[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
Du bist aber auch net schlecht dabei mit Deinem e8600er!
Mit welcher FSB Termination läuft der E8600 auf dem Rampage Extreme am besten?
Testen........;)
Eckdaten:
Min.: beim 45nm und auf Serie 4 Chipsätzen = 1.14 Volt
Standard: beim 45nm und auf Serie 4 Chipsätzen = 1.20 Volt
Max.: beim 45nm und auf Serie 4 Chipsätzen = 1.26 Volt
Absolute noch von INTEL freigegebebe Max. = 1.45 Volt
2.6.1 Table 3 im Link Absolute Min. und Max. Ratings
und 2.6.2 Table 4 im Link Voltage und Current Specifikations
http://download.intel.com/design/processor/datashts/318732.pdf
Und immer VTT unter VCC....... ;)
Mein E86 läuft atm mit 1,43131V. Um so mehr, um so stabiler läuft die CPU.
Mit 1,43131 VTT fahre ich > 5Ghz........ ;)
Ein 45nm braucht keine so hohe VTT, es sei denn du willst ihn im 24/7 Betrieb grillen. :rolleyes:
Mein e8600 macht absolut stabil 450 x 10 = 4.5 Ghz mit 1.224 Vcore und 1.20 VTT
und 4 Ghz unter VID von 1.1625 mit 1.16 Vcore und VTT 1.14 :bigok:
Hi rampager:wink:
schafft jedes rampage 600fsb ??? oder nur ausnahmen,
mein striker hat 2 tropfen wasser ausm schott bekommen, mausetot:angel::mad:
überlege jetzt welches board besser ist, evtl. geht mein E8600er ja mit 5Ghz:eek: aufm SIIE kam ich schon ins Windows - regelmäßig nur bei Anwendungen schmierte er ab.
Hallo Rampage Extreme Fans
kann sein das Prime verbugt ist? nur prime macht fehler sonst leuft alles intel burn , linx und memtest aber prime macht immer fehler...windows und spiele laufen ohne abstürze.
meine hardware
QX9650
2x HD4850
4x G Skill F3-12800CL9-2GBRL
Code:
Ai Overclock Tuner: manuel
OC From CPU Level UP:Auto
OC From Memory Level UP:Auto
FSB Frequency:425
CPU Ratio Control:8,5
- CPU Clock Skew:Auto
- NB Clock Skew:Auto
FSB Strap to North Bridge:333
PCI-E Frequency:100
DRAM Frequency:1701
DRAM Command Rate:n2
DRAM Timing Control:Auto
- CAS# Latency:
- RAS# PRE Time:
- RAS# ACT Time:
- REF Cycle Time:
- Read to PRE Time:
DRAM Static Read Control:Auto
DRAM Dynamic Write Control:Auto
DRAM Skew Control:Auto
Ai Clock Twister:Auto
Ai Transaction Booster:Auto
EPU II Phase Control:Auto
CPU Voltage: 1,2625
Load-Line Calibration:aktiviert
CPU PLL Voltage: 1,55081
FSB Termination Voltage: 1,23266
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:1,43147
DRAM Voltage:1,53756
- NB DDRVref:Auto
South Bridge 1.5 Voltage:1,5106
South Bridge 1.05 Voltage:1,07364
CPU Spread Spectrum:Auto
PCIE Spread Spectrum:Auto
hat einer nen paar einstellungen für den QX ? ich möchte 4ghz fahren aber wen möglich unter 1,35v für den 24/7 gebrauch.
--------edit--------17.10.2010--------
ich bekomm prime nicht stable, immer steigt beim blend nach ein paar secunden der 1. oder 2. aus. ich habe schon alles mögliche versucht aber irgendwie ohne erfolg, das komische ist das mein system sonst stabil laufen zu scheint, ich kann spiele spielen wie battlefield bad company 2 oder medal of honor und nie ein absturz selbst windows ist bis jetzt noch nie abgestürzt.
was verursacht die fehler, CPU oder RAM ist das eine mischung aus beiden oder was sollen das für fehler sein weil grade in games geht ja einiges wen noch meine 2 grafikkarten dazu kommen aber warum laufen die spiele stunden lang nur prime macht beim blend sofort fehler??? memtest habe ich auch schon laufen lassen 1xpass
mit den GTLVerf habe ich auch schon rumprobiert aber daraus werde ich noch nicht schlau, muss ich da was ausrechnen um den wert da einzugeben oder ist das eine gefühls sache?
