[Sammelthread] Corsair Dominator Platinum - ft. Corsair Link ( DDR3-1600 bis 2800+ )
No difference between Z87 and Z97 :)
I have a good cpu, I can stable 5.1 with vcore 1.34 , But now I cpu in stock and want to test the memory
My problem is that I never did overclock memory so I'm a little
lost :/
I try to rise slightly voltages below?
VCCSA
VCCIO d
VCCIO a
It is probably not a timing issue, but might be a case of VCCSA and VCCIO(a/d) needing a slight voltage bump. This varies from CPU to CPU. Maybe try increasing both individually in small steps of 10mV, until you find stability. You probably don't need more than +30/50mV total each.
My CMD16GX3M4A2666C10 @ DDR3-2400 CL9 on MSI Z97M GAMING:
Edit: please remove the picture from your quote above
you have enabled xmp profile or put all manual,
Timmins primary, secondary and tertiary all manual?
Exactly these.
Those are manual timings, since my DDR3-2666 kit does not have an XMP for 2400.
What do you think of these voltages below to 2400MHz 4x4gb
I try to increase the voltage to how many + -
VCCSA 0.85 to 0.95
VCCIO didital 1.0 to 1.05
VCCIO analog 1.0 to 1.03
I try so to 24/7?
Like i said in #1019 try increasing voltages individually in small steps of 10mV, until you find stability. You probably don't need more than +30/50mV total each for DDR3-2400.
Made some screenshots for you that should help hopefully :)
RTL section in BIOS with initial values:
Timing Configurator:
Edit: Sag mal emi, haben wir hier im Forum eigentlich schon einen Ghetto bilder Thread? :fresse:
Die hier haben wenigstens noch schöne Heatspreader, im Gegensatz zu meinem Stammkit^^
very good,
what voltage you used for these steps to corsair dominator platinum 2400c9 4x4gb (24/7)?
I have random blue screen, memtest85 0 errors
4790k stock
I do not use offset mode
VCCSA voltage= 0.86v (stock) raise to= ?
VCCIO Digital voltage= 1.016v (stock) raise to=?
VCCIO Analog voltage= 1.016v (stock) raise to=?
I see that you manually set for these steps
IO Compensation (CHA1) =22 <auto settings, I use auto cause problem?
IO Compensation (CHA2) =22 <auto settings, I use auto cause problem?
RTL Init Value (CHA1) =13 <auto settings, I use auto cause problem?
RTL Init Value (CHA2) =14 <auto settings, I use auto cause problem?
Hey krusty, I replied to your message. You can take a screenshot by pressing F12 with a thumb drive attached - it would be easier to help you if you show us what your IO comp / RTL init values as well as RTL and IO-L look like.
thanks for the reply :d
My bios is configured so, I have to change something?
I have random blue screen and memtest85 0 errors
image 1
image 2
image 3
image 4
Hat jemand zufällig ebenfalls ein 8GB Kit 2400er CL10 mit 1,65V? Mich würden ein paar Vergleichswerte freuen.
@emi
Hast Du evtl. auch ein paar Infos dazu - also ICs, Rank o. ä. ?
@Sysnet: Welche Version hat dein Kit (steht auf dem Modellaufkleber am Heatspreader)?
Sind Samsung 2GBit D-Die und damit Dual Rank, wie auch die CMD8GX3M2A2133C9 oder CMD16GX3M4A2400C9, aber wohl ein schlechterer Bin. Mit mehr Spannung macht dein Kit aber vielleicht auch 2400 CL9 oder 2600 CL10, das kannst du nur selbst testen (wenn du es herausfinden willst). Die Performance @ XMP Settings sollte sich nicht großartig von anderen Kits mit solchen Spezifikationen unterscheiden.
Vielen Dank emissary! Hast mir jetzt schon in vielen Themen (bspw. G.Skill ECOs, mehrfach mit den Gigabyte Boards und natürlich hier) gute Hilfe geleistet. Finde die Threads von dir einfach super. :bigok:
Hallo zusammen,
habe heute meine alten Dominator(siehe Sig.) in den Ruhestand geschickt und mir dafür ein 2 x 8GB 2400MHz 11-13-13-31 Kit eingebaut.
