[Sammelthread] DFI LANparty UT X58-T3eH8 (Intel X58) [1]
DFI LANPARTY UT X58-T3eH8​
Inhalt des Sammelthreads:
  • Spezifikationen
  • Bilder
  • Das Bios
  • Downloads
  • Wichtige Informationen
  • Wichtige Links
Spezifikationen:
  • CPU
  • LGA 1366 socket for Intel® Core™ i7 processors
  • Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
  • Integrated Memory Controller (IMC) supports 3 channels of DDR3
  • Intel Hyper-Threading Technology delivers 8-threaded performance
  • 8-phase digital PWM provides stable voltage to the CPU
    Chipset
  • Intel chipset
  • Northbridge: Intel X58 Express chipset
  • Southbridge: Intel ICH10R
    QPI
  • System bus - 4.8GT/s to 6.4GT/s
    System Memory
  • Six 240-pin DDR3 DIMM sockets
  • DDR3 800/1066/1333/1600(O.C.) MHz DIMMs
  • Triple-channel memory architecture
  • Supports up to 24GB system memory
  • Delivers up to 43.2GB/s bandwidth
  • Unbuffered x8/x16, non-ECC and ECC, up to 4Gb DDR3 devices
    Expansion Slots
  • 3 PCI Express (Gen 2) x16 slots
  • a. 2-way CrossFire at x16/x16 transfer rate lanes; or
  • b. 3-way SLI at x16/x8/x8 transfer rate lanes
  • 1 PCI Express x4 slot
  • 2 PCI slots
    BIOS
  • Award BIOS
  • 8Mbit SPI flash memory
  • CMOS Reloaded
  • Graphics
  • Multiple GPUs (Graphics Processing Unit)
  • 3 graphics cards in 3-way SLI or Quad CrossFireX configuration
    Audio
  • Bernstein audio module
  • Realtek ALC889 8-channel High Definition Audio CODEC
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
  • 2 coaxial RCA S/PDIF-in/out jacks
  • 1 optical S/PDIF connector
  • 1 CD-in connector
  • 1 front audio connector
  • 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
    LAN
  • Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers with Teaming technology
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Storage
  • Intel ICH10R chip
  • Intel Matrix Storage technology
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • JMicron JMB363 PCI Express to SATA and PATA host controller
  • Supports up to 2 UltraDMA 100Mbps IDE devices
  • Supports 2 SATA devices
  • RAID 0 and RAID 1
  • IEEE 1394
  • VIA VT6308P
  • Supports two 100/200/400 Mb/sec IEEE 1394a ports
    Rear Panel I/O
  • 1 Mini-DIN-6 PS/2 mouse port
  • 1 Mini-DIN-6 PS/2 keyboard port
  • 1 IEEE 1394 port
  • 6 USB 2.0 ports
  • 2 RJ45 LAN ports
  • Internal I/O
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 connector for an IEEE 1394 port
  • 1 connector for the Bernstein audio module
  • 1 IrDA connector and 1 CIR connector
  • 8 Serial ATA connectors
  • 1 40-pin IDE connector and 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 8 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power switch and reset switch)
    Power Management
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
  • Wake-On-LAN and Wake-On-Ring
  • RTC timer to power-on the system
  • AC power failure recovery
    Hardware Monitor
  • Monitors CPU/system/Northbridge temperature and overheat alarm
  • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
  • 6 layers, ATX form factor;
  • 24.5cm (9.64") x 30.5cm (12")
Bilder:
Die Verpackung und das Zubehör:
Das Board selbst:
Quelle: XtremeSystems.org (Thanks to AndreYang for sharing the Pics!)​
Das Bios:
Special THANKS to: :wink:eva2000:wink: from i4memory.com! great SHARING!​
Bios Template vom Bios LX58DC18 "Genie Bios"
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.605v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.21v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO/800Mhz/1067Mhz/1333Mhz/1600Mhz/1866Mhz/2133Mhz (ratio referenced to default 133 bclk - so 1333Mhz /133Mhz = 10x DRAM multiplier)
UnCore Frequency: AUTO/1600/2133/2400/2666/2933/3200/3466/3733/4000/4266 (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Downloads:
Bios Downloads:
Major Reasons of Change:
1. Fixed CPU turbo ratio can't over 30.
2. DDR3 1066 can't boot with Intel i7 "C0" stepping CPUs.
3. ICH10 STAT can't boot from DVD rom on AHCI and RAID mode.
Wichtige Links:
P.S: Das ist mein erster Sammelthread überhaupt, ich hoffe er ist gut geworden! Wenn was Falsch sein sollte oder irgendwas zu bemängeln gibt bitte lasst es mich wissen! LOB & Kritik sind also erwünscht!
Frohe schlacht!
gibts nen Gulftown B Stepping Bios oder irgendwas nach dem 6.1.?
Ich bekomm meinen 6 Kern Xeon 5650 B Stepping nich zum laufen verdammt.
Ich musste schon September erste A Stepping Gulftowns verkaufen weil DFi nich fähig war wie ASUS / Gigabyte /Evga beta Bios mit Support zu bringen, und jetzt derselbe Scheiß mit B Stepping. Man man man, nie wieder DFI.
Falls irgendwer ein prerelease Bios nach dem 6.1. hat bite PN an mich.
---------- Beitrag hinzugefügt um 10:41 ---------- Vorheriger Beitrag war um 10:09 ----------
okay, mein X5660 is unterwegs.
DFI meint übrigens
gut soweit.
Übrigens haben die neuen 6 Kern +2 beim Turbo auf allen Kernen ;)
Wieso sollen die auch auf dem DFI laufen wenn du die CPU's eigentlich garnicht haben darfst???
1. sind es ES (illegal)
2. sind die als Xeon für Server gedacht;)
Außerdem. Wie lange hat sich Asus damals Zeit gelassen bis man die W3520 auf dem REII mit 10er RAM Multi fahren konnte? Wochen? Monate? Und da waren die W3520 im Gegesatz zum 5650 schon im Handel. Glaube das CF unterstützt die xeon 5650/5660 bisher auch nicht.
mir ist uaf board bios rom gecrashed
wie oft soll das kommen
DFI sollte etwas finden wie dual bios z.B.
so ein OC monster hat immer gefahr dass bios wegfliegt
ich habe ersatz chip für solche fälle und mache hot flash
Gibbet doch schon?
http://www.dfi.com/portal/CM/cmprod...sWindow?action=e&windowstate=normal&mode=view
Hab bisher leider noch keinen Händler gefunden der das Teil hat? HPM wollte mal schauen? Genau mit dem Ding reaktivieren die in NL tote Boards :banana:
Wird auf den Stecker in der Nähe der SB gesteckt und schon funktioniert das Teil wieder........
Frag mal Wendell Smith wann die Teile endlich kommen?
lol und so was soll ich kaufen :) ?
lol DFI
Ach und ich habe mich immer gefragt wofür der Flash Bios connector ist, also klar der Name sagt ja alles aber mein Gedanke war immer warum habe wir DFiler nichts davon hehe, schliesslich ist DFi eher ein profi Board und Profis stehen auf so etwas oder:wink:
---------- Beitrag hinzugefügt um 15:01 ---------- Vorheriger Beitrag war um 15:00 ----------
Ja wenn du keine Lust hast Wendel zu nerven gib mir seine Adresse und ich tue das hehe, ich will so ein Teil haben!!!!!!!!!!!
lol hackts dir?
Sehr wohl ist diese CPU Sockel 1366 und sehr wohl soll diese auf dem DFI laufen.
Aber da DFI sich wohl aus dem Desktop-Markt zurückziehen will haben sie die BIOS Truppe gestuzt (sogar drastisch sagen meine Quellen / der DFI Support).
Gigabyte und ASUS unterstützen genau wie EVGA die CPU seit September...
