Skeemo
Mit deiner Antwort hast du ja alle Register gezogen Hut ab. Sind schon wieder Ferien?
Interpunktion, ausreichend viele Verben und eine klare Aussage
Geht doch
F1 2012 isn't scary because we're going to hold your hand from the beginning. So, right from the start of the game when you fire it up, we go from the introduction sequence, which is commentator David Croft talking about drivers testing in Abu Dhabi, and then the player testing (will be) over a period of two days in game time.
Then we're showing the player what the basic controls are: this is how you drive the car, do some simple tests then from that point forward we assume that you're past the basics and you can go into front-end play whenever you want.
Having said that, the suspension did feel too rigid, so we tried to fix that in F1 2011, but made it too light at the back. Now what we've got with the suspension is that the car is very stable at high speeds, allowing the player to throw it around the track, but when the speed drops then the player is relying on the mechanical grip of the car's tyres and this has them locking up as you slow down and emitting smoke.
Lizenz, es heißt Lizenz *sorry ^^
Scrush, du willst das Ding allen Ernstes wieder kaufen?
Ist doch Standart, oder ?
Mit welchen Eingabegeräten spielt Ihr denn so?
VG
und so schlecht fand ich es nicht. Lenkräder sind mir atm zu sperrig um mir eins zu besorgen (hab nicht genug platz in meinem Zimmer), Pad hab ich weil ich eine xbox besitze also wieso nicht nutzen
Klar gehts es mit Lenkrad viel besser! Aber ganz so schlimm ist es mit Gamepad nun auch wieder nicht
