[Sammelthread] DFI LANparty DK 790FXB-M2RS / -M2RSH / -M3H5 / 790GX-M2RS (AMD 790FX / 790GX) [2]
Sammelthread
Inhaltsverzeichniss:
top
AM2+
AM3
Anhang:
AM2+
AM3
Vorwort:
Da die Boards nahezu identisch ausgestattet sind habe ich nur die Details zusammengefasst, die sich von den anderen unterscheiden. Die Features die fehlen, kann man vom M2RSH übernehmen.
Nun gehts also los mit dem Sammelthread der DFI Lanparty DK series:
AM2+:
790FXB
DFI Lanparty DK 790FXB-M2RS
I. Technische Details zum Board:
CPU:
  • AMD Phenom / Athlon 64 X2 / Athlon 64 FX / Athlon 64
  • Socket 940 AM2 65nm
Chipset:
  • Northbridge: AMD 790FX
  • Southbridge: AMD SB750
System Memory:
  • Four 240-pin DDR2 DIMM sockets
  • Supports DDR2 667 and DDR2 800 DIMMs
  • Supports dual channel (128-bit wide) memory interface
  • Supports up to 8GB system memory
  • Supports unbuffered non-ECC x8 and x16 DIMMs
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots
    - 2-way or 4-way CrossFire at x16/x16/NC bandwidth
    - 3-way CrossFire at x16/x8/x8 bandwidth
    - 2-way CrossFire + Physics at x16/x8/x8 bandwidth
  • 3 PCI slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM overclocking
  • CPU/DRAM/Chipset overvoltage
  • 8Mbit flash memory
  • AM3 support ab BIOS-Version R7SD327 (beta), bzw. R7SD421 (final)
Audio:
  • Realtek ALC885 8-channel HD Audio Codec
  • High-performance DACs with 106dB dynamic range (A-Weight), ADCs with 101dB dynamic range (A-Weight)
LAN:
  • Marvell 88E8053 PCIE Gigabit LAN controller
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
Power Management:
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 Keyboard/Mouse
  • Wake-On-USB Keyboard/Mouse
  • Wake-On-Ring
  • Wake-On-LAN
  • RTC timer to power-on the system
  • AC power failure recovery
Hardware Monitor:
  • Monitors CPU/system/chipset temperature
  • Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature during system boot-up
IDE:
  • One IDE connector allows connecting up to two UltraDMA 133Mbps hard drives
Serial ATA with RAID:
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1 and RAID 0+1
Rear Panel I/O:
  • 1 mini-DIN-6 PS/2 mouse port
  • 1 mini-DIN-6 PS/2 keyboard port
  • 1 optical S/PDIF-out port
  • 1 coaxial RCA S/PDIF-out port
  • 6 USB 2.0/1.1 ports
  • 1 RJ45 LAN port
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
Internal I/O:
  • 2 connectors for 4 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 front audio connector
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 4 Serial ATA connectors
  • 1 40-pin IDE connector
  • 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 6 fan connectors
  • EZ touch switches (power switch and reset switch)
PCB:
  • ATX form factor
  • 24.5cm (9.64") x 30.5cm (12")
II. Layout:
III. Reviews:
http://www.ur-hardware.com/mainboard/40-review-dfi-lanparty-dk-790fx
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...ormal&mode=view&downloadFlag=false&itemId=539
Treiber: http://www.dfi.com.tw:8080/portal/C...normal&mode=view&downloadFlag=true&itemId=539
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383889.html
M2RSH
DFI Lanparty DK 790FX-M2RSH
CPU:
  • AMD® AM2+ processors: Phenom FX / Phenom / Athlon / Sempron
  • HyperTransport 3.0 (5200MT/s for AM2+)
  • AMD OverDrive provides tuning options using the new“Advanced Clock Calibration” overclocking feature.
  • Socket 940 AM2+ 65nm
Chipset:
System Memory:
  • Supports DDR2 667/800/1066 MHz DIMMs
Expansion Slots:
  • 3 PCI slots
II. Layout:
III. Reviews:
http://www.modreactor.com/english/R...XB-M2RSH-AMD-LanParty-Motherboard-Review.html
http://www.overclock.net/amd-motherboards/399854-smt-review-dfi-lanparty-790fxb-m2rsh.html
IV. Links:
Herstellerseite: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Treiber: http://www.dfi.com.tw:8080/portal/CM/cmproduct/XX_cmproddetail/XX_WbProdsWindow?action=e&downloadType=driverTab&windowstate=normal&mode=view&downloadFlag=true&itemId=547
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a383891.html
790GX
DFI Lanparty DK 790GX-M2RS
CPU:
Chipset:
  • Northbridge: AMD 790GX (RS780)
Expansion Slots:
  • 2 PCI Express (Gen 2) x16 slots
    - Hybrid CrossFireX - combination of the integrated graphics and a discretegraphics card in a PCIE slot (8-lane port).
