[Sammelthread] Clevo Barebone - Upgrade & Modifikationen (alle Modelle)
Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones :wink:
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR (Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/091. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/091. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/091. System BIOS 1.02.08 for P570WM only.
2013/01/191. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/191. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/191. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/071. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/071. System BIOS 1.00.02 for P570WM only.
LINKS:
[Sammelthread] 17,3" Clevo P570WM(3) SLI/CFX High-End DTR (2012)
# 17,3" Clevo X7200 (Release Q3/2010) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/10/281. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/231. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/081. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/101. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/201. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/251. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/111. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/251. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/051. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/151. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
2010/09/301. System BIOS 1.00.03.
2. Solve "system can't identify nVIDIA GTX 460M VGA card correctly" issue.
LINKS:
[How-to-Video] AMD Radeon HD 7970M CrossFireX Installation in EUROCOM Panther 2.0 (X7200)
# 17,1" Clevo D90xF (Release Q2/2009) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/05/251. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/301. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/221. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/161. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/241. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
LINKS:
[User-Review] 17,1" Clevo D900F Gamer/Workstation Notebook
[How-to-Video] NVIDIA GeForce GTX 680M upgrade in EUROCOM D900F Panther
# 17,1" Clevo D90xC (Release Q2/2007) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2008/12/121. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/121. KBC/EC firmware for Windows XP keyboard only.
2008/12/121. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/201. KBC/EC firmware for VISTA keyboard only.
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/201. KBC/EC firmware for XP keyboard only.
2008/10/14Support Q9550 CPU.
2008/09/10Support nVIDIA NB9x series VGA.
2008/07/22Support 9800M GT VGA card.
2008/06/121. KBC/EC firmware for XP keyboard only.
2. Solve "sometimes system can't boot up" issue.
2008/06/121. KBC/EC firmware for VISTA keyboard only.
2008/05/20Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30 1. KBC/EC firmware for VISTA keyboard only.
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/301. KBC/EC firmware for XP keyboard only.
2008/03/21Support both partnet board and daughter board.
2008/03/12Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/121. KBC/EC firmware for VISTA keyboard only.
2. Solve VGA temperature probe inaccuracy issue.
2008/03/121. KBC/EC firmware for XP keyboard only.
2008/01/21Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/181. KBC/EC firmware for XP keyboard only.
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/291. KBC/EC firmware for VISTA keyboard only.
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/291. KBC/EC firmware for Windows XP keyboard only.
2007/10/291. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/231. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/161. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
LINKS:
[User-Review] CLEVO D901C ...8700GT SLI trifft Quadcore
SLI/CFX GAMER NOTEBOOK (Mobil CPU)
# 17,3" Clevo P370EMx (Release Q3/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/081. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/261. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/261. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/261. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/151. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/241. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/241. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/241. System BIOS 1.02.06 for P370EM3 only.
2012/10/121. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/281. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
LINKS:
[Sammelthread] 17,3" Clevo P370EM(3) SLI/CFX Gamer Notebook (2012)
# 18,4" Clevo P180HM (Release Q3/2011) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/07/061. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/181. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/041. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/211. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/071. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/02/251. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/221. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/101. EC firmware 1.00.08.
2. Modify nVIDIA VGA fan table.
2010/07/151. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support ATI HD5870 VGA.
2010/05/071. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/151. System BIOS 1.00.06.
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/301. System BIOS 1.00.04 and EC firmware 1.00.02.
2010/02/051. System BIOS 1.00.02.
2. Update code base.
LINKS:
[How-to-Video] NVIDIA GeForce GTX 680M Upgrade in EUROCOM X8100 Leopard
[How-to-Video] AMD Radeon HD 7970M upgrade in 18.4" EUROCOM X8100 Leopard Notebook
17" GAMER NOTEBOOK
# 17,3" Clevo P170EM (Release Q2/2012) 03.05.13
TECHNISCHE DATEN: (Modell C)
BIOS CHANGELOG:
releasechanges
2013/04/151. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/091. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/301. System BIOS 1.02.14 for P170EM only.
