[Sammelthread] Asus Rampage II Extreme R.o.G. (Intel X58) [5]
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 12 GB, DDR3 1800(O.C.)/1600(O.C.)/1333/1066 Non-ECC,Un-buffered Memory
    - Triple channel memory architecture
    - * Supports Intel® Extreme Memory Profile (XMP)
    - **Due to Intel spec definition, DIMMs of DDR3-1333 or above are out of spec.
Expansion Slots
  • 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
  • 2 x PCIe 2.0 x 1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xUltraDMA 133/100/66/33 for up to 2 PATA devices
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
Audio
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8 -Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports 1 x S/PDIF out header
    - Supports Coaxial/Optical S/PDIF out ports on rear
LAN
  • Dual Gigabit LAN controllers, both featuring AI NET2 Support Teaming Technology
Internal I/O Connectors
  • 3 x USB connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector
  • 7 x SATA connectors
  • 1 x IEEE 1394a connector
  • 1 x Chassis Fan connector
  • x 8-pin ATX 12V Power connector
  • 24-pin ATX Power connector
  • 1 x EL I/O Shield Connector
  • 3 x thermal sensor connector
  • 1 x En/Dis-able Clr CMOS connector
  • System Panel
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 8 x ProbeIt connectors
  • 1 x LCD Poster connector
  • 1 x BIOS FlashBack boot up selection header
  • 1 x ROG light connector
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port(purple)
  • 1 x External SATA port
  • 2 x LAN (RJ45) port
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Special Features
  • External LCD Poster
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • EL I/O
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS EPU-6 Engine
  • ASUS Q-Connector
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo3
Accessories
  • ProbeIt Cable
  • 3-Way SLI Cable
  • SLI Cable
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • EL I/O Shield
  • Thermal sensor cables
  • Cable Ties
  • User's manual
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: Xfastest.com)​
Das BiosDas Bios
- Bilder folgen
Biostemplate (Extreme Tweaker)Biostemplate (Extreme Tweaker)
Code:
Extreme Tweaker
CPU Level Up:
Memory Level Up:
Ai Overclock Tuner:
OC From CPU Level Up:
OC From Memory Level Up:
CPU Ratio Setting:
BCLK Frequency:
PCIE Frequency:
DRAM Frequency:
UCLK Frequency:
QPI Frequency:
EPU II Phase Control:
Loadline Calibration:
CPU Differential Amplitude:
Extreme OV:
CPU Voltage:
CPU PLL Voltage:
QPI/DRAM Core Voltage:
IOH Voltage:
IOH PCIE Voltage:
ICH Voltage:
ICH PCIE Voltage:
DRAM Bus Voltage:
Debug Mode:
Keyboard TweakIt Control:
CPU Spread Spectrum:
PCIE Spread Spectrum:
CPU Clock Skew:
IOH Clock Skew:
CPU-Configuration
CPU Ratio Setting:
C1E Support:
Hardware Prefetcher:
Adjacent Cache Line Prefetch:
Intel(R) Virtualization Tech:
CPU TM Function:
Execute Disable Bit:
Intel(R) HT Technology:
Active Processor Cores:
A20M:
Intel(R) C-STATE Tech:
-C State package limit setting:
DRAM Timing Control
DRAM CAS# Latency:
DRAM RAS# to CAS# Delay:
DRAM RAS# PRE Time:
DRAM RAS# ACT Time:
DRAM RAS# to RAS# Delay:
DRAM REF Cycle Time:
DRAM WRITE Recovery Time:
DRAM READ to PRE Time:
DRAM FOUR ACT WIN Time:
DRAM WRITE to READ Delay:
DRAM Timing Mode:
DRAM Round Trip Latency on CHA:
DRAM Round Trip Latency on CHB:
DRAM Round Trip Latency on CHC:
DRAM WRITE to READ Delay(DD):
DRAM WRITE to READ Delay(DR):
DRAM WRITE to READ Delay(SR):
DRAM READ to WRITE Delay(DD):
DRAM READ to WRITE Delay(DR):
DRAM READ to WRITE Delay(SR):
DRAM READ to READ Delay(DD):
DRAM READ to READ Delay(DR):
DRAM READ to READ Delay(SR):
DRAM WRITE to WRITE Delay(DD):
DRAM WRITE to WRITE Delay(DR):
DRAM WRITE to WRITE Delay(SR):
DRAM REF Voltage
DRAM DATA REF Voltage on CHA/B/C:
DRAM CTRL REF Voltage on CHA/B/C:
DownloadsDownloads
Bios Downloads
  • Bios 0407
    - First release Bios
  • Bios 0503
    - Revised QPI/DRAM Core Voltage setting in CPU Level Up
  • Bios 0602
    - Fix system may hang after resume from S3
    - Improvie Memory compatibility
  • Bios 0701 (beta)
    - keine Changelog
  • Bios 0705
    - Fixed the CPU ratio setting incorrect in TweakIt Batch File function.