    - Two graphics cards support CrossFireX; each operating at x8 (8-lane ports)bandwidth
  • 1 PCI Express x1 slot
  • 3 PCI slots
Graphics:
  • Integrated ATI Radeon HD 3300 graphics core
  • One DVI-I connector for digital LCD display (ACHTUNG!! DVI Anschluss nur als Pin-Connector ausgeführt)
  • Microsoft® DirectX 10
  • Hybrid CrossFireX technology combines the onboard GPU and adiscrete PCIE graphics card
  • Onboard Performance cache for added performance
II. Layout:
III. Reviews:
http://www.madshrimps.be/?action=getarticle&articID=894
IV. Links:
Link zum "DVI-Problem": http://www.csd.dficlub.org/forum/showthread.php?t=8221
Treiber: http://www.dfi.com.tw:8080/portal/C...g=false&action=e&windowstate=normal&mode=view
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a356442.html
Lanparty JR Sammelthread: http://www.hardwareluxx.de/community/showthread.php?t=590779
hex
Anhang:
Für erweiterte Optionen im BIOS F9 drücken!
Achtung an alle Extrem-OC´er: das Board zeigt nur maximal -83°C an !
Hexcode Tabellen Für CPU-NB-VID und NB-Multi(790FXBM2RS/H):
tabelle
Vergleich zwischen den Boards:
kühler
Kompatible Kühler:
790FXB-M2RS(H):
passt:
Cooler Master Hyper TX (bläst nach hinten)
EKL Alenföhn Groß Clock'ner Blue Edition (bläst nach hinten)
EKL Alpenföhn Brocken (bläßt nach oben)
Scythe Infinity/Mugen (bläst nach oben)
Thermalright IFX-14 (bläst nach hinten), (ACHTUNG: bei verwendung der Thermalright Backplate auf Isolierung achten!)
Thermaltake GunMetal Orb (bläst nach unten)
OCZ Vanquisher (bläst nach oben)
Xigmatek HDT-S1283 (bläst nach oben)
Zalman CNPS 9500AM2 (nach hinten)
passt mit Modifikationen:
passt nicht:
790GX-M2RS:
passt:
passt nicht:
passende Wasserkühler für NB/SB und Spawa´s gibt es bei Anfi-tec oder Watercool
Lochabstände vom NB-kühler, Danke an Andreoid von Anfi-tec :bigok:
ram
RAM Kompatibilitätsliste:
790FX-M2RS/H:
läuft:
Cellshock 2x 1GB DDR2-667 (CS2110650)
GeIL DIMM 4 GB kit DDR2-800 (GX24GB6400C4UDC)
G.Skill Pi Series 4GB DDR2 1100 (F2-8800CL5D-4GBPI)
G.Skill 4GB kit DDR-1000 (F2-8000CL5D-4GBPQ)
Kingston HyperX 4GB kit DDR-1066 (KHX8500D2K2/4G)
Mushkin 4GB kit DDR-1066 (996599)
OCZ Platinum XTC 4GB kit DDR-800 (OCZ2P10004GK)
OCZ Titanium 4GB kit DDR-1150 (OCZ2T11504GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800C32GK)
OCZ Reaper HPC Edition 2GB kit DDR2-800 (OCZ2RPR800EB2GK)
OCZ Reaper HPC 2x2GB kit DDR2-1066 (OCZ2RPR10662G), (Tony´s SPD)
OCZ XTC Platinum 2 GB kit DDR2-1066 (OCZ2N10662GK)
macht Probleme:
läuft nicht:
Vollbestückung:
4GB
2x1GB OCZ Reaper (OCZ2RPR800C32GK) + 2x1GB OCZ Reaper (OCZ2RPR800EB2GK)
DDR800 | CL4-4-4-12 | Vdimm 2,0V
4x1GB Aenon Xtune DDR1066 | CL5-5-5-15 | Vdimm 1,85V
6GB
2x2GB Geil Ultra Plus (GX24GB6400C4UDC) + 2x1GB Cellshock
DDR800 | CL4-4-4-10 | Vdimm 1,85V
8GB
4x2GB G.Skill Pi Series (F2-8800CL5D-4GBPI) | DDR800 | CL5-5-5-18 | Vdimm 1,9V
2x4GB kit Mushkin XP2-8000 (996591) | DDR1000 | CL5-5-5-15 | Vdimm 2,1V
2x4GB kit
Mushkin DDR-1066 (996599) | DDR1066 | CL5-5-5-15 | Vdimm 2,05V
790GX-M2RS:
läuft:
Aeneon Xtune DIMM 2 GB DDR2-1066 Kit (AXT760UD00-19DM97-K-2G)
macht Probleme:
OCZ Reaper HPC 2 GB DDR2-1066 Kit (OCZ2RPR10662GK); (abstürtze mit 1066Mhz)
läuft nicht:
Vollbestückung:
4GB
6GB
8GB
Tipps für 8GB RAM bei 1066Mhz *klick*
FAQ
FAQ:
Q: Ab welcher BIOS-Version bietet das Board Deneb-Support?
