[Sammelthread] Clevo Barebone - Upgrade & Modifikationen (alle Modelle)
Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones :wink:
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR (Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/091. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/091. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/091. System BIOS 1.02.08 for P570WM only.
2013/01/191. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/191. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/191. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/071. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/071. System BIOS 1.00.02 for P570WM only.
LINKS:
[Sammelthread] 17,3" Clevo P570WM(3) SLI/CFX High-End DTR (2012)
# 17,3" Clevo X7200 (Release Q3/2010) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/10/281. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/231. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/081. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/101. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/201. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/251. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/111. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/251. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/051. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/151. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
2010/09/301. System BIOS 1.00.03.
2. Solve "system can't identify nVIDIA GTX 460M VGA card correctly" issue.
LINKS:
[How-to-Video] AMD Radeon HD 7970M CrossFireX Installation in EUROCOM Panther 2.0 (X7200)
# 17,1" Clevo D90xF (Release Q2/2009) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/05/251. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/301. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/221. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/161. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/241. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
LINKS:
[User-Review] 17,1" Clevo D900F Gamer/Workstation Notebook
[How-to-Video] NVIDIA GeForce GTX 680M upgrade in EUROCOM D900F Panther
# 17,1" Clevo D90xC (Release Q2/2007) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2008/12/121. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/121. KBC/EC firmware for Windows XP keyboard only.
2008/12/121. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/201. KBC/EC firmware for VISTA keyboard only.
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/201. KBC/EC firmware for XP keyboard only.
2008/10/14Support Q9550 CPU.
2008/09/10Support nVIDIA NB9x series VGA.
2008/07/22Support 9800M GT VGA card.
2008/06/121. KBC/EC firmware for XP keyboard only.
2. Solve "sometimes system can't boot up" issue.
2008/06/121. KBC/EC firmware for VISTA keyboard only.
2008/05/20Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30 1. KBC/EC firmware for VISTA keyboard only.
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/301. KBC/EC firmware for XP keyboard only.
2008/03/21Support both partnet board and daughter board.
2008/03/12Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/121. KBC/EC firmware for VISTA keyboard only.
2. Solve VGA temperature probe inaccuracy issue.
2008/03/121. KBC/EC firmware for XP keyboard only.
2008/01/21Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/181. KBC/EC firmware for XP keyboard only.
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/291. KBC/EC firmware for VISTA keyboard only.
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/291. KBC/EC firmware for Windows XP keyboard only.
2007/10/291. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/231. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/161. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
LINKS:
[User-Review] CLEVO D901C ...8700GT SLI trifft Quadcore
SLI/CFX GAMER NOTEBOOK (Mobil CPU)
# 17,3" Clevo P370EMx (Release Q3/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/081. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/261. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/261. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/261. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/151. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/241. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/241. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/241. System BIOS 1.02.06 for P370EM3 only.
2012/10/121. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/281. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
LINKS:
[Sammelthread] 17,3" Clevo P370EM(3) SLI/CFX Gamer Notebook (2012)
# 18,4" Clevo P180HM (Release Q3/2011) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/07/061. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/181. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/041. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/211. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/071. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/02/251. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/221. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/101. EC firmware 1.00.08.
2. Modify nVIDIA VGA fan table.
2010/07/151. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support ATI HD5870 VGA.
2010/05/071. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/151. System BIOS 1.00.06.
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/301. System BIOS 1.00.04 and EC firmware 1.00.02.
2010/02/051. System BIOS 1.00.02.
2. Update code base.
LINKS:
[How-to-Video] NVIDIA GeForce GTX 680M Upgrade in EUROCOM X8100 Leopard
[How-to-Video] AMD Radeon HD 7970M upgrade in 18.4" EUROCOM X8100 Leopard Notebook
17" GAMER NOTEBOOK
# 17,3" Clevo P170EM (Release Q2/2012) 03.05.13
TECHNISCHE DATEN: (Modell C)
BIOS CHANGELOG:
releasechanges
2013/04/151. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/091. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/301. System BIOS 1.02.14 for P170EM only.