Leider bootet dei Kiste mit 1T nicht, mit 2T läuft alles sauber. Ich bin mittlerweile zuiemlich aus dem ganzen Thema raus, ist es überhaupt
realistisch ein 2 x 8GB Kit mit 2T ordentlich laufen zu lassen? Früher war mir 1T ja immer so wichtig.. :angel:
Bis dato habe ich nur die oben aufgeführten Timings manuell im Bios eingestellt, sonst nichts. Woran muss ich denn evtl. drehen um das zum
laufen zu bekommen?
Oh man, wie ich kein Plan mehr von der Materie habe.. :fresse:
Danke!
Hängt auch vom Board ab. Wenn du die Kiste nicht unbedingt zum benchen verwendest, kannst du aber auch einfach drauf pfeifen... denn so groß ist der Performanceunterschied nicht ;)
Ja, eigentlich ist es irrelevant.. Hab bei SuperPi 32M 2 Sekunden weniger oder so, ist ja Jacke wie Hose :)
Trotzdem danke für das Feedback!
Mal ne Frage zur Höhe der Domi's, wie weit bekommt man die runter? Kann man ggf vom "Gartenzaun" ein paar Zacken rausbrechen / bohren damit man mit großen Towerkühlern hinkommt?
Welche Dominator genau? Hier geht es ja eigentlich um die Platinum, deren Lightbar ist zwar demontierbar aber den flachen Kühlerkörper darunter zu entfernen würde vermutlich zu Garantieverlust führen. Dann ist es wohl sinnvoller sich nach einem anderen Kühler umzusehen, denn Alternativen mit guter Kompatibilität zu höheren Speichermodulen gibt es inzwischen ja mehr als genug.
Edit: Bei den GT hingegen kannst du die Topfins problemlos abnehmen.
Das Forum ist heute morgen ein Gruselkabinett. Erst lese ich von Leuten, die beim Aufsetzen der Sockelschutzkappe den Sockel ihres Mainboards zerstören, dann wollen Leute einzelne Stege der Lightbar rausbrechen.
Nimm doch einfach Low Profile, unter dem Towerkühler sieht man wahrscheinlich eh nicht mehr viel.
Es geht bei mir nicht darum was ich damit mache, sondern die Auswahl an kaufbaren (gebraucht/neu) ist leider nicht mehr wirklich groß wenns um DDR3 mit 2133+ Takt geht. Von daher möchte ich mir nur paar Optionen offenhalten - und ja mich interessiert auch nicht wie die Dinger aussehen nach eine möglichen "Verkleinerung", da eh keiner in meiner Rechner schauen kann :)
Der Marktplatz ist voll bis oben hin mit günstigem, gutem DDR3.
ist er leider nicht, bin da schon Wochen drauf unterwegs - da findest meist nur <2133 oder sowas wie 4x2GB...
aber hier gehts mir nicht um was wo zu kaufen ist (oder nicht) sondern ob jmd mir einfach mal sagen kann - ja kann man machen, ist ungefährlich, geht nix bei kaputt oder nicht machen, weil dann gleich der halbe Kühlkörper zerbröselt und die Ramchips gleich mithimmelt... und ggf noch wie hoch dann so ein Riegel ist.
Er hat aber recht, ich hatte sogar selbst ein 2666er Kit im Angebot bis vor ein paar Tagen.
Die Platinum würde ich zum zerfrickeln nicht empfehlen, es gibt ein gewisses Risiko die Module selbst zu beschädigen und das Kit ist hinterher praktisch wertlos. Dann nimm besser streetjumper16's GT, die sollten problemlos 2600+ machen (wie andere gute Samsung 2Gbit D-Die Kits auch).
Ich sitz auf 8 Riegeln tridentX 4GB 2400 9-9-9... wenn man die rote Flosse abnimmt, sind die flacher als Domplats, fast so flach wie Kingston Hyperx fury. Wär das was?
