[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [5]
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
  • Bios 1704
    - Support new CPUs.
  • Bios 1802
    - Support new CPUs.
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
Hi!
hab da eine Frage: kann ich im Bios SMT aktivieren?! Wo liegt eigentlich der Unterschied zwischen SMT und HT ?! Ich glaube bei meinem Board kann ich nur HT aktivieren... :(
SMT = HT
ist ist ein und das selbe ;)
seit gestern läufts mit 1914
das problem mit der PCIE-16x habe ich aber leider immer noch:
hin und wieder habe ich nach einem neustart nur PCIE 1x, 2x, 4x oder 8x anstelle von 16x
grafikkarte ist eine 5870er!
mögliche lösungsvorschläge??
Mit welchem Programm liest du die Pci-Anbindung aus. Merkst du es auch an der Performance? Steckt die Karte richtig? Welchen Pci-e belegst du, eigentlich ersten logischerweise oder? Was für Karten stecken evtl in den anderen Pci-e Slots?
auslesen tu ich es mit CPU-Z, aktuelle version (vcore wird nicht angezeigt)
bei der performance fällts schon auf - Left 4 Dead2 hat slowdowns wenn z.b. nur PCIE 2x angezeigt wird - zumindest kommt es mir so vor.
die karte steckt im obersten PCI-E anschluss!
ansonsten ist nur die mitgelieferte soundkarte verbaut. sämtliche andere PCI und PCI-E slots sind leer.
die karte müsste schon richtig drinstecken - sonst würde ja garnix gehen.
ich schalte den PC übrigens mittels stromleiste nach gebrauch immer stromlos.
edit: deine signatur hat mich gerade auf eine unvernünftige idee gebracht => 5870 crossfire :d
Hmm komische Sache. Vermute ja in erster Linie dass CPU-Z falsch ausliest evtl. Werde morgen mal testen was bei mir so angezeigt wird.
Signatur änder ich gleich. Ist nur noch eine 5870 drinne. Warte ab ob's ne 580 GTX oder AMD 6970 wird:-)
habe gestern abend mal wieder etwas zeit für den PC gehabt.
ich bin jetzt mit der vcore herunten auf 1,17v bei last @ 3800Mhz - vorher war ich irgendwo bei +1.25
die aktuellste CPU-Z version liest die vcore nicht aus - deshalb hab ich nochmal die vorletzte installiert. bei der wurde die vcore ausgelesen. und bei den letzten ~5 neustarts wurde immer PCIEx16 angezeigt.
vielleicht kannst du das auch mal ausprobieren - einmal mit CPU-Z 1.56 und dann mit 1.55
Ja teste ich mal. Bin aber noch @Work bis heute Abend.
Sagt mal wieviel IOH Voltage braucht ihr so für 200er BCLK. Bin so bei 1.13V im Bios. Teste grade 1913 und wollte auf meine vorigen Referenzwerte verzichten.
Bin etwas ausm übertakten rausgekommen, aber IOH ist doch zu 90% für max BCLK zuständig oder?
Gibt es irgendwelche Gründe aufs 1914 zu wechseln? Mich interessiert besonders maximaler Ramtakt bzw Uncore.
Grüße!
Gibt es eine Übersicht was man Einstellen muss, um einen Core i7-920 zu übertakten?
Dies ist ja nun schon der 5. Thread zu diesem Board und ich finde hier nicht die alten Seiten.
Wie man beim Übertakten vorgeht ist mir klar, keine Sorge.
Bräuchte nur mal nen Anstoss für die Werte im Bios:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
CPU Clock Skew:
IOH Clock Skew:
Vielleicht kann mir ja jemand mal seine Werte zeigen zum Vergleich.
es liegt an den rog boards
ich habe vom entwickler eine CPU-Z ROG Board version bekommen die die vcore wieder korrekt anzeigt darf diese aber noch nicht veröffentlichen
CPU-Z 1.55 funktioniert auch...soweit
die 1.56 hat bei mir core voltage bis über 60V angezeigt :fresse:
Hast du bei Asus zu den Bios Entwickler connections?