DFI steht für High-End, da kann man sich sowas nicht erlauben weil es sehr wohl viele leute gibt die genau diese und andere ES darauf laufen haben wollen. Und ein ES ist nich illegal.
Das RE2 war Anfangs eh Müllgeburt da es Biosversionen brauchte bis man überhaupt den 21 Multi auf sienem i7 920 sehen konnt...
Aber durch die Bank laufen die Gulftowns mittlerweile seit bald einem halben Jahr.
Für mich durchaus ein Grund zur Abwende von DFI hin wieder zu Gigabyte, die imho am schnellsten neue CPU supporten. Aber die Optik ist da halt fürn Arsch.
Das DFI ist top, das schireb ich auch, aber die BIOS Support ist leider unter Durchschnitt. BTW - sogar ASROCK kennt die CPU mittlerweile...
lol hackts dir?
Irgendwie hast du nicht verstanden was ich gepostet hab, oder?
Logo ist das S1366, hab nix anderes gehauptet (Xeon sind lt. Intel Server CPU's, oder etwa nicht?)
Seit Sep. ist ja übertrieben? Als ich das DFI P55 probiert habe (Ende Oktober, liefen die Gulftown noch nicht richtig auf Evga bei (Neo4ever) und GB bei (RomeoJ)
Ein ES ist es auch, richtig? Also verstehe ich nicht was du willst? Ein ES ist und bleibt Eigentum von Intel. Die CPU ist nur in deinem Besitz. Und ich gehe einfach mal davon aus das du die nicht von Intel bekommen hast, oder?
Im Handel ist der ab 16.03.10 somit auch richtig
http://www.computerbase.de/news/hardware/prozessoren/intel/2009/dezember/westmere-ep_maerz_2010/
welches Bios hast du drauf? Die beta vom 06.01.? Die soll doch mit den neuen laufen
Added new micro code for support Intel Gulftown 6 core CPUs.
Kannst dir wieder GB kaufen oder besser Evga, da das DFI X58 LP UT eh "EOL" ist, wird bzw. ist ersatzlos gestrichen! Leider!!!!:heul:
Kein Nachfolger. Die Boards die immo im Handel sind das sind die Reste. Freu dich wenn überhaupt noch 2-3 bios Versionen kommen?
Das DK bleibt erstmal, aber es wird wohl keine neuen X58 Boards mehr geben?
Die konzentrieren sich auf die kleineren Boards P55 usw., vorallem aber auf die Industry Boards, wo die ursprünglich ja auch herkommen.
mit dem neuen mögen eventuell die alten A Stepping laufen ja... Laut DFi is das Problem mit den neuen, bereits benamten Xeons (Stepping B) der Fall, daran arbeitet man.
Anfang September hatte ich 3 Stück zu Hause, auf dem Gigabyte Extreme X58 liefen sie (eig alle), auf Evga und auf ASUS RE2, aufm P6T nur einige. Klar kams immer auf die Batch an und klar ist es einfach zu früh. Aber dass es bei anderen Herstellern (ASROCK, Evga, gigabyte, ASUS) bereits mit aktuellen B Stepping geht - seit 1.1 ca, zeigt mir, dass DFI da etwas hinterher hinkt.
Ich hatte auch große Hoffnung in das beta vom 6.1. - bringt nur wenig.
Ist ja au nix gegen das Board an sich, das ist Top, aber das DFi schon immer etwas später verkaufte war ja schon immer klar. Das es ES so spät unterstützt wusste ich nich... schade. Genau da hatte ich eig hohe Erwartungen, genau wie beim Overclocking.
