[Sammelthread] EVGA P55 MicroLE/Micro/LE/SLI/FTW/FTW 200/Classified 200 (Intel P55) [2]
EVGA P55 Micro LE/Micro/LE/SLI/FTW/FTW 200/Classified 200
EVGA P55 Micro
EVGA P55 Micro(E652)
Inhaltsverzeichnis:
1. Spezifikationen
2. Features
3. Bilder/Mainboard
4. Das Bios
5. Overclocking
6. Downloads
7. Reviews
1. Spezifikationen
Performance
Based on Intel P55 chipset
Supports Intel Socket 1156 Processors
Memory
4 x 240-pin DIMM sockets
Dual Channel DDR3
Maximum of 16GB of DDR3 2000MHz+
Expansion Slot
2 x PCIe x8, 1 x PCIe x1
1 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
Integrated Peripherals
8 Channel High Definition
1 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
13 x USB2.0 ports (7 external + 6 internal headers)
Audio connector (Line-in, Line-out, MIC)
FireWire
Form Factor
mATX Form Factor
Length: 9.6in - 243.84mm
Width: 9.6in - 243.84mm
2. Features
Key Features
USB 2.0 Support
A standard plug and play interface providing easy-to-use connectivity for USB devices.
PCI Express® 2.0 / 1.1 Support
Allows 500MB a lane or up to 8 GB/s at 16x speeds - allows for full support for new PCI-E 2.0 graphics cards.
Serial ATA II
Also known as SATA2, features a 3.0 Gbit/s transfer speed, faster than Standard Serial ATA.
Solid Capacitors
Offers a longer lifespan, better stability when at high frequencies, can operate at higher temperatures, and no longer runs the risk of exploding.
Passive Heatsink
Consist of a metal heatsink.
On-Board Clear CMOS Button
An onboard clear CMOS button which allows you to easily clear your BIOS without moving a jumper.
2-Way SLI® Support
Feel free to turn up the eye candy and experience the performance of 2 Graphics Cards running together.
Windows XP™ Support
Windows Vista™ Support
DDR3 Support
Full support for the latest in DDR technologies.
Dual-Channel Support
Supports Dual-Channel memory configurations for increased amounts of system memory bandwidth.
Intel® Core i7 Support
With an integrated memory controller, Intel® Core i7 (Socket 1366) processors feature amazing performance for however you use your computer.
3. Bilder/Mainboard
EVGA Bilder:
4. Das Bios
Coming soon...
5. Overclocking
Coming soon...
6. Downloads
Bios/Treiber/Manuals/Utilities
*klick*
Bios Update Anleitung
*klick*
EVGA P55 Wallpapers
*klick*
7. Previews/Reviews
Previews:
Reviews:
EVGA P55 LE
EVGA P55 LE(E653)
Inhaltsverzeichnis:
1. Spezifikationen
2. Features
3. Bilder/Mainboard
4. Das Bios
5. Overclocking
6. Downloads
7. Reviews
1. Spezifikationen
Performance
Memory
Dual Channel DDR3
Expansion Slot
1 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
3 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
1 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
14 x USB2.0 ports (8 external + 6 internal headers)
FireWire
Form Factor
ATX Form Factor
Length: 12in - 304.8mm
2. Features
Key Features
USB 2.0 Support
Serial ATA II
Solid Capacitors
Passive Heatsink
On-Board Power Button with Integrated Power Light
An onboard power button for easily powering on or off your system. Also shows a power indication light.
On-Board Reset Button with Integrated HDD Activity Light
An onboard reset button for easily rebooting your system as well as gives current status of your HDD via an activity light.
On-Board Diagnostics LED Readout
Helpful for when diagnosing a problem is needed.
2-Way SLI® Support
Windows XP™ Support
DDR3 Support
3. Bilder/Mainboard
EVGA Bilder:
4. Das Bios
Coming soon...
5. Overclocking
Coming soon...