So habe mal beide CPU-Z Versionen getestet und bei mir werden immer 16 Lanes angezeigt.
Bin noch am testen von 1913 aber scheint keine großen Verbesserungen zu geben. Vcore brauch ich genauso viel und Uncore komm ich trotzdem nicht weiter. 3800 Uncore mit Krampf und 4000 mehr oder weniger impossible. Aber das liegt wohl anner CPU halt.
Bin ja total heiß auf nen Gulftown, aber die Preise schocken mich. Habe mir vorgenommen Sandy Bridge zu überspringen, es sei denn der Leistungzuwachs wäre extreme. Habe auch keine Lust auf USB 3.0 und den ganzen Zusatzkontroller Müll. Ja mein RIIE und ich^^
Hat jemand Erfahrung hier mit nem 980 970? Wie lassen die sich takten und wie sieht's mitm Uncore aus. Machen die i.d.R 4000 uncore mit?
Uncore ist die Spannung, um die Cpu rum, mal einfach gesagt.
Hier kannst du mal schauen und es nachlesen, ist sehr gut beschrieben. [How To] Overclock Core i7
Habe nun erste Versuche mit meiner Cpu hinter mir, aber irgendwie will das nicht so recht...
Extreme Tweaker
CPU Ratio Setting: 19
BCLK Frequency: 211
PCIE Frequency: 107
DRAM Frequency: 1691Mhz
UCLK Frequency: Auto
QPI Frequency: Auto
EPU II Phase Control: Aktiv
Loadline Calibration: Deaktiviert
CPU Differential Amplitude: Aktiviert
Extreme OV: Deaktiviert
CPU Voltage: 1,25V
CPU PLL Voltage: 1,81xxx V
QPI/DRAM Core Voltage: 1,2625V
IOH Voltage: 1,219V
IOH PCIE Voltage: 1,524V
ICH Voltage: 1,153V
ICH PCIE Voltage: 1,524V
DRAM Bus Voltage: 1,6581V
CPU Spread Spectrum: Auto
PCIE Spread Spectrum: Auto
CPU Clock Skew: Auto
IOH Clock Skew: Auto
DRAM Timing Control
DRAM CAS# Latency: 9
DRAM RAS# to CAS# Delay: 10
DRAM RAS# PRE Time: 9
DRAM RAS# ACT Time: 20
Cpu: W3520 (A366) Screens 4GHz 4,2Ghz 4,4Ghz
RAM: Kingston HyperX 2000Mhz Cl9
Möchte eigentlich nur die 4,0Ghz vorerst anpeilen.
Ob nun mit 21*191 oder 19*211 weis ich noch nicht.
Wenn ich 191 BCLK nehme, könnte ich den RAM auf 19414Mhz laufen lassen, theoretisch.
Aber fakt ist, mit meinen geposteten Einstellungen ist das Ding nicht stabil, 40Sekunden Prime Small und es hängt und endet mit nem Bluescreen..
@xXRadioaktivXx
Nimm 200x20 und hau den Uncore mindestens auf 3600 oder 3800. Je nachdem wieviel QPI du dafür brauchst. Der Ramtakt ist ehrlich gesagt kaum interessant.
Uncore ist UCLK im Bios und regelt kurz gesagt den Durchsatz vom Ram oder den Speed halt.
Hab nun etwas rum probiert. Es will aber nicht, egal wie ich es anstelle..
Code:
BCLK Frequency: 211
PCIE Frequency: 102
UCLK Frequency: 3592Mhz
QPI Frequency: 3804Mhz
CPU Voltage: 1,25V
CPU PLL Voltage: 1,811xx V
QPI/DRAM Core Voltage: 1,2875V
IOH Voltage: 1,179V
ICH Voltage: 1,153V
CPU Spread Spectrum: Deaktiviert
PCIE Spread Spectrum: Deaktiviert
DRAM Timing Control
DRAM RAS# ACT Time: 27
Mit diesen Einstellungen freezt prime small schon, wenn ich small auswählen und okay klicke. Linx freezt schon, wenn nichtmal alle Kerne unter Last sind, genauer gesagt wenn 1 Kern 100% Load hat... Kann es auch an meinem Speicher liegen? Hab den Kingston HxperX 2000Mhz Cl9 verbaut.