2012/10/301. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/121. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/281. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/311. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/241. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/271. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/111. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/151. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/081. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
LINKS:
[Sammelthread] 17,3" Clevo P170EM(3) Gamer Notebook (2012)
# 17,3" Clevo P170HMx (Release Q1/2011) 04.05.13
TECHNISCHE DATEN: (Modell C & D)
BIOS CHANGELOG:
releasechanges
2011/10/281. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/161. EC firmware 1.00.08.
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/091. System BIOS 1.01.10 for P170HM only.
2011/09/091. System BIOS 1.01.05 for P17xHM3 only.
2011/08/111. System BIOS 1.01.03 for P17xHM3 only.
2011/08/051. System BIOS for P170HMxx only (except P170HM3).
2011/06/101. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/271. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/061. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/221. EC firmware 1.00.05.
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/181. EC firmware 1.00.03.
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/251. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/141. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
LINKS:
[Prema Mod] P1x0HMx Mod-BIOS
[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
# 17,3" Clevo W88xCU (Release Q3/2010) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/10/081. System BIOS 1.00.05.
2. Solve the audio problem of BIOS 1.00.04.
2010/09/141. System BIOS 1.00.04.
2. Solve "Windows Experience Index is incorrect" issue.
2010/08/061. System BIOS 1.00.03.
2. Solve “system can’t identify Intel K0 stepping CPU” issue.
2010/07/091. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/03/03ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/261. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/221. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/081. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/201. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/171. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/201. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/181. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/301. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/251. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/111. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
LINKS:
26.06.10 [User-Review] Clevo W870CU / XMG7.c - bis zu 3,8GHz
15" GAMER NOTEBOOK
# 15,6" Clevo P15xEMx (Release Q2/2012) 04.05.13
TECHNISCHE DATEN: (Modell A & B)
BIOS CHANGELOG:
releasechanges
2013/03/231. System BIOS 1.02.17 for P150EM only.
2013/03/151. System BIOS 1.02.17 for P151EM1 only.
2013/01/191. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/191. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/301. EC firmware 1.02.11 for P151EM1 only.
2012/10/301. System BIOS 1.02.14 for P151EM1 only.
2012/10/301. EC firmware 1.02.11 for P150EM only.
2012/10/301. System BIOS 1.02.14 for P150EM only.
2012/10/121. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/281. EC firmware 1.00.08 for P150EM only.
2012/09/071. System BIOS 1.00.10 for P151EM1 only.
2012/09/071. System BIOS 1.00.10 for P150EM only.
2012/08/311. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/241. EC firmware 1.00.07 for P150EM only.
2012/07/121. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/291. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/151. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/041. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
LINKS:
28.06.12 notebookreview.com = P150EM Upgrading from 675M to 680M!
# 15,6" Clevo P15xHMx (Release Q1/2011) 04.05.13
BIOS CHANGELOG:
releasechanges
2011/11/041. EC firmware 1.00.13.
2. Solve “sometimes screen flickers” issue.
2011/09/161. EC firmware 1.00.12.
2011/09/091. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/051. System BIOS 1.01.12.
2011/07/151. EC firmware 1.00.11.
2011/07/011. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/061. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
(need to update LAN driver to 6.0.26.6 or later)
2011/03/251. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/251. System BIOS 1.01.04.
2011/01/141. System BIOS 1.00.03 and EC firmware 1.00.02.
LINKS:
# 15,6" Clevo W860CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/3/3 ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/10/29 1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20 1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17 1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6 1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11 1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21 VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/4/30 1. System BIOS 1.00.13 for W86xCU only.