6. Downloads
*klick*
*klick*
EVGA P55 Wallpapers
*klick*
7. Previews/Reviews
Previews:
Reviews:
EVGA P55 SLI
EVGA P55 SLI(E655)
Inhaltsverzeichnis:
1. Spezifikationen
2. Features
3. Bilder/Mainboard
4. Das Bios
5. Overclocking
6. Downloads
7. Reviews
1. Spezifikationen
Performance
Memory
Dual Channel DDR3
Maximum of 16GB of DDR3 2600MHz+
Expansion Slot
2 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
2 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
8 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1, RAID5, JBOD
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
ATX Form Factor
2. Features
Key Features
USB 2.0 Support
Serial ATA II
Solid Capacitors
Passive Heatsink
2-Way SLI® Support
Windows XP™ Support
DDR3 Support
3. Bilder/Mainboard
EVGA Bilder:
4. Das Bios
Coming soon...
5. Overclocking
Coming soon...
6. Downloads
*klick*
*klick*
EVGA P55 Wallpapers
*klick*
7. Previews/Reviews
Previews:
Reviews:
EVGA P55 FTW
EVGA P55 FTW(E657)
Inhaltsverzeichnis:
1. Spezifikationen
2. Features
3. Bilder/Mainboard
4. Das Bios
5. Overclocking
6. Downloads
7. Reviews
1. Spezifikationen
Performance
Memory
Dual Channel DDR3
Expansion Slot
Storage I/O
x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
ATX Form Factor
2. Features
Key Features
USB 2.0 Support
Serial ATA II
Solid Capacitors
Passive Heatsink
2-Way SLI® Support
Windows XP™ Support
DDR3 Support
Delivers up to 600w of CPU Power
3. Bilder/Mainboard
EVGA Bilder:
4. Das Bios
Bilder von Fatal1ty
5. Overclocking
Coming soon...
6. Downloads
*klick*
*klick*
EVGA P55 Wallpapers
*klick*
7. Previews/Reviews
Previews:
Reviews:
Overlockerstech
Firingsquad
Anandtech
EVGA P55 FTW 200
EVGA P55 FTW 200 (E658)
Inhaltsverzeichnis:
1. Spezifikationen
2. Features
3. Bilder/Mainboard
4. Das Bios
5. Overclocking
6. Wasserkühler
7. Downloads
8. Reviews
1. Spezifikationen
Performance
Memory
Dual Channel DDR3
Expansion Slot
3 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
Storage I/O
x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
ATX Form Factor
2. Features
Key Features
USB 2.0 Support
Serial ATA II
Solid Capacitors
Passive Heatsink
2-Way SLI® Support
3-Way SLI® Support
Experience the amazing performance that only 3 Graphics Cards can deliver, a visual experience that will take you to the next level.
Windows XP™ Support
DDR3 Support
3. Bilder/Mainboard
EVGA Bilder:
4. Das Bios
Coming soon...
5. Overclocking
Coming soon...
6. Wasserkühler
Anfitec
http://shop.anfi-tec.de/product_info.php/info/p125_Anfi-tec-EVGA-P55-FTW-fullcover-Waterblock.html
http://shop.anfi-tec.de/product_info.php/info/p156_Anfi-tec-PWM-028-EVGA-P55-oberer-Kuehler.html
http://shop.anfi-tec.de/product_info.php/info/p116_Anfi-tec-PWM-029-EVGA-P55-linker-Kuehler.html
Set:
http://shop.anfi-tec.de/product_info.php/info/p145_EVGA-SET01-P55-FTW.html
Bilder:
http://www.anfi-tec.de/forenbilder/P55/1.JPG
http://www.anfi-tec.de/forenbilder/P55/2.JPG
http://www.anfi-tec.de/forenbilder/P55/3.JPG
http://www.anfi-tec.de/forenbilder/P55/4.JPG
http://www.anfi-tec.de/forenbilder/P55/5.JPG
http://www.anfi-tec.de/forenbilder/P55/6.JPG
http://www.anfi-tec.de/forenbilder/P55/7.JPG
http://www.anfi-tec.de/forenbilder/P55/8.JPG
Anfitec Rabattaktion:
http://www.hardwareluxx.de/community/14026723-post132.html
7. Downloads
*klick*
*klick*
EVGA P55 Wallpapers
*klick*
8. Previews/Reviews
Previews:
Reviews:
EVGA P55 Classified 200
EVGA P55 Classified 200 (E659)
Inhaltsverzeichnis:
1. Spezifikationen
2. Features
3. Bilder/Mainboard
4. Das Bios
5. Overclocking
6. Downloads
7. Reviews
8. Besonderheiten
1. Spezifikationen
Performance
Memory
Dual Channel DDR3
Expansion Slot
5 x PCIe x16/x8, 1 x PCIe x4, 1 x PCIe x1
0 x 32-bit PCI, support for PCI 2.1
Storage I/O
x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
FireWire
Form Factor
EATX Form Factor
Length: ?
