[Sammelthread] ASUS Sabertooth P67 (Intel P67)
ASUS Sabertooth P67 B3
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 Spezifikationen
2.Information
2.1 Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler/Wakü
3.1 Downloads
Algemeines
Bilder:
folgen
Lieferumfang:
showpic.php
- 1 x Mainboard
- 2 x SATA-3 Kabel
- 2 x SATA-3 Kabel
- 1 x I/O-Blende
- 1 x SLI Bridge
- 4 x Schraube für Optionnale Lüfter
- 1 x "Zuverlässigkeit-Zertifikat" für die verbauten Komponenten.
- Treiber-DVD und englischer Dokumentation
Spezifikation:
CPU Intel® Socket 1155 for Intel® 2nd Generation Core™ i7 Processor/Core™ i5 Processor/Core™ i3 Processor/
Support Intel® 32nm CPU
Supports Intel® Turbo Boost Technology 2.0
* The Intel® Turbo Boost Technology 2.0 support depends on the CPU types
* Refer to ASUSTeK Computer for Intel CPU support list
Chipset Intel® P67(B3) Express Chipset
Memory 4 x DIMM, Max. 32 GB, DDR3 1866/1800/1600/1333/1066 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
Supports Intel® Extreme Memory Profile (XMP)
* According to Intel® SPEC, the Max. 32GB memory capacity can be supported with DIMMs of 8GB (or above). ASUS will update QVL once the DIMMs are available on the market.
* Hyper DIMM support is subject to the physical characteristics of individual CPUs. Some hyper DIMMs only support one DIMM per channel. Please refer to Memory QVL for details.
* Due to CPU behavior, DDR3 1800 MHz memory module will run at DDR3 1600 MHz frequency as default.
* Please refer to ASUSTeK Computer or user manual for Memory QVL.
Expansion Slots 2 x PCIe 2.0 x16 (single at x16 or dual at x8/x8 mode)
3 x PCIe 2.0 x1
1 x PCI
Multi-GPU Support Supports NVIDIA® Quad-GPU SLI™ Technology
Supports ATI® Quad-GPU CrossFireX™ Technology
Storage Intel® P67(B3) Express Chipset
2 xSATA 6.0 Gb/s ports (brown)
4 xSATA 3Gb/s ports (black)
Intel® Rapid Storage Technology Support RAID 0,1,5,10
Marvell® PCIe SATA 6Gb/s controller
2 xSATA 6Gb/s ports (gray)
JMicron® JMB362 SATA controller
1 xPower eSATA 3Gb/s port (green)
1 xExternal SATA 3Gb/s port (red)
LAN Intel® 82579 Gigabit LAN- Dual interconnect between the Integrated LAN controller and Physical Layer (PHY)
Audio Realtek® ALC892 8-Channel High Definition Audio CODEC
- Absolute Pitch 192khz/24bit True BD Lossless Sound
- BD Audio Layer Content Protection
- Supports Jack-Detection, Multi-streaming, and Front Panel Jack-Retasking
- Optical S/PDIF out port at back I/O
IEEE 1394 VIA® VT6308P controller supports 2 x 1394a port(s) (one at mid-board; one at back panel)
USB NEC USB 3.0 controllers
- 4 x USB 3.0/2.0 ports (2 ports at mid-board for front panel support; 2 ports at back panel [blue])
- 14 x USB 2.0/1.1 ports (6 ports at mid-board, 8 ports at back panel)
ASUS Unique Features Exclusive TUF Features
"Ultimate COOL!" Thermal Solution
- TUF Thermal Armor
- TUF Thermal Radar
"TUF ENGINE!" Power Design
- 8+2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
"Safe & Stable!" Guardian Angel
- ESD Guards
- MemOK!