2010/2/25 1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11 1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
LINKS:
10.01.11 [How-to-Video] Mount AMD Radeon HD6970M to EUROCOM Cougar Laptop (W860CU)
10.01.11 [Video-Review] EUROCOM W860CU Cougar HD 6970M
08.12.10 [User-Review] 15,6" Clevo W860CU Gamer Notebook
ANHANG
# Clevo Barebone - MXM3.0B Grafikkarten 16.09.12
nVidia GeForce GTX 280M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 285M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 460M (GF106/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 480M (GF100/352SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 485M (GF104/384SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 560M (GF116/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 670M (GF114/336SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 680M (GK104/1344SP) 4096MB (256Bit/GDDR5) 100W-TDP
_
ATI Mobility Radeon HD 5870 (RV840/800SP) 1024MB (128Bit/GDDR5) ~75W-TDP
_
AMD Radeon HD 6970M (RV940/960SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
AMD Radeon HD 7970M (Wimbledon XT/1280SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
@vss:
Alle sind Deppen, nur du nicht? Verblendeter kann man nicht sein und zeigt wessen Geites Kind du bist. Kompetenz oder Objektivität sind es ganz offensichtlich nicht. Und das sehen viele User auch so, aber das sind ja in deiner kleinen Welt alles Deppen. Du pisst nicht anwesende Leute von der Seite an und weinst dann wenn es nicht unkommentiert bleibt.
http://www.hardwareluxx.de/communit...gen-kann-dies-sein-951800-2.html#post20432676
http://www.hardwareluxx.de/communit...gen-kann-dies-sein-951800-2.html#post20433932
Hawkforce sollte auch seine Hawkforce Crew einstampfen, beim Support Forum haben sie es ja doch schon eingesehen, nur gehören auch die unglaublichen Rekruten dazu. Besser kein Support, als solche pubertären "Uniformträger", die das Hawkforce Marketing in der dümmsten Weise in die Welt tragen.
Nicht alle hier sind so vss, Chaoten gibt es überall.
Leider lassen sich manche provozieren, was dann meist nach hinten los geht. (Hüte dich vor den dummen, sie ziehen dich auf ihr Niveau herunter und schlagen dich dort mit Erfahrung) :fresse:
Es wurde weiter getrieben als nötig gewesen wäre - kommt nicht oft vor.
Ich mag Hawkforce, aber jede Firma hat ihre Schattenseiten...
diese Zitat ist an Aktivste User adressiert (im Relationen HF-> Rest der Welt) , nun wenn geht um Fachkenntnisse im Bereich NB dann meldet sich keine von dem Pro User :) ,
ich kaufte mir ein Notebook und das hat euch nicht gefallen ? das ist doch lächerlich, und wenn ich bin zufrieden von dem Notebook dann muss ich der Böse sein hahah, geht euch noch Gut? glaube nicht!
dann wo ist der hacken hier ? wenn geht nicht um Notebook , jedoch anscheint geht um Notebook besser gesagt oder deutlicher "CrossFire" , und meine CrossFire SetUp lief optimal Butter-weich dabei Temperaturen sind niedriger als bei nVida GTX680m :banana: " CF kühler und schneller als NvIdia" ja ja dabei konnte sich jemand verschlucken nicht war ?, und denke ich mir das ist der einziger Grund wieso hier und Da rasten Pro User auf :
Erfahrung: alle Mittel zugelassen Cool ,
Danke Pirate
wollt nur damit sagen das ich steige aus! , so mit Eure Erfahrung mit Reseller macht Clevo Bereich Unbrauchbar für mich , zum Glück im meine leben komme ich zu recht weil ich Plan habe!
mir ist noch was eingefallen : jede Kritik verbessert dem Service wen im geringste teil aber doch positiv , nun bitte mit dem Kritik nich übertreiben weil kann es sein das HF mit seine Service irgendwann stellt euch im Schatten :),
Ich glaub du hast meine Aussage bisl falsch verstanden als ich es eigentlich meinte bzw aussagen wollte, aber egal. Ich hatte nie und habe ebenfalls keinerlei Interesse das weiter breit zu treten und diesem ganzem völlig sinnlosem Scheibenkleister weitere Zeit zu schenken. Nein, es besteht kein weiterer Diskussionsbedarf meiner seits.
Keine Fullquotes in der Länge bitte :rolleyes:
Das schlimmste ist das es hier gar nicht mehr um " Clevo Barebone - Upgrade & Modifikationen (alle Modelle) " geht. Welcher normale User wird hier demnächst noch lesen. Habe gerade 10 Minuten verschwendet um nur annähernd raten zu können was die letzten Posts bringen sollen ??????????????????????????????????????????????????????????????????????????????? Sorry , Guido
Darum wurde Schriftgröße verkleinert, wurde angepasst.
