[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [5]
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
  • Bios 1704
    - Support new CPUs.
  • Bios 1802
    - Support new CPUs.
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
Danke, sonst muss ich nichts machen?
Geht nämlich noch nicht mit dem Programm auf meinem HD2 den PC zu starten
Doch, du musst "Wake up on PCIe" noch aktivieren, da der LAN Chip am PCIexpress dran hängt.
Quisa
wie kann ich bei dem mainboard sockel pins am besten wieder hoch biegen gibt es da irgendwelche hilfsmittel???
ne gute lupe die ordentlich vergrößert,dann ne nadel oder was fein genug ist (am besten aus plastik weil es nicht leitet) und ne ruhige hand. mehr eigentlich nicht
also ich hab das board jetzt am laufen aber es ist sind zwei probleme aufgetreten erstes problem ich kann irgendwie win 7 nciht installieren und dann noch werden die usb tastatur und die maus nciht erkannt ich kann nciht ins bios garnichts liegt das vllt am Netzteil????
bitte um hilfe
mein system
asus rampage 2 extreme
core i7 920 C0
Corsair 6x2GB XMS3 1333MHz
Nvidia GTX 480
Samsung 500GB
Samsung 1TB
550watt LC Power
Win 7 64bit
Hi leute hab das neuste Bios draufgeflached 1914.
Lief durch 1a jedoch beim neustarrt machte er CMOS ERR.
dachte mir WOW SUPER.
Batterie raus strom raus nach 30 min ging alles cmos war sauber alles eingestellt und lief.
Muss ich mir jetzt irgendwie im nachhinein gedanken machen? weil eig lief der immer 1a.
Seit heute macht er INIT ROM und blieb hängen war seit 2 Jahren das erste mal mit INIT ROM und blieb hängen, nach einen neustart ging wieder alles.
Kann mir einer was zu den 2 sachen da oben sagen?.
PS: Eben ist mir was neues Passiert hab XMP mal auf profil 2 gestellt da stellt er die neuen rams auf 1.5V was die neuen so brauchen und QPI auf 1.20 bekomme da nen bluescreen.
Jedoch wenn ich Profil 1 nehme und da stellt er nur die QPI auf 1.35 dann rennt er WIESO? macht das ein dicken unterschied bzw soll es eh net unter 1.25 sein?
hi Leute,
ich habe ein problem seit gestern geht mein rechner nicht mehr an!!! Wenn ich den Strom anmache dann blinkt das Board! (die Soundkarte, die Leuchte unten an den USB Connectoren, und die weisse belüftung blinkt),.... ich habe keinen schimmer was das sein soll,... von einen auf den anderen tag,...
HILFE
Hatte ebenfalls das 1914er BIOS drauf und nach langer Zeit ohne Probleme fuhr mein Rechner auch nicht mehr hoch. Nachdem alles wieder lief kam das Problem nach paar Tagen wieder. Somit bin ich wieder beim 1504er BIOS das vorher schon Monate ohne Mucken lief.
Dann mache es doch:)!
Ich musste nichts downgraden. Ich hab auf dem ersten BIOS-Stein das 1504er drauf und den zweiten BIOS-Stein nehm ich zum experimentieren in dem Fall das 1914er. Die BIOS wahl bestimme ich via Jumper so bin ich immer auf der sicheren Seite.
Und falls es mal nicht mit dem 2. BIOS läuft einfach Stromkabel ziehen,Batterie falschrum einsetzen,10 Minuten warten,Batterie wieder richtig rein,CMOS-Clear drücken,Bios-Jumper umsetzen,Stromkabel rein und es läuft wieder.
Welches Bios ist eigentlich das beste?
Ich habe aktuell das 1914er drauf...
Ich kenne das von anderen Boards, das gibts Bios'e bei denen man die geringere Spannungen braucht und bei anderen wieder mehr?
Das Board hat doch eine Bios FlashBack Option ;)
Ich brauche beim 1504er und 1914er die selben Spannungen und die gleichen oc Werte. Ich denke nicht das man das SO pauschal sagen kann,da sich ja jede CPU und jedes Board da anders verhält. Da hilft nur ausprobieren würd ich sagen.
Hi Leute,
Wollte nur mal sagen das ich meinen Eintrag mit den 12Gb Patriot Viper 2 Sector 7 1600MHZ LLK Riegeln wieder revidiere. HAbe andauernd Kalt boot bugs. Das nervt tierisch Händler wil nicht umtauschen weil er das mit seinem Testsystem nicht nach vollziehen kann kotz. Hab mir jetzt mal wieder Corsair bestellt, da weiß man wenigstens das die vernünftig laufen so.
Ich nutzte auch das Bios 1914, meiner Meinung nach das beste seit dem 1639. Mit dem 1639 hab ich persönlich die nidrigsten Spannungen gebraucht und mit dem 1914 brauch ich nur ganz ganz wenig mehr um mein Sys stabil zu bekommen.
hi also meint ihr das liegt bei mir auch am bios ? oder wie kann ich mir garnicht vorstellen
weil ich bekomm den rechner ja nicht mal mehr an
Hallo liebe community,
Also mein System besteht aus Folgenen Komponenten:
- 1366 i7 920 D0
- Corsair XMS3 6GB DDR3 1600MHz 7-7-7-20
- Asus Rampage II
- Gainward GeForce® GTX 480 1536MB GDDR5
- ASAX SSD 128GB
- HX 850 Watt
- Wasserkühlung
- cuplex kryos XT
- aquagraFX für GTX 480
- aquastream XT USB 12V Pumpe - Ultra Version
- Phobya G-Changer 360 Ver. 1.2 Black
- 13mm Schläuche
Nun meine Fragen:
Ich würde gerne meinen System Übertagten.