    - Revised the default value of keyboard TweakIt control hotkey to "P" in BIOS setup
  • Bios 0804
    - Updated EC firmware (Fixed system would hang at POST with ADAPTEC SAS RAID Controllers ASR-5405 attached.)
  • Bios 0901
    - Fixes Bug issues with 4870X2's in Crossfire X not showing Video.
    - Fixed Memory Compatibility Issues
  • Bios 0903
    - Fixed the function for adjusting BCLK abnormal in TurboV when set BCLK > 200MHz in BIOS setup
  • Bios 0904
    - System Stability Improved When Overclocking Bclk High
  • Bios 1001
    - Fix AI suite report different CPU temperature as LCD Poster
  • Bios 1403 (beta)
    - keine Changelog
  • Bios 1504
    - Updated configuration table of OC Station.
    - Fixed Target DRAM Frequency incorrect for DDR3-1333 with non-extreme CPU when set DRAM Frequency to auto in BIOS setup.
    - Supported display warning message when set CPU Voltage or QPI/DRAM Core Voltage over 1.8V in TurboV.
  • Bios 1639
    - Improve memory compatibility
    - Updated ASUS EZ Flash 2 from V3.38 to V3.44
    - Updated ASUS O.C. Profile from V1.38 to V1.44
  • Bios 1704
    - Support new CPUs.
  • Bios 1802
    - Support new CPUs.
Wichtige InformationenWichtige Informationen
  • Achtet auf die Speicheranordnung, wenn die Riegel in den falschen Slots sind bootet das Mainboard nicht (hat mit dem IMC der CPU zu tun!)
    - Dazu bitte Seite 2-15 im Handbuch nachschlagen.
[/blockquote]
Also geht auch mit überbrückung nicht an?
Mal ausgebaut und das Laminat von hinten an geschaut? Im Oberen bereich des CPU Sockel?
Hey, ich nochmal, hab mir das Board heute aus Langeweile nochmal vorgenommen. Das Board ist optisch ohne Beschädigungen, hab ich schon minutiös kontrolliert. Um Wasser oder brüchiges Lötzinn auszuschließen, kam das Board gerade mal für 20 Minuten bei 100°C in den Backofen. Hat aber leider alles nichts geholfen, selbes Symptom.
Ich tippe mal stark darauf, dass der große iROG Chip unten rechts durchgebrannt ist. Du hast nicht zufällig ne Idee, ob und wo ich dafür nen Ersatzteil kriege? Aufgelötet kriege ich den dann schon irgendwie (hoffe ich). Nen zweites defektes Board kaufen würde wohl leider nicht lohnen :/
Nop
Ersatzteile hab ich nichts mehr da
Mache schon lange nichts mehr ... Kaum noch zeit durch die Kinder
Wüsste jetzt auch niemand
Verkauf es als Defekt und lass gut sein
Kannst nur zu Asus schicken und checken lassen aber das würde sich nicht lohnen
Mfg
Tja meins läuft leider wieder auf Standard-Settings und das ist echt etwas frustrierend. Meine Settings waren so gut auf über 4 Ghz eingestellt. Leider hab ich keine Aufzeichnungen mehr, wie das genau eingestellt war. Bios Batterie ist wohl platt, und irgendwie sind die gespeicherten Settings wie weggezaubert.