2012/10/301. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/121. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/281. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/311. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/241. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/271. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/111. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/151. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/081. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
LINKS:
[Sammelthread] 17,3" Clevo P170EM(3) Gamer Notebook (2012)
# 17,3" Clevo P170HMx (Release Q1/2011) 04.05.13
TECHNISCHE DATEN: (Modell C & D)
BIOS CHANGELOG:
releasechanges
2011/10/281. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/161. EC firmware 1.00.08.
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/091. System BIOS 1.01.10 for P170HM only.
2011/09/091. System BIOS 1.01.05 for P17xHM3 only.
2011/08/111. System BIOS 1.01.03 for P17xHM3 only.
2011/08/051. System BIOS for P170HMxx only (except P170HM3).
2011/06/101. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/271. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/061. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/221. EC firmware 1.00.05.
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/181. EC firmware 1.00.03.
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/251. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/141. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
LINKS:
[Prema Mod] P1x0HMx Mod-BIOS
[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
# 17,3" Clevo W88xCU (Release Q3/2010) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/10/081. System BIOS 1.00.05.
2. Solve the audio problem of BIOS 1.00.04.
2010/09/141. System BIOS 1.00.04.
2. Solve "Windows Experience Index is incorrect" issue.
2010/08/061. System BIOS 1.00.03.
2. Solve “system can’t identify Intel K0 stepping CPU” issue.
2010/07/091. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/03/03ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/261. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/221. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/081. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/201. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/171. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/201. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/181. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/301. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/251. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/111. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
LINKS:
26.06.10 [User-Review] Clevo W870CU / XMG7.c - bis zu 3,8GHz
15" GAMER NOTEBOOK
# 15,6" Clevo P15xEMx (Release Q2/2012) 04.05.13
TECHNISCHE DATEN: (Modell A & B)
BIOS CHANGELOG:
releasechanges
2013/03/231. System BIOS 1.02.17 for P150EM only.
2013/03/151. System BIOS 1.02.17 for P151EM1 only.
2013/01/191. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/191. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/301. EC firmware 1.02.11 for P151EM1 only.
2012/10/301. System BIOS 1.02.14 for P151EM1 only.
2012/10/301. EC firmware 1.02.11 for P150EM only.
2012/10/301. System BIOS 1.02.14 for P150EM only.
2012/10/121. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/281. EC firmware 1.00.08 for P150EM only.
2012/09/071. System BIOS 1.00.10 for P151EM1 only.
2012/09/071. System BIOS 1.00.10 for P150EM only.
2012/08/311. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/241. EC firmware 1.00.07 for P150EM only.
2012/07/121. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/291. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/151. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/041. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
LINKS:
28.06.12 notebookreview.com = P150EM Upgrading from 675M to 680M!
# 15,6" Clevo P15xHMx (Release Q1/2011) 04.05.13
BIOS CHANGELOG:
releasechanges
2011/11/041. EC firmware 1.00.13.
2. Solve “sometimes screen flickers” issue.
2011/09/161. EC firmware 1.00.12.
2011/09/091. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/051. System BIOS 1.01.12.
2011/07/151. EC firmware 1.00.11.
2011/07/011. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/061. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
(need to update LAN driver to 6.0.26.6 or later)
2011/03/251. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/251. System BIOS 1.01.04.
2011/01/141. System BIOS 1.00.03 and EC firmware 1.00.02.
LINKS:
# 15,6" Clevo W860CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/3/3 ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/10/29 1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20 1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17 1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6 1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11 1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21 VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/4/30 1. System BIOS 1.00.13 for W86xCU only.
