[Sammelthread] Asus Rampage Extreme R.o.G. (Intel X48) [2]
[blockquote]
InhaltInhalt des Sammelthreads
Spezifikationen Spezifikationen
CPU
  • LGA 775 socket for:
    - Intel® Core™2 Extreme/Core™2 Quad/ Core™2
  • Supports Intel Enhanced Memory 64 Technology (EMT64T)
  • Supports Enhanced Intel SpeedStep Technology (EIST)
  • Supports Intel Hyper-Threading Technology
  • Supports 1600/1333/1066/800MHz FSB
Intel® chipset
  • Northbridge:
    - Intel® X48 Express chipset
    - Intel® Fast Memory Access technology
  • Southbridge:
    - Intel® ICH9R
Memory
  • 4 x DIMM, Max. 8 GB, DDR3 2000(O.C.)/1800(O.C.)/1600/1333/1066/800
  • ECC,Non-ECC,Un-buffered Memory
  • Dual Channel memory architecture
    *Overclock speed
    - Supports Intel® Extreme Memory Profile (XMP)
    - For the X.M.P. support, CPUs with FSB 1333 or above are recommended
Expansion Slots
  • 2 x PCIe 2.0 x16 , support at full x16, x16 speed
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
BIOS
  • AMI BIOS
  • 16 Mb Flash ROM
  • DMI 2.0
  • PnP
  • WfM 2.0
  • SM BIOS 2.4
  • ACPI 2.0a
  • Multi-language BIOS
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2
  • Support Teaming Technology
IDE
  • Marvell® 88SE6121 controller
    - 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
Serial ATA with RAID
  • Southbridge:
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • Silicon Image Sil5723 controller:
    - 2 x SATA 3.0 Gb/s port
    - Supports RAID 0, 1
Rear Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD SATA connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x LCD Poster connector
  • 1 x EL I/O Shield connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS slide switch
  • System panel connector
Accessories
  • Fusion Block System Accessory
  • Optional Thermal Kit for NB and MOS
  • DIY Pedestal
  • ASUS Optional Fan
  • External LCD Poster
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
Overclocking Features
  • Fusion Block System with optional thermal kit on MOS and NB
  • Extreme Tweaker
  • TweakIt
  • Extreme Engine
    - 16-phase CPU power design
    - 3-phase NB power design
    - 2-phase DDR3 power design
    - ML Caps on CPU, memory and NB respectively
  • Speeding HDD
  • iROG
  • BIOS Flashback
  • Loadline Calibration
  • Intelligent overclocking tools:
    - CPU Level Up
    - Memory Level Up
    - AI Gear 3 + ™
    - ASUS AI Booster Utility
    - O.C Profile
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Special Features
  • Onboard Switches: TweakIt / Power / Reset / Cls CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Form Factor
  • ATX Form Factor
  • 30.5cm x 24.5cm
BilderBilder
Verpackung & Accessoires
Layout
Zusatzkühler für den Betrieb mit Lukü montiert
Bauteile im Detail
Das BiosDas Bios
OC VerhaltenOC Verhalten
Vom Board bereitgestellte Spannungen im Bios:
  • CPU Spannung: 0.85v ~ 2.50v in 0.00625 Volt Schritten
  • CPU PLL Spannung: 1.50v ~ 3.00v in 0.013 Volt Schritten; Standard 1.50 Volt
  • FSB Termination Spannung: 1.10v ~ 2.00v in 0.013 Volt Schritten; Standard 65nm = 1.20 Volt / 45nm = 1.10 Volt
  • DRAM Spannung: 1.50v ~ 2.80v in 0.013 Volt Schritten; Standard 1.50 Volt
  • Northbridge Spannung: 1.25v ~ 2.05v in 0.013 Volt Schritten; Standard 1.25 Volt
  • Southbridge 1.05v Spannung: 1.05v ~ 1.96v in 0.013 Volt Schritten; Standard 1.05 Volt
  • Southbridge 1.50v Spannung: 1.05v ~ 2.05v in 0.013 Volt Schritten; Standard 1.50 Volt
  • NB DDRVref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
  • DDR3 Channel A/B Vref: -157.5mV ~ +200mV in 10mV Schritten; Standard [AUTO]
Biostemplate für das Extreme Tweaker Menü:
Code:
Ai Overclock Tuner:
OC From CPU Level UP:
OC From Memory Level UP:
FSB Frequency:
CPU Ratio Control:
- CPU Configuration:
- CPU Clock Skew:
- NB Clock Skew:
FSB Strap to North Bridge:
PCI-E Frequency:
DRAM Frequency:
DRAM Command Rate:
DRAM Timing Control:
- CAS# Latency:
- RAS# to CAS# Delay:
- RAS# PRE Time:
- RAS# ACT Time:
- RAS# to RAS# Delay:
- REF Cycle Time:
- Write Recovery Time:
- Read to PRE Time:
- Read to Write Delay(S/D):
- Write to Read Delay(S):
- Write to Read Delay(D):
- Read To Read Delay(S):
- Read To Read Delay(D):
- Write To Write Delay(S):
- Write To Write Delay(D):
- Write to PRE Delay:
- Read to PRE Delay:
DRAM Static Read Control:
DRAM Dynamic Write Control:
DRAM Skew Control:
- DRAM CMD Skew on Channel A/B:
- DRAM CLK Skew on DIMM A1/A2/B1/B2:
- DRAM CTL Skew on DIMM A1/A2/B1/B2:
Ai Clock Twister:
- Ai Clock Skew for Channel A:
- Ai Clock Skew for Channel B:
Ai Transaction Booster:
- Common Performance Level:
- Pull-In of CHA PH1:
- Pull-In of CHA PH2:
- Pull-In of CHA PH3:
- Pull-In of CHA PH4:
- Pull-In of CHA PH5:
- Pull-In of CHB PH1:
- Pull-In of CHB PH2:
- Pull-In of CHB PH3:
- Pull-In of CHB PH4:
- Pull-In of CHB PH5:
EPU II Phase Control:
CPU Voltage:
Load-Line Calibration:
CPU PLL Voltage:
FSB Termination Voltage:
- CPU GTLVref (0):
- CPU GTLVref (1):
- CPU GTLVref (2):
- CPU GTLVref (3):
North Bridge Voltage:
DRAM Voltage:
- NB DDRVref:
- DDR3 ChannelA Vref:
- DDR3 ChannelB Vref:
South Bridge 1.5 Voltage:
South Bridge 1.05 Voltage:
CPU Spread Spectrum:
PCIE Spread Spectrum:
Ein paar OC Ergebnisse von OnePageBook (OCX)
500FSB Everest & Orthos:
600FSB Everest & Orthos:
Speicher KompatibilitätslisteSpeicher Kompatibilitätsliste
2x1024MB Kits
  • 2x1GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x1GB Kit OCZ Intel Extreme PC3-12800
  • 2x1GB Kit Patriot Viper PC3-12800
  • 2x1GB Kit Patriot Viper PC3-14400
  • 2x1GB Kit Patriot Viper PC3-15000 (Micron D9GTR)
  • 2x1GB Kit TeamGroup Xtreem PC3-12800 (Micron D9GTR)
2x2048MB Kits
  • 2x2GB Kit Adata XSeries PC3-12800
  • 2x2GB Kit Chaintech APOGEE GT Blazer PC3-14400
  • 2x2GB Kit CompuStocx Diablo PC3-16000 (Micron D9GTR)
  • 2x2GB Kit OCZ Intel Extreme PC3-12800
Passende Kühler (Lukü)Passende CPU Kühler (Lukü)
Luftkühler:
  • Zalman CNPS 9500 AT
FAQFAQ
F: Wie funktionieren die GTL Einstellungen?
A: Beim Rampage Extreme funktioniert dies über einen festen GTL Multi und einer justierbaren Spannung (-155mV bis +155mV).
Die festen Multis sehen wie folgt aus:
  • CPU 0 = 0.635
  • CPU 1 = 0.67
  • CPU 2 = 0.635
  • CPU 3 = 0.67
Die GTL Voltage wird so eingestellt / berechnet:
  • VTT (FSB Spannung) x GTL Multi +/- xxx mV = GTL Spannung
  • 1.16v (VTT) x 0.635 (Multi) - 25mV (Spannung) = 0.7116v
F: Ist mein altes Backplate noch ohne weiteres nutzbar?
