[Sammelthread] DFI LANparty UT X58-T3eH8 (Intel X58) [1]
DFI LANPARTY UT X58-T3eH8​
Inhalt des Sammelthreads:
  • Spezifikationen
  • Bilder
  • Das Bios
  • Downloads
  • Wichtige Informationen
  • Wichtige Links
Spezifikationen:
  • CPU
  • LGA 1366 socket for Intel® Core™ i7 processors
  • Intel® QuickPath Interconnect (QPI) technology - point-to-point interface that connects to X58; providing a dynamically scalable interconnect for increased bandwidth, lower latency and stability
  • Integrated Memory Controller (IMC) supports 3 channels of DDR3
  • Intel Hyper-Threading Technology delivers 8-threaded performance
  • 8-phase digital PWM provides stable voltage to the CPU
    Chipset
  • Intel chipset
  • Northbridge: Intel X58 Express chipset
  • Southbridge: Intel ICH10R
    QPI
  • System bus - 4.8GT/s to 6.4GT/s
    System Memory
  • Six 240-pin DDR3 DIMM sockets
  • DDR3 800/1066/1333/1600(O.C.) MHz DIMMs
  • Triple-channel memory architecture
  • Supports up to 24GB system memory
  • Delivers up to 43.2GB/s bandwidth
  • Unbuffered x8/x16, non-ECC and ECC, up to 4Gb DDR3 devices
    Expansion Slots
  • 3 PCI Express (Gen 2) x16 slots
  • a. 2-way CrossFire at x16/x16 transfer rate lanes; or
  • b. 3-way SLI at x16/x8/x8 transfer rate lanes
  • 1 PCI Express x4 slot
  • 2 PCI slots
    BIOS
  • Award BIOS
  • 8Mbit SPI flash memory
  • CMOS Reloaded
  • Graphics
  • Multiple GPUs (Graphics Processing Unit)
  • 3 graphics cards in 3-way SLI or Quad CrossFireX configuration
    Audio
  • Bernstein audio module
  • Realtek ALC889 8-channel High Definition Audio CODEC
  • Center/subwoofer, rear R/L and side R/L jacks
  • Line-in, line-out (front R/L) and mic-in jacks
  • 2 coaxial RCA S/PDIF-in/out jacks
  • 1 optical S/PDIF connector
  • 1 CD-in connector
  • 1 front audio connector
  • 108dB Signal-to-Noise ratio (SNR) playback (DAC) quality and 104dB SNR recording (ADC) quality
    LAN
  • Marvell 88E8052 and Marvell 88E8053 PCIE Gigabit LAN controllers with Teaming technology
  • Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
    Storage
  • Intel ICH10R chip
  • Intel Matrix Storage technology
  • Supports up to 6 SATA devices
  • SATA speed up to 3Gb/s
  • RAID 0, RAID 1, RAID 0+1 and RAID 5
  • JMicron JMB363 PCI Express to SATA and PATA host controller
  • Supports up to 2 UltraDMA 100Mbps IDE devices
  • Supports 2 SATA devices
  • RAID 0 and RAID 1
  • IEEE 1394
  • VIA VT6308P
  • Supports two 100/200/400 Mb/sec IEEE 1394a ports
    Rear Panel I/O
  • 1 Mini-DIN-6 PS/2 mouse port
  • 1 Mini-DIN-6 PS/2 keyboard port
  • 1 IEEE 1394 port
  • 6 USB 2.0 ports
  • 2 RJ45 LAN ports
  • Internal I/O
  • 3 connectors for 6 additional external USB 2.0 ports
  • 1 connector for an external COM port
  • 1 connector for an IEEE 1394 port
  • 1 connector for the Bernstein audio module
  • 1 IrDA connector and 1 CIR connector
  • 8 Serial ATA connectors
  • 1 40-pin IDE connector and 1 floppy connector
  • 1 24-pin ATX power connector
  • 1 8-pin 12V power connector
  • 2 4-pin 5V/12V power connectors (FDD type)
  • 1 front panel connector
  • 8 fan connectors
  • 1 diagnostic LED
  • EZ touch switches (power switch and reset switch)
    Power Management
  • ACPI and OS Directed Power Management
  • ACPI STR (Suspend to RAM) function
  • Wake-On-PS/2 / Wake-On-USB Keyboard/Mouse
  • Wake-On-LAN and Wake-On-Ring
  • RTC timer to power-on the system
  • AC power failure recovery
    Hardware Monitor
  • Monitors CPU/system/Northbridge temperature and overheat alarm
  • Monitors Vcore/Vdimm/Vnb/VCC5/12V/V5sb/Vbat voltages
  • Monitors the speed of the cooling fans
  • CPU Overheat Protection function monitors CPU temperature and fan during system boot-up - automatic shutdown upon system overheat
    PCB
  • 6 layers, ATX form factor;