Width: ?
2. Features
Key Features
USB 2.0 Support
Serial ATA II
Solid Capacitors
Passive Heatsink
2-Way SLI® Support
3-Way SLI® Support
Windows XP™ Support
DDR3 Support
10 Phase Digital PWM
300% more gold content in the CPU socket
Super-low ESR and ESL film capacitors
3. Bilder/Mainboard
EVGA Bilder:
Eigene Bilder:
4. Das Bios
Bilder
Video zum Bios Bios.
5. Overclocking
Coming soon...
6. Downloads
*klick*
*klick*
EVGA P55 Wallpapers
*klick*
7. Previews/Reviews
Previews:
Video
Hardwarecanucks
Reviews:
Anandtech
Guru 3D
8. Besonderheiten
Show Volt Feature
Das Show Volt Feature ist ein Onboard Multimeter. Damit hat man die möglichkeit
ohne ein zusätzliches MM die Spannungen des Mainboards sich direkt anzeigen
zu lassen. Dazu hier ein Beispiel Video.
Quellen EVGA/Hardwarecanucks/Guru 3D
Ja.. ist P55 Chip bedingt. Ist beim ASUS ähnlich..
Mal ne kurze Frage irgendwie check ich das net :-(
Wieso haben einige die Einstellung und andere wiederum eine komplett andere, was genau bringt das und wirkt es sich auf die Lebensdauer des Boards/Hardware aus ?!
CPU PWM Frequency - 849KHz
VTT PWM Frequency - 634KHz
DDR PWM Frequency - 634KHz
CPU PWM Frequency - 477KHz
VTT PWM Frequency - 240KHz
DDR PWM Frequency - 240KHz
PS: Und was genau bringt PCIE 104 anstatt 100 ?! Kann man damit net die Graka schrotten ?!
Danke für die Aufklärung ;-)
MFG
Sharie
Es hat mit der Frequenz der Ströme zu tun. Das genauer zu erklären, würde grad zu weit gehen, aber umso höher desto besser bei extrem OC - z.B. wird die Vcore mit einer gewissen Frequenz gesendet - umso höher, desto sauberer das Signal.
Somit können hohe Werte bei OC helfen stabil zu werden.
Wenn es mit weniger stabil ist, brauchst Du die Werte nicht anheben.
Je nach Board-Edition gibt andere Werte, weil mehr Phasen oder gar digitale Spannungswandler (classified).
PCIe - wenn Du den gesamten Bustakt anhebst (BLCK) - werden die Signale ja schärfer übers Board geschickt.. Da werden manche Signale z.B. nicht mehr 100% synchron verarbeitet. Da kann es helfen den PCIe Takt anzuheben - mehr wie 106 ist aber meist unnötig. Auch das Anheben von PCIe ist nur zu testen, wenn man das Sys bei OC nicht stabil kriegt, brauch man meist erst ab BLCK größer 200 MHz.
Super ich danke dir Dozer, also kann da null passieren wenn ich einfach die werte nutze ja ?!
MFG
Sharie
Null Probleme - aber stell mal runter - wenn das stabil geht, hast Du geringe VRM Temperaturen.. Aber die können gute 100 Grad ab.
Meistens wird mit maximalen Werten es so 55 Grad warm..
Oki, Danke nochmals ;-)
Passt dann alles bei mir soweit ales hab heute noch ne neue SSD bekommen und endlich meine Soundkarte.