Hi Leute,
hab mir neuen Speicher gekauft, Patriot Viper II Sector 7 DIMM Kit 12GB PC3-12800U CL7-9-7-21. Wollte nur bescheid geben das der Speicher perfekt mit dem R2E läuft. Für die Leute die aufrüsten wollen ;-)
Mal ne andere Frage warum bekome ich meinen 920 D0 nicht mit 4000MHZ stabiel ?
Mit 3900MHZ läuft er ohne Probleme.
CPU Ratio Setting: 20
BCLK Frequency: 195
PCIE Frequency: 105
DRAM Frequency: 1562Mhz
UCLK Frequency: 3124Mhz
QPI Frequency: 3515Mhz
Loadline Calibration: Aktiv
CPU Differential Amplitude: Auto
CPU Voltage: 1,28V
QPI/DRAM Core Voltage: 1,32V
IOH Voltage: 1,20V
IOH PCIE Voltage: 1,51V
ICH Voltage: 1,20V
ICH PCIE Voltage: 1,51V
DRAM Timing Control
DRAM CAS# Latency: 7
DRAM RAS# to CAS# Delay: 9
DRAM RAS# PRE Time: 7
DRAM RAS# ACT Time: 21
Das sind meine Einstellungen für das 3900 MHZ Settup. Wenn ich bis 400MHZ gehe dann ändere ich den BCLK auf 200 und hab schon einiges versucht an VCore auch ohne LLC bin da so bis 1,38V gegangen. Gibt es evtl. irgendetwas was ich übersehen habe ? mit dem 3900MHZ Setup hab ich unter Prime auf zwei Kernen max 80°C. Hier ist auch schon die Grenze erreicht, aber denke über eine Wasserkühlung nach. Naja hatte die CPU Pretestet gekauft und sie soll 4000MHZ machn find ich schon zum kotzen das ich selbst hier eine schlechte erwischt hab. Andere machen unter Luft schöießlich 4200 MHZ. Wäre nett wenn mal einer einen Vorschlag machen könnte.
Jaja ohne LLC auch schon probiert. Krass eh hab heute meinen Rechner gestartet kam Fehlermeldung beim einloggen ins Win 7 " dieser Speicher verweist auf 00 irgendwas " und dann nen blauen bekommen. Ok dann lässt dr sich wohl nicht mit 1T sondern nur mit 2T betreiben. Der hat auch ziemlich Stress gemacht als ich die Timings von 7.9.7.21 auf 7.8.7.21 gesetzt hab, kammen in Prime nach paar Minuten sofort fehler.
---------- Beitrag hinzugefügt um 12:08 ---------- Vorheriger Beitrag war um 12:07 ----------
@Octacore wie sähe denn ein wirklich gutes Setup ohne LLC aus ? Kein großer unterschied ausser mehr Spannung geben oder ?
Hat jemand hier die Kingston HyperX 2000Mhz Cl9 auf dem Brett verbaut?
Ich glaube, dass die nicht mit dem Board warm werden und meine Cpu deswegen nicht stabil wird.
@Rimbado
thx :)
Moin Mädels!
Hab mich ja schon so ewig nicht mehr mit OC beschäftigt, mir dennoch aber eine Frage gestellt...
Ich hörte letztens mal wieder etwas zur Loadline Calibration und dass dessen deaktivierung gesünder für die CPU sei. Man solle LLC nur für die Findung der stabilen Vcore nutzen im OC, aber für die 24/7 Settings den Wert der Vcore finden, die die CPU für Stabilität braucht. Dann unter deaktivierter LLC die Vcore so hoch einstellen, dass der ermittelte Wert mit VDroop immernoch erreicht wird. Was ja dann bedeutet, dass maneine generelle höhere Abwärme im Idle hätte, unter Last allerdingsansich eher nicht, da der Wert ja eh wieder dropped. Das soll vermeiden, dass die anfallenden Spannungsspitzen, beim Last-Idlewechsel anfallen so niedrig wie möglich (durch den Vdroop) gehalten werden und somit der CPU weniger Schaden verursachen.
