Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR(Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
release
changes
2013/03/09
1. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/09
1. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/09
1. System BIOS 1.02.08 for P570WM only.
2013/01/19
1. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/19
1. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/19
1. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/15
1. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/15
1. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/07
1. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/07
1. System BIOS 1.00.02 for P570WM only.
1. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/23
1. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/08
1. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/10
1. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/20
1. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/25
1. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/11
1. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/25
1. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/05
1. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/15
1. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
1. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/30
1. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/22
1. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/16
1. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24
nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/24
1. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
1. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/12
1. KBC/EC firmware for Windows XP keyboard only.
2008/12/12
1. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/20
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/20
1. KBC/EC firmware for XP keyboard only.
2008/10/14
Support Q9550 CPU.
2008/09/10
Support nVIDIA NB9x series VGA.
2008/07/22
Support 9800M GT VGA card.
2008/06/12
2. Solve "sometimes system can't boot up" issue.
2008/06/12
2008/05/20
Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/30
2008/03/21
Support both partnet board and daughter board.
2008/03/12
Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/12
2. Solve VGA temperature probe inaccuracy issue.
2008/03/12
2008/01/21
Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/18
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18
Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19
Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/29
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/29
2007/10/29
1. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/23
1. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/16
1. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
1. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/26
1. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/26
1. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/26
1. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/15
1. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/24
1. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/24
1. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/24
1. System BIOS 1.02.06 for P370EM3 only.
2012/10/12
1. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/28
1. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
1. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/18
1. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/04
1. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/21
1. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/07
1. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
release
changes
2011/02/25
1. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/22
1. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/10
2. Modify nVIDIA VGA fan table.
2010/07/15
2. Support ATI HD5870 VGA.
2010/05/07
1. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/15
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/30
1. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/09
1. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/30
1. System BIOS 1.02.14 for P170EM only.
2012/10/30
1. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/12
1. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/28
1. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/31
1. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/24
1. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/27
1. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/11
1. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/15
1. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/08
1. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/11
1. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
1. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2011/10/28
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/16
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/09
1. System BIOS 1.01.10 for P170HM only.
2011/09/09
1. System BIOS 1.01.05 for P17xHM3 only.
2011/08/11
1. System BIOS 1.01.03 for P17xHM3 only.
2011/08/05
1. System BIOS for P170HMxx only (except P170HM3).
2011/06/10
1. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/27
1. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/06
1. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/22
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/18
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/25
1. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/14
1. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
1. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
release
changes
2012/03/03
ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/26
1. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/22
1. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/08
1. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/20
1. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/17
1. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/20
1. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/18
1. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21
VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/30
1. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/25
1. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/11
1. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
1. System BIOS 1.02.17 for P150EM only.
2013/03/15
1. System BIOS 1.02.17 for P151EM1 only.
2013/01/19
1. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/19
1. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/30
1. EC firmware 1.02.11 for P151EM1 only.
2012/10/30
1. System BIOS 1.02.14 for P151EM1 only.
2012/10/30
1. EC firmware 1.02.11 for P150EM only.
2012/10/30
1. System BIOS 1.02.14 for P150EM only.
2012/10/12
1. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/28
1. EC firmware 1.00.08 for P150EM only.
2012/09/07
1. System BIOS 1.00.10 for P151EM1 only.
2012/09/07
1. System BIOS 1.00.10 for P150EM only.
2012/08/31
1. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/24
1. EC firmware 1.00.07 for P150EM only.
2012/07/12
1. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/29
1. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/15
1. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/11
1. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/04
1. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
1. EC firmware 1.00.13.
2011/10/28
2. Solve “sometimes screen flickers” issue.
2011/09/16
1. EC firmware 1.00.12.
2011/09/09
1. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/05
1. System BIOS 1.01.12.
2011/07/15
1. EC firmware 1.00.11.
2011/07/01
1. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/06
1. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
2011/04/22
(need to update LAN driver to 6.0.26.6 or later)
2011/03/25
1. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/25
2011/01/14
1. System BIOS 1.00.03 and EC firmware 1.00.02.
1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20
1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17
1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6
1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11
1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21
2010/4/30
1. System BIOS 1.00.13 for W86xCU only.
2010/2/25
1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11
1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
Und wenn ja, benötige ich dann Stecker weiblich oder Stecker männlich?
@Perma ich wollte mal ganz lieb fragen ob du auch ein modifiziertes Bios für das P170HM besitzt?
Hintergrund des Ganzen ist:
Mein Clevo P150HM ist bereits mit einer Radeon 7970M ausgerüstet, nun soll ein Core I7 2960XM folgen.
Backplate ist schon modifiziert, ALU Tape angebracht, die zusätzlichen Kupferkühler auch.
Als nächstes folgt dann der Bios Flash auf ein P170HM Bios und danach der Einbau der CPU.
Da die 180 Watt sicher nicht für eine Overclocked CPU und GPU reicht wollte ich mal fragen ob man nicht ganz simpel ein P170HM Netzteil nehmen kann.
Sollte demnächst (wer weiss wie BF4 mit der 7970M skaliert) ein neues Book kommen, da ich auch gerne eine Tastatur Beleuchtung hätte dann wirds aber auf Grund der Updatepolitik bei Clevo wohl eher ein Ivy Alien, als ein Haswell Clevo. Die aktuellen Aliens sehen mir zu doof aus und sind viel zu überteuert. Und da im R4 auch eine 780M spielt, kann ich auf die paar % zw. Ivy und Haswell verzichten.