A: Aufgrund des zusätzlichen Fujitsu Chips auf der Rückseite des Sockels kann man nicht ohne weiteres jedes Backplate
nutzen oder man muss es bearbeiten. Für diejenigen die sich lieber ein passendes Kaufen weil sie nicht die möglichkeit
haben es zu bearbeiten hat der User "Navigator1" ein passendes rausgesucht, hier der Link zu dem passenden Post
DownloadsDownloads
Bios Downloads (Flashen auf eigene Gefahr!)
Treiber & restliche Downloads
[/blockquote]
Danke ,-)
Danke RonnyD für deine schnelle Antwort und Ausführliche Beschreibung, hast mir echt sehr geholfen!
Habe jetzt den Cpu auf 3995.1MHz
und den Ram auf 1566MHz
Leuft alles sehr stabil unter Prime95,3D Mark 06,Memtest.
Hoffe ich bekommen nächste woche meine ATI 5970!
Ich Habe mir noch etwas für meine WaKü gekauft, da ich nicht glaube das
1x120mm und 1x240mm Radiatoren für mein Komplettes System reichen!
Da die ATI 5970 ja schon eine Ordentliche Verlustleistung hatt.
Habe mich für den Cape Cora HF 642 entschieden, da ich in den Tests zu diesem Passivkühler gute Ergebnisse gesehen habe.
Der Verkäufer am Telefon meinte das der 642 eine Verlustleistung von
ca.300Watt Kühlen kann und somit mit einem 360mm Aktiv Radiator gleich zu setzen ist.
Ich werde den 642 an die seite von meinem Gehäuse schrauben.
Dazu habe ich noch einen 250mm Lüfter von Sharkoon Bestellt, den ich an den Cape Cora HF 642 Radiator montieren möchte um die Leistung zu erhöhen.
Hoffe somit die Komponenten gut Kühlen zu können!
Hier noch mein Bios Template-->
Rampage Extreme 1202 Bios Template
Extreme Tweaker
Ai Overclock Tuner: [Manual]
OC From CPU Level UP: [Auto]
OC From Memory Level Up: [Auto]
FSB Frequency: [470]
CPU Ratio Setting: [8.5]
CPU configuration:
CPU clock skew [Auto]
NB clock skew [Auto]
FSB Strap to North Bridge [400]
PCIE Frequency [100]
DRAM Frequency [1566]
DRAM Command Rate [2N]
DRAM Timing Control [Manual]
1st information
CAS# Latency [6]
RAS# to CAS# Delay [8]
RAS# PRE Time [6]
RAS# ACT Time [24]
RAS# to RAS# Delay [Auto]
REF Cycle Time [Auto]
WRITE Recovery Time [Auto]
READ to PRE Time [Auto]
2nd information
READ to WRITE Delay(S/D) [Auto]
WRITE to READ Delay(S) [Auto]
WRITE to READ Delay(D) [Auto]
READ to READ Delay(S) [Auto]
READ to READ Delay(D) [Auto]
WRITE to WRITE Delay(S) [Auto]
WRITE to WRITE Delay(D) [Auto]
3rd information
WRITE to PRE Delay [Auto]
READ to PRE Delay [Auto]
PRE to PRE Delay [Auto]
ALL PRE to ACT Delay [Auto]
ALL PRE to REF Delay [Auto]
DRAM Static Read Control [Disabled]
DRAM Dynamic Write Control [Disabled]
DRAM Skew Control :
DRAM CMD Skew on Channel A [Auto]
DRAM CLK Skew on DIMM A1 [Auto]
DRAM CLK Skew on DIMM A2 [Auto]
DRAM CTL Skew on DIMM A1 [Auto]
DRAM CLT Skew on DIMM A2 [Auto]
DRAM CMD Skew on Channel B [Auto]
DRAM CLK Skew on DIMM B1 [Auto]
DRAM CLK Skew on DIMM B2 [Auto]
DRAM CTL Skew on DIMM B1 [Auto]
DRAM CTL Skew on DIMM B2 [Auto]
Ai Clock Twister [Moderate]
Ai Transaction Booster [Manual]
(-- Manual --)
Common Performance Level [10]
Pull in of CHA PH1 [Disabled]
Pull in of CHA PH2 [Disabled]
Pull in of CHB PH1 [Disabled]
Pull in of CHB PH2 [Disabled]
(-- Manual --)
EPU II Phase Control [Auto]
*** Please key in numbers or select voltage!***
CPU Voltage [1.3625]
Load-Line Calibration [Auto]
CPU PLL Voltage [1.51106]
FSB Termination Voltage [1.31]
CPU GTLVref(0) [+90mV]
CPU GTLVref(1) [+50mV]
CPU GTLVref(2) [+90mV]
CPU GTLVref(3) [+50mV]
NB GTLVref [+60mV]
North Bridge Voltage [1.45]
DRAM Voltage [1.65]
NB DDRVref [Auto]
DDR3 Channel A Vref [Auto]
DDR3 Channel B Vref [Auto]
South Bridge 1.5 Voltage [1.51106]
South Bridge 1.05 Voltage [1.06039]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
C1E Support: [Disabled]
CpU TM Function: [Enabled]
Max CPUID Value Limit: [Disabled]
Vanderpool Technology: [Enabled]
Execute Disable Bit: [Enabled]
Core MultiPprocessing: [Enabled]
Bitte Bitte, keine Ursache......... ;)
Die 5970 ist der Knaller, ein Freund von mir hat die XFX 5970 Black Edition mit OV Tool, das Ding geht ohne Ende, mit dem Q9550 kannst du sie schön befeuern. :bigok:
Auf den neuen Cape Cora HF 642 Konvekt schwarz in überarbeiteter Ausführung und HF bin ich mal gespannt......... :)
Ich verwende extern den Mora 2 Pro mit 9 Yate Loons......... :d
Template ist soweit in Ordnung und Prime stable ist er auch, also alles bestens. :bigok:
Lass mal paar Benchmarks rüberwachsen, wenn du das Monster drin hast.
Ja werde ich machen!
Ich lasse dan am Besten die 3D Mark Vantage drüber laufen.
Wollte die Radeon HD 5970 von Sapphire mit dem Redline OC Tool von Sapphire auf 2x850MHz Bringen, soll mit WaKü laut Test ohne Probleme gehen!
Habe den WaKü-Block schon!
Hier sind zwei Bilder
Der Kühler ist sehr gut verarbeitet!
Jetzt fehlt mir nur die Karte:(
Hoffe nur das sie nächste Woche kommt!
Habe die 5970 für 536€+Versnd und Nachnahmegebühren Bestellt was sehr günstig ist! Denn bei andern Shops ist die Karte erst ab 550 zu bekommen
So habe noch ein kleines Problem wegen dem OC, der PC läuft in den Tests stabil, aber sobald ich Spiele wie z.B. ArmA2 zocke bekomme ich ein komplett Freeze des Systems und muss neu Starten!
Wie kann ich das beheben?
Braucht irgendwas mehr Volt?
Meinst du ich sollte lieber den Mora 2 Pro mit dem 250mm Lüfter betreiben will keine 9Lüfter ,-)
Danke dir schonmal für deine Antwort :banana:
Vom Feinsten, der Block........ :bigok:
Das mit dem Mora ist so ne Sache, ich persönlich würde ihn auf jeden Fall dem Cape vorziehen und der 250er Lüfter ist ausreichend.........
wegen der Sache, die ich meinte, noch im April soll der Mora 3 Pro kommen, was er kann und wie er es kann, steht noch in den Sternen.
Aber der M2P ist, wenn man nicht immer das neueste haben muss, absolut ok und ein Kühlkraftwerk, das man nicht in die Knie zwingen kann.
Kannst ihn für noch paar mehr Grade auch mit nem 360er betreiben...... ;)
360mm Silent LED Case Fan - Rexus Corp - Huge selection Panaflo NMB-MAT by Panasonic
Ja Prime stable ist nicht gleich Game stable......... :(
Teste mal immer nur einzelne Spannungen, ob es damit behoben ist, anfangen mit Vcore, dann Vtt, dann NB usw. immer nur eine Nuance hoch, falls Freeze nochmal hoch und wenn wieder Freeze nochmal hoch, bei z. B 1.3625 Vcore bis 1.45 hoch, was Intel frei gibt usw.
Wie gesagt einzelne Spannungen, damit du dich am Ende nicht verrennst. ;)
Okay den Den Cape cora habe ich erstmal abbestellt!