Morgen kommt auch endlich mein 120 hrz Monitor von Benq und Asus zum testen bei mir zuhause an, mal schauen für welchen ich mich dann entscheide ich steh ja mehr auf glare :hail:
Sprich, Dragon Age ² und Crysis ² können kommen :asthanos:
MFG
Sharie
Mich würde ja mal interessieren, wie warm dein 860 bei 4,4 GHz wird..
- ansonsten - dickes System - hast Du mal Fotos :)
Hey du.
Max etwa 65° da ich nur Zocke und nix anderes mit der kiste mache auf was die temps beim benchen gehen kann ich dir net sagen da ich net benche ;-)
Ich kann dir auch ganz ehrlich net sagen ob der überhaupt Prima stabil ist, nochnie getestet aba ich kann sagen das er bis jetzt noch kein bluescreen etc hatte, sprich läuft eig perfekt für meine anwendungen :love:
Habe nur Bilder wo noch meine beiden GTX 480 drin sind, neue habe ich nochnet gemacht werden nachgereicht :d
Schaut atm net viel anders aus, nur halt zwei GTX 580 und oben im slot die SSD drin.
MFG
Sharie
Hallo an alle An- & nicht Anwesenden,
Und ein "full fat salute for Dozer"
Sorry...das ich mich erst jetzt zurückmelde...
[konnte mich leider die letzten Tage vom Video-Projekt nicht lösen. Bin aber so gut wie fertig...heute Abend werden die letzten Cuts fertig gemacht.]
Und dann können wir endlich loslegen...& als Entschädigung für die Geduld gibts jetzt mal ein paar Pic´s vom Rechner.
Werde mich Donnerstag Abend wieder melden & bin dann v. Fr. - So. a. H.
Bis dahin viel Erfolg bei allem...ähm...naja bei fast allem was läuft oder laufen sollte...:d
Gruß Neo
Ach ja die Temp-Anzeige [vierte Bild von links & Belegung von oben nach unten ...falls jemand fragt] :lol:
1. CPU
2. GraKa No. I
3. Graka No. II
4. Northbride
5. Rams
Danke :bigok:
@Neo - wir haben ja sogar das gleiche Case :)
@Shariela - danke für die Bilder
ok - dann versteh ich das - bei Prime wird das wohl eng werden mit den Temps - aber wenn alles problemfrei läuft, kann man damit ja auch leben.
Aber da brauchste gute Kopfhörer^^
sooo^^
ram ist heut da, gleich verbaut und 2 runs mit memtest gemacht..
alles ok!
jetzt ans oc...
naja muss den ram mit 1440 mhrz laufen lassen anders gehts leider nicht und vdimm ist 1.68 anstatt 1.5....ist das sehr gefährlich? hab das RAVEN I gehäuse un da ist gut luft drinne :P
bin grad an primeln..
mal überwiegend auf auto gelassen und bin bei 1.305 / 1.317 Vcore bei 3,6 ghz
*hust*
Ja, Moin,
habe seit heute ein 200 FTW Board in meinem Gehäuse verbaut...nun stehe ich ein wenig ratlos vor dem BIOS und hab ehrlich gesagt keinen richtigen Plan wie ich das vernünftig anstelle meinen i5-750 auf 4GHz zu takten....
Wenn wer nen paar kurze Tipps hat wäre das super:
Hier so 2-3 Infos zum System:
Board: EVGA P55 200 FTW
CPU: Intel Core i5-750
Ram: Corsair Vengeance 4GB CL8-8-8-24 (DDR3-1600)
CPU-Kühler: CoolIT ALC ECO
Grafik: EVGA GTX570 SC
Hey Leute, was muss im Bios bei der Lüftersteurung einstellen damit ich all meine Lüfter per Speedfan oder mit nem ähnlichen Prog steuern kann ? die laufen alle mit voller Power, obwohl ich schon 'Duty' ausgestellt habe. Mitm alten Board ging das ohne Probs
Geht nicht bei allen Anschlüssen.. Welche Anschlüsse auf dem Board hast Du verwendet.