Kenne mich auch schon ein bischen aus siehe Sys Komponenten. Wenn ich im Bios Übertacke komme ich nur auf einen BLC wert von 189 Stabiel.
>>>>>>>>>http://a.imagehost.org/0528/Unbenannt.png <<<<<<<<<<<<<
So nun habt ihr hoffentlich genug Infos um mir zu helfen !!!!!!!!!!!!!!!!!
Möchte gerne den cpu auf 200MHz und 4GHz stabil laufen lassen kann mir einer da behilflich sein ???????
Hab den Post schon mal wo anderes rein aber hier glaube ich kann mir eher einer Helfen. Vielen Herzlichen Dank Schon im voraus !!!!
@madc270
wie soll ich denn das bios zurückflashen? Ich kann den rechner ja nicht anmachen es geht nichts mehr,... außer das alles was auf dem mainboard leuchten soll blinkt ghet nichts!
Ist heute RIIE Problemtag? :fresse:
Hab gerade eben eine zweite GTX 570 (beide @ lukü noch) eingesetzt, SLI-Bridge drangesetzt, Strom angeschlossen und gebootet.
Was sehe ich? CPU-Fan Error. Das hatte ich wegen Wakü deaktiviert, also irgendwas stimmt nicht. Ab ins Bios und alle Settings weg!?
Wollte dann mein OC-Profile laden... auch weg!
Wie kann das sein? Einfach weg. Ich kenne meine Settings doch gar nicht mehr :( Hab über ein Jahr nichts verändert. Ist das ein Mist. Kann man da noch etwas wiederherstellen? Bios2 muss man doch über Jumper aktivieren oder nicht!? Also kann ichs doch nicht versehentlich umgeswitched haben oder?
Ich hab meine Settings aufm Blatt Papier aufgeschrieben,weil bei mir auch auf einmal alles weg war.
Setz einfach den Jumper aufm Brett für Bios 2. Und ob du den Jumper versehentlich umgestöpselt hast weiss ich nicht :fresse:
also ich kann euch sagen das hat nichts gebracht
das ist mies,was ist denn wenn du den bios jumper mal manuel auf bios 1 bzw bios 2 setzt?
Die einstellungen hat man im Kopf ;)
Peebee hab dir auf die PN geantwortet :fp
Bin noch arbeiten daher dauerts bissl mit dem iPhone :d
---------- Beitrag hinzugefügt um 19:42 ---------- Vorheriger Beitrag war um 19:40 ----------
Ps
Geschaut ob du den Jumper runter gemacht hast mit der zweiten graka beim Einbau?
Jumper hängt definitiv fest. Da hab ich nichts gerüttelt ;)
Evtl Batterie Kontakt unterbrochen?
Also das gespeicherte Profiel geht normal nicht verloren
Nur bei nem Bios Update wird es überschrieben und somit unbrauchbar
Hast du beide Bios Roms auf die Profile abgesucht?
Du kannst sie im Bios auch selber switchen.....
Evtl hat er nur das Falsche Rom von beiden eingelesen....
Tja mich wunderts ja auch. Hab Bios mal umgeswitched, aber das ist nicht mal konform für den W3520 :fresse:
Batteriekontakt unterbrochen durch einsetzen der Graka? Äußerst unwahrscheinlich. Ich finds saumerkwürdig. :(
Habs mal wieder grob eingestellt. Muss ich mal wieder auf Stabilität testen. Ich danke dir aber erstmal wieder für deine Hilfe Marvin! :)
Hardreset machen
-MoBo Batterie falschrum einsetzen
@madc270:
GANZ böse Idee :fire:!!! Wer hat dir denn den Schmarn beigebracht :grrr:? Schon mal was davon gehört das ICs bei falscher Vcc Polung abrauchen wenn sie keine Schuzschaltung haben?
Zum Bios reseten gibt es einen ganz klaren und supporteten Weg von Asus:
  1. CLRTC_SW Jumper muss auf enabled stehen
  2. Netzteil muss eingesteckt sein. Rechner sollte heruntergefahren sein.
  3. Auf der Rückseite den Knopf CLR CMOS 1x ca 3 Sek. drücken
  4. Danach beim Einschalten / Hochfahren
die ENTF Taste gedrückt halten
Nur wenn obgies nicht funktioniert, die Batterie für ca 1 Std entfernen.
@Guggy:
Ich sehe du hast bei DRAM Rev Voltage nur 1,64V hast.
Ich habe 2x nen i7 mit dem Asus Board. Bei dem Rechner wo ich den Corsair XMS3 Speicher drin hatte bootet er nicht sauber wenn er weniger als 1,65V hat. Der andere Rechner mit dem Mushkin Speicher ist nicht so empfindlich. Auch würde ich CPU Spread Spektrum und PCIE Spread Spektrum raus nehmen.
Quisa
Das mit der BIOS-Batterie sagten mir seit Striker 2 zeiten mehrere ASUS-Techniker am Telefon.