Bitte sag mir, warum hat hier jeder andere zugeschaut als ein Beitrag nach dem anderem am Thema vorbei ging mit reiner Provokation? Bitte sag mir, warum sagte niemand anders einem gewissen User JETZT REICHT ES HIER ABER (bis zuletzt eine Ausnahme), obwohl alle gesehen haben das es gar nichts mit dem Thema zu tun hat und auf reine Provokation hinausläuft?
Sorry ganz ehrlich, es ist mir langsam auch egal ob hier oder meiner anderen Sammelthreads (ST) einer lesen will, weil ich einfach keine Zeit mehr aufbringen werde diese zu pflegen und gar nicht dran denke neue zu erstellen. Meine Intention bei den Threads war sehr gute neutrale ST für alle Clevo User des jeweiligen Barebone zu erstellen, mit allem drum und dran im aktuell gehaltenen Startbeitrag. Nicht ich unterstütze t5SN, sondern t5SN hat mich unterstützt die ST interessanter zu gestalten für andere User bzw. Interessenten. Geb ich deswegen überall t5SN Kaufempfehlungen oder predige überall wie toll die sind? Nein! Hat t5SN dafür irgendwas in der Richtung verlangt? Nein! Warum machen sie das (fragte ich mal): Weil in den Sammelthreads Kompetenzen zusammelaufen und der Bekanntheitsgrad der Clevo Geräte erhöht wird (war die Antwort eines Mitarbeiters).
Wieviele haben sich denn in den ST "gut informiert" gefühlt und haben sich ein Gerät bei einem anderen Reseller gekauft? (Was völlig okay ist) Zum Beispiel bei dem Reseller dessen Hilfskräfte ständig gegen den einzigen Clevo Anbieter schießen, welcher die Community hier in den ST z.B. mit BIOS Files versorgte oder sich bei Problemen einsetzte gegenüber Clevo, von dem am Ende alle User profitiert haben egal bei welchem Anbieter gekauft?
Das einzige was ich tue, besonders bei zwei allseits bekannten Hilfskräften eines Anbieters, sagen es reicht wenn diese mal wieder aus Spaß schwachsinnige Beiträge loslassen die jeder Logik entbehren als auch am Thema vorbei geht und rein der Diskreditierung dienen. Aber das muß ich mir wohl auch in meinen aufwendig geführten ST gefallen lassen, um den allgemeinen Frieden zu wahren. Denn offensichtlich hat der überwiegende Großteil die "nichts hören, nichts sehen, nichts sagen" Einstellung ... deswegen wird hier ein anderer User schon als "mein Diskussionspartner" betitelt. Vielen Dank! Aber vielleicht hab ich nur so ein falsches Unrechtsbewusstsein, ich entschuldige mich dafür in aller Form...
Dir die Antwort auf deine "Frage" mit den Worten meines Arbeitskollegen gesagt: "Das ist mir (langsam) bums!"
Ahoi,
wenn ich über GPU-Z mein vBIOS Auslese, kann ich dies ohne weiteres mit dem ATI Flash Tool auf meine zweite 7970m übertragen oder sollte ich noch auf etwas achten?
Mal schauen ob ich die zweite 7970m hier nicht doch zum leben erwecken kann.
Grüße
F1r3
Ich denke nicht, dass da Probleme aufkommen. Die Karten selbst sind ja baugleich und das BIOS wird wohl auch die selbe Größe, ggfs sogar die selbe Version haben.