Die Einstellungen für die regelbaren Ports findest Du im BIOS ..
k danke, ich schau gleich mal nach
guten tag miteinander
habe folgendes problem mit einem EVGA P55 micro
und zwar startet der rechner mal und mal wieder nicht...
beep code kommt dann 1 x lang 8 x kurz
zum rechner
mainboard: p55micro
cpu : i5 760
netzteil: enermax liberty
ram : Corsair DIMM 4 GB DDR3-1333 Kit (TW3X4G1333C9A, XMS3)
grafikkarte: EVGA 9800gtx
gabs sowas schon mal und wenn ja was habt ihr dagegen getan?
Hey Leute,
ich hab folgendes Problem. Seitdem ich auf von 4gb auf 8gb aufgerüstet habe bootet der PC, geht aus und bootet nochmal. Erst dann kommt ein Bild und anschließend Windows.
CPU: Intel Core i5-750, 4x 2.67GHz
RAM: GeIL Black Dragon DIMM Kit 4x2GB PC3-10667U CL7-7-7-24 (DDR3-1333)
Mainboard: EVGA P55 Micro, P55
Grafikkarte: MSI N260GTX-T2D896 GeForce GTX 260 896MB GDDR3
SSD: Super Talent Ultradrive GX MLC 64GB, 2.5", SATA II
HDD: Western Digital Caviar Green 500GB, 32MB Cache, SATA II
Gehäuse: Cooler Master Elite 334 black
Netzteil: Corsair CX 500W ATX 2.3
Hoffe ihr könnt mir helfen!
Gruß Blah123 :wink:
Welches Bios?
Hast Du zufällig was im Bios geändert?
Wenn Du sagst er bootet, meinst Du aber nicht daß er voll zum screen bootet,
sondern lediglich daß die Lüfter anlaufen, Monitor bleibt schwarz, geht wieder aus und fährt dann normal hoch.
Wenn das so ist, ist das normal! Kann man aber ab (ich glaube) A71 abstellen.
Schau mal kurz in Evga (englisch) Forum, genau was umgestellt werden muß.
Bios hab ich jetzt das A74 drauf.
Wirklich geändert hab ich nix nur das ich halt 2 weitere gleiche Ram-Module eingebaut habe.
Ja er bootet, Lüfter etc. laufen an, Bildschirm bleibt schwarz (sucht dann über Analog/Digital ein Bildsignal), dann geht der PC aus und der Rechnen bootet dann ganz normal.
Problem wurde durch das A74 Bios nicht behoben. Nur das er jetzt beim booten 4x piept. :d
Ich hab genau dasselbe, seit ich die die andern 2 von 4 Riegeln Corsair drin habe... (P55 SLI). Ich glaube gelesen zuhaben das das eine Art Selbsttest ist. Ist schon nervig
Aus dem ami Forum:
Look in the Bios under (Frequency/Voltage Control)
Look and see if Clockgen Switch Mode is Enabled.
That might be it. Disabled might stop that.
Das piepen danach ist auch normal: ein piep pro USB Gerät.
Das ist ein Intel P55 Feature!
Die Meisten von uns waren happy, daß Evga dieses Feature nicht (oder fehlerhaft) implementiert hatte..............
Exakt
Clockgen Feature im BIOS deaktivieren. Ab FSB 200 ist das immer an.. Und wenn man den PCIe Takt um
Mehr als 5% erhöht.
Das Piepen ist normal (USB Devices)
Aus dem ami Forum:
Exakt
Clockgen Feature im BIOS deaktivieren. Ab FSB 200 ist das immer an.. Und wenn man den PCIe Takt um mehr als 5% erhöht.
Ahhh merci für die Infos. Jetzt muss ich mich entscheiden ob ich den CPU-Takt etwas senke oder das rebooten akzeptiere. :)
Welchen Takt fährst Du bei welcher CPU?
200 MHz BLCK sollten aber ohne Clockgen gehen.
Hat jemand von euch ne Liste fürs P55 SLI parat für die Diagnose LED?
Hab grad ein paar Probleme und das würde mir ein gutes Stückchen weiter helfen.