--------edit--------18.10.2010--------
@Napalmarsch
hi eine frage ich betreibe das rampage momentan mit ocz 1600ter speicher würde ein upgrade auf ddr3 2000 sich noch bemerkbar machen / etwas bringen beim übertackten?
so läuft er 24/7 http://valid.canardpc.com/show_oc.php?id=1372747
ich würde mal sagen mit freigegebenen 2000mhz speicher kannst du mehr erreichen als mit 1600mhz speicher übertacktet auf 2000 weil bei 2000mhz orginal hast du auf jeden fall noch einen weiteren bereich nach oben und mit dem 1600 bist du schon fast am ende
@2ultima4
weiter am anfang gibts da einen trick mit einem alten bios auf ein neues bios flashen aber da dreht es sich um über 600fsb , ich denke jedes board ist nie 100% wie das andere
Hi Leute, ich hab mal eine Frage zum betreiben von RAM auf dem Mainboard. Ich weiß die Frage zu passendem Ram kam schon öfters, aber ich will nicht einfach Ram bestellen und nachher feststellen, dass es nicht funktioniert.....
Ist es ohne weiteres Möglich 2x "Corsair Dominator GT mit 2133MHz" drauf zu stecken und diesen nachher mit 1600MHz-1800MHz laufen zu lassen und die CL`s einfach schärfer einzustellen oder bekomm ich sowas schon gar nicht zu laufen?!
Habe nämlich gesehen, dass dieser RAM nicht alzu teuer ist und würde daher zu diesem tendieren....., will auch nicht Hardcore OC`en sondern nur ein gut laufendes System bei dem ich mein E8400 bei ca. 3,8GHz laufen lassen will, was ca. 425FSB ergeben sollte evtl. auch ein wenig mehr, was halt unter Luft ohne kritische Temps möglich ist.
Bin auch gern noch für Ratschläge offen für Speicher, da viele schreiben, dass es oft Probs gibt!!!
THX
ich hatte das problem auch, speicher gekauft eingebaut und er lief nur auf 1333 auf 1600 bootet er erst garnicht und wen doch dan irgendwan bluescreen obwohl es 1600mhz speicher war. Ich habe dan speicher gefunden wo auf der hersteller seite mein board in der liste stand, jetzt leuft zwar alles aber wen ich sehe was hier manche für speicher haben 7-7-7-24 und auf 1800mhz dan frage ich mich warum der kingston hyper x nicht mal mit 8-8-8-24 auf 1600 laufen wollte???
ich würde sagen um sicher zu gehen schau dich um was leute auf dem Rampage Extreme für speicher zum laufen gebracht haben und kauf diesen, das hätte ich auch machen sollen da mein speicher schlechte timings hat 9-9-9-24 sobald ich die schärfer mache blackscreen, das einzigst gute was ich mit dem speicher habe ist 8gb auf 1700mhz laufen super nur prime spinnt warum auch immer
1:2
FSB400 = DDR1600
FSB425 = DDR1700
FSB450 = DDR1800
FSB500 = DDR2000
ich glaube so irgendwie ist das
auf auto einstellung leufts sowiso nicht und es wird extrem übervoltet
mit 4gb auf auto hat die NB fast 1,4v bekommen und mit 8gb ich dachte ich guck nicht richtig 1,55v und der ram bekommt auch zu viel
Erstmal Thx für deine Antwort.
Ich hab schon geschaut was die Leute so verbaut haben und wenn mein E8400 so wie der von WEBFORHUNTER läuft, dann ist alles gut!!! :hail:
Nur will ich kein so teuren Speicher kaufen....
Ich schau schon seit Tagen nach Speicher und mir ist das mit den Teilern schon klar. Nur ist es so, dass ich halt "noch" nicht genau weiß was für Teiler es für den Speicher im BIOS gibt, da ich das Board noch nicht laufen hab, da ich erstmal Speicher brauch!!! :-[ Dazu hab ich Speicher noch nie runtergetaktet, sondern immer nur erhöht. Aber hatte vor kurzem GEIL DDR2 und da gingen statt 800MHz grad mal 805MHz, während mein XMS2 locker 900 macht wenn ich ihn ordentlich bedüse!!!