  • 24.5cm (9.64") x 30.5cm (12")
Bilder:
Die Verpackung und das Zubehör:
Das Board selbst:
Quelle: XtremeSystems.org (Thanks to AndreYang for sharing the Pics!)​
Das Bios:
Special THANKS to: :wink:eva2000:wink: from i4memory.com! great SHARING!​
Bios Template vom Bios LX58DC18 "Genie Bios"
Code:
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Timing
Memory Control Setting: AUTO
Memory LowGap: 1536M
DRAM Command Rate: AUTO/1N/2N etc
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: AUTO
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.605v
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: AUTO
CPU VTT Voltage: 1.21v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.10v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 26x
2 core Max Turbo Ratio: 25x
3 core Max Turbo Ratio: 25x
4 core Max Turbo Ratio: 25x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO/4.8GT/s/5.866GT/s/6.4GT/s
CPU Base Clock (BCLK): 133 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 100 Mhz
DRAM Frequency: AUTO/800Mhz/1067Mhz/1333Mhz/1600Mhz/1866Mhz/2133Mhz (ratio referenced to default 133 bclk - so 1333Mhz /133Mhz = 10x DRAM multiplier)
UnCore Frequency: AUTO/1600/2133/2400/2666/2933/3200/3466/3733/4000/4266 (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Downloads:
Bios Downloads:
Major Reasons of Change:
1. Fixed CPU turbo ratio can't over 30.
2. DDR3 1066 can't boot with Intel i7 "C0" stepping CPUs.
3. ICH10 STAT can't boot from DVD rom on AHCI and RAID mode.
Wichtige Links:
P.S: Das ist mein erster Sammelthread überhaupt, ich hoffe er ist gut geworden! Wenn was Falsch sein sollte oder irgendwas zu bemängeln gibt bitte lasst es mich wissen! LOB & Kritik sind also erwünscht!
Frohe schlacht!
Du ich glaube Wendell Smith gibt dir keins mehr da die Werbung jetzt für'n Ar...
ist nach dem EOL des Boards:shot::haha::lol::lol::lol:
OC Fähigkeit eines Mainboards welches nicht mehr im Handel erhältlich ist, ist scheißegal?
Mal ehrlich! Gut finde ich das eh nicht, das du Mainboards schrottest durch übermäßiges OC und dann von Wendell Smith scheinbar ein neus Board bekommst?
Jeder Normal-User der es übertrieben hat bekommt von DFI die "Rote Karte" und somit einen Arschtritt aber kein neues Board. Aber du ja scheinbar schon was ich äußerst uncool und vorallem unfair finde.
Hmmmm, not sure what to make of that comment. Maybe it is just my bad understanding of German. In any event the UT X58 board is not "full EOL" as in officially scrapped from the production line. That said I don't expect any more to be produced and unless demand increases alot I also don't expect DFI europe will stock any more of them either (I still have some in stock thou). BIOS development will continue for some time.
labrador
ich wollte doch kein neues board von ihm bekommen
ich hab nie neues bekommen
er hat meins immer repariert
immer!!!sogar wenn ich kein anspruch mehr hatte trotzdem hat er es in service genommen
und was ich gefragt hab war bloss,ich erreiche weltbeste DFI ergebnisse und würd ich gerne in zukunft ein Board von DFI presentieren :)
mehr nichts
will nichts geschenkt
ich takte mit T3eH8 seit 14 Monate schon
85% der ergebnisse bei mir sind mit dem Board
gestern hab EVGA classified von thron gekickt in 920 ranking
findest es einfach ;)?
250 Bclk voll stabil zu takten
hier:
beste SPi1M ergebnisse mit DFI 58
http://hwbot.org/searchResults.do?d...facturerId=&memProductId=&memTypeId=&offset=0
SPI32M
wprime 1024
wprime32
^Hi Leute,
habe seit heute das Problem das ich die LED88 Anzeige bekomme und der Bildschirm schwarz bleibt. Kann nicht verstehen wodurch der Fehler plötzlich kommt. Vielleicht kann ja jemand helfen der das selbe Problem bereits hatte denn im Buch steht nur das man das CMOS zurücksetzen soll oder es zur RMA schicken soll.
