[Sammelthread] ASUS Sabertooth P67 (Intel P67)
ASUS Sabertooth P67 B3
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 Spezifikationen
2.Information
2.1 Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler/Wakü
3.1 Downloads
Algemeines
Bilder:
folgen
Lieferumfang:
showpic.php
- 1 x Mainboard
- 2 x SATA-3 Kabel
- 2 x SATA-3 Kabel
- 1 x I/O-Blende
- 1 x SLI Bridge
- 4 x Schraube für Optionnale Lüfter
- 1 x "Zuverlässigkeit-Zertifikat" für die verbauten Komponenten.
- Treiber-DVD und englischer Dokumentation
Spezifikation:
CPU Intel® Socket 1155 for Intel® 2nd Generation Core™ i7 Processor/Core™ i5 Processor/Core™ i3 Processor/
Support Intel® 32nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types
* Refer to ASUSTeK Computer for Intel CPU support list
Chipset Intel® P67(B3) Express Chipset
Memory 4 x DIMM, Max. 32 GB, DDR3 1866/1800/1600/1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
* According to Intel® SPEC, the Max. 32GB memory capacity can be supported with DIMMs of 8GB (or above). ASUS will update QVL once the DIMMs are available on the market.
* Hyper DIMM support is subject to the physical characteristics of individual CPUs. Some hyper DIMMs only support one DIMM per channel. Please refer to Memory QVL for details.
* Due to CPU behavior, DDR3 1800 MHz memory module will run at DDR3 1600 MHz frequency as default.
* Please refer to ASUSTeK Computer or user manual for Memory QVL.
Expansion Slots 2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)
3 x PCIe 2.0 x1
1 x PCI
Multi-GPU Support Supports NVIDIA® Quad-GPU SLI™ Technology
Supports ATI® Quad-GPU CrossFireX™ Technology
Storage Intel® P67(B3) Express Chipset
2 xSATA 6.0 Gb/s ports (brown)
4 xSATA 3Gb/s ports (black)
Intel® Rapid Storage Technology Support RAID 0,1,5,10
Marvell® PCIe SATA 6Gb/s controller
2 xSATA 6Gb/s ports (gray)
JMicron® JMB362 SATA controller
1 xPower eSATA 3Gb/s port (green)
1 xExternal SATA 3Gb/s port (red)
LAN Intel® 82579 Gigabit LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Audio Realtek® ALC892 8-Channel High Definition Audio CODEC
- Absolute Pitch 192khz/24bit True BD Lossless Sound
- BD Audio Layer Content Protection
- Supports Jack-Detection, Multi-streaming, and Front Panel Jack-Retasking
- Optical S/PDIF out port at back I/O
IEEE 1394 VIA® VT6308P controller supports 2 x 1394a port(s) (one at mid-board; one at back panel)
USB NEC USB 3.0 controllers
- 4 x USB 3.0/2.0 ports (2 ports at mid-board for front panel support; 2 ports at back panel [blue])
- 14 x USB 2.0/1.1 ports (6 ports at mid-board, 8 ports at back panel)
ASUS Unique Features Exclusive TUF Features
"Ultimate COOL!" Thermal Solution
- TUF Thermal Armor
- TUF Thermal Radar
"TUF ENGINE!" Power Design
- 8+2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
"Safe & Stable!" Guardian Angel
- ESD Guards
- MemOK!
- Anti Surge
Other Special Features
- Front Panel USB 3.0 Support
- ASUS EFI BIOS EZ Mode featuring friendly graphics user interface
- AI Suite II
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
Back Panel I/O Ports 1 x PS/2 Keyboard/Mouse Combo port
1 x External SATA 3Gb/s port (red)
1 x Power eSATA 3Gb/s port (green)
1 x IEEE 1394a
1 x LAN(RJ45) port(s)
2 x USB 3.0/2.0 ports (blue)
8 x USB 2.0/1.1 ports
1 x S/PDIF Out (Optical)
8 -Channel Audio I/O
Internal I/O Connectors 1 x USB 3.0/2.0 connector(s) supports additional 2 USB ports (19-pin; moss green)
3 x USB 2.0/1.1 connector(s) support additional 6 USB ports
1 x MemOK! button
4 x SATA 6.0Gb/s connectors ( 2 x gray; 2 x brown)
4 x SATA 3.0Gb/s (black)
1 x IEEE 1394a connector
1 x CPU Fan connector(s) (4-pin)
2 x Chassis Fan connector(s) (1 x 4-pin; 1 x 3-pin)
1 x Power Fan connector(s) (3-pin)
1 x Assistant Fan connector (3-pin)
1 x S/PDIF Out connector
24-pin EATX Power connector
8-pin EATX 12V Power connector
1 x Front panel audio connector
1 x COM connector
1 x System Panel (Q-Connector)
1 x Clear CMOS jumper
BIOS 32 Mb Flash ROM , EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME,PXE
Accessories User's manual
2 x SATA 3.0Gb/s cables
2 x SATA 6.0Gb/s cables
1 x Q-Shield
1 x Q-Connecor (2 in 1)
1 x ASUS SLI bridge cable
1 x TUF Certification card
1 x TUF 5 Year Warranty manual (by region)
4 x screws for Assistant Fan
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities
Form Factor ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Features:
TUF Thermal Armor TUF Thermal Radar DIGI+ VRM E.S.P. Efficient Switching Power Design TUF-Komponenten (Chokes mit Speziallegierung, Caps & MOSFETs - zertifiziert nach Militärstandard) MemOK! ESD Guards
Information:
Asus site
http://www.asus.com/product.aspx?P_ID=ZYgjt71bzlh62Zk9&templete=2
Reviews
ASUS Sabertooth P67 Mainboard - Review Hartware.net
User-Review von Helios1969
http://www.hardwareluxx.de/community/f12/asus-sabertooth-p67-tuf-serie-779976.html
Preisvergleich
Hardwareluxx - Preisvergleich
Video Unboxing and first look
YouTube - Asus Sabertooth P67 Core i7 LGA1155 Motherboard Unboxing Linus Tech Tips
Kompatibele RAMs
Code:
Corsair 8 GB DDR3-1600 Kit (CMZ8GX3M2A1600C9, Vengeance)
Corsair 16 GB DDR3-1600 Quad-Kit (CMZ16GX3M4A1600C9, Vengeance)
G.Skill RipJaws-X DIMM Kit 16GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7Q-16GBXH)
Code:
[B][U]LuftKühler
[/U][/B]Corsair Air Series A70
Zalman CNPS9900 MAX BLUE
Thermalright Silver Arrow
Thermalright HR-02
Prolimatech Megahalems
Megashadow
Super Mega
[U][B]On board Lüfter[/B][/U]
