[Sammelthread] ASUS P8Z77-V / -PRO / -Deluxe / -Premium (Intel Z77)
- Sockel: LGA1155 - Chipsatz: Intel Z77 Sammelthread -
P8Z77 | Geizhals.at Deutschland
INHALTSVERZEICHNIS
1.Spezifikationen 1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77V
- Zusammenfassung Spezifikationen / Features -
Prozessor / Sockel:
Intel® Socket 1155 for 3rd/2nd Generation Processors
Supports Intel® 22 nm CPU
Supports Intel® 32 nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
Chipset:
Intel® Z77
Memory:
4 x DIMM, Max. 32GB, DDR3 2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture
Supports Intel® Extreme Memory Profile (XMP)
* Hyper DIMM support is subject to the physical characteristics of individual CPUs.
* Refer to ASUS or user manual for the Memory QVL (Qualified Vendors Lists).
Graphic:
Integrated Graphics Processor
Multi-VGA output support : HDMI/DVI/RGB/DisplayPort ports
- Supports HDMI with max. resolution 1920 x 1200 @ 60 Hz
- Supports DVI with max. resolution 1920 x 1200 @ 60 Hz
- Supports RGB with max. resolution 2048 x 1536 @ 75 Hz
- Supports DisplayPort with max. resolution 2560 x 1600 @ 60 Hz
Supports Intel® HD Graphics, InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™
Multi-GPU Support:
Supports NVIDIA® Quad-GPU SLI™ Technology *1
Supports AMD Quad-GPU CrossFireX™ Technology
Supports AMD 3-Way CrossFireX™ Technology
Supports LucidLogix® Virtu™ MVP Technology *2
Expansion Slots:
2 x PCIe 3.0/2.0 x16 (x16 or dual x8) *3
1 x PCIe 2.0 x16 (x4 mode, black)
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
Intel® Z77 chipset :
2 x SATA 6Gb/s port(s), gray
4 x SATA 3Gb/s port(s), blue
Support Raid 0, 1, 5, 10
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *5
ASMedia® PCIe SATA controller : *6
2 x SATA 6Gb/s port(s), navy blue
LAN:
Intel® 82579V, 1 x Gigabit LAN Controller(s)
Intel® LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Wireless Data Network:
Wi-Fi 802.11 b/g/n
Supports single band frequency 2.4GHz
Audio:
Realtek® ALC892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- DTS Ultra PC II
- DTS Connect
- Optical S/PDIF out port(s) at back panel
USB Ports:
ASMedia® USB 3.0 controller : *7
2 x USB 3.0 port(s) (2 at back panel, blue)
Intel® Z77 chipset : *7
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
10 x USB 2.0 port(s) (2 at back panel, black, 8 at mid-board)
Overclocking Features:
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
Special Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
- Smart DIGI+ Key- quickly delivers higher VRM frequency, voltage and current for superior CPU/iGPU/DRAM overclocking performance with one switch.
- Smart CPU Power Level (Intel® VRD 12.5 Future Power Design)- provides the best digital power saving conditions.
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
ASUS Digital Power Design :
- Industry leading Digital 12 Phase Power Design
(8 -phase for CPU, 4 -phase for iGPU)
- Industry leading Digital 2 Phase DRAM Power Design
- CPU Power Utility
- DRAM Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *8
- Wi-Fi GO! Remote for portable Smartphone/Tablet, supporting iOS & Android systems
- Wi-Fi Engine for network sharing and connection: Client Mode, AP Mode
ASUS Exclusive Features :
- USB BIOS Flashback
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- Stylish Fanless Design Heat-sink solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x PS/2 keyboard/mouse combo port(s)
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
1 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)
1 x WLAN connector(s) for ASUS wireless module
Internal I/O Ports:
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin)
4 x USB 2.0 connector(s) support(s) additional 8 USB 2.0 port(s)
1 x TPM connector(s)
1 x COM port(s) connector(s)
4 x SATA 6Gb/s connector(s)
4 x SATA 3Gb/s connector(s)
1 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
1 x Optional Fan connector(s)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s)
1 x MemOK! button(s)
1 x TPU switch(es)
1 x EPU switch(es)
1 x Clear CMOS jumper(s)
1 x USB BIOS Flashback button(s)
Accessories:
User's manual
I/O Shield
2 x SATA 3Gb/s cable(s)
2 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x ASUS Wi-Fi GO! card(s)
1 x Wi-Fi Ring Moving Antenna(s)
BIOS:
64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
Manageability:
WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Anti-virus software (OEM version)
Form Factor:
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Note:
*1: With 2 PCIex16 graphics card.