Ob das Board mit all seinen Treibern wohl auf Windows 10 kommen kann? Ich fürchte fast nicht!?
Hab auch keine Zeit mehr für OC. Wenn was neues her muß, dann muss es eben von Grund auf gut sein und reichen. >300€ für ein OC-Board gebe ich sicher nicht mehr aus. Nur der Wakü und dem SLI will ich treu bleiben.
Das müsste mit Win 10 noch laufen. Brauchst ja nur nen paar Treiber, um die Schose zum Laufen zu bekommen, da werden Intel und Asus die wichtigsten Sachen schon noch updaten. Die wollen ihr Betriebssystem ja auch verkaufen, nützt ja nix wenn sich das nur auf PCs installieren lässt, die jünger als 3 Jahre sind ;)
Ob das komplette AI Suite Zeug dann allerdings auch noch funktioniert, kann ich dir nicht so aus dem Stegreif sagen.
Ach das AI-Zeugs brauche ich eh nicht mehr.
Es heißt ja, das Microsoft, da ein kostenloses Upgrade von Win7 zu 10 schmeißen will. Aber da soll es sich um ein befristetes Jahr handeln. Und bevor ich da überhaupt etwas unternehme, muss ich wissen, ob das Board das wohl packt.
Speichern auf CF-Karte mit FAT war möglich *freu*
Meine Settings waren (wahrscheinlich wegen leerer Bios-Batterie) mal wieder platt und ich habe das Backup brav noch auf meinem NAS gespeichert.
Wie ist das...? Kann ich nicht auch eine SD-Karte, die in FAT formatiert ist mit nem Card-Reader anschießen?
Habs gestern nicht mehr getestet, aber viell. hat da jemand Erfahrung mit gemacht? Meine CF-Karte ist leider damals mit Cam weggegangen :fresse:
Welche Batterie brauch ich eigentlich für Rampage II und wo bekomm ich die am besten günstig?
Neues System wird wohl erst nächstes Jahr kommen. Solang hätt ich gern meine Settings nochmal wieder zurück. :fresse:
Bitte um Hilfe, wie ich den cmo-file wieder ins Board bekomme :-)
Jo danke dir! Dazu muss ich wohl etwas Wasser ablassen :fresse:
Komme wegen SLI nicht dran.
Hat jemand eine Idee, ob oder wie man die Bios Settings wieder importiert? Oder kann man diesen File auslesen irgendwie?
Hi, sagt mal wisst ihr ob ein Xeon X5650 auf dem Rampage II Extreme läuft ?
Weil würde gerne ein drauf stecken, aber der wird ja offiziell nicht unterstützt, habe aber irgendwo gelesen das wohl angeblich jeder 1366er Xeon auf jedem Desktop Board auch laufen würde, stimmt das ?
Radeon Rx 480 läuft nicht wirklich....
Hallo hoffe ich finde hier noch Jemanden ist ja nen altes thema .
Habe ein rampage ii extreme
Mit nem Xeon w 3680 drauf und 6Gb RAM .
Wollte mir ne neue Grafikkarte gönnen und habe ich auch gemacht : die xfx Radeon Rx 480 rs mit 8 Gb RAM .
Und da fangen die Probleme an . Auf den beiden blauen pci Express Slots läuft die Karte nicht an .
Auf den weißen pci Express 2.0 der x8 ist da läuft die Karte wäre alles halb so wild aber der Slot ist ganz unten und Bauart bedingt passt die Karte nicht ins Gehäuse weil das Netzteil im Weg ist .
Woran kann es liegen das die blauen slots also die pci Express 2.0 x16 nicht funktionieren .