Silent Series 50mm
Revoltec "Air Guard" 50mm
[B][U]Wakü
[/U][/B]Corsair Hydro Series H50
Corsair Hydro Series H70
Downloads
ftp server
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1155/SABERTOOTH_P67/
aktuelles bios
1502
1. Enhance USB input device compatibility under UEFI interface.
2. Enhance XHCI Legacy support.
3. TPU firmware updated to enhance the effect of TPU on some processors.
Ich stehe eher auf die konservative Note....aber mir gefaellts..und sieht scharf aus beim Booten:
In einem der letzten Bios wurde der Microcode von Intel geupdated im Bezug auf Ram-Kompatibilität. Vielleicht lag's daran...
juhu - ich hab mir auch ein "silberzahn" rausgelassen... Oo
Hey...mir platzt gleich mein EE-PC....*fg....änder mal die Grösse---< ;)
E://
btw...schicke Schlauchverlegung, würde mich mal ein Bild von der Hinterseite interessieren. Aber dann im 800D-Fred...;=))
schlauchverlegung ist so ne sache. Oo
die rückwand beult sich "etwas aus".
nein, nein, nein - man darf sie nicht mal anschauen sonst springt sie aus der "verankerung".
:heul:
hALLO Leute,
Hatte gestern mal den Rechner durchbenchen lassen mit 3dmark06 und abgesehn davon das ich mit mein System I7-2600K@3,4ghz und 2x480GTX Palit leider immer noch 32000 Punkte habe hat sich von den Punkten her nicht viel geändert.
Nach dem Bench aber sagte mir die ASUS Suite das mein USB3.0-2 Sensor 75 Grad hatte.
Ist das normal? habe keine USB 3.0 Geräte dranne und der Port ist auch leer, wollt edemnächst mal den Lüfter raufschrauben und schauen ob sich was von den Temperaturen verändert, wird aber wohl Problematisch da Oben im PCIE1 Slot meine Creative XFI Titanium drinne steckt.
mfg SilentDeath
Bei mir zeigte die AI Suite auch schon mehrfach 123 Grad Mainboard Temperatur an. 75 Grad Temp beim USB3 Sensor halte ich fuer eher unwahrscheinlich trotz Hitzeentwicklung durch SLI.
Kommt meist vor wenn noch ein zweites Monitoring-Tool nebenbei läuft, welches auf die Sensoren zugreift. Dann spinnt die Suite manchmal für ein paar Millisekunden :)
Jau, kann man ja auch problemlos alles laufen lassen, wenn man weiß was los ist ^^
Einfach ignorieren und gut ;)
Kann mir mal jemand die thermalradar.exe umd .dll per email schicken? Befindet sich im Windows Ordner
Will mal probieren zu starten ohne Installation.
Danke. Werde gleich testen.
Nö geht ned. Da fehlt noch der Ordner Resource mit den Image Dateien.
BIOS mit DDR3-2000 Teiler
Ich habe mal eine Frage zum Speicherteiler.
Gibt es ein BIOS, welches einen Speicherteiler vorsieht, welche DDR3-2000 bei 100MHz BCLK zulässt? Der Sprung zwischen 1866 und 2133 ist ja doch recht groß und man muss ziemlich am BCLK drehen um die 2000er Marke zu erreichen...
Wie gesagt, du wirst kein Board finden wo das möglich ist, zumindest nicht im SB-Bereich :)
Welches Bios hast du drauf?
Und mal komplett resettet per Jumper und danach Defaults geladen?
Das Problem an sich kommt mir bekannt vor, aber nicht unbedingt vom Sabertooth...
Schon länger oder erst seit Kurzem? Netzteil etc ausgeschlossen?
Das hatte ich auch ! Wenn ich morgens den Pc anmachen wollte ging nix . ich muste den Schalter am NT ausschalten 5sec warten und wieder an .
Dann konnte ich den Pc vorne Starten und die Bios einstellungen waren alle weg . Profiel laden und alles ging .
Dachte NT wäre defekt getauscht und am nästen morgen das selbe spiel .
Habe das Board zurück geschickt und in 7 Tagen ein neues bekommen . Es lag am Board irgent ein defekt ? weis der geier welcher ? aber jetzt rennt es wieder !
Kann dir nur empfehlen es einzuschicken !
Ich habe das 1850 BIOS und das war jetzt das 2`te mal. ich werde das noch ein bissel beobachten.
oOO...wenn das der Fall ist, dann habe ich natürlich echt pech. Denn ich bin ab Montag 7 Tage weg, so ein Dreck...mal sehen, werde es mal weiter checken und schauen ob es morgen früh wieder auftritt..!!!
Danke dir..