- Anti Surge
Other Special Features
- Front Panel USB 3.0 Support
- ASUS EFI BIOS EZ Mode featuring friendly graphics user interface
- AI Suite II
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
Back Panel I/O Ports 1 x PS/2 Keyboard/Mouse Combo port
1 x External SATA 3Gb/s port (red)
1 x Power eSATA 3Gb/s port (green)
1 x IEEE 1394a
1 x LAN(RJ45) port(s)
2 x USB 3.0/2.0 ports (blue)
8 x USB 2.0/1.1 ports
1 x S/PDIF Out (Optical)
8 -Channel Audio I/O
Internal I/O Connectors 1 x USB 3.0/2.0 connector(s) supports additional 2 USB ports (19-pin; moss green)
3 x USB 2.0/1.1 connector(s) support additional 6 USB ports
1 x MemOK! button
4 x SATA 6.0Gb/s connectors ( 2 x gray; 2 x brown)
4 x SATA 3.0Gb/s (black)
1 x IEEE 1394a connector
1 x CPU Fan connector(s) (4-pin)
2 x Chassis Fan connector(s) (1 x 4-pin; 1 x 3-pin)
1 x Power Fan connector(s) (3-pin)
1 x Assistant Fan connector (3-pin)
1 x S/PDIF Out connector
24-pin EATX Power connector
8-pin EATX 12V Power connector
1 x Front panel audio connector
1 x COM connector
1 x System Panel (Q-Connector)
1 x Clear CMOS jumper
BIOS 32 Mb Flash ROM , EFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2, ASUS CrashFree BIOS 3
Manageability WfM 2.0,DMI 2.0,WOL by PME,WOR by PME,PXE
Accessories User's manual
2 x SATA 3.0Gb/s cables
2 x SATA 6.0Gb/s cables
1 x Q-Shield
1 x Q-Connecor (2 in 1)
1 x ASUS SLI bridge cable
1 x TUF Certification card
1 x TUF 5 Year Warranty manual (by region)
4 x screws for Assistant Fan
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities
Form Factor ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )
Features:
TUF Thermal Armor TUF Thermal Radar DIGI+ VRM E.S.P. Efficient Switching Power Design TUF-Komponenten (Chokes mit Speziallegierung, Caps & MOSFETs - zertifiziert nach Militärstandard) MemOK! ESD Guards
Information:
Asus site
http://www.asus.com/product.aspx?P_ID=ZYgjt71bzlh62Zk9&templete=2
Reviews
ASUS Sabertooth P67 Mainboard - Review Hartware.net
User-Review von Helios1969
http://www.hardwareluxx.de/community/f12/asus-sabertooth-p67-tuf-serie-779976.html
Preisvergleich
Hardwareluxx - Preisvergleich
Video Unboxing and first look
YouTube - Asus Sabertooth P67 Core i7 LGA1155 Motherboard Unboxing Linus Tech Tips
Kompatibele RAMs
Code:
Corsair 8 GB DDR3-1600 Kit (CMZ8GX3M2A1600C9, Vengeance)
Corsair 16 GB DDR3-1600 Quad-Kit (CMZ16GX3M4A1600C9, Vengeance)
G.Skill RipJaws-X DIMM Kit 16GB PC3-10667U CL7-7-7-21 (DDR3-1333) (F3-10666CL7Q-16GBXH)
Code:
[B][U]LuftKühler
[/U][/B]Corsair Air Series A70
Zalman CNPS9900 MAX BLUE
Thermalright Silver Arrow
Thermalright HR-02
Prolimatech Megahalems
Megashadow
Super Mega
[U][B]On board Lüfter[/B][/U]
Silent Series 50mm
Revoltec "Air Guard" 50mm
[B][U]Wakü
[/U][/B]Corsair Hydro Series H50
Corsair Hydro Series H70
Downloads
ftp server
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1155/SABERTOOTH_P67/
aktuelles bios
1502
1. Enhance USB input device compatibility under UEFI interface.
2. Enhance XHCI Legacy support.
3. TPU firmware updated to enhance the effect of TPU on some processors.
Dürfte passen würde ich behaupten, Silver Arrow, Mugen etc passen ja auch. So hoch sind die Kühler gar nicht..
SpaWa Kühler sind nicht höher als normaler RAM. Sollte also eigentlich keine Probleme geben
hm, ich hatte heute zum ersten mal nen blackscreen für einige sekunden. dann war das bild wieder da und im infobereich kam ne meldung das der anzeigetreiber wieder hergestellt wurde blabla. jemand ne idee?
vor paar tagen den 280.26 installiert. davor nie sowas gehabt. muss also nicht gleich zwingend bedeuten das was kaputt ist ja?
nein, ist der Treiber, garantiert. Zudem soll es auch Probs mit der richtigen Taktung der Karten geben bei dem Treiber
Mein Tip 270.61 !
hallo, habe mir einen neuen PC zusammengestellt und nun Temperaturprobleme mit dem Sabertooth , vielleicht kann mir jemand weiterhelfen.
hier mal die Komponenten
Lian Li PC-60FN
ASUS Sabertooth P67
I5 2500K Sandybridge
Enermax Gehäuselüfter vorne und hinten
Top Blow Cpu Kühler Scythe Grand Kama Cross
Gainward Gtx 580 Phantom
hier mal 2 Screenshots vom AI Suite , die ersten Temps sind nach 30 minuten surfen , die zweiten Temps nach 30 minuten F3AR zocken.
ich bekomme dann ne warnung vom PCIE-1 Slot da er die 60 Grad überschritten hat.
was könnt ihr mir empfehlen ? Thermal Armor runtermachen? oder Assistent Fan drauf?
vielen dank im voraus !
