[Sammelthread] DFI LANparty UT X58-T3eH8 (Intel X58) [1]
DFI LANPARTY UT X58-T3eH8​
Inhalt des Sammelthreads:
  • Spezifikationen
  • Bilder
  • Das Bios
  • Downloads
  • Wichtige Informationen
  • Wichtige Links
Spezifikationen:
  • CPU
  • LGA 1366 socket for Intel® Core™ i7 processors
  • Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
  • Integrated Memory Controller (IMC) supports 3 channels of DDR3
  • Intel Hyper-Threading Technology delivers 8-threaded performance
  • 8-phase digital PWM provides stable voltage to the CPU
    Chipset
  • Intel chipset
  • Northbridge: Intel X58 Express chipset
  • Southbridge: Intel ICH10R
    QPI
  • System bus - 4.8GT/s to 6.4GT/s
    System Memory
  • Six 240-pin DDR3 DIMM sockets
  • DDR3 800/1066/1333/1600(O.C.) MHz DIMMs
  • Triple-channel memory architecture
  • Supports up to 24GB system memory
  • Delivers up to 43.2GB/s bandwidth
  • Unbuffered x8/x16, non-ECC and ECC, up to 4Gb DDR3 devices
    Expansion Slots
  • 3 PCI Express (Gen 2) x16 slots
  • a. 2-way CrossFire at x16/x16 transfer rate lanes; or
  • b. 3-way SLI at x16/x8/x8 transfer rate lanes
  • 1 PCI Express x4 slot
  • 2 PCI slots
    BIOS
  • Award BIOS
  • 8Mbit SPI flash memory
  • CMOS Reloaded
  • Graphics
  • Multiple GPUs (Graphics Processing Unit)
  • 3 graphics cards in 3-way SLI or Quad CrossFireX configuration
    Audio
  • Bernstein audio module
  • Realtek ALC889 8-channel High Definition Audio CODEC
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
  • 2 coaxial RCA S/PDIF-in/out jacks
  • 1 optical S/PDIF connector
  • 1 CD-in connector
  • 1 front audio connector
  • 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
    LAN
  • Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers with Teaming technology
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Storage
  • Intel ICH10R chip
  • Intel Matrix Storage technology
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • JMicron JMB363 PCI Express to SATA and PATA host controller
  • Supports up to 2 UltraDMA 100Mbps IDE devices
  • Supports 2 SATA devices
  • RAID 0 and RAID 1
  • IEEE 1394
  • VIA VT6308P
  • Supports two 100/200/400 Mb/sec IEEE 1394a ports
    Rear Panel I/O
  • 1 Mini-DIN-6 PS/2 mouse port
  • 1 Mini-DIN-6 PS/2 keyboard port
  • 1 IEEE 1394 port
  • 6 USB 2.0 ports
  • 2 RJ45 LAN ports
  • Internal I/O
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 connector for an IEEE 1394 port
  • 1 connector for the Bernstein audio module
  • 1 IrDA connector and 1 CIR connector
  • 8 Serial ATA connectors
  • 1 40-pin IDE connector and 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 8 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power switch and reset switch)
    Power Management
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
  • Wake-On-LAN and Wake-On-Ring
  • RTC timer to power-on the system
  • AC power failure recovery
    Hardware Monitor
  • Monitors CPU/system/Northbridge temperature and overheat alarm
  • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
  • 6 layers, ATX form factor;
  • 24.5cm (9.64") x 30.5cm (12")
Bilder:
Die Verpackung und das Zubehör:
Das Board selbst:
Quelle: XtremeSystems.org (Thanks to AndreYang for sharing the Pics!)​
Das Bios:
Special THANKS to: :wink:eva2000:wink: from i4memory.com! great SHARING!​
Bios Template vom Bios LX58DC18 "Genie Bios"
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.605v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.21v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO/800Mhz/1067Mhz/1333Mhz/1600Mhz/1866Mhz/2133Mhz (ratio referenced to default 133 bclk - so 1333Mhz /133Mhz = 10x DRAM multiplier)
UnCore Frequency: AUTO/1600/2133/2400/2666/2933/3200/3466/3733/4000/4266 (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Downloads:
Bios Downloads:
Major Reasons of Change:
1. Fixed CPU turbo ratio can't over 30.
2. DDR3 1066 can't boot with Intel i7 "C0" stepping CPUs.
3. ICH10 STAT can't boot from DVD rom on AHCI and RAID mode.
Wichtige Links:
P.S: Das ist mein erster Sammelthread überhaupt, ich hoffe er ist gut geworden! Wenn was Falsch sein sollte oder irgendwas zu bemängeln gibt bitte lasst es mich wissen! LOB & Kritik sind also erwünscht!
Frohe schlacht!
Hab ein neues Problem seit ich das DFI drin habe.