Habe jetzt den Mora 2 Pro Bestellt für 118,89€!...:)
Dazu noch einen Besseren Ausgleichsbehälter
Und ein neues Pumpenflügelrad, mal kucken was das bringt;)
Der 360mm Lüfer ist FETT!!!:)
Leider aber nirgends zu haben (auser in Amiland) naja der 250mm wirds wohl auch tun:) auserdem glaube ich das mein Pc dan abhebt bei dem 360mm das ding ist total Krass!
Hat wer das Handbuch auf Deutsch für das Board, bei Asus kann ich es nicht finden. Und mein Bruder ist der Sprache nicht mächtig und ich habe da keine Lust ihm alles übersetzen.
@ Feldi123 :bigok:
@Zanzza
Mir ist nichts bekannt, dass es das REX Manual jemals in German gegeben hat...... ;)
Bei mir beim Installieren von win7 stürtzt es ab oder bleibt bei 82% hängen.
Bei mir war W7 Ruck Zuck aufgesetzt, keinerlei Probs, weder damals auf der F3 noch danach auf der Intel X-25-M G2 Postville SSD. :bigok:
Hast du eine funktionierende Internetverbindung ?????
.....nach der Produkt-Key Eingabe und Haken zur automatischen Aktivierung wird diese nämlich gebraucht !!!!!!!! ;)
Falls nicht, bleibt er an diesem Punkt hängen. ;)
Wenn überhaupt nichts geht, würde ich mit dem alten BS das System mal auf Stabilität testen. ;)
Ich habe jetzt nur einen Speicher verbaut und vorher mit zwei blieb es bei 98% hängen. Ob es am Speicher liegt der war die ganze Zeit in anderem System drin ohne Probleme.
Wenn du nur einen Dimm benutzt, dann darfst du ihn entweder nur in B2 oder A2 fahren.........
Bei Dual Channel nur B2 / A2
oder bei 4 Dimm's B2 / A2 / B1 / A1
schau mal in CPU-Z nach dem JEDEC des RAM und ob er so im Bios läuft..... ;)
Weil das die empfohlenen Memory Konfigurationen sind........... ;)
Ok, Danke. Ich habe es jetzt nur mit einem Speicher versucht und bis jetzt läuft, jetzt mache ich das wieder mit zwei aber dann in B2 / A2 . Und wenn läuft mache die ganzen Treiber und rest drauf.
bis jetzt geht alles aber öfters nach einer Zeit bekomme ich ein bluescreen. Gibt es ein Programm womit ich es auslesen kann.
Lass doch mal Prime laufen, ob/wann er aussteigt........ ;)
Prime95 Download - ComputerBase
Hier kannst du die STOP Meldungen und ihre Bedeutungen einsehen........ ;)
http://www.jasik.de/shutdown/stop_fehler.htm
Hier habe ich noch ein Progi (habs gestern nicht mehr auf die Schnelle gefunden) mit dem du die BS in den Dumptexten des Progis bzw. deren Verursacher sehen kannst.
Das Tool laden und die Daten im Minidump auslesen. Neustart bei Bluescreen sollte man vorher natürlich ausstellen.
http://www.nirsoft.net/utils/blue_screen_view.html
also bis jetzt läuft, auch keine weiteren Bluescreen´s. Habe bis jetzt noch alles auf Standard eingestellt. Bei dem Board kann man aber schon vieles einstellen, das ist im vergleich zu X58 oder 790i großer unterschied.
hi ihr lieben,fogendes problem bei system was in signatur steht.
Bios einstellungen: Ai Overclock Tuneer X.M.P: 1600MHz 7-7-7-28 aN-1,90v
:CPU Ratio Setting 10
:C1E Support Aktiviert läuft auf 4,02 GHz im IDL @2402.6MHz
:FSB speed 1608 MHz
:CPU Voltage 1,30625v
:CPU PLL Voltage 1,53756v
:North Bridge Voltage 1,43147
:dRAM Voltage 1,90856v
:South Bridge [1,5 voltage] =1,5118v
:South Bridge [1,05 voltage] = 1,06039
Restliche einstellungen stehen auf AUTO
Voltage Monitor im Bios:
:Vcore Voltage 1,283v
:CPU PLL Voltage schwangt zwischen 1,528-1,535v
:FSB Termination Voltage 1,197v
:dRAM Voltage schwangt zwischen 1,898-1,905v und wird Rot!