...das nächste ist, dass der Corsair dominator GT mit 2133MHz und 1866MHz echt günstig wäre im Gegensatz zum Rest:
Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-17066U CL9-10-9-27 (DDR3-2133) (CMT4GX3M2A2133C9) | Geizhals.at Deutschland
Corsair XMS3 Dominator GT DIMM Kit 4GB PC3-14900U CL8-8-8-24 (DDR3-1866) (CMT4GX3M2A2000C8) | Geizhals.at Deutschland
...und in den Test sind die immer im guten Mittelfeld bis relativ weit vorne!!!
Aber dann würdest mir echt eher zu den mit den CL8 raten?!
Bin da halt echt überfragt, da manche n teuren OCZ Reaper kaufen und dann geht nix, das würd mich nerven.....
Perfekt wäre Speicher der was taugt, den ich evtl. auch mal auf einem 1366 verbauen kann und halt jetzt anpassbar an mein E8400 ist. Will wie gesagt auch nur so 3,8GHz laufen lassen unter Luft und 4GB Speicher verbauen!
Danke für jede Hilfe
du kannst nicht unsyncron laufen lassen mit dem board deswegen das sind die fsb einstellungen für die speichergeschwindigkeiten
1:2
FSB400 = DDR1600
FSB425 = DDR1700
FSB450 = DDR1800
FSB500 = DDR2000
du kannst mit fsb 333 nicht 1600mhz laufen lassen also ich auf jeden fall nicht, geht garnicht von der einstellung her im bios
ich kann nach unten viel machen FSB 400 und DDR1333 und weniger aber du kannst halt nicht unsynclaufen lassen wie z.b. FSB400 DDR1800 oder halt FSB 333 und DDR1600
kauf dir den speicher teste ihn inrhalb 14 - 30 tage wen er nicht leuft dan schick ihn zurück und gib an das der speicher nicht kompatible ist und du eine gutschrift wünschst fals der speicher fehler frei ist, so habe ich das auch gemacht aber ich bin leider bei einem kit hängen geblieben weil ich es nicht inerhalb 30 tage zurück geschickt habe...
Thx, das hilft mir schon extrem weiter, dann brauch ich nämlich nur schauen was für Multiplikatoren (CPU) ich hab und kann dann nach denen Speicher kaufen.
z.B. FSB450 = DDR1800 und dann zieh ich den Multi vom CPU auf 8 und hau dann noch beim Multi um 0,5 hoch wenn es die Einstellung gibt.
Dann hab ich 450*8,5=3,825GHz aufm CPU und 1800MHz (450MHz*4) auf den Riegeln. Bin ich da mit meinem denken Korrekt oder sind die zu schnell?!
Könnt ja evtl. auch nen 9er Multi aufn CPU hauen und Ram leicht drosseln.
Aaaaah, ich kanns kaum erwarten das Ding einzubauen!!! :fresse2:
Danke norT, werd dich weiterempfehlen!!! :d
das RE kann FSB 400 und DDR 1600 im orginal zustand, DDR1800 ist OC, bei dir fängt der OC bereich schon bei 400 an also musst du ein paar sachen einstellen
ich denke jeder speicher leuft auf dem board mit 1333mhz aber bei 1600 gehts gut zur sache und da laufen nicht alle speicher und schon garnicht auf auto einstellung im bios
selbst mein ram der vom hersteller freigegeben war hat auf auto fehler bei memtest gemacht weil die spannungen auf NB nicht koreckt eingestellt waren und ich musste sogar von 1,5v DDR auf 1,53v, ich denke das liegt auch an der vollbestückung das überall mehr saft drauf muss
Jo, aber das ist ja kein Problem.
Bisher haben die meisten Boards wo ich so kenne on den RAMS her eingestellt werden müssen. Aber das ist ja gleich gemacht (hoffe ich zumindest).