2010/2/25 1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11 1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
LINKS:
10.01.11 [How-to-Video] Mount AMD Radeon HD6970M to EUROCOM Cougar Laptop (W860CU)
10.01.11 [Video-Review] EUROCOM W860CU Cougar HD 6970M
08.12.10 [User-Review] 15,6" Clevo W860CU Gamer Notebook
ANHANG
# Clevo Barebone - MXM3.0B Grafikkarten 16.09.12
nVidia GeForce GTX 280M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 285M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 460M (GF106/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 480M (GF100/352SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 485M (GF104/384SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 560M (GF116/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 670M (GF114/336SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 680M (GK104/1344SP) 4096MB (256Bit/GDDR5) 100W-TDP
_
ATI Mobility Radeon HD 5870 (RV840/800SP) 1024MB (128Bit/GDDR5) ~75W-TDP
_
AMD Radeon HD 6970M (RV940/960SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
AMD Radeon HD 7970M (Wimbledon XT/1280SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
Hab die P-EM Serien Prema Mod BIOS (P150EM, P151EM, P170EM, P370EM, P370EM3) jetzt fuer ALLE auf meinen Blog gestellt.
Viel Spass damit! ;)
Was gibt's für Unterschiede zu dem normalen BIOS? :)
Einiges:
http://biosmods.wordpress.com/p-em/ schrieb:
Main Features:
Full Fan Speed Mode (Press FN+9)
Longer CPU Turbo Time (up to 120s)
Snappier RAM Command Rate (T1)
All RAID modes enabled (0,1,5 & 10)
RAID TRIM support (v12 ROMs)
Updated oROMs & modules
CPU Overclocking (XTU EDITION & only 3720QM+) SOON
Flexible CPU TDP & RAM Timings (XTU EDITION ONLY) SOON
Custom BIOS logo v2
Finde ich ne Klasse Arbeit von Prema :hail:
Jeder der die Files nutzt sollte Ihm seinen Aufwand auch mit einer "Kleinigkeit" belohnen ;)
@ Prema
... wo warst du nur zu D900F Zeiten?! ^^
Hast du Ahnung wie man einem betagterem Gerät z.B. D900F neue nicht unterstützte Grafikkarten bekannt macht? Ist das sehr aufwendig?
Was heißt "Updated oROMs & modules" genauer?
Hab nun mal etwas Alu Tape in mein P150HM "verbaut". Ist das verkleben der Rückplatte sodass Kontakt zu den Kühlkörpern entsteht sinnvoll? Wenn ja, wie dick sollte die Aluschicht denn da sein? (Habe bisher die Ritzen abgeklebt für besseren Luftfluss) Windows 8 lass ich erstmal, bin zu faul dafür. Außerdem läuft mein Monitor nun Testweise mit 90 Hz. (habe ich in einem Englischsprachigen Forum gesehen.) Wie ist das mit dem Monitor OC, gibt es da Berichte wie viel Lebenszeit das kostet?
In Sachen Monitor gleich noch ne Frage. Habe nen LG DM2780D über HDMI laufen, dieser kommt mir weniger flüssig vor wie mein internes Pannel. (Auch wenn beide mit 60Hz laufen) Liegt das an HDMI?
@Vorny: Habe die gleiche Erkenntnis gewonnen, 6970M mit 840/1000 läuft laut 3DMark11 etwa gleich wie 840/1100. Ob noch mehr als 840 geht habe ich bisher nicht getestet.
Einiges:
@ Prema
Es gibt bereits ein BIOS fuer D900F was die GTX680M unterstuetzt...PM mich wenn Du moechtest ;)
oROMs (Option ROMs) sind Bestandteile des BIOS, zustaendig fuer LAN, RAID, dGPU etc, mit Modulen meine ich in diesem Fall deren UEFI Counterparts (Sorry kenne das Deutsche Wort nicht).
Weiß nicht genau was du meinst?!
Also läuft die 680M im D900F im Eurocom Video wegen einem neuen BIOS?
Kannst du in einem BIOS sehen welche CPUs unterstützt werden? Mich würde interessieren welche Xeon E5 im P570WM inoffiziell unterstützt werden?!
http://tof.canardpc.com/preview/5a8ca553-63a9-4dca-a795-835994ebfb9d.jpg
So sieht das aus, beschreibung des Users aus dem NBR-Forum, bei dem ich das gesehen habe:
"I glued several layers of aluminum tape on the backplate (inside face) to achieve a thickness which comes into contact with the heatsink, it can enlarge the dissipation surface of the heatsink, then I paste 4 ram copper heatsink covering on the gpu and 3 on cpu. "
Klar ist es eine BIOS vBIOS Kombination...