:dRAM VTT Voltage schwangt zwischen 0,946-0,952v
:North Bridge[1,25 Voltage] 1,409v
:12v Voltage 12,152v
:5v Voltage 5,088v
:3,3v Voltage 3,296v
Core Temp sagt Core#0 39 grad und Core#1 30 grad,hab Prime 15 min laufen lassen keine probleme doch nun hab ich bei Bfbc 2 oder WOW bluescreens
http://img364.imageshack.us/img364/6489/blue1.jpg
http://img718.imageshack.us/img718/4643/blue2.jpg
http://img717.imageshack.us/img717/1658/blue3s.jpg
http://img16.imageshack.us/img16/7821/blue4t.jpg
hoffe mir kann jemand helfen würde gern bei den 4,02 GHz bleiben:) soll halt nur stabil laufen,wenn noch infos fehlen sollten reiche ich die gern nach wüsste jetzt spontan nich was fehlt. achso,mmtest lief auch wie butter durch.
mfg ich
läuft auf windows 7 Ultimate
.......hab Prime 15 min laufen lassen keine probleme doch nun hab ich bei Bfbc 2 oder WOW bluescreens
Bei dir steigt immer wieder ein Kernel aus...........
15 min Prime95 sind definitiv zu kurz und null aussagekräftig. ;)
Ich verlinke dir mal ein Prime how to nach dem du vorgehen kannst, mache die verschiedenen Tests Small FFTs: In-place large FFTs: usw. und schaue, wo er aussteigt, zu den einzelnen Tests wird angegeben, was für eine Spannung es sein könnte, mach aber nicht den Fehler und drehe an mehreren Spannungen, sonst weißt du bei erneutem aussteigen nicht was es war.
http://www.hardwareluxx.de/communit...inen-pc-stabil-nach-ocen-teil-2-a-687885.html
bist einfach nen super kerl vom fach,danke dir werde das mal machen,mal schauen werde mich melden.
---------- Beitrag hinzugefügt um 16:49 ---------- Vorheriger Beitrag war um 16:46 ----------
RAM VTT Voltage schwangt zwischen 0,946-0,952v das verwirrt mich sobald er im Ram VTT auf die 0,952v steigt is er im ram voltage auf 1,905v die dann halt rot sind wie schon geschrieben,der ram soll aber mit 1,9v gefahren werden laut ocz
Danke Pansengulasch für die Blumen.......... :d
Du hast ein Signal (Daten) die durch eine Spannung repräsentiert wird. Jetzt muss, damit man diese Spannung als Daten nutzen kann , unterschieden werden, ob es sich dabei um eine 1(High) oder eine 0(Low) handelt.
Du hast als Ausgangswert die Vdimm, die beispielsweise 1.8V beträgt. Nur wie willst du nun bei Spannungen zwischen 0 und 1.8V festlegen was nun datenmäßig 0 oder 1 ist. Hier fehlt etwas! Genau das fehlende Glied ist somit die DRAM VTT, die normalerweise fest bei 0.5 x Vdimm steht (also bei 1.8V ist sie 0.9V und bei 2.1V ist sie 1.05V usw.). Anhand dieser Spannung wird nun entschieden was High und was Low ist. <Low und >High."
So jetzt noch mal zum Praktischen !!!
Kannst aber auch mal ohne XMP Profil ocen und RAM von Hand einstellen mit 333er oder 400er Strap.
Darüber hinaus stimmt da irgendwas nicht wegen roten Voltages, normalerweise bollert er locker noch gelb bei über 2.0V VDimm
Bild: dsc01457qan.jpg - abload.de
Liegt iwi an XMP meiner Meinung nach.
Wie gesagt, machs raus und oce oldschool. :wink:
ATI 5970 auf WaKü umrüsten!!! + Asus Rampage Extreme
y:haha::);)Tag zusammen habe jetzt endlich eine ATI XFX HD5970 bekommen :love:
Hier mal für alle die nicht wissen wie es geht oder zum ersten mal machen (wie ich)
Umbau von der Grafikkarte auf Wasserkühlung!
Schritt [1]
Alles auspacken und freuen :banana:
Danach alles was zum Umbau benötigt wird bereit legen (Kleiner Kreuzschlitz,mittlerer Kreuzschlitz,Imbus,Schraubenschlüssel,Anschlüsse,Graka,Kühler,Wärmeleitpads,Küchenpapier,Wärmeleitpaste/nicht leitende!)
Schritt [2]
Rückplatte entfernen :hail:
Mit dem mittleren Schlitzschraubenzieher die Schrauben langsam aber mit Kraft von der Rückplatte lösen. (über Kreuz)
Anschließend die kleinen Schrauben mit dem kleinen Schlitzschraubenzieher lösen, und nur noch die Schrauben von der Slot blende entfernen.
Jetzt sitzt die Rückplatte locker und kann entfernt werden!
Schritt [3]
Entfernen der Haltebügel :asthanos:
Nun vorsichtig mit dem Schraubenzieher umgehen, und nicht abrutschen!
Langsam die schrauben über Kreuz lösen, dabei mehrmals die Schraube wechseln nicht auf einmal raus drehen!
Schritt [4]
Entfernen des Standard-Kühlers :stupid:
Langsam den Kühler vom PCB (Karte) anheben, dann vorsichtig seitlich bewegen damit sich die festgeklebten Kühlpads vom Kühler lösen.
Dabei sehr vorsichtig vorgehen es braucht keine große Kraft nur etwas Gewackel und Geduld!
Schritt [5]
Entfernen der Kühlpad Reste und der Wärmeleitpaste :coolblue:
Vorsichtig mit etwas Küchenpapier den größten teil der Wärmeleitpaste entfernen, danach mit einem Stück Plastik (am besten aus einer alten Verpackung schneiden) vorsichtig den Rest der Wärmeleitpaste vom Rand der GPU´s nehmen.
Die Klebereste auf den Speichern und Spannungswandlern entfernen,falls vorhanden mit Küchenpapier.
Schritt [6]
Auflegen der Wärmeleitpads :cool:
Erst die Plastikfolien von dem Wärmeleitpad entfernen, dann vorsichtig auf die Speicher und den Chip legen.
Schritt [7]
Schritt [8]
Schritt [9]
Nicht leitende Wärmeleitpaste großzügig auf beide GPU´s auftragen.
Schritt [10]
Auflegen des Wasserkühlers :rolleyes:
Den Wasserkühler mit den Bohrungen übereinstimmend auf das PCB (Karte) legen.
Dann wird die Karte mit Wasserkühler umgedreht zum verschrauben,
jetzt können die Imbusschrauben mit Unterlegscheibe um die GPU´s eingesetzt, und nur zur Hälfte ein gedreht werden.
Schritt [11]
Auflegen der Rückplatte :wink:
Die Rückplatte einfach wieder auf die Karte, passend zu den Bohrungen legen. Danach die Schrauben einsetzen und wieder bis zur Hälfte verschrauben!
Nachdem alles soweit vorbereitet ist können die Schrauben um die GPU´s verschraubt werden.
Wieder über Kreuz fest ziehen, aber nicht zu fest!
Jetzt werden die Schrauben der Rückplatte verschraubt wie immer über Kreuz und nicht zu fest!
Schritt [12]
Einbau der Karte :shot:
Nun kann die Karte einfach in euren PCIe Slot gesteckt werden.
ACHTUNG beim Asus Rampage Extreme ist beim oberen PCIe Slot der Kühler im weg, so dass die Karte nicht bis zum Anschlag eingesetzt werden kann!:grrr:
LÖSUNG einfach die Karte in den unteren PCIe Slot stecken!!!:rolleyes:
Um das ganze zu Kühlen habe ich einen Mora2 Pro an die Seite von meinem Gehäuse gebaut und mit 4 x 180mm Lüftern von SilverStone versehen.
Danke RonnyD!
Habe es mal in das Wasserkühlungs Thema der 5970 Geschrieben ,-)
hey,
gibt es mittlerweile eine Lösung um die dem Board beiliegende "X-Fi" unter Win 7 zu betreiben?
danke für eure hilfe! :)
mfg,
Mexxim
Ist mein Benchmark net nice!?
Webbie!