Läuft die? Ist das vertrauenswürdig soweit? Bin bei dem Preis halt echt am überlegen mir jetzt das Upgrade doch mal noch zu gönnen... auch wenn mir an sich die 6970M auch gut reicht.
F1r3 kann dazu wohl mit Abstand am meisten sagen. Ich meinte, du brauchst ein modifiziertes BIOS, wo die Prüfungsroutine (wegen Enduro) fehlt. Dann gibts auch ein Bild.
Der Preis ist super - wirst aber vermutlich nirgends Garantie haben.
Wenn die Karte aus einem p1x0em stammt, kommst um das blind flashen nicht rum, die p370em Karte könnte so glaube ich spielen, da beim 370er auch enduro aus sein muss.
Blind Flash geht aber mit jaybee's autoexec aus SFVogts Link Recht gut.
Beachte auf der Suche folgende Regel: Clevo Karten laufen in Alienware Books, umgekehrt leider nicht.
Hm... ich bin echt am hadern... wie sinnvoll erachtet ihr das Upgrade denn? Werde das Notebook vermutlich noch mindestens nen Jahr benutzen, da ich noch nen Jahr am Bachelor hänge. (Ich bin gefühlt der einzige Mensch, dem 15" nicht zu schwer sind um das Ding täglich dabei zu haben rofl) Habe halt das Gefühl, günstiger komme ich an die 7970M nicht mehr ran. Wie viel bekommt man denn noch für die alte 6970M, oder sollte man die dann eher als Notfallersatz behalten?
Und wie sieht das inzwischen mit HDMI aus? Geht das oder "nur" DVI?
die Sinnhaftigkeit basiert auf Kompatibilität mit dem notebook und nicht zuletzt auf der fps rate der von dir favorisierten Spiele. entscheiden musst du selber. ich z.b. werde von 7970CF weder auf 780 Sli noch 8970 CF umsteigen. ersteres ist ein schlechtes PL Verhaeltnis und letzteres bietet zuwenig Mehrleistung, als dass ein Umstieg darauf gerechtfertigt ist. der performance sprung von 6970 zu 7970 war sehr gross und wenn die gpu funktioniert, mach es.
Der Performancesprung von 6970m zu 7970m ist gewaltig, ich habe ihn ja genau so durchgeführt - allein für BF3 wars das ganze Wert Ich würde daher schon zum Kauf der Karte tendieren, für deine alte 6970m wirste aber nicht mehr wie 150-175 Euro erwarten können. Als Ersatz wäre es daher eine Überlegung sie zu behalten. Andersrum, verklopp Sie und du hast für das Upgrade nur ca. 100 Euro bezahlt aber die doppelte FPS-Leistung als vorher
Es gibt vereinzelt User im NBR; bei denen sogar HDMI funktioniert - warum das so ist, weiss keiner..
Naja, weis halt nicht, kenne soweit Ebay und Notebookbarebone (wo ich nach F1r3's Erfahrungen wohl nicht kaufen werde). Weis ja nicht ob man wo anders vllt auch noch an eine 7970M kommen kann. Hier im Forum wird wohl keiner eine wieder verkaufen wollen?
Habe meine 7970M auch über Ebay für 220€ bekommen. Sind immer mal wieder gebrauchte Karten drinn. Musst halt etwas Geduld haben. Oder Du schreibst mal Clevo DE an, vielleicht nehmen die deine 6970M sogar im Tausch mit Zuzahlung.
Die Idee von SFVogt ist recht gut, Goldenstar könnte das ggf. sogar machen. Schenker oder Hawkforce leider nicht, da hatte ich das damals selbst angefragt
Ansonsten schau mal im NBR auch rein, da sind öfters Karten drin, auch aus Europa (GB; Switzerland, Greece etc.) für recht gute Kurse.
Habe mal eine E-Mail an Goldenstar gesendet. Mal sehen was passiert. Im NBR finde ich aktuell nur Alienware Karten, welche ja nicht passen sollen. Erstmal heißt es in der Sache wohl abwarten.
Eine 780M? Das wäre schon recht nett, aber das Ding wär mir echt zu teuer.. Davor würd ich mir dann wohl doch noch das Angebot von vss leisten können. rofl Spaß beiseite, aber die Nvidia Karten finde ich einfach zu teuer, auch wenn sie paar nette Features und bessere Treiber haben.
Schau dir die Performance im Vergleich zur 7970m an und dann schau mal, wie die 780m mit OC geradezu explodiert was die Leistung angeht.. war bei der 680m genauso
Naja, okay, ist schon ein Argument. Allerdings wäre für mich so ne 7970M schon voll okay, an sich reicht mir ja die 6970M noch, glaube aber, wenn es sich lohnen soll noch ein Upgrade zu machen, dann wird es langsam Zeit.
Alternative könnte es tatsächlich fast sein das Notebook als ganzes zu verkaufen und nen gebrauchten P150EM zu besorgen... mit Glück scheint das auch um 200-300€ Aufpreis machbar. Hänge aber eigentlich auch etwas an meine "kleinen".
Ich würde das Upgrade auf 7970M vorziehen. Alleine um Enduro aus dem Weg zu gehen
Es ist zwar nicht schlecht oder so, aber die Karten performen ohne noch was besser. Außerdem sind gute Quads im P150EM teuer. Du bekommst für 300€ schon einen 2960 XM für das HM.