Ist das so korrekt? Schade ich meiner CPU somit permanent durch eine standardmäßig aktivierte LLC?
naja das glaube ich eher weniger
vdrop ist dsas was man nicht will um einen stabilen proz zu haben
warum sollte ich es wieder aktiveren ?
der vdrop geht meistens nach unten
sagen wir ich brauche 1,2V für 4GHz stabil
stelle die 1,2V ein aktiviere LLC
wenn ich aber LLC wieder deaktiviere muss ich evl auf 1,28 oder mehr stellen weil er aus lange weile mal einbricht auf unter 1,2V ich finde die spanne die manche boards beim vdrop haben einfach zu groß als das ich LLC deaktiviert lasse
eine konstante spannung ist immer besser als eine schwankende, spannungsspitzen treten doch bei der schwankenden viel eher auf als bei einer konstanten
auf meinem r2e hatte ich mal 1,38V laufen und ohne llc ist die vcore bis auf 1,3V runter, das ist nicht gerade forderlich für einen stabilitätstest :/
Die quasi unmessbaren hohen Spannungsspitzen treten immer auf. Dein Equipment wird wohl nicht reichen, um die zu messen. Daher ist der Vdroop gewollt. Lies mal im www nach loadline calibration. Dann wirst du es verstehen. Allerdings wollte ich damit gerne wissen, wie die meisten damit umgehen.
Hallo zusammen,
Ich weiß nicht warum aber bei mir lässt mein Pc keine veränderungen via OC stabil laufen, sobald ich etwas übertakte kommen fehler, nicht in Form von Prime stürzt ab oder so..... Installationen zeigen Fehler, spiele laufen schlecht. Ich weiß nicht mehr weiter.
Mein System
i7 920 D0
G.skill Trident 6gb 1600 CL6
GTX 470
Bios 1804
Meine übertaktungsversuche waren immer sehr vorsichtig, spannungen wurden immer auf standart gehalten ausser VCORE max 1,3.
selbst bei ergebnissen 3 ghz war der pc unstabil
bitte um Rat
@ Madmax
Aber auf Standard Takt läuft alles oder wie? Eventuell den RAM vergessen per Teiler runterzutakten? Ram versagt mal gerne auch leicht über den Spezifikationen. Ansonsten mal IOH etwas anheben. Eventuell Auch QPI Wegen Ram. Ist halt nicht so einfach auf die schnelle zu beantworten. Gibt da viele Möglichkeiten.
Oh das ging aber schnell :)
Ja mit dem Ram teiler hab ich auch schon probiert. Es ist sehr blöd, hab mir extra alles gekauft um ein wenig zu übertakten und naja kommt nix bei rum.
Ja bei allem auf Auto läuft alles.
Ioh erhöhen hab ich nicht nicht probiert. Wie schon gesagt hab alles von Auto auf standart Werte gestellt, Vcore auf VID Höhe aus Cpuz 1,29vcore, und auf 3,2ghz übertaktet. Prime Memory84 läuft alles ohne Probleme, aber sacred 2 installation meldet Fehler, Patch auch.
Mit dem Arbeitsspeicher hab ich aber auch so meine Probleme.... wird manchmal selbst bei Default Einstellungen nur teilweise erkannt. 2gb manchmal 4gb aber auch mal 6gb ;)
Hab auf allem noch Garantie, wüsste aber nicht wo ich anfangen soll bzw ob es normal ist.
CPU ist plan geschliffen, ist das vor das Problem?
Gruß Max
Sent from my iPhone using Hardwareluxx
Okay auch wenns müsam ist wäre es ganz gut wenn du mir mal deine kopletten Einstellungen ausm Extreme Tweaker postest. Beim Ram problem besteht die Möglichkeit das Problem zu beheben indem du den CPU Kühler etwas lockerst. Hatte ich auch mal und danach wars weg. Natürlich nicht zu locker. Paar Umdrehungen bzw nach Gefühl.Wie Kühlst du deinen Prozessor? Luft, Wasser?
Das bekommen wir schon in den Griff:-)