*2: LucidLogix Virtu MVP supports Windows 7 operating systems.
*3: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*4: The PCIe x1_2 shares bandwidth with SATA6G_E12. SATA6G_E12 is enabled by default for system resource optimization.
*5: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*6: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*7-1: Supports ASUS USB 3.0 Boost UASP Mode.
*7-2: The USB 3.0 ports only support Windows® 7 or later versions.
*8: Available with V1.01.00 or later.
*9: Due to Intel® chipset limitation, P8Z77, P8H77 and P8B75 series motherboards do not support Windows® Vista operating system.
CPUs für P8Z77-V:
ASUS - Mainboards- ASUS P8Z77-V
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V PRO
Prozessor / Sockel:
Chipset:
Intel® Z77
Memory:
Graphic:
Multi-GPU Support:
Expansion Slots:
2 x PCIe 2.0 x1 *4
2 x PCI
Storage:
LAN:
Wi-Fi 802.11 b/g/n
Audio:
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB Ports:
Special Features:
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 16 Phase Power Design
(12 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Back I/O Ports:
1 x DVI-D
1 x D-Sub
1 x DisplayPort
1 x HDMI
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
Internal I/O Ports:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
4 x Chassis Fan connector(s)
1 x System panel(s)
1 x TPU switch(es)
1 x EPU switch(es)
Accessories:
User's manual
ASUS Q-Shield
1 x SLI bridge(s)
BIOS:
Manageability:
Support Disc:
Drivers
ASUS Utilities
ASUS Update
Form Factor:
ATX Form Factor
Note:
CPUs für P8Z77-V Pro:
ASUS - Mainboards- ASUS P8Z77-V Pro
Tests (deutsch):
http://www.awardfabrik.de/mainboards/asus-p8z77-v-pro.html
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Deluxe
Prozessor / Sockel:
Unterstützt Intel® 22 nm-Prozessoren
Unterstützt die Intel® Turbo Boost-Technologie 2
* Die Unterstützung der Intel® Turbo Boost-Technologie 2.0 ist vom Prozessor-Typ abhängig.
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 MHz Non-ECC, Un-buffered Memory
Dual Channel-Speicherarchitektur
Unterstützt Intel® Extreme Memory Profile (XMP)
* Die Hyper DIMM-Unterstützung ist von den Merkmalen des jeweiligen Prozessors abhängig.
* Eine Liste freigegebener Speichermodule finden Sie auf der Webseite ASUS oder im Benutzerhandbuch.
Grafik:
Integrierter Grafikprozessor
Multi-VGA Ausgaben Unterstützung : HDMI/DisplayPort Schnittstellen
- Unterstützt HDMI mit einer max. Auflösung von 1920 x 1200 @ 60 Hz
- Unterstützt DisplayPort mit einer max. Auflösung von 2560 x 1600 @ 60 Hz
Multi-GPU-Unterstützung:
Unterstützt die AMD® Quad-GPU CrossFireX™-Technologie
Erweiterungsschächte:
1 x PCIe 2.0 x16 (x4 Modus, schwarz)
4 x PCIe 2.0 x1 *4
Speichersystem:
2 x SATA 6Gb/s-Schnittstellen, grau
4 x SATA 3Gb/s-Schnittstellen, blau
Unterstützen RAID 0, 1, 5, 10
Marvell® PCIe 9128 controller :
2 x SATA 6Gb/s-Schnittstellen, navy blue
2 x eSATA 6Gb/s-Schnittstellen, red
LAN:
Realtek® 8111F, 1 x Gigabit LAN Controller(s)
Dual Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance
Wi-Fi 802.11 a/b/g/n
Supports dual band frequency 2.4/5 GHz
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Kanal High Definition Audio CODEC
- Unterstützt : Anschlusserkennung, und Multistreaming, Technologien sowie automatische Geräteerkennung an der Gehäusevorderseite
Audio Feature :
- Blu-ray audio layer Content Protection
- optischer S/PDIF-Ausgang an der Gehäuserückseite
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
4 x USB 3.0 Schnittstellen (4 an der Gehäuserückseite, blau)
4 x USB 3.0 Schnittstellen (2 an der Gehäuserückseite, blau, 2 intern)
8 x USB 2.0 Schnittstellen (4 an der Gehäuserückseite, schwarz, 4 intern)
Übertaktung:
Sicherheit beim Übertakten :
Besondere Features:
ASUS Dual Intelligent Processors Technologie 3 - SMART DIGI+ Power Control :
SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU-Taste
ASUS EPU :
- EPU
- EPU switch
- Industry leading Digital 20 Phase Power Design
(16 -phase for CPU, 4 -phase for iGPU)
- CPU Power Utility
ASUS Wi-Fi GO!:
- MemOK!
