[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
fehler gefunden NB wird verdammt heis trotz wasser mal schaun worans liegt werd mal alles abschrauben!
Vielleicht keine WLP drunter? Müsste 2x WLP drauf sein. Einmal zwischen der Heatpipe und der NB und einmal zwischen dem Kühler und der Heatpipe.
Christian
joa weis ich ging die ganze zeit nur jetzt von heut auf morgen hab ich das problem naja mal schaun morgen kommt das ding mal unter den schraubenzieher
Ich würde es auf jeden Fall machen, die Paste die drauf ist, ist nämlich nicht besonders. Ich konnte mit der guten Noctua Paste, ca. 5°C NB-Temp rausholen.
Christian
hi,
hast den NB-Mod gemacht?
zwei unterlegscheiben auf die schrauben bei der NB auf die rückseite des boards gesteckt, hast damit mehr anpressdruck.
web
so folgendes prolem mein brett wollte nicht mehr starten ging immer an dann aus hatte mich dann doch mal ins bios gelassen und da war die NB sehr hot habe die paste neu gemacht und immernoch der gleiche fehler so wenn ich jetzt die cpu rausnehme und starte läuft es an aber sobald ich die CPU spanne gehts wieder na aus an aus pins habe ich alle mit lupe überprüft sind ok
hab überlegt ob ichs mal zur RMA sende
gibts probleme beil die HP ab war?????
danke schonmal im voraus
ASUS ist was die RMA angeht nen sehr komischer Verein, könntest also Probleme bekommen, aber kann dir vorher keiner genau sagen!
Mach wenn du es wegschickst vorher auf jedenfall Detailfotos von allem am Board!
kann mir einer sagen warum ich meinen ram bei 1800nhz nur im strap 400 ans laufen bekomme?
warum fotod vom board machen?
weil ich ein schönes RE dahin geschickt habe zur RMA und es von ASUS nicht getauscht werden sollte weil ich es angeblich zerkratzt hatte (siehe Foto)!
Du kannst dir sicherlich vorstellen wie schwer es ist nachzuweisen, dass du es nicht warst wenn man keine Fotos hat...
Da hatte wohl eine große Taiwanesisch Hardwarefirma keinen Bock auf RMA Tausch
vermutlich weil die anderen "schärfer" sind und dein Board bzw. der RAM das nicht mitmacht!
also habe ich keine andere wahl als den fsb hochzujagen um den ram höher zu bekommen!??
Das maximale, was du an Ramtakt bekommen kannst, ist der FSB * 2. Und das geht nur im 400er Strap, weil der 266er dafür viel zu straff ist...
Christian
fahre 540x7,5 strap 400.macht unter win 1800mhz bei cl.8-8-8-24. ist das gut oder kann ich da noch mehr rausholen???
Also auch nochmal für dich:
Du fährst im Moment 810Mhz (oder 1620Mhz) und nicht 900Mhz (oder 1800Mhz). Der 2:3 Teiler wird im 400er Strap falsch ausgelesen, nämlich als 3:5 Teiler, der aber nur im 200er Strap vorhanden ist...
Von daher müsste auch zB CL7 drin sein, aber da hilft 1. hierden Fred lesen und 2. testen...
Christian
was müste ich demnach machen bzw einstellen damit ich reale 1800mhz fahren würde???
Tom
450Mhz FSB und Speicherteiler 1:2. Dann müsste es gehen...
Alternativ 563Mhz FSB und den 5:8 im 333er Strap, wobei ich nicht glaube, dass das läuft, bei mir läuft alles oberhalb von 550Mhz im 333er Strap läuft nicht...
Christian
hi@Alle,
also 450 FSB und Ramteiler 1:2 funzt net.
563 FSB und 5:8 Teiler im 333er Strap sowie im 400er Strap funzt net.
518 FSB und 5:3 Teiler im 400er Strap RAM 863Mhz funzt!
Vielleicht bekommt man 450 FSB mit RAMTeiler 1:2 mit den 2000er Diabolos hin!?
Hat das schon einer getestet?
Aber ich glaube die laufen auch nur mit 933Mhz mit dem RE.
Also bei mir funzen, die 450Mhz 1:2, weil zB das XMP genau das bei mir einstellt. Zwar werden die Spannungen sowas von angehoben, aber es geht und das auch mit wesentlich humaneren Spannungen, muss das mal testen.
Das das bei dir nicht geht, liegt vielleicht an der Vollbestückung mit insgesamt 8GB Speicher...
Christian
naja mann sollte auch ram haben der 2000real rennt :d
aber der 3/5 teilr wird falsch ausgelesen !
Ich bekomm dieses Mb einfach nicht zum laufen zu 100% , egal welche RAM timings ich einstelle, es läuft nicht richtig und verursacht irgendwann fehler und der PC kackt ab.
@Webforhunter
Welcher strap wäre das dann???
Und welche spannung müste ich dafür anheben???
habe ja die diabolos....bekomme sie bislang aber auch nur real auf 1650mhz.....
tom
@Pit Bull:
Wie du die Spannungen anheben musst, kann dir keiner sagen, musstest halt austesten, desweiteren bleibt dir nur der 400er Strap über, soweit ich weiß.
266er wird auf jeden Fall nicht laufen und ob es im 333er auch einen 1:2 Teiler gibt, weiß ich nicht aus dem Kopf...
@Eliteknight:
Bitte pack nicht so viele Infos in deinen Post..:rolleyes:
Christian
Hoffe das bald mein board bald wieder kommt
die ram bänke funzten nicht mehr und ser sokel war eine pin verbogen.
@Pit Bull:
@Eliteknight:
Christian
Also ich hab einen Q9450, RE Mb, 4Gb Diablo3 DDR3 2000mhz, und eine GTX280
Ich bekomme einfach wenn ich die Timings selber einstelle keine Kombi hin, wo alles läuft.
1. Wenn ich den Speicher bei Fsb 400 z.B. auf 1600mhz stelle, gibt es zwar kombis wo ich ins windows komme und spielen kann, allerdings bleibt dann das Spiel immer hängen, was sich nur durch öffnen der Steuerungskonsole beheben lässt, geht man dann wieder ins spiel, hängt es wieder und immer so weiter, bis es durch einen speicherfehler abbricht.
2. Egal ob 1600, 1400 oder 1333, irgendwann kackt der PC ab, und er geht quasi aus und Monitor zeig no-signal an.
Am besten läuft es wenn ich sie auf auto lasse, dann sind die Ruckler und Spiele probs weg, allerdings läuft er auch hier nicht richtig und es kommt ab und an no-signal.
oder was öfters ist, dann stell ich was ein und paar tage später gehts net mehr.
Ai Overclock Tuner: Manual
OC From CPU Level UP: Auto
OC From Memory Level UP: Auto
FSB Frequency: 333
CPU Ratio Control: 8.0
- CPU Clock Skew: Auto
- NB Clock Skew: Auto
FSB Strap to North Bridge: 400Mhz
PCI-E Frequency: 100
DRAM Frequency: DDR3-1332Mhz
DRAM Command Rate: 1N
DRAM Timing Control: Auto
- CAS# Latency:
- RAS# PRE Time:
- RAS# ACT Time:
- REF Cycle Time:
- Read to PRE Time:
DRAM Static Read Control: Disabled
DRAM Dynamic Write Control: Disabled
DRAM Skew Control:
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
EPU II Phase Control: Auto
CPU Voltage: 1,22500
Load-Line Calibration: Enabled
CPU PLL Voltage: 1,51106
FSB Termination Voltage: auto
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage: 1,35197
DRAM Voltage: 1,65681
- NB DDRVref: Auto
- DDR3 ChannelA Vref: Auto
- DDR3 ChannelB Vref: Auto
South Bridge 1.5 Voltage: 1,55081
South Bridge 1.05 Voltage: 1,07364
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
So steht es gerade bei mir, und bisher geht es, aber das Bootlogo läuft schon abgehackt, das heißt könnte schneller sein^^
Immer wenn ich den FSB auf 400 gestellt habe, die ram timings selber einstelle, kommt es zu Problemen, die DDR-Voltage hatte ich bei 1600mhz immer 1,8xx die meisten anderen werte hatte ich eigentlich gleich gehabt.
Jemand einen Vorschlag?
lol - wirst es bald wiederbekommen aber nicht getauscht... das mit dem verbogenen Pin ist ein "Nicht Austausch Grund"
das ist mir egal haupt sache ich bekomme es wieder und es funzt
habe mir nähmlich ein Q9650 E0 steping gekauft und hoffe das es mit 500FSB
läuft
läuft
aber das sage ich doch: wenn ein Pin krumm ist hast du keine Garantie mehr, also reparieren die auch nichts!
UND:
FSB 500 mit nem Quad ist sehr schwer für das RE...wenn du funzende Settings hast, sag sie mir!
das board habe ich schon verschickt die sagten von asus selber das ich es her schicken sollte.