Ahoi,
Grüße
F1r3
Im worst case gehts so aus: irreversibler Brick aufgrund fehlerhaftem und nicht vollständig durchgeführtem flashvorgang. kann bei winflash als auch bei atiflash im dosmodus passieren. mir ist damit die 6990m eingegangen letztendlich. wenn du flash machst und der flashvorgang mit fehler endet, darfst du keinesfalls das notebook neu starten, nur standby und am strom lassen bzw. an lassen. beim reboot wird vbios ausgelesen und dann steht die kiste. wenn der flashvorgang normal endet, sollte alles passen und die kiste rebootet mit neuer Gpu Seele :)
Naja wenn die GPU bricked wäre es erstmal egal, hab ja die aktuelle Karte die bis jetzt auf wundersameweise läuft als sei gar nichts - nur die Schmauchspur ist ein Makel ;)
Thanks for the info btw :)
Es geht noch mehr... stock for the win ;)
Nach etwas tweaken mit der Folie etc. pp. bin ich nun bei 0.975v @ core clocks (850/1200) mit max. 61 Grad beim gamen (BF3 @ 3 stunden) und benchen (3D Mark(11/13)) - gut zu wissen, dass die GPU noch Reserven hat.
Klingt gut! man könnte ja mal eine Email an schenker oder besser direkt clevo/Goldenstar schreiben.
Mache ich später ;)
Hallo ich bin beim googlen grad auf folgenden Blogeintrag gestoßen.
und es geht weiter … neues BIOS P170HM.1.00.14c von Clevo fürs P701 | Michaels Tech Blog
Hat jemand nähere informationen wo man dieses neue Bios für die P701Hm modelle finden und downloaden kann?
Eventuelle verbesserungen bezüglich Windows 8 Helligkeitsbug ?
Dieses BIOS-Update liefert keinen Win8-Support nach sondern behebt lediglich einen seltenen Microcode-Bug mit bestimmten Intel-CPUs.
Das Update wird in Kürze unter mysn.de/driver/Archiv/XMG_P701/BIOS/ verlinkt.
Die da wären? Nicht zufälligerweise der 2760QM der von heute auf morgen TM1/TM2 meinte nicht mehr zu haben laut CPU-Z?
Kann ich als nicht mySN Kunde das BIOS nutzen oder wird da eurerseits noch was hineingewünscht?
Thx for your reply!
Nein, das BIOS ist original und unmodifiziert. Hier ein Link zur Original-Datei (von Clevo) ohne XMG-Logo:
https://www.dropbox.com/s/n5qwph4n4b5n54y/P170HM.1.00.14c.rar
Zum Inhalt: es handelt sich um ein Update der im BIOS hinterlegten CPU-Microcodes, mehr nicht. Wir sind gespannt auf deinen Erfahrungsbericht!
Also wenn man von Clevo eine unveroeffentlichte BIOS base bekommt wenn man einfach ein cpu microcode update bestellt, dann haette ich bitte gerne das gleiche update fuer die 3D version P170HM3. DANKE :)
EDIT: Sieht aus als waehre der korrekte Name 1.01.10c, da hat einer bei Clevo wohl am Ende was mit dem P150HM durcheinander gewuerfelt. :)
Im Startbeitrag für fast jedes Barebone die technischen Daten hinzugefügt :wink:
BIOS Changelog zu allen aufgeführten Barebones hinzugefügt :wink:
Kurzes Update zu meiner 7970m Odysee...
Ich hatte mit dem mySN Support hier im Forum Kontakt auf Grund eines meiner Posts, da kamen wir auch auf mein Problem Thema Notebookguru/Barebone zu sprechen und das meine Ersatzkarte ja einen defekt hat und sich keiner mehr meldet etc. - mySN hat darauf hin für mich einen RMA eröffnet und das Problem gegenüber Clevo angezeigt. Ich habe dann die Karte an mySN versendet, mit der Absprache, sollte kein Fehler zu finden sein oder Clevo nicht weiter reagieren, dass ich im "ungut"-Fall dann eben die 60 Euro Service Pauschale gegenüber Clevo/Goldenstar übernehmen müsste.