Hab mich jetzt für die hier aufgrund der Latenzen, dem Takt und des Preises entschieden:
GeIL EVO TWO DIMM Kit 4GB PC3-16000U CL6-9-6-24 (DDR3-2000) (GET34GB2000C6DC) | Geizhals.at Deutschland
und werd die morgen bestellen und mal testen!!! 4GB reichen mir eh, kenn keine Anwendung, bei der ich so viel Speicher bräuchte!!
Grüße
das kommt ganz drauf an was man verbaut hat, wen meine kiste vollast leuft sind das knapp 400Watt durchgehend.
ich glaube du soltest deine frage anders formulieren...
hallo,
habe mir vor kurzen neue Rams zugelegt G.skill DDR3 1600 ECOs 8GB 1,35V allerding laufen diese auf 1,5V Vdim niedriger geht leider nicht.
Jetzt habe ich das Problem das ich wenn ich übertakte und er überhaupt nicht mehr ins Win kommt. Habe mal alles auf Auto gestellt und mal geguckt was er so einstellt.
Der unterschied bestand in der Änderung der Vdim von 1,5 auf 1,65V da der Ram aber nur 1,5V braucht kannes daran nicht liegen...
Jetzt habe ich noch festgestellt das die DRAM VTT sich ja auch mit ändert und zwar ist die DRAM VTT, die normalerweise fest bei 0.5 x Vdimm steht von 0,75V auf 0.825 gestiegen und das macht den Unterschid anscheint aus warum es dann Stabil läuft.
Mein Frage wie kann ich die DRAM VTT, die normalerweise fest bei 0.5 x Vdimm steht erhöhen ohne die Ramspannung zu erhöhen so das ich dise auf 1,5V lassen kann??
mfg Rachus
hi leute, hoffe hier ist noch jemand unterwegs....
habe ein problem mit dem bios update:
wollte Bios1 flashen (auf ein älteres), da das 1202 und 1301 anscheinend nicht laufen...
> nach jedem neustart oder selbst wenn ich im bios nur eine kleinigkeit umstelle, bootet er net mehr (entweder locked oder det ram,) dann hilft nur ein neustart und dann ist da immer oc failed....
auf jeden fall, wenn ich das bios dann drauf gespielt habe kommt ein startbild, aber der rechner hängt....
hoffe da kann mir jemand noch weiter helfen
Da ist beim BIOS-Flash was falsch gelaufen. :rolleyes:
Beim BIOS-Flash sowie beim BIOS-Flashback von 2 auf 1 oder 1 auf 2 gilt vorher die Setup Defaults zu laden und ein CMOS Clear durchzuführen (wie's geht --> Handbuch Kap. 2.6).
Danach entweder mit ezFlash2 das BIOS flashen oder BIOS-Flashback je nachdem was man machen will oder braucht. ;)
1202 und 1301 laufen bei mir wie alle anderen auch. ;)
ja hatte das bios genauso geflasht, also erst die defaults laden und dann nen cmos clear...
der Fehler besteht trotzdem...
ne auf dem 2. Bios hatte ich das noch net probiert....
aber die andere methode werd ich mal ausprobieren..
danke
Hallo
Ich habe eine Frage an die Besitzer eines Rampage Extreme X48 Mainboards mit Wasserkühlung:
Hat jemand die Wasserkühler von Liquid Extasy verbaut und kann mir sagen wie es mit der Qualli aussieht?
Es handelt sich um folgende Bauteile:
North und Southbridge:
Spannungswandler oben/rechts:
Mfg
C170DAW
Da keiner hier geantwortet hat habe ich frei nach Trail and Error einen Wkü Satz von Liquid Extasy bestellt.
Ich habe jetzt aber eine neue Frage: Kann man einen 10kOhm Wassertemperatursensor an die Temperatursensoranschluss anschließen?
Mfg
C170DAW
2x4Gb Module für rampage extreme
Hy,
da ja einige Zeit ins Land gegangen ist seit das Rampage extreme auf den Markt gekommen ist wollte ich fragen ob jemand Erfahrung mit
2x4Gb Modulen hat?
Und da ja die Empfehlungsliste recht dünn ist, könnt Ihr vielleicht einen Vorschlag für 2x4Gb machen.
Auch hab ich gehört, dass über Bios update mehr als 8Gb möglich sind.??? kann das sein???
Besten Dank
Sys: asus Rampage Extreme
q9550
noch keine Rams :-)