Muesste man schauen welcher Microcode enthalten ist, sollten aber Theoretisch alle laufen or zum Laufen zu bringen sein.
Ich weiß nicht ob das so viel bringt, da die Serviceklappe ohnehin ein schlechter Wärmeleiter ist, zumal man dabei noch Gefahr läuft ungünstig Druck auf den Kühler auszuüben?!
Zumindest für mich war das bisher nicht so klar. Am Ende des Videos bei der Angabe der Systemkonfiguration wird ja auch nichts von modifizierten BIOS Files erwähnt?!
Wenn ich mich recht erinner, war der E5-2680 der einzige CPU neben dem i7-3820 sowie i7-3960X und i7-3970X, welcher beim BIOS Boot Screen nicht korrekt erkannt wurde mit Model Bezeichnung. Das ganze interessiert mich aus dem Grunde, da ich mir ein E5-2689 gekauft habe für das P570WM und hoffe dieser wenigstens inoffiziell unterstützt, also 100% richtig erkannt, wird. Offiziell gibt Clevo ja nur den 3820, 3930K und 3960X an...
Kurzes Update: Habe von Hand mal alles was AMD/ATi heisst von der Platte geschmissen bzw. aus der Registry entfernt, im abgesicherten Modus nochmals das ganze gegengeprüft und die Karte im Geräte Manager deinstalliert - bis jetzt keine Bildfehler mehr, alles i.O. trotz den Schmauchspuren. Weiterhin keinerlei Kontakt seitens NBG/NBB erhalten, daher werde ich die Rechtschutz mal nutzen.. Mal schauen was bei rum kommt..
Das ist schön zu lesen! :)
Danke ;) Hoffe der Zustand bleibt so - dennoch alles sehr ärgerlich mit der Karte, der Umbau selbst ist ein Kinderspiel. Schreibe bei Zeiten dann mal den Guide ;) Für den ersten Umbau mit Fotos etc. habe ich eine Stunde gebraucht - jetzt tausche ich die Dinger in 10 Minuten inkl. Treiber installieren.. Hab an der Kiste genug geübt - hehe - genauso flashen..
Diese "Kontakt-Problematik" hatte ich mal bei deinem 7970M-Verkäufer angesprochen. Schade das sich da augenscheinlich nicht ausreichend etwas getan hat, das man solche Schritte gehen muß wie bei dir jetzt :(
Ja das ist leider mehr Service-Wüste als alles andere... Naja, im Endeffekt müsste NBB/NBG mich kontaktieren, ich habe ja im Moment zwei 7970m bei mir und für ihn ist das auch totes Kapital ;)
@prema
gibt es schon einen bios/vbios für das alte d900f modell, dass die grafikkarte geforce 560m unterstützt?
wenn ja, soll ich dich anschreiben, oder hast du vielleicht einen link für mich?
Weiss jemand, wo das Hawkforce Unterforum im Support/Herstellerbereich hin verschwunden ist? Sehr dubiös.
Wurde auf Wunsch von HawkForce deaktiviert.
besser gesagt auf Wunsch von manche User , die ganze Rasterei und Provokationen und so, haben dazu beigetragen , auf ein gute Wort über HawkForce haben gleich mehrere User sich mit negative Wort über HF gemeldet (im Großteil haben die nicht mal HF kennengelernt) , ist das bissen Krank aber egal , das was habe ich hier erlebt habe ich noch nie gesehen , bin selber hier ausgerutscht weit Tief auf level von einem User "SF" .
wenn soll das auch so sein dann meine letzte News hier :
Undervolting : erst Master auf 0.975Mhz , in Single funktioniert einwandfrei
Lg Vss
ed
VIP Stuff erscheint auf andere Forum ,
Nein, das hab ich so von ganz oben. Das stimmt schon, vss.
Hat er sich gemeldet über die Feiertage?
Nur nen kleiner Hinweis: Bilder-Zitate werden im forumdeluxx nicht gern gesehen von den Mods ("Foren-Regel").
GLG
@ ch4f&vss: Danke für die Info - macht mich etwas "traurig"
traurig finde das auch für mich , weil so tief bin ich im meinem ganze leben nicht gerutscht, nur das ich spaßeshalber gespielt habe das Abbild "Pro" User (aka Schauspieler) , das Forum von sich selbst finde ich genial , aber was hier abgeht habe ich noch nie im andere Foren gesehen (wie Waschvorgang im Schlamm ) Relationen SFVogt(aka Schauspieler) und Rest von der Truppe->HF, aber dankt diese verhalten habe für mich das Bild von andere Reseller gemacht , nicht für ungut , gute daran ist , das niemand von meine Kreis betätigt sein kauf bei Reseller welche SFVogt (aka Schauspieler) unterstützt . ,
meine Schreibweise ist nicht das was wird hier erwünscht ,bin 36 Jahre alt , verständige mich mit 3 sprachen so wie Chinesisch schwaches Grundsatz (aber ich bin lernfähig und ich gebe nie auf !) das reicht mir um zu überleben.
lg
Nicht alle hier sind so vss, Chaoten gibt es überall.
Leider lassen sich manche provozieren, was dann meist nach hinten los geht. (Hüte dich vor den dummen, sie ziehen dich auf ihr Niveau herunter und schlagen dich dort mit Erfahrung) :fresse:
Es wurde weiter getrieben als nötig gewesen wäre - kommt nicht oft vor.
Ich mag Hawkforce, aber jede Firma hat ihre Schattenseiten...
Gesendet von meinem HTC One V mit der Hardwareluxx App
mir tut weh diese verhalten , da sind zahlreiche aussagen editiert manchmal Monate nach dem sie Erstellt worden , und genau diese Aspekt ab Position 9 , das ganze hat mich anfrage um Echtheit meines Notebook gekostet dankt meine Anwalt und was für eine Alarm habe ich bei HF geschlagen ehhhh , nun jetzt habe ich in zwischen erfahren das das Glaskugel muss nicht immer spiegelglatt sein.
ich habe mit HF ganz klare Abmachung: HF liefert teile ich bastle als Hobby , weil war für mich das klar ob mit oder ohne HF werde ich so wieso was gebastelt , so mit bin HF Pro User geworden nur weil andere haben kein Plan
@all: Mir ist grad aufgefallen, das CPU-Z bei mir die TM1 und TM2 rot ausgeleuchtet sind - ich weiss jetzt nicht ob das beim 2760QM bereits nach dem Einbau so war.. Woran kanns liegen? Betreibe die Kiste grad mit Clevo Setting auf "Balanced" und auch Windows mit der Mittelstellung. Da sollte doch nix am Thermal Monitor geändert sein?! Temps etc. sind auslesbar, auch die Spannungen, Taktraten werden je nach Last gesenkt/gesteigert. XTU habe ich nicht installiert.
@ vss
Da a) deine Hetzbeiträge in mehreren Topics offensichtlich gar nicht mehr zum Ende kommen sowie b) die Meldung deiner Provokationen hier an die Mods wohl ungehört blieben und c) ich der "HawkForce (HF) Feind Nr1" deiner Wahl bin, nötigst du mich das ich Stellung dazu nehme und dir mal ein paar unangenehme Eckpunkte ins Gedächtnis rufe:
  • Ich habe keine Schuld daran, das sich ein nichts ahnender Notebook Besitzer mit seinem "P370EM - Crossfire überhitzt" Thema hilfesuchend an die HLuxx Forengemeinde richtete! Dies ist gang und gäbe in Foren und damit sollten Anbieter in der heutigen Zeit rechnen können wenn er ein "Support Forum" einrichten lässt.
  • Ich habe keine Schuld daran, das HF sich seinem Kunden in diesem Thema erstmalig so "unhöflich" gegenüber äußerte. Dies empfand nicht nur ich so (und habe mich dennoch zurück gehalten), sondern auch andere User. Diese hatten möglicherweise keine eigenen HF Kauferfahrungen, äußerten aber ihre Meinung/Eindruck zum Themenverlauf, das ist völlig legitim in Internetforen!
  • Ein Internetforum (von lat. forum, Marktplatz; engl. Bezeichnungen: internet forum, message board und webboard), auch Diskussionsforum, ist ein virtueller Platz zum Austausch und Archivierung von Gedanken, Meinungen und Erfahrungen.
  • HF entschied sich seinem Kunden so gegenüber zu äußern. HF entschied sich andere User "anzupöpeln". HF entschied sich das Thema ohne Entschuldigung zu schließen. HF entschied sich das Thema 3 Tage später zu löschen. HF hat hier maßgeblich zur Eskalation beigetragen und hat persönlich für Empörung bei anderen Usern gesorgt!
  • Ich habe keine Schuld daran, wenn andere HLuxx User ihre Empörung/Unverständnis weniger sachlich ausdrücken und damit zu Wort melden! Ich stufe meine Aussage zur damaligen Thematik als sachlich ein. Jedoch sind Private Nachrichten von dir mit zweifelhaftem Inhalt definitiv untragbar und weit übers Ziel hinaus.
  • Ich habe auch keine Schuld an der letzten großen Diskussion im HF Support Bereich! Ich habe mich aktiv nicht zu Wort gemeldet um Diskussionen mit dir aus dem Weg zu gehen! Auch in diesem Thema keine (versöhnliche?!) Stellungnahme vom Anbieter. HF hat sich entschieden kein Kommentar abzugeben bzw. die Chance auf Schadensbegrenzung nicht zu nutzen. HF hat sich entschieden den Support Bereich zu deaktivieren.
  • Du ganz allein entscheidest darüber wie du dich (im Internet/Forum) präsentierst und "wie tief du sinkst". Weder ich noch andere HLuxx User schreiben deine Beiträge! Du bist einzig für dein Handeln verantwortlich egal in welcher Situation, ob das immer so hilfreich ist für deinen Anbieter wage ich zu bezweifeln. Und ja, weit tiefer als ich ... bis zum "(HF) Fanatiker" ... ohne Worte.
  • Ich editiere (auch ältere) Beiträge aus einem ganz simplen Grund der vielleicht "ein bisl" pedantisch wirkt: Rechtschreibfehler die ich übersehen habe im Eifer des texten oder auch Ausdruck der manchmal etwas unverständlich ausgefallen ist. Andere legen da kein Wert drauf, ich schon, zumindest wenn es mir direkt auffällt!
Die Schuld kannst du zu gleichen Teilen bei dir (der gern gegen einen anderen Anbieter pöpelt/provoziert und dann den Unschuldigen spielt wenn er eine Retourkutsche kassiert) als auch HF selbst suchen und nicht nur auf mich und deine "auserkorene böse HF Feind Truppe" abwelzen!
Verantwortung übernehmen für euer eigenes (Fehl-)Verhalten, bitte!
OFF TOPIC an allle Diskussionsfreudigen über HF; mySn..
Ganz ehrlich - könnt ihr euer gebashe bitte in PNs miteinander klären, ohne jedesmal die Öffentlichkeit hier im Forum in Mitleidenschaft zu ziehen? Es geht mir persönlich beidseitig total an die Nerven, da in fast jedem Thread der hier auch nur annäherend etwas mit Clevo Barebones zu tun hat, irgendwo Seitenlang immer wieder Diskussionen stattfinden, die rein gar nichts mit dem Thema zu tun haben und völlig sinnfrei für den Thread sind!
Ich fühle mich hier im Clevo Bereich wie im Kindergarten, da schreibt der eine dem anderen seine Meinung vor, weiss es in jedem Fall besser oder verweist auf Misstände die Wochen her sind und eigtl. niemanden mehr interessieren.
Ihr dürft gerne eure Meinung preisgeben, aber bitte passend zum Thread oder zu Fragen die gestellt werden und nicht seiten später wieder ein Bash in die andere Richtung, wenns um einen Subvendor geht, dann macht doch einen Diskussionsthread auf, bei dem es um die Qualität des einzelnen geht oder sonstwas, da kann man sich dann auch gerne die Köpfe einschlagen - da muss ich nämlich nicht immer wieder reingucken, weil ich denke es findet eine Diskussion oder ein Hinweis zu einem Barebone Platz im Thread.
BACK TO TOPIC:
Prema konnte mir bezgl. dem TM1/TM2 Thema im NBR helfen, ist alles i.O. und die Ausgabe von HWInfo in diesem Fall nicht ernst zu nehmen. Er hat das an Hand der Microcode Update Revision festgestellt.
Entschuldige bitte das ich dir das sagen muss, aber Du warst derjenige welcher diese Diskussion in dieses Thema getragen hat. Das dies nicht folgenlos bleibt, war abzusehen...
Gesendet mit der Hardwareluxx App von meinem SONY XPERIA Z
Nun ja, das würde ich nun nicht als Anstoß der Diskussion sehen. VSS musste wieder auf den Anderen rumhacken. Das war der Auslöser. Die Frage war imo definitiv berechtigt.
@SFVogt: Ich wüsste ganz ehrlich nicht, wo ich hier etwas trage bezüglich einer Diskussion - ich stelle eine normale Frage auf ein fehlendes Unter-Forum, nicht mehr, nicht weniger. Wo soll ich sie sonst stellen, ausser im allgemeinen Clevo Thread? Natürlich besteht die Möglichkeit, das ich bei Hawkforce direkt Anfrage, aber wegen einem fehlenden Unterforum mache ich mir da nicht unbedingt die Mühe. Ich denke du gehst auf das "Sehr dubiös" ein, was nach meiner Frage steht - das ist nur meine Feststellung und keine Aufforderung auf gebashe - die Rückfrage war mit der Antwort von CH4F für mich schon erledigt.
Wenn hier zwei Parteien meinen, sie müssen auf Grund dieser Frage wieder ein geplänkel am Thema vorbei anfangen, ist das nicht mein vergehen. Die ganzen Diskussionen trage nicht ich, sondern immer wieder DU und dein Diskussions-Partner VSS, um einfach mal zwei Namen zu nennen. Ich fühle mich nicht für irgendwas hier verantwortlich, ich Frage nach Meinungen, Erfahrungen und gebe meine Meinungen und Erfahrungen mit den Geräten weiter und eben auch Themen, wenn bei einem Teil für das Endgerät was nicht stimmt was ich von Subvendor XYZ bestellt habe.
Ich bashe aber nicht fortwährend in jedem Thread über immer das gleiche Thema. Auch unterstelle ich niemanden etwas oder leite irgendwelche Dinge aus seinen Posts ab - sondern behandle hier jeden Threadteilnehmer gleich, ohne einen Hintergedanken (ob Fanboy, gesponsored oder sonstwas).
Das tue ich bei dir, das tue ich bei vss und auch bei anderen, weil mir die Erfahrungen die ihr gesammelt habt natürlich auch etwas nutzen und ich hoffe, das ihr diese auch weiter teilt. Denn man kann eigentlich in keinem Umfeld genug Wissen und Erfahrungen machen da viel aus, um Dinge beurteilen zu können. Ob das nun bei einem Notebook ist oder im Beruf etc. pp.
Ich hoffe du verstehst was ich meine, ich bin gerne bereit weiter zu diskutieren, falls das notwendig ist in deinen Augen - dann aber bitte per PN. Ich denke die meisten hier sind alt genug, um Themen die im Raume stehen lösen zu können ohne das die Forumschaft daran teilnehmen muss.
@CH4F: Danke, sehe ich auch so.