Na was soll ich sagen.. Habe die Karte am Dienstag versendet und ratet mal was der Postbote gerade bei mir abgestellt hat.. Genau, eine Nagel-Neue 7970M mit dem aktuellsten Layout, ohne Burnmarks ohne sonstige Anzeichen von Pfusch wie bei meinen beiden alten Karten ;-)
DAS!!!!!! nenne ich Support, nachdem ja nicht mal Kunde bei mySN bin - werde ich das wohl aber in naher Zukunft wohl werden! Habe selten so eine Aktion erlebt, die rein auf Hilfe und ohne Gewinnabsicht passiert - kann daher nur massiv lobend über mySN sprechen - das ist vorbildlich!
Tausend Dank auch hier nochmal!
Jetzt muss die neue Karte nur noch spielen, ich gehe aktuell davon aus das ich sie mit dem HM-BIOS erstmal betanken muss, aber das kann ich erst kommende Woche prüfen ;)
Es grüßt ein richtig gut gelaunter
F1r3
@ F1r3
Top das über Umwegen doch noch ne einwandfreie Karte bekommen hast. So eine "Fremd-RMA-Abwicklung" wurde mir auch schon mal bei einem Barebone-Problem von mySN angeboten, staunte ich auch nicht schlecht ;)
Manche hersteller können halt mit ihrem Support glänzen ;) ok genung off topic von meienr seite.
Guten Morgen, ich hatte zwar schon einmal gefragt aber is ja auch was her. Habe ein XMG P502 Pro von mySN/Schenker mit beleuchteter Tastatur,
verbautes MB ist ein P150EMx mit i7-3612QM - 16GB Ram und GTX660M.
Was mich nach wie vor etwas annervt ist das Bios, die Einstellmöglichkeiten tendieren gegen null.
Ich möchte gerne die CPU dauerhaft etwas runtertakten weil die Lüfter alle fuz lang hochdrehen. Gibt es evtl. mittlerweile ein Bios mit
Einstellmöglichkeiten?
Danke, Michael.
Danke, Michael.
Der BIOS Spezi Prema hat sich der BIOS "Problematik" angenommen, siehe folgenden Link:
P150EM / NP9150 | Prema Mod
Hier kannst du ein Mod BIOS runterladen was den Umfang wohl sichtbar erweitert.
Um den CPU Takt zu senken, kannst du mit der XTU Software (auf Treiber CD) die Multiplikatoren verringern, sodass die CPU nicht mehr so hoch taktet.
Sollte funktionieren, einfach mal testen.
Hallo SFVogt, Danke, dann schau ich mal beim Prema vorbei. Was die XTU Software betrifft, die hab ich noch gar nicht gesehen. Das wäre dann aber
doch nur im laufenden Betrieb unter Windows oder? Das wär für mich nur ne Notlösung, mir wäre das am liebsten wenn ich das im Bios einmal einstelle
und dann vergessen kann...
Gruss, Michael.
Wie der BIOS Umfang aussieht weiß ich nicht, habe weder das passende Barebone und Screens habe ich noch keine gesehen. Kannst du nur mal flashen und schauen ob es dir weiter hilft :wink:
Das Über-/Untertakten geht ausschließlich mit XTU, im BIOS wirst du nichts finden.
Hi, ich bin gerade eben auf diesen schönen Thread aufmerksam geworden und wollte gleich mal ein paar Fragen stellen:
Weiß hier jemand ob es möglich ist ein P170HM 230 Watt Netzteil mit einem P150Hm Notebook zu betreiben?
Netzteil 230 Watt, original fr Clevo P170HM - ipc-computer.de
Und wenn ja, benötige ich dann Stecker weiblich oder Stecker männlich?
@Perma ich wollte mal ganz lieb fragen ob du auch ein modifiziertes Bios für das P170HM besitzt?
Hintergrund des Ganzen ist:
Mein Clevo P150HM ist bereits mit einer Radeon 7970M ausgerüstet, nun soll ein Core I7 2960XM folgen.
Backplate ist schon modifiziert, ALU Tape angebracht, die zusätzlichen Kupferkühler auch.
Als nächstes folgt dann der Bios Flash auf ein P170HM Bios und danach der Einbau der CPU.
Da die 180 Watt sicher nicht für eine Overclocked CPU und GPU reicht wollte ich mal fragen ob man nicht ganz simpel ein P170HM Netzteil nehmen kann.