Edit: ne hab sie nicht direkt von Intel - aber so komm ich meist weit billiger weg als wenn ich sie retail kaufe (aktuell bekommt man 6 Kerne 32nm für 350€... selbst im B Stepping). Außerdem kauf ich sie nicht über 5 Ecken wo 10 mit verdienen. Stepping A ging ich dann gezielt aus dem Web. Mit B Stepping kann man was anfangen, die sind im Grunde so gut wie die retail.
einer hat in letztem thread wegen perfect strom cl8 gefragt
also die sind bis jetzt beste ddr3 was ich gehabt habe
EL Hyper Chips drauf
keine degradation
skalieren die bei mir mit maximal 2.06V
geniale speicher wirklich
die gibt es komischerweise aber gar nicht mehr
genauer gesagt ich habe 2000mhz 8-8-8-21
1600 6-6-5-16 1T 55TRFC mit 1.58VDimm/1.28VTT läuft bei mir 8 fach Hyperpi32M stabil :)
belastung geht über 4GB während diese test
1866 7-7-6-18 1T 1.62VDimm/1.32VTT auch genauso
2000 7-8-7-22 (kein 20..nur ab 22) 1T 1.66V/1.36VTT
super also
wieviel mal hab ich die über 2V gebracht
kein problem
laufen immernoch fehlerfrei
keine degradation
super also
kein problem
Doch die gibt es noch. Ich hatte die auch, nur Probleme damit, selbst 2000
9-9-9-24 nicht stabil. Marvin82 hatte auch nur Probleme damit und noch einige hier im Luxx?
Bei mir waren auch Hyper drauf.
CL1? Alle hyper etc sind CL2 chips....desweitern kacken die gerne ab mit zuviel volt.
ja mir sind schon welche abgekackt
deswegen sag ich ,stroms sind sehr gut
in letzte beta bios hab ich was neues entdeckt
warum schreiben die das nicht in beschreibung rein
jetzt kann man 3 kerne aktivieren sogar
früher immer nur 1,2 oder ALL
jetzt geht es auch 3
und was zum teufel soll das mit rd boot und falsche screen ausschnitte?
"rd Boot", das ist falsch! Da sind Blöcke verschoben innerhalb des Bios.
Ist ein Fehler, an der Stelle "PLL Voltage"
is halt nur beta? ;)
So mal ein paar Fragen
1. mit welches Bios kann man am wenigsten VDimm einstellen und was ist das wenigste bei meinem Bios ist es zur Zeit 1,45 würdeaber mal gerne weniger probieren da ich die G:SKILL ECOS habe.
2. Habe das Problem was ich vorher nicht hatte wenn ich von einer Platte was auf die andere kopiere das die Datenübertragung bis auf wenige KBits einbricht und z.b 128 Stunden angezeigt werden , aktuelle Chipsatztreiber sind drauf BS Win 7 64 Bit
zu 1. Wieso weniger? Nur weil du dir die S1156 Riegel gekauft hast, wobei ich mich eh frage warum eigentlich? für die 2 x 4GB Kits hättest du auch ein sehr gutes Triple Kit bekommen :)
zu 2. Kann ich dir nicht sagen was da bei dir schief läuft, aber seltsam ist es schon. :shake:
Wieso habe ich mir 1156 Riegel gekauft ? DDR3 ist doch auch für 1366 Sockel.
Verstehe nicht was du meinst.
Die 4GB Kits G.Skill ECO gibt es nicht als 6 GB Kit, richtig? Warum?
Es sind Riegel mit Low Voltage Spez. von 1,35V. Wären die 100%ig auch für Triple Channel mit 1,35V geeignet, dann hätte G.Skill die sicher auch als entsprechendes Triple Kit in den Handel gebracht. Somit mußt du wohl mit mind. 1,45V oder mehr betreiben bei 3 Stück, niedriger gibt es auch auf den Boards keine Einstellung. Die sind auch nur max. 1600
spez. und du hättest bestimmt für das Geld auch einen triple Kit 2000er bekommen? Welche ECO hast du?
Jo ist reiner So. 1156 Speicher, DDR3 sagt da garnichts! Auch wenn keiner gesagt hat das Ecos's nicht auch auf 1366er Plattformen laufen, sollte jedem bewusst sein das es meisst der Fall sein wird.
