Nvidia GF9300/9400
Asus P5N7A-VM
Gigabyte GA-E7AUM-DS2H
weitere Infos: http://www.hexus.net/content/item.php?item=15372
......NVIDIA's spokesmen were particularly bullish about the graphics performance of MCP7A, citing that, in internal testing, it was up to 5x faster than Intel's G45 (X4500 HD) and, cross-comparing, up to 2x quicker than AMD's 790GX.
The comparisons were pulled from the default 3DMark Vantage test, and it seems that rubbishing Intel's IGPs is not only an AMD preserve.
Chewing through a maximum TDP of 32W for chipset, MCP7A will harness Hybrid SLI, where a discrete card can be added to improve performance. Right now, though, those cards are limited to GeForce 8300 and 8400 GPUs........
...NVIDIA's VP3 engine is integrated to help decode of high-definition codecs, we were told. NVIDIA also brought the inevitable PhysX and CUDA to our attention......
.....The chipset provides a single x16 Gen 2.0 graphics connection, but it doesn't support Hybrid Power, where a discrete card can be switched off and video routed through the IGP in instances where big-bore 3D power isn't needed......
Asus P5N7A-VM
