2015-11-25T18:59:07.553Z cpu0:34317 opID=d7687719)Vol3: 3639: Created VMFS-5.60 with config 0x6 on vol 'RAID 10'
2015-11-25T18:59:07.597Z cpu0:34317 opID=d7687719)Vol3: 731: Couldn't read volume header from control: Not supported
2015-11-25T18:59:07.597Z cpu0:34317 opID=d7687719)FSS: 5099: No FS driver claimed device 'control': Not supported
2015-11-25T18:59:07.659Z cpu7:34317 opID=d7687719)VC: 2052: Device rescan time 43 msec (total number of devices 8)
2015-11-25T18:59:07.659Z cpu7:34317 opID=d7687719)VC: 2055: Filesystem probe time 54 msec (devices probed 4 of 8)
2015-11-25T18:59:07.659Z cpu7:34317 opID=d7687719)VC: 2057: Refresh open volume time 7 msec
2015-11-25T18:59:07.675Z cpu7:34317 opID=d7687719)Vol3: 678: Unable to register file system RAID 10 for APD timeout notifications: Already exists
2015-11-25T18:59:07.675Z cpu7:34317 opID=d7687719)LVM: 13177: File system '[RAID 10, 565604fb-e567a551-ac89-002590c8b99e]' (LV 565604fb-a7083ed7-f0e8-002590c8b99e) mounted in 'rw' mode.
2015-11-25T18:59:10.242Z cpu0:36465)LVM: 13197: One or more LVM devices have been discovered.
2015-11-25T19:04:17.679Z cpu3:34442)WARNING: Partition: 1224: Partition 1 is active, failure to update partition table for naa.600605b000ac95101de625ccb088d788
2015-11-25T19:04:17.679Z cpu7:37100)NMP: nmp_ThrottleLogForDevice:2349: Cmd 0x85 (0x412e808281c0, 34442) to dev "naa.600605b000ac95101de625ccb088d788" on path "vmhba2:C2:T0:L0" Failed: H:0x0 D:0x2 P:0x0 Valid sense data: 0x5 0x20 0x0. Act:NONE
2015-11-25T19:04:17.679Z cpu7:36786)ScsiDeviceIO: 2363: Cmd(0x412e808281c0) 0x4d, CmdSN 0x115 from world 34442 to dev "naa.600605b000ac95101de625ccb088d788" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0x5 0x20 0x0.
2015-11-25T19:04:17.679Z cpu7:36786)ScsiDeviceIO: 2363: Cmd(0x412e808281c0) 0x1a, CmdSN 0x116 from world 34442 to dev "naa.600605b000ac95101de625ccb088d788" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0x5 0x24 0x0.
2015-11-25T19:08:02.602Z cpu2:35224)WARNING: Res3: 6909: Invalid clusterNum: expected 2240, read 0
2015-11-25T19:08:02.602Z cpu2:35224)FS3DM: 2074: status Invalid metadata copying 1 extents between two files, bytesTransferred = 0 extentsTransferred: 0
2015-11-25T19:08:55.850Z cpu0:34318 opID=f3579760)World: 14302: VC opID hostd-eabc maps to vmkernel opID f3579760
2015-11-25T19:08:55.850Z cpu0:34318 opID=f3579760)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:08:55.851Z cpu0:34318 opID=f3579760)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:08:55.852Z cpu0:34318 opID=f3579760)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.512Z cpu7:32878)WARNING: Res3: 6909: Invalid clusterNum: expected 2240, read 0
2015-11-25T19:13:22.512Z cpu7:32878)BC: 4891: Failed to flush 128 buffers of size 8192 each for object 'Neue virtuelle Maschine-flat.vmdk' f530 28 3 565604fb e567a551 2500ac89 9eb9c890 4030c4 2 0 0 0 0 0: Invalid metadata
2015-11-25T19:13:22.514Z cpu7:32878)WARNING: Res3: 6909: Invalid clusterNum: expected 2240, read 0
2015-11-25T19:13:22.514Z cpu7:32878)BC: 4891: Failed to flush 128 buffers of size 8192 each for object 'Neue virtuelle Maschine-flat.vmdk' f530 28 3 565604fb e567a551 2500ac89 9eb9c890 4030c4 2 0 0 0 0 0: Invalid metadata
2015-11-25T19:13:22.515Z cpu7:32878)WARNING: Res3: 6909: Invalid clusterNum: expected 2240, read 0
2015-11-25T19:13:22.515Z cpu7:32878)BC: 4891: Failed to flush 54 buffers of size 8192 each for object 'Neue virtuelle Maschine-flat.vmdk' f530 28 3 565604fb e567a551 2500ac89 9eb9c890 4030c4 2 0 0 0 0 0: Invalid metadata
2015-11-25T19:13:22.516Z cpu7:32878)WARNING: Res3: 6909: Invalid clusterNum: expected 2240, read 0
2015-11-25T19:13:22.516Z cpu7:32878)BC: 4891: Failed to flush 106 buffers of size 8192 each for object 'Neue virtuelle Maschine-flat.vmdk' f530 28 3 565604fb e567a551 2500ac89 9eb9c890 4030c4 2 0 0 0 0 0: Invalid metadata
2015-11-25T19:13:22.537Z cpu6:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.538Z cpu6:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.539Z cpu6:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.629Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.630Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.631Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.632Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.633Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.634Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.635Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.636Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.637Z cpu3:35224)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.639Z cpu3:34318 opID=46749655)World: 14302: VC opID 24289317-000026AB-e4-5b-13 maps to vmkernel opID 46749655
2015-11-25T19:13:22.639Z cpu3:34318 opID=46749655)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.640Z cpu3:34318 opID=46749655)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.641Z cpu3:34318 opID=46749655)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:22.679Z cpu5:37987)Vol3: 2790: Failed to get object 28 type 2 uuid 565604fb-e567a551-ac89-002590c8b99e FD 4 gen 1 :No filesystem on the device
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: Invalid lock address 4216294627692527883
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: [lockAddr 4216294627692527883] Invalid lock type 0x3a8349a0
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: [lockAddr 8552448] Invalid lock addr 4216294627692527883
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: [lockAddr 4216294627692527883] Invalid lock numHolders 80
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: [lockAddr 4216294627692527883] Invalid lock mode 16651
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: DLX: 914: Volume 565604fb-e567a551-ac89-002590c8b99e ("RAID 10") might be damaged on the disk. Corrupt lock detected at offset 8552448
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: [type 3a8349a0 offset 4216294627692527883 v 4216410626169241600, hb offset 16651
gen 0, mode 16651, owner 00000004-00616d65-0000-000000000000 mtime 0
num 80 gblnum 0 gblgen 0 gblbrk 0][0m
2015-11-25T19:13:27.655Z cpu1:32876)WARNING: J3: 2282: Error freeing journal block (returned 0) <FB 428800> for 565604fb-e567a551-ac89-002590c8b99e: Invalid metadata
2015-11-25T19:13:27.655Z cpu2:32876)Vol3: 2710: Error closing the volume: Invalid metadata. Eviction fails.