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS UEFI BIOS (EZ-Modus) inkl. benutzerfreundlicher, grafischer Oberfläche
- ASUS SSD Caching
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- Stylish Fanless Design Heat-pipe solution
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Anschlüsse (Rückseite):
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) Schnittstelle
6 x USB 3.0
4 x USB 2.0
1 x S/PDIF-Ausgang (optisch)
6 x Audio-Anschlüsse
1 x Bluetooth V4.0 connector(s) for ASUS Wi-Fi GO! card
1 x USB BIOS Flashback Button(s)
interne Anschlüsse:
1 x USB 3.0-Anschluss unterstützt zusätzlich 2 USB 3.0-Schnittstellen (19-pin)
2 x USB 2.0-Anschlüsse unterstützen zusätzlich 4 USB 2.0-Schnittstellen
4 x SATA 6Gb/s-Schnittstellen
1 x Prozessorlüfteranschluss
4 x Gehäuselüfteranschlüsse
1 x S/PDIF-Ausgang
1 x 24-Pin EATX Netzanschluss
1 x 8-Pin ATX 12V Netzanschluss
1 x Audio-Anschluss an der Gehäusevorderseite (AAFP)
1 x MemOK!-Taste
1 x System panel(s)
1 x TPU-Taste
1 x EPU-Taste
1 x Clear BIOS-Taste
1 x Power-on button(s)
1 x Reset button(s)
Zubehör:
User's manual
ASUS Q-Shield
2 x SATA 3Gb/s-Kabel
4 x SATA 6Gb/s-Kabel
1 x SLI bridge(s)
2 x Wi-Fi Ring Moving Antenna(s)
BIOS :
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
12 " x 9.6 " ( 30.5 cm x 24.4 cm )
Anmerkung:
- CPU-Liste -
Grundsätzlich sind alle LGA1155 Sandy-Bridge CPUs kompatibel zum ASUS P8Z77-V Deluxe. Wer jedoch seinen Prozzi möglichst weit übertakten möchte,
der kommt an einem Modell mit dem Zusatz "K" im Namen nicht vorbei. Denn auschliesslich diese lassen einen höheren "Turbomulti" zu. Modelle ohne "K"
besitzen einen festen maximalen "Turbomulti" und sind daher für OC ungeeignet, da der Referenztakt nur von 100MHz auf maximal 105-110MHz
erhöht werden kann (kommt sonst zu Instabilitäten!).
CPUs für P8Z77-V Deluxe:
ASUS - Mainboards- ASUS P8Z77-V DELUXE
Tests (deutsch):
http://www.ocaholic.ch/xoops/html/modules/smartsection/item.php?itemid=733&sel_lang=german
http://www.hartware.net/review_1463.html
Bios History:
0801
0906
1015
1206
1401
1502
1504
1617
1709
1805
1908
2003
2104
1.Spezifikationen
ASUSTeK Computer Inc. - Motherboards - ASUS P8Z77-V Premium
CPU:
Intel® Socket 1155 for 3[SUP]rd[/SUP]/2[SUP]nd[/SUP] Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.ChipsetIntel® Z77
Chipsatz:
Intel® Z77
Arbeitsspeicher:
4 x DIMM, Max. 32GB, DDR3 2800(O.C.)/2600(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333/1066 MHz Non-ECC, Un-buffered Memory
Thunderbold:
ThunderboltVGA output support
Data transfer rate up to 10 Gbps
Daisy-chain up to 6 Thunderbolt devices
Grafik:
Multi-VGA output support : HDMI/DisplayPort/Thunderbolt ports
- Supports Thunderbolt with max. resolution 2560 x 1600 @ 60 Hz
Maximum shared memory of 1696 MB
Supports NVIDIA® 4-Way SLI™ Technology
Supports AMD 4-Way CrossFireX Technology
Supports LucidLogix® Virtu™ MVP Technology *[SUP]1[/SUP]
4 x PCIe 3.0/2.0 x16 (dual x16 or x16, x8, x8 or quad x8) *[SUP]2[/SUP]
2 x PCIe 2.0 x1
Speichersystem:
Intel® Z77 chipset : 2 x SATA 6Gb/s port(s), gray
3 x SATA 3Gb/s port(s), blue
1 x mini-SATA 3Gb/s port(s) with onboard 32GB SSD, black
Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology *[SUP]3[/SUP]
Marvell® PCIe 9230 controller :
4 x SATA 6Gb/s port(s), navy blue
Support Raid 0, 1, 10
ASMedia® PCIe SATA controller : *[SUP]4[/SUP]2 x eSATA 6Gb/s port(s), red
LAN:
Intel® 82583, 1 x Gigabit LAN Controller(s)
Bluetooth:
Bluetooth V4.0
Bluetooth V3.0+HS
Audio:
Realtek® ALC898 8-Channel High Definition Audio CODEC
Audio Feature :
- DTS Ultra PC II
- DTS Connect
USB-Schnittstellen:
Intel® Z77 chipset : *[SUP]5[/SUP]4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
Intel® Z77 chipset :6 x USB 2.0 port(s) (2 at back panel, black, 4 at mid-board)
Übertaktung:
Besondere Features:
ASUS Dual Intelligent Processors 3 - SMART DIGI+ Power Control :SMART DIGI+ :
ASUS TPU :
- Auto Tuning
- TurboV
- GPU Boost
- TPU switch
ASUS EPU :
- EPU
- EPU switch
- CPU Power Utility
ASUS Wi-Fi GO!:
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send *[SUP]6[/SUP]
ASUS Exclusive Features :- USB BIOS Flashback
- AI Suite II
- Ai Charger+
- USB Charger+
- Anti-Surge
- ASUS SSD Caching II
- Network iControl
- USB 3.0 Boost
- Disk Unlocker
- ASUS Fan Xpert 2
ASUS EZ DIY : - ASUS O.C. Tuner
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
1 x Thunderbolt port(s)
1 x DisplayPort
1 x HDMI
2 x eSATA 6Gb/s
2 x LAN (RJ45) port(s)
4 x USB 3.0
2 x USB 2.0
6 x Audio jack(s)
interne Anschlüsse:
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
6 x SATA 6Gb/s connector(s)
3 x SATA 3Gb/s connector(s)
1 x mSATA connector(s) with 32GB SSD onboard
1 x CPU Fan connector(s) (4 -pin)
1 x CPU OPT Fan connector(s) (4 -pin)
1 x System panel(s) (Q-Connector)
1 x TPU switch(es)
1 x EPU switch(es)
1 x CPU/DRAM overvoltage jumper(s)
1 x Reset button(s)
1 x Clear CMOS button(s)
Zubehör:
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x 3-Way SLI bridge(s)
1 x 4-Way SLI bridge(s)
1 x SLI bridge(s)
1 x ASUS Front Panel USB 3.0 Box(es)
BIOS:
Verwaltung:
Support CD:
Drivers
ASUS Utilities
ASUS Update
Formfaktor:
ATX Form Factor
Anmerkung:
*1: LucidLogix Virtu MVP supports Windows 7 operating systems.
*2: PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
*3: Supports on Intel® Core™ processor family with Windows 7 operating systems.
*4: These SATA ports are for data hard drivers only. ATAPI devices are not supported.
*5: The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
*6: Available with V1.01.00 or later.
3.UEFI-Einblicke (ehemals Bios) 3.UEFI-Einblicke (ehemals Bios)
4.Downloads 4.Downloads
allgemein:
Hinweis:
Nach dem Download nicht vergessen die zip.-Datei zu entpacken.
UEFI-Update möglichst mit EZ-Flash durchführen. Näheres dazu siehe Handbuch.
Flash erfolgt grundsätzlich auf eigenes Risiko!
6.kompatible CPU-Kühler 6.kompatible CPU-Kühler
Alle Sockel 1156-Kühler könnten auf dem Z77 passen, da die Lochabstände 1156/1155 identisch sind! Vorausgesetzt sie kollidieren nicht mit Anbauten/Heatpipes
(fast) problemlos passende Luftkühler: :)
Be quiet! Dark Pro Advanced
EKL Brocken
Intel Boxed Kühler
Noctua NH-C12P SE14
Noctua NH-D14
Prolimatech Genesis (es kann möglicherweise zu Problemen mit dem Pcie x1 anschluß kommen, kleiner abstand zum kühler)
Thermalright HR-02 Macho (SE / Rev. A) - keine Probleme (neuere Revisionen mit Innenbefestigungsklammern)
Zalman CNPS11X Performa (auch bei Vollbestückung knapp passend)
Mit Einschränkungen !!! :
be quiet! Dark Rock Pro 2 (es sollten low Profile Ram verwendet werden)
Noctua NH-U14S (oberster PCIe Slot nur eingeschränkt nutzbar)
Scythe Mine 2 unter verwendung FSMB 4 Backplate und weiteren einschränkungen
Scythe Mugen II Revision B mit dem 1156er Kit Ram Bänke A1 und B1 nur noch mit low profil Ram bestückbar
Scythe Mugen 3 B
wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright Archon SB-E u. Thermalright Archon - blockiert teilweise obersten Slot (PCIe x1), sonst keine Probleme
Thermalright HR-02 Macho wenn nicht so hohe Arbeitsspeicher eingebaut sind, sonst bekommt man Probleme mit dem Lüfter oder den Lüfter-Haltklammern
Thermalright HR-02 Macho 120 - keine Probleme bei Nutzung von Ram ohne hohe HS, andernfalls kann der erste Ramslot nicht genutzt werden
Thermalright Silver Arrow SBE SE -
Nur die 2 blauen RAM Slots lassen sich nutzen wenn der erste Lüfter normal sitzt, will man alle haben muss man ihn höher montieren, nur LP Ram Pci-e wird blockiert
Thermalright True Spirit 140 längere Pcie Karten auf Slot Pcie x1 sind nicht mehr verwendbar.
Wasserkühler und Flüssigkeitskühler
Antec H2o 620
Corsair H80
7.kompatibler RAM 7.kompatibler RAM
Corsair XMS3 PC3-16000U CL9
Corsair XMS3 Dominator Platinum DIMM Kit 8GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMD8GX3M2A2133C9) Achtung Ram hat Überhöhe !!
Corsair Dominator CMP16GX3M4X1866C9 4x4 Kit
Corsair XMS3 Dominator GT DIMM Kit 16GB PC3-17066U CL9-11-10-27 (DDR3-2133) (CMT16GX3M4X2133C9)
Corsair Vengeance Low Profile schwarz DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600)
Corsair Vengeance 2*8GB (CML16GX3M2A1600C10)
Corsair Vengeance Low Profile 16GB PC3-12800U CL9-9-9-24 (DDR3-1600) (CML16GX3M4A1600C9)
Corsair Vengeance Low Profile 16GB (DDR3-1600) CML16GX3M4A1600C9
Corsair Vengeance Low Profile 4x8GB CL10-10-10-27 (DDR3-1600) (CML32GX3M4A1600C10B)
Crucial Ballistix Sport CL9 2 x 8GB Crucial BLS8G3D1609DS1S00
Crucial Ballistix Tactical LP (8GB Single) mit Einschränkungen siehe Post 1233
GeIL Evo Corsa GOC38GB1866C9DC
G.Skill Ares F3-1600C9D-8GAO
G.Skill F3-1866C10D-16GAB
G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB)
G.Skill Ares F3-2133C9Q-16GAB - CL9-11-10
G.Skill RipJaws-X DIMM Kit 8GB PC3L-12800U CL9-9-9-24
G.Skill RipJaws-X DIMM Kit 8GB PC3-17066U CL11-11-11-30 (DDR3-2133) (F3-17000CL11D-8GBXL)
G.Skill RipJaws 4x 4GB 1600MHz CL 9-9-9-24 @ 1.5V ~ F3-12800CL9Q-16GBRL
G.Skill RipJaws 16GB DDR3 F3-12800CL9Q-16GBRL
Hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C
Kingston KHX1333C9D3B1K2/8G 2x4 GB (DDR-3-1333)
Kingston HyperX blu. DIMM XMP Kit 8GB PC3-12800U CL9-9-9-27 (DDR3-1600) (KHX1600C9D3B1K2/8GX)
Kingston HyperX Plug n Play DIMM Kit 8GB PC3-12800U CL9 (DDR3-1600) (KHX1600C9D3P1K2/8G)
Kingston HyperX DDR3-1600 16 GB Kit (Typ: KHX1600C9D3K4/16GX)
Patriot (PXD316G1866C9K, Viper Xtreme DIVISION2) DIMM 16 GB DDR3-1866 Kit
Muskin Stileto DDR3-1333
Samsung Green Series DIMM Kit 8GB PC3L-12800U CL11 LP (MV-3V4G3D)
TeamGroup Elite 4x4GB PC3-10667U CL9-9-9-24
Danke an alle die dazu Beitragen das die Liste der Kompatibilität länger wird ...:hail:
sonstige Links
Da immer wieder die Fragen nach den unterschieden der Boards untereinander aufkommen, habe ich mal ein PDF Tabelle online gestellt, wo ich mich bemüht habe die meisten Unterschiede zu markieren.
Viel Spass damit:
http://netload.in/dateiHl4LsFD9cy/Vergleichsliste Asus P8Z77 Boards.pdf.htm
Update: 13.08.2012 (Changelog siehe Spoiler)
Threadupdate-History:
- 27.04.2015: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 08.01.2013: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 13.08.2012: mehr kompatible Ram und Cpu Kühler hinzugefügt
- 05.07.2012: Bios History deluxe hinzugefügt
- 07.06.2012: Vergleichsliste gebaut und auf netload hochgeladen
- 04.06.2012: Tests hinzugefügt
- 03.06.2012: ein paar änderungen und P8Z77 Premium hinzugefügt
- 02.06.2012: Thread übernahme und aktualisierung der kompatiblen CPU Kühler sowie Arbeitsspeicher
- 19.04.2012: Sammelthread gestartet
:) Bei Gefallen des Threads darf der "Danke-Button" gerne gedrückt werden. :)
mal ein Beitrag bezgl. der CPU-Kühler Kompatibilität,
habe einen Thermalright Silver Arrow SB-E verbaut auf dem P8Z77-V Deluxe mit voller RAM-Bestückung.
Da liegt auch mein Problem, bei voller Bestückung mit G.Skill RipJaws-X DIMM Kit 16GB F3-12800CL9Q-16GBXL mit AUTO DRAM Voltage kommt der Q-Code 55 (Memory not installed).
Musste die Spannung erst mit 2 eingebauten Riegeln etwas anheben damit ich dann mit 16 GB booten konnte.
RAM ist getestet mit Memtest86 ohne Fehler.
Bios: 0906
Sollte ich den RAM tauschen oder liegt es vielleicht am Board?
Scythe Mine 2 passt auf P8Z77-V Deluxe unter Verwendung der FSMB 4 Backplate statt der mitgelieferten.
Der Kühler blockiert die zwei RAM-Slots die dem Sockel am nächsten sind für hohe RAM-Module. Montiert man einen zusätzlichen Lüfter auf der RAM-Seite sind in allen 4 Slots keine hohen Module möglich.
Außerdem kompatibel: hynix RAM DDR3-1333 | 2x 2048 MB | Typ: HTM325U6CFR8C | schwarze Slots
Welche USB 3.0 Ports am IO-Shield hinten sind die von Intel?
Die, die beim Deluxe den Soundanschlüssen am nächsten sind. Handbuch Seite 2-51.
Folgender Ram ist kompatible: G.Skill Ares DIMM Kit 16GB PC3-14900U CL9-10-9-28 (DDR3-1866) (F3-1866C9Q-16GAB) kann eingetragen werden falls bedarf besteht P8Z77-v deluxe
Der Low Profile RAM Corsair Vengeance 2*8GB (CML16GX3M2A1600C10) funktioniert auf dem Board P8Z77-V Deluxe (in der QVL sind ja noch keine 8GB Module gelistet...).
Ich habe eine Frage zum Kühler... ich würde gerne den nervigen Boxed Kühler des 3770k loswerden und wollte eigentlich meinen alten Mugen 2B weiterverwenden. Der Kühlkörper an sich würde auch passen, das Problem ist aber die Backplate bzw. die Beinchen diverser Bauteile auf der Board-Rückseite des Deluxe. Die sind so lang, dass sie schon ohne Druck durch den Kühler die Gummiunterlage der Backplate durchstossen. Ich befürchte, dass man früher oder später einen Kurzschluss fabrizieren würde wenn der Anpressdruck dann auch die letzte Plastikschicht unter dem Gummi durchstößt und Verbindung mit dem Metall zustande kommt. Deshalb meine Frage an alle mit dem Deluxe-Board: Welchen Kühler verwendet ihr? Passt insbesondere die Noctua Backplate? Ich würde die CPU gerne möglichst leise im Bereich 4-4,3GHz betreiben.
Benutz doch die FSMB 4 Backplate. Die kann dir der Support zuschicken und die machte eigentlich keinerlei Probleme auf dem Deluxe. Ich nutze diese gerade mit dem Mine 2.
Super, danke für den Tipp. Grade den Support angeschrieben. Da bin ich ja froh, dass ich den Kühler nicht wie schon geplant in die Bucht gestellt hatte :)
Merkwürdig, eben habe ich bei Asus für das Z77-V Deluxe das neue Bios 1015 runtergeladen und installiert.
Jetzt ist es auf der Asus-HP wieder verschwunden...
Bios 1015
http://dlcdnet.asus.com/pub/ASUS/mb/LGA1155/P8Z77-V_DELUXE/P8Z77-V-DELUXE-ASUS-1015.zip
[ 1015 ]
1.Improve system stability.
2.Improve memory compatibility.
3.Enhance compatibility with some USB devices.
4.Support new CPUs. Please refer to our website at: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us
kann mal einer mit ner ivy cpu und nach dem flash des 1015 mal unter dem reiter schauen was bei euch steht bei der cpu ratio rnage??
http://www.hardwareluxx.de/community/f248/3770k-und-die-multi-anzeige-im-bios-886902.html
So, Antwort vom Support bekommen aber zuschicken wollen die mir nichts sondern haben mich an Online-Händler verwiesen... Naja, immer noch besser als nen neuen Kühler zu kaufen ;)
Das ist schade. Ich wusste gar nicht, dass es die FSMB 4 zu kaufern gibt. Im Universal Ret Kit 3 ist sie nämlich nicht.
selbnst die neue pcgh schreibt 63 als max multi ist leider immer noch en bios bug
Verbesserung nach update 1015 beim HDMI Ausgang vom Mainboard, zuvor wie im Lotto einmal Bild OK, dann
wieder einmal ein leichtes zittern am oberen Bildschirmrand, welches nur durch einmal Umschalten auf niederige
Auflösung und zurück normalisierte. Kann natürlich auch an meinem Asus Monitor MK241H liegen ist schon ein
älterer Herr :), jedoch hatte ich dies bei meinem alten Rechner mit GF 280 mit Atapter DVI -> HDMI nicht.
Vielleicht auch mit der HDMI Norm zu tun, Monitor glaube ich 1.1 MB 1.4a
Rechner starten mit USB Tastatur finde ich keine Einstellung ist dies korrekt?
Meine HD ST31000524As wird jetzt beim booten(Marvell controller 6G) nicht angezeigt und im bios auch nicht, win 7 64 funzt trotzdem noch :)
Meinen 3 pin Lüfter kann ich nur regeln(FanXpert2) ohne das die Drehzahl angezeigt wird mit einem kleinen Trick zuerst
4 pin Lüfter stecken auto fanspeed und dann wieder 3 pin Lüfter anstecken.
Auto fan Stop funzt damit auch, man sollte jedoch die Anlaufspannung vom Lüfter berücksichtigen, bzw. mit
den Bällchen etwas spielen (bei mir 65% bei 40 Grad) und die Leds leuchten auch.
Eine Frage hätte ich noch, für den Display Port bräuchte ich noch einen Adapter auf DVI, kann mir jemand einen
empfehlen und ob aktiv oder passiv? Danke
---------- Post added at 21:14 ---------- Previous post was at 21:08 ----------
1015 ist das aktuellste, 1009 ist ein Beta Bios
Danke
Welche FanXpert Version hast Du?
Mit der FanXpert-Version 1.00.15 werden die 3-pin Gehäuselüfter ohne Probleme geregelt, auch die Drehzahlen werden angezeigt.
Für jeden Lüfter habe ich eine eigene Leistungskurve angelegt, auf der man sehen kann wie die Drehzahlen je nach Temp rauf und
runter gehen - angezeigt wird die Drehzahl auch rechts (Sensor anklicken).
Beispiel Fan 2:
Wie man aus der Grafik sehen kann, ist der (3-pin) Lüfter Fan 2 von 30...100 % regelbar, begrenzt ist er nach unten auf 40% (600 RPM)
und nach oben auf 100% (1200 RPM).
Gut finde ich bei der V 1.00.15, dass man jetzt alle Gehäuselüfter einzeln einstellen kann.
Einzig die Wasserpumpe wird nicht geregelt, die Leistungskennlinie ist durchgängig auf 100% (4485 RPM) eingestellt.
Ich hätte mal eine Fragen zu meinem Mainboard dem P8Z77-V LE. Es ist zwar nicht im Startpost aufgeführt, aber da es ja nur eine abgespeckte Variante, der normelen -V Edition ist, denke ich mal das passt trotzdem hier hin.
Mein Problem ist die Audiwiedergabe mit dem Realtek ALC892. Bei allen früheren Mainboard die ich hatte, konnte ich die Wiedergabe von allen Sachen auf beide Ausgänge hinten und vorn gleichzeitig legen, sodass Musik über Boxen, als auch über Headset kamen. Sobald ich nun mit einem im TS geredet habe, musste ich nur meine Boxen leise stellen und gut war. Jetzt mit dem neuen Mainboard muss ich immer umständlich das Standardgerät umstellen.
Ich denk ja, dass sie es eigentlich gut meinen, da sie glaube wollten, dass man zwei verschiedene Audisignale auf die verschiedenen Ausgabegeräte legen kann. Ich frage mich bloß jetzt ob es überhaupt noch eine Option gibt (und wenn ja wo) mit der ich einstellen kann, dass wieder auf beide Ausgänge gesendet wird.
Denn im Audi Manager gibt es unter Optionen nur:
*Schalten Sie das hintere Ausgabegerät stumm, wenn ein Front-Kopfhörer eingesteckt wird
oder
*ermöglicht die simultane Wiedergabe von zwei unterschiedlichen Audio-Streams auf den vorderseitigen und rückseitigen Ausgangsgeräten
Hat jemand auch Installationsprobleme mit Virtu MVP, sowohl mit der aktuellen Version 2.1.112 als auch mit der auf der ASUS-MoBo-DVD.
Mein Rechner (sonstiges sh. Systeminfo):
Asus P8Z77-V Deluxe
Intel i5-3570K
Win7 Home/64 bit
Nach der Installation erscheint immer diese Meldung - bei allen Versionen, sowohl mit dem Bios 902 und 1015.
Die Normalversion 1.2.114 lässt sich hingegen fehlerfrei installieren.
Für jeden Rat oder Tip bin ich dankbar.
Fehlermeldung bei MVP (sh. Grafik):
Hat jemand eine Idee zu meinem Virtu-MVP Problem?
Beispiel Fan 2:
Das ist so nicht ganz richtig scheinbar ist es sehr davon abhängig was für Lüfter man benutzt, darf ich fragen was du für welche hast ?!
Bei mir habe ich die gleichen Probleme wie Furby1 (welche Lüfter hast du denn?)
Danke für die Info, funzt jetzt, schuld war ein leiser Lüfter mit Leds, das mag asus nicht bzw.
wird nicht richtig erkannt ausser mit dem Umstecken.-
Mit meinem Noctua NF S12-800 funzt es, jedoch werde ich noch zwei ander Lüfter besorgen be quiet! Shadow Wings SW1 120mm Low-Speed 5-12V
Virtu MVP habe ich noch nicht einmal installiert, versuche mal neue driver von Intel homepage vielleicht hilft es, das mit den driver ist auch so eine Sache.-
Hallo, ich wollte mal fragen, ob ihr denn Backplates installiert?
Und wenn ja, ob es dabei was wichtiges zu beachten gibt?
Hab mir mal die von Watercool bestellt, aber bisher noch nie eine Montiert.
Wäre sehr erfreut über Tips ;)
Grüße
Die Gehäuselüfter (vorne und oben) sind ganz normale und preisgünstige 3-pol. 12 V-Lüfter (120 + 140 mm). Der vorne war beim Gehäuse dabei, den oben habe
ich zugekauft.
Beide lassen sich über FanXpert drehzahlregeln. Der 4-pol. CPU-Lüfter vor dem Wärmetauscher wird - auch wegen der Lautstärke - ebenfalls drehzahlgeregelt.
Die Wasserpumpe (Corsair H60) wird mit konstanter Drehzahl betrieben. Im übrigen lässt sich das Regelverhalten der Ventis im FanXpert sehr gut beobachten.
Die Lüfteranschlüsse auf dem Board sind alle 4-polig.
Immer wenn ich die CPU auslaste, springt meine CPU Temperatur sofort hoch auf 55 Grad und geht dann runter auf 41 Grad, obwohl die CPU gestresst wird.
Deshalb dreht mein CPU Lüfter langsamer als er eigentlich unter Last laufen soll !
Ist das ein Biosproblem oder ein Hardwaredefekt ?
Ich habe Bios 0801, 0906 und 1009 gestestet und bei allen war der Effekt gleich.
Die CPU wird beim Board kühler unter Last bei der CPU Temperatur, aber laut Coretemp sind es bei den Cores so 66 Grad unter Last und Asus zeigt mir eine CPU Temperatur von 44 Grad an.
Obwohl Asus mir kurz nach dem Start von Prime95 eine CPU Temperatur von 55 Grad angezeigt hat, sind es ein paar Sekunden später nur noch 44 Grad.
Hoffentlich kann mir hier jemand helfen:
Ich versuche gerade, Windows auf meiner neuen Kiste (P8Z77-M Pro, OCZ Vertex 4) zu installieren aber scheitere daran, dass Windows im Install-Menü keinen Treiber für die Festplatte findet (AHCI im BIOS eingstellt, klappte in meinem alten System auch). Liegt das eventuell daran, dass ich die OCZ an den Z77 SATA-III Port angeschlossen habe? Müsste ich Windows am SATA-II Port installieren und die Platte dann später an den 6gb-Port umstöpseln? Ist das normal so?
der SATA 3 am chipsatz ist schon richtig. Du installierst doch nicht XP oder?
Nein, Windows 7 x64...drum wundert mich das ja auch so!