A: Ab FinalVersion R7SDC26
Q: Ab welcher BIOS-Version bietet das Board AM3-Support?
A: Ab Final Bios R7SD421 bzw. ab Beta R7SD327
Q: Mit welcher BIOS-Version lassen sich die X3´s freischalten?
A: Beta Version R7SD310A
Q: Wie flashe ich mein BIOS mit einem USB-Stick?
A: Tutorial auf der DFI-Club-Seite *klick*
Eine deutsche Übersetzung der POST Codes aus dem Handbuch findet ihr HIER
under construction...
AM3:
m3h5
DFI Lanparty DK 790FXB-M3H5
CPU:
  • AMD Phenom II processor
  • HyperTransport 3.0 (5200MT/s), HyperTransport 1.0 (2000/1600MT/s)
  • AMD OverDrive provides tuning options using the new "Advanced Clock Calibration" overclocking feature.
  • Socket 938 AM3 45nm
Chipset:
System Memory:
  • Four 240-pin DDR3 DIMM sockets
  • Supports DDR3 1600 (O.C.)/1333/1066Mhz
  • Supports non-ECC unbuffered DIMMs
  • Supports up to 16GB system memory
Expansion Slots:
  • 3 PCI Express (Gen 2) x16 slots - 2-way crossfire at x16/x16 or x16/x4 bandwith - 3-way crossfire at x16/x16/x4 bandwith
  • 3 PCI-Slots
BIOS:
  • Award BIOS
  • CMOS Reloaded
  • CPU/DRAM Overclocking
  • CPU/DRAM/Chipset Overvolting
  • 8Mbit SPI Flash Memory
Audio:
Lan:
  • Marvell 88E8056 PCIE Gigabit LAN controller
  • SATA speed up to 3GB/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
IDE:
  • One IDE connector allows up to two UltraDMA 133Mbps hard drives
Rear Panel I/O Ports:
  • 1 RJ45 LAN port
  • line-in, line-out (front R/L) and mic-in jacks
I/O Connectors:
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 CD-in connector
  • 1 IrDA connector
  • 1 CIR connector
  • 6 Serial-ATA connectors
  • 6 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power and reset switch)
Power Management:
  • ACPI STR (Suspend to RAM) funktion
  • Wake-On-Ring
  • Wake-On-LAN
Hardware Monitor:
  • Monitors 12V/5V/3,3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
  • CPU Over Heat Protection function monitors CPU temperature during system boot-up
PCB:
  • ATX form factor
  • 24,5cm (9,64") x 30,5cm (12")
II. Layout:
III. Reviews:
User-Review von Öse:
http://www.hardwareluxx.de/community/showpost.php?p=11771090&postcount=1
http://www.ninjalane.com/reviews/motherboards/lanpartydk-790fxb-m3h5
IV: Links:
Preisvergleich: http://preisvergleich.hardwareluxx.de/deutschland/a417781.html
kühler
Anhang:
Kompatible Kühler:
Die Sockelhalterung entspricht exakt der AM2(+) version, daher passen alle Kühler die auch mit dem M2RS(H) kompatibel sind.
Passende Wasserkühler:
Das Boardlayout entspricht ebenfalls dem des M2RSH, daher passen alle Wasserkühler die auch mit dem 790FXB-M2RS(H) verwendet werden können.
Also als erstes Anleitung auf eigene Gefahr ;)
Ich versuche es aus der Erinnerung, da es schon länger her ist, seit ich das das letzte mal gemacht habe. Es müsste auch irgend wo im dem Thread stehen.
Hier die Anleitung für das ganze mit einer Diskette
How to use AWARD Flash Utility
Mit dem USB Stick geht das fast gleich.
zuerst USB Stick vorbereiten. Dazu dieses Tool verwenden. USB Stick wird formatiert. (Als Admin ausführen)
USB-DOS - Download - CHIP Online
Dann die Dateien aus dem ZIP Ordner auf den Stick kopieren
DFI Lanparty - Support
Es empfiehlt sich alle Laufwerke zu entfernen
und die Bios Einstellung zurück zu setzen "LOAD OPTIMIZED DEFAULTS"
Danach vom Stick Booten.
jetzt kann man der Anleitung ab Schritt drei folgen
Werde mich am we mal daran begeben :)
Lohnt sich sonst ein x6 auf dem Board?
Lg
Gesendet von meinem GT-I9300 mit der Hardwareluxx App
Kann dir nicht sagen ob sich ein x6 lohnt.
Lg
Kommt drauf an, was Du vor dem X6 für eine CPU hattest oder noch hast. Wenn Du nen Dual-Core hast, dann lohnt es sich megamäßig. Wenn Du nen hochgetakteten X4-Phenom hast, relativiert sich das Ganze schon wieder ein wenig.
Dann macht nen X6 wirklich nur bedingt Sinn. Nen Kumpel hat nen X6 und ein 5850-Crossfire-Gespann und er muß die CPU auf 4 GHz takten, damit dieser die Radeons ordentlich befeuern kann. Dabei hat er ne CPU-Auslastung von ca. 80-90% (auf allen Kernen).
Beim updaten scheint was schief gelaufen zu sein.
Nach dem update bleibt das Bord bei C1 hängen.
Batterie schon raus genommen...
Bord scheint hin zu sein?
Lg
C1 Bedeutetprobleme mit dem RAM. Versuch mal nur mit einem Riegel zu starten
Batterie wie lang rausgenommen? Nur mal kurz reicht nicht. Pack sie für 10 min raus und probier es nochmal.
Sent from my iPhone using Hardwareluxx app
Muss jetzt arbeiten. BIOS Reset hab ich schon.
Lasse die Batterie mal so lange wie ich arbeiten muss raus.
Berichte dann nachher
Lg
C1 = Detect memory, Auto-detection of DRAM size, type and ECC, Auto-detection of L2 cache
Hast Du die Möglichkeit und kannst anderen RAM oder ne andere CPU testen?
Weil normalerweise kannste das BIOS per Update nicht so zerschießen, daß ein C1-Fehler kommt.
Dann hätte ich ja CPU zerschossen und oder alle meine RAM Riegel welche 4 Stück sind.
Denke echt das es das board ist.
Denn bei CPU würde nichts passieren.
Sorry fürs hochholen von dem Thread, aber hat von euch zufällig noch jemand die aktuellste Biosversion rumliegen? Momentan habe ich das Bios vom 10.03.2009 auf dem Board.
Verrat mir die Bezeichnung deiner BIOS Version, dann schau ich mal ob der DFI Server was aktuelleres hatte.
Danke schonmal. Ich weiß nicht, ob das die Biosversion ist, aber im POST steht neben dem Datum (10.03.2009) noch 8A66AD4ZC-00. Ganz vergessen, es handelt sich um n 790FXB-M2RSH
Mit etwas wahlloser und planloser Suche bin ich auf die Bezeichnung einer Biosversion gestoßen, die den X4 965 sicher untstützen sollte, und hab in nem (bosnischen?) Forum n zip File mit nem Bios gefunden, das gut passen könnte. Zumindest ist es die passende Bezeichung (R7SDA08):
Die verlinkte Biosversion hat meine Probleme gelöst. CPU hängt jetzt nicht mehr bei 800MHz fest :fresse:
Hello, first, my apologies for not speaking in German on a German speaking forum... but I would like to ask for some help.
Do you have a backup of the DFI FTP server? I am searching for the latest BIOS for the DFI DK 790GX-M2RS. The known BIOS files I have are;
R7GD922 (09/22/2008)
R7GDA17 (10/17/2008)
R7GDA30 (10/30/2008)
R7GDB21 (11/21/2008
R7GDC30 (12/30/2008)
I was wondering if there is a more recent BIOS from 2009 or later?
I would really apreciate your help. Thank you.
@Lostdotfish Please try to figure out if there indeed was a newer version and what it is called. I would need the filename to look for it in the archive.
I've tried searching to see if there was a newer BIOS released. There was for the JR 790GX M2RS so I assume there may have been one for this board also. It contains some microcode updates.
Unfortunately information on the full ATX 790GX is scarce. I spent an evening on archive.org trying to pull up any old support pages without luck.
If it exists it will be R7GDC*.* or R7GDD*.*
Are you able to see the BIOSes listed above in your archive?
Checked the two bottom ones and they are both in the archive. If you don't know the filenames, it is difficult for me to help, since I cannot discern the official releases from the unofficial ones (like test BIOSes) and don't want to get in trouble again, for giving out a confidential file.
Edit: according to a forum post at overclockzone and hardwarebg, this one should be one of the later official releases:
  • R7GD706.zip
This is perfect, I think it adds Phenom II X6 microcodes. Thank you.
Ähnliche Themen