Mach den Assistent Fan drauf und Alles ist ok. Obwohl ich auch einen Top Blow CPU Kühler habe, sind die Temps nach Installation des Revoltec "Air Guard" 50mm um ca. 5-8° gesunken. Habe zwar nie Probleme gehabt, aber es beruhigt das Gewissen. Er ist wirklich nicht zu hören, ich wollte es nicht glauben, obwohl er mit ca. 3000 rpm dreht.
Den Thermal Armor würde ich nicht runtermachen.
okay, danke . den Revoltec hab ich mir schon bestellt. vielleicht liegt es auch daran dass es sich um ein geschlossenes Gehäuse handelt, also keine Luftschlitze an der Seite sind.
hab den Revoltec selbst hier auf dem Sabertooth und wer sagt er sein nicht unhörbar sollte dringenst mal bei HNO arzt vorbei schauen ;)
Natürlich ist der zu hören und das nicht zu knapp, selbst wenn er runter geregelt wird auf ca 2500 U/min.
Jeder wirkliche Silent anhänger baut den lüfter genauso schnell wieder aus wie er ihn eingebaut hat und lebt mit den etwas höheren temps oder setzte auf eine gute be und entlüftung des PC´s was durchaus leiser zu bewerkstelligen ist als der Revoltec 60 mm lüfter bei ähnlich guten temps, vorraus gesetzt das Gehäuse bietet diese möglichkeit.
Genau meine meinung, ich hab ihn auf 5V gehängt läuft nun mit ca 1800RPM so hör ich ihn nicht mehr raus.
Ich hab den 50mm Fractal bei mir eingebaut.
Mal von anfänglichen leichten Schleifgeräuschen die wieder verschwunden sind ist er ne Nummer leiser als der Revoltec.
Läuft jetzt bei ca. 2000rpm nahezu lautlos
Mal sehen, evtl test ich bei gelegenheit mal den Fractal, wenn er mir bei einer zukünftigen bestellung zufällig mit in die hande fällt.
Den Revoltec jedenfalls empfinde ich nicht als leise.
Eilig hab ichs aber nicht, trotz Wasserkühlung (CPU und Graka) sind die temps hier ganz brauchbar, der guten Gehäuse be/entlüftung sei dank.
hatte auch den Revoltec dran,war aber ehrlich gesagt nicht hörbar.
jetzt Graka unter Wasser,brauch ich den nicht mehr,kommt keine warme luft mehr ins Gehäuse.
Na ja, es soll auch Leute geben, die das Gras wachsen hören, bei mir jedenfalls ist er nicht zu hören. Habe noch 5 140er Gehäuselüfter, die mir ca. 700rpm laufen. Man hört wirklich nur ein minimales Rauschen.
Übrigens, war ich erst beim HNO-Arzt, ist alles bestens, habe auch keinen Gehörsturz oder Tinnitus.
Ist das Board ähnlich wie das Maximus 4 oder eher die Standartreihe ala P8P67 aufgebaut?
hi leute, ...
hab vor kurzem mein p67 sabertooth b3 bekommen und win7 64 installiert.
als ich die lüfter über "Thermal Radar" ansteuern wollte stiegen die temps ohne ende an.
als ich neustart machte ging nix mehr. keine ssd erkannt. ende !
musste os neu installieren !!!
dann im bios die lüftersteuerung verändert --> gespeichert.
wieder endlos booting. keine HD (ssd) erkannt. ende !
was tun jetzt ?
Hast du das neuste BIOS drauf ? --> 1850
SSD an den Intel AHCI ?? --> ?
...mal die bootoption optimiert ? --> wie ? ja die ssd ... davor gings auch !
ahci war immer an !
hatte es am weissen und braunen ports --> ging alles !
erst als ich was am thermal monitor machte spinnte es. temps rauf / keine ssd erkannt.
im bios habe dann load opt. defaults geladen ging auch nix mehr.
kann man alle lüfter über thermal radar steuern ?
wenn man speedfan nutzen will - muss man dann Q-fan-controll deaktivieren ?
ich hätte es gerne ausprobiert - aber dann kommt immer das problem !!
---------- Beitrag hinzugefügt um 20:26 ---------- Vorheriger Beitrag war um 18:15 ----------
jetzt geht nix mehr ... kein bios möglich ! oO
Wenn der CMOS Reset nicht hilft, dann CPU rausnehmen, 30 Sekunden warten, und wieder reinsetzen, hat bei mir jedes Boot problem geloest.