Wo ich mein P5Q-E drin hatte wurde mir unter System 3,5 GB Ram angezeigt habe 4 drin aber Windows kann ja nur zwischen 3,2 und 3,5 verwalten na ja egal jedenfalls seit ich das DFI drin habe steht da nur noch 2,5 GB Ram
Mir fehlt 1 GB Ram wo ist der hin hat das mit dem Board zu tun ? muss ja oder ?
Habe nur CPU , Board und Speicher verändert alles andere st so geblieben.
Hat jemand eine Idee.
Besorg Dir mal ein 64 Bit OS........
edit: alleine "Nur" MoBo -ram und Cpu gewechselt, viel ist da aber nicht mehr über:fresse:
Du Witzbold!
Schau mal unter den RAM Settings, da findest du Memory Low Gap, da steht
1536 glaube ich? Das ist der für die Graka reservierte RAM.
Verstehe mal wieder nicht wo dein Problem ist?
Hey solltest mal auf der web-site unter UT - LP UT X58 - Document - dir die pdf's downloaden, das du mal deine Bios Optionen kennenlernst, wäre ratsam oder nicht schlecht? :motz:
@REJ
Mit Lukü brauchst du eh keine bessere CPU! 3,8 oder 4,0GHz ist Jacke wie Hose. Wenn die Leistung und Performance die du jetzt hast für deine Zwecke ausreicht, ist das völlig okay. Haste eigentlich Windoof 7 oder immernoch das üble Vista?
Du Witzbold!
@REJ
ja da geb ich dir ja recht mit Lukü bin aber dabei mir ne wakü anzuschaffen und dann sollte es auch höher als 4 ghz gehen-----hab momentan beides drauf und muss einfach sagen vista hat die bessere performance als win7 (win7 ist die suchfunktion richtig gut wie ich finde) dieser 3d quasch auf den desktop ist voll scheisse wie ich finde aber auch den kann man ja ausschalten!
komme zurück auf T3eH8
UD7 ist definitiv nix für mich
etwa anfänger bios und bugz ohne ende
danke gigabyte
ich werd i7 960 unter kälte+t3eh8 testen
schauen wir was das bringt :)
XSPC
Hat den einer bestellt oder sogar schon verbaut?
Wenn ja mal bitte ein paar Bilder mit verbauter GraKa im oberen Slot.
wir warten alle auf Bilder von Hardy ...
Ich möchte auch einen bestellen, ist aber im Moment nicht lieferbar.
solltest kein monsterergebniss erwarten :)
MIPS hat PWM bei mir unter 50 grad gebracht
sogar mit 5.3Ghz unt 1.56V VTT waren die 46 grad warm
ich mein...noch mehr kann man unter wasser net erreichen
aber mips kann man auf neue generation weiter benutzen :)
und XSPC ist nur genau für dieses board gedacht
deswegen würd ich net kaufen
MIPS DFI PWM Rev2 passt auf fast alle intel UT Boards
und in zukunft wird es wahrscheinlich weiter passen
Ja klar, ich suche aber eine adäquate Lösung für Multi-GPU und will mir nicht die Heatpipe zersägen! Ausserdem behalte ich das X58 UT für immer, geht wenn ich was neues kaufe in den Rechner meiner Frau und dannach an die Wand:fresse:
Leider werden aber keine neuen Boards mehr von DFI kommen, so wie es aussieht.
erst ab x68
UT X68-T3eH10 stell ich mir vor
glaub net dass DFI mehr volterras einbaut
DFI ist kein asus+gigabyte
die werben nie mit 100 Phase oder so was
wenig und effektiv
aber 8 volterras sind wenig halt
10 sind optimal
8 werden viel zu belastet und werden sehr warm
gleiche problem hat evga sehr gut gelöst
10 volterras und 2x5 CPL
die werden weniger belastet und bleiben unter 70 grad
DFI geht sogar über 90 mit stock wenn man 4.6 prime testet
erst ab x68
wenig und effektiv
10 sind optimal
Ehrlich, ich glaube dass kein neues Board, auch kein X68 kommt?
Das DK P55 hat 10 Volterras was man direkt an den Temps merkt!
Wieso das?
Die jetztigen sind doch top!
Weil die sich wohl aufgrund der allgemeinen Situation gezwungen sehen in ihr altes Segment zurück zu gehen und das waren eher Industrielle Plattformen (Server etc.). Man sieht doch das es momentan allen schlecht geht, mein Betrieb muss sich jetzt auch anders am Markt plazieren und neue Wege gehen bzw. altes wieder aufgreifen um zu überleben:coolblue:
OK aber DFI hat in letze Jahe kein CHipsatz von Intel verpasst
es gab P35,P45,X38,X48,X58
warum sollten die X68 verpassen? :)
kann ich auch nicht nachvollziehen warum bei DFI schluss sein soll.....die bretter von DFi wurden ja immer gerne gekauft...und gelesen hab ich auch noch nichts dazu
Ja nur lohnen muß sich die Sache!
1. DFI läßt produzieren (bei Foxconn)
2. die Ausstattung der Boards (feature's, Kühler , heatpipe) das kostet natürlich
HP (inkl. flame freezer) kommt von Thermalright???
Am Anfang als das Brett noch bei 270-290€ lag, da hat DFI noch Geld verdient,
doch bei 240-220€ sah die Sache wohl nicht so gut aus?
Es gibt bisher 2 Bretter mit dig. Spawas DFI (ca.230€) und CF ???€
Glaube auch am P55 mit den dig. Spawas 10 Volterras wird nicht viel verdient?
Beim X38 u. X48 gab es immer auch die LT Versionen (billigere Kühllösung)
Das LP UT wird wohl auch nur max. 20000 Stück zählen, was im Vergleich zu GB oder Asus wenig ist.
Der Kunde will halt immer mehr, immer besser, für immer weniger Geld, leider! Oder man muß so einen Hype wie Evga für das CF veranstalten?
Überhaupt keine Frage das Board ist sehr gut, aber der Preis ist nicht gerechtfertigt im Vergleich zum LP UT, genauso wenig wie der vom REII gerechtfertigt ist.
Das DFI hat am Anfang um die 300€ oder darüber gekostet. Denke die haben die auch nur billiger gemacht, weil die die Boards loswerden wollten?
Die Produktzyklen sind auch einfach zu kurz geworden. Asus und GB haben die Lager noch voll mit P45 Boards, oder warum kommt Asus mit EFI dem Bios Nachfolger auf solch alten Boards? In USA verkauft sich S775 (P45) immernoch sehr gut, hier in Europa schreit man schon nach X68 und P65, unglaublich aber ist so. Den Amis geht USB 3.0 und S-ATA3 am berühmten Ar... vorbei und hier hätte es am liebsten schon fast jeder......zweite
---------- Beitrag hinzugefügt um 13:45 ---------- Vorheriger Beitrag war um 13:31 ----------
Die Mannschaft in Taiwan wurde jedenfalls gewaltig verkleinert.
Hab mich mal schlau gemacht.... Also wie es immo aussieht kommt "kein" X68 !!!!!!!
@Labrador
ja stimmt eigentlich
was evga mit CF macht ist alles ausser fair
so viel werbung
alle top OCer bekommen es fast umsonst damit CF sich grosse name macht
bei allem respekt es ist einfach nicht besser
hab selbst unter LN2 getestet
UT X58 ist meiner meinung nach bessere Xtreme OC Board als CF
und DFI konnte locker 300 dafür verlangen
halt asus und gogabyte werben besser
rampage 2 extreme wäre für 220euro in ordnung aber 300 ist halt zu viel
ich kann deine argumente nachvolziehen
aber glaube kaum dass DFI X68 verpassen wird
USB3 und Sata3 für was bitte?
wofür?haben moderne HDDs schon Sata 2 ausgenutzt?
oder USB3?haben moderne USB sticks genug bandbreite für 2.0?niemals
ich verbleibe mit hoffnung dass UT X68 kommt
aber deine argumente sind richtig
bloss DFI hat bis jetzt keine generation verpasst
und wenn DFI X68 jetzt nicht baut,für mich bedeutet die wollen von markt abziehen
DFI war und wird nie asus und gigabyte konkurent in verkaufszahlen sein
die haben eigene kunden halt
XSPC Sethat Pads dabei
ich würd nur gute nicht leitende paste empfehlen
pads sind einfach nicht passend in 8 volterra@2CPL 4+4 design
Worauf beziehtst du dich kann das nicht ganz nachvollziehen!AUf den neuen XSPC Kühlerblock?
webseite von XSPC hat PDF datei
ich habs angeschaut und dabei sind 2 pads 1x für volterras und 1x für CPL
hab schon beide unter Pads gehabt und performance sucks
MX2 danach drauf und gute 20 grad unterschied
mit pads hab fast gleiche ergebnisse gehabt wie mit stock kühler
dann bist du schon glücklicher besitzer des Kühlblocks von XSPC?..und auch schon eingebaut wie es scheint ja
ja die PDF hab ich auch schon gesehen.
Auch wenn es ein gutes Board ist, würde ich momentan keins mehr kaufen.
So gute Biose wie früher wirds wohl nicht mehr geben was ja schade ist.
R.I.P
@Krautmaster
Mal daran gedacht das dein Xeon ein Stepping haben könnte was nicht unterstützt wird? Ist ja immerhin ein ES..........
Oder glaubst du etwa die Hersteller dürften das ohne Erlaubnis von Intel??? Das Brett ist EOL, womöglich hat Intel da dann eben "nein" gesagt.
Dann könnte das DFI aber einem sagen. Außerdem ist es bis dato so, dass alle Xeons auf X58 Brettern laufen. Man muss sich nur bei anderen Herstellern umsehen.