Ich hatte dir am Telefon versucht das ganze zu erklären H5N1 aber du hast nicht zugehört und immer wieder versucht auf das dir wichtige Gesprächsfragment zu switchen, kommt davon:wink:
also na ja
er kann auch 2 kits davon kaufen
insgesamt 4X2GB
und mit 4 module geht tripple channel auch
und es gibt kein sonder PCB,IC oder irgendwie herstellungs besonderheit für 1366 und 1156
es hat mit voltage zu tun
wenn ein 1366 board gewisse speicher unterstützt und 1156 auch,dann werte werden bis 1600 gleicha ausfallen
danach hat es auch mit IMC zu tun
wenn er so was kaufen wollte,hat er damit eigentlich nichts falsch gemacht find ich :)
so hat er halt dual channel
aber 4X2gb und tripple geht auch
1.35V kann man auch einstellen mit manche X58 boards
DFI hat 1.50 aber gibt 1.47VDimm
leichte OC für speicher und die werden auch bessere OC eigenschaften zeigen
ich denke nicht dass es irgendwie garantie stört
Ja darum geht es ja, er hat nichts falsch gemacht, jedenfalls unter logischen Gesichtspunkten, aber viele 1366er Boards sind nicht dafür ausgelegt, wobei ich da eher vom Bios spreche als von der Hardware:wink: Bin sehr gesapnnt was sich da tut, problematisch ist aber seine Kombi das wollte ich ihm auch vermitteln, der H5N1 bewegt sich auf ganz normalem Niveau was seine Vorstellung angeht und macht es sich so vllt. unnötig schwer. Ein Tripplechannel Kit währe eh mehr als genug gewesen.
Ich habe so eine Kiste auf der Arbeit und verarbeite 2-12GB große Files die gerendert werden etc. um sie dann auf Druckmaschinen zu schieben und glaube mir unsere Software ist voll auf solche Systeme ausgelegt (Multithreating etc.) und sie schafft es nie unsere Systeme voll an die Grenzen zu bringen. Daher frage ich mich so oder so nach dem Sinn von 8GB Speicher? Jetzt wo viele SSD's nutzen ist man so oder so weniger auf den Speicher angewiesen da die Teile schnell genug sind und auch das Thema Ramdisk langsam aber sicher uninteressant wird...
Aber wie gesagt jedem das seine:wink:
LG Hardy
Es geht ja auch darum das wenn ich diese 1600er RAM's angenommen die schaffen 2000, als 4GB Kit können die das wie einige in den 1156er Fred's bewiesen haben(z.Bsp. Brutus, Wernersen usw.) mit ca. 1,55-1,65 betreiben muß für 9-9-9-24 :haha:
Somit ist der ECO-Effekt 1,35V für'n Ar...? Und ne Garantie das die Teile das auf S1366 schaffen hat man auch nicht, somit ist in meinen Augen der Kauf nur Mumpitz und es wäre besser gewesen sich Trident, Mushkin oder Kingston 2000
CL9 zu kaufen, oder? Auf nem P55 mit max. 1600 mag das ja schön und gut sein nur hier beim X58 gehören die Riegel in die Rubrik: "Dinge die die Welt nicht braucht!" :bigok:
Für das Geld was hier (ECO) 2 4GB Kits (8GB) kosten hätte es Kingston 6GB 2000 CL8 gegeben!!!
hatte jemand vlt. auch schonmal das Problem mit der Soundkarte? Ich hab genau das Problem noch nirgends gefunden...
wenn ich alles ohne Soundkarte anschließe, hochfahre etc. funktioniert es prolemlos.
stecke ich aber das Sound-Modul an, schalte das NT ein, dann blinkt das NT und der Power-Button nur noch und ich kann nicht booten...
Das Soundmodul kam gerade erst neu von DFI... Hat das wohl schon direkt einen weg?
Ja oder sie haben das falsche zurück geschickt, ist alles möglich, wobei ich DFi so etwas kaum zutraue. Naja sieht wohl so aus als das es im Eimer ist:fresse:
