Kabel ziehen kann eigentlich gar nicht schneller gehen, weil sich die Elkos so wesentlich langsamer entladen. Wenn das Board Probleme mit den Chips auf den Ram-Modulen hat, hilft oft auch kein langsameres takten. Und wie der Vorredner schon sagte, du kannst den Ram ja auch zurückschicken - ich würde dann einfach mal solche Module bestellen, die ich dann auch behalte könnte, wenn sie denn laufen. Und wenn das System mal stabil lief, bei unveränderten Einstellungen und identischer Hardware, dann musst du ja eigentlich selber am besten wissen, was du geändert hast. Und wenn es ein Problem mit der Spannungsversorgung wäre, wären wir ja wieder bei Netzteil - wir drehen uns also im Kreis. Aber du sagst ja es kann beides nicht sein, gut, dann kann dir wohl auch keiner mehr helfen - so etwas nennt man dann Beratungsresistent. ;)
Grüße
Ich habe das 1908 drauf, bis jetzt ohne Auffälligkeiten, läuft rund.
Grüße
also erstmal Danke für eure Antworten. Dann zu dem Beratungsresistent: Werde mir mal neue Riegel bestellen und euren Rat folgen. Auf die Idee zukommen die wieder zurück zu schicken bin ich gar nicht erst gekommen da ich mal welche im Shop gekauft hatte und diese nicht umtauschen konnte. Aber Dank Onlinehandel ist dieses ja nun möglich. ;-)
Ist halt nur komisch das alles funktioniert hat und auf einmal nicht mehr. Obwohl nix geändert worden ist. Erst nach dem 4 Runterfahren fing ich an zu testen und andere Einstellungen auszuprobieren.
Naja und das sich RAM Fehler so äußern hätte ich auch nicht für möglich gehalten. Aber man lernt ja nie aus. :-D
Habt ihr irgendwelche Empfehlungen zu den RAM-Riegeln aus der QVL? Habe nur zwei Voraussetzungen 16GB und blau sollten sie schon sein.
MFG
Achja @ Trill Der Netzschalter ist auch hinten am Netzteil, also muss ich so oder dahin. ;-)
Also bei mir dauert der Start nun deutlich länger und meine 2te SSD wird auch nicht mehr erkannt :motz::d
Gefällt mir gerade gar nicht:hmm:
Das kann ich nicht bestätigen. Beim Start (1908) das gleiche Verhalten wie vorher, die SSD werden beide erkannt.
Ich würde mit Flashback das Bios nochmal neu aufspielen. Evtl OC-Werte vorher zurücknehmen.
Hat sich schon erledigt, ich hatte vor kurzem die beiden SSDs an den ASMedia Anschlüsse gesteckt um was zu testen und danach vergessen die wieder umzustecken.
Nachdem beide wieder am Intel hängen funktionieren beide wieder wie vorher.
Aber die ASMedia Anschlüsse scheinen nach dem Update ne macke zu haben, aber das ist mir im Moment ziemlich egal:fresse:
Die Asmedia waren nach meinem empfinden davor schon nicht wirklich toll. Hab da eh nix angeschlossen.
Mein P8Z77-V Deluxe läuft eig. aktuell ganz gut ohne Probleme... Lohnt es sich das neue BIOS drauf zu machen? Gibt es Vorteile? Habe auch über die Intel SATA Ports ein RAID 1 konfiguriert. Ist das danach weg?
Fragen über Fragen! :-)
lg Kuhni
edit: Und was bewirkt es den Mod einzuspielen?
@Sal3Z,
Danke für das aktuelle MOD-Bios.