Meine Hardware könnt ihr aus dem Link meiner Signatur entnehmen
ok also du hast jumper
denn kannstauf reset modus umstecken und dann wieder zurück
normalerweise muss es gehen
probier bitte wenn es startet mit 88 und druck auf power knopf lange
ob es ausgeht oder weiter mit 88 läuft
wenn bios cmos reset nicht hilft dann musst rma machen ja
wenn du 2te gleiche board hast kannst bios chip rausnehmen und von einem anderen t3eh8 reinstecken vielleicht hastbios rom crash
wieist es passiert eigentlich?was hast vorher gemacht
3?
Mit dem SB Kühler wirste nix anfangen können<>Graka...vorallem ist der kleine obere chip dann ganz nackisch :d
nimm die 2 Mipse da haste Ruhe.
Das passt, habe ich schon bei nem Kumpel gesehen :)
dann zeig mal Bilder wenn du es verbaut hast, meiner Meinung nach geht das nicht ...Schläuche und Schrauben...
habe einen jumper reset gemacht aber das hilft nicht, wenn ich den power button drücke und halte geht es nach einer gewissen zeit aus bleibt aber bis zum aufgehen auf 88
ein zweites identisches board habe ich nicht, mache ja keine benchmark weltrekorde :P
habe nichts gemacht es lief problemlos nun habe ich es ca. 2 wochen liegen gehabt und nicht getestet und gestern nach dem einschließen lief es nicht mehr. das einzige was an den hardwarekomponenten geändert wurde ist das ich eine neue grafikkarte bekommen habe (ASUS 5870) kann das der grund sein?
wo hast es gekauft und wie alt ist es?
erste 6 monate lang kriegst sofort umgetauscht eigentlich aber wenn du dahin bringst
einschicken dauert immer ewig
oder rma von dfi nutzen
insgesamt ca 10 tage
---------- Beitrag hinzugefügt um 17:46 ---------- Vorheriger Beitrag war um 17:45 ----------
echt jetzt?
mit dem Kühler und die Graka im oberen Slot?
er meint wohl mit 1x oder 2x vga
wäre kein problem
aber wenn man 3x vga benutzt dann geht das nichtmehr
2 pcie bleiben doch frei
hat jemand interesse an einem vollkommen intakten DFI UT X58 sammt MIPS Complete Wakü POM also in summe ca 380€ Einkaufspreis?
Habe mir in etwa 250€ vorgestellt... also falls jemand Interesse hat oder verhandeln möchte -> PM ;)
Ich verkaufe übrigens weil mein 6 Kern nicht unterstützt wird, da ES und B0 Stepping.
350 euro für ein T3eh8?
ist zu veil denk ich
verkaufe grad einz für 160 und 180 sgar mips spawa dabei
sorry hab falsch gelesen
250 inkl ist gute preis denk ich :)
hab nichts anderes als dfi
und in valis kann man ja immer sehen
aber das stimmt was du sagst :)
1M geht noch natürlich
aber komischerweise komm ich nicht über 256bclk
DICE ist zu wenig halt
just kidding :)
Der 920er sieht sehr gut aus und mit LN2 sollte bestimmt noch was gehen....
256Mhz ist auch langsam dann Limit und jedes weitere MHz wird zum Geduldspiel :d
Single Channel könnte weiterhelfen (kommst du im low qpi mode höher?)
klar singe channel hilft mit so ca 2-4 bclk
LN2 pot hab ich nicht leider :(
1kg mini pot hab ich
diese ergebnisse sind mit -40 grad
einer hat 270 validiert
wie macht er das :d
lol
magic 920 oder was?
Steck mal den "roten Jumper" um und die beiden "blauen Jumper" unter der SB um
und zusätzlich die Batterie raus. Blau leert die Register komplett! :bigok:
ja stimmt
kann man so auch versuchen aber ob das hilft :)
ich hab immer extra bios chip dabei
10 euro zahlen und hab meine ruhe :)
ich hab einz zum verkaufen
165 inkl
alles dabei
OVP zubehör rechnung
250 bombenstabil :)
hab weltrekord mit 920
249.9X21 auf wprime 32 und 1024
Jo ich schreibe mal in seinem Namen, der hatte Mipse drauf usw. hat der Wessi geschickt gelöst! Glaub mir 250er BCLK unter Luft wäre ja der Oberhammer....
Auf jeden Fall ein gutes Brett was der da anbietet:wink:
