So weil es bisher noch keinen Sammelthread sondern lediglich einen Bericht zu dem Board gibt habe ich mir gedacht, dass ich einfach mal einen erstelle.
1. Das Mainboard
1 - 2x IEEE1394a Firewire Header
2 - SPDIF connector
3 - USB 2.0 Header für 6 Ports
4 - Front Panel Header
5 - 6x SATA 300 MB/s
6 - Floppy connector
7 - 2-Kanal IDE connector
8 - Front Panel Audio Out Header Controller
Noch mehr Bilder
1.1 Spezifikationen
Spezifikationen
Form Factor
Micro ATX form factor; 24.4cm x 24.4cm
BIOS
1. 1 4Mbit flash ROM
2. Use of licensed AWARD BIOS
3. PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b
Chipsatz
1. North Bridge Chipset: AMD 690G
2. South Bridge Chipset: ATI SB600
3. Super I/O chip: ITE IT8716
4. Integrated Peripherals
1. Realtek RTL8110 Gigabit Ethernet
2. Realtek ALC889A Audio Codec
Prozessor
1. AMD Socket AM2 Athlon™ 64 FX / Athlon™ 64 X2 Dual-Core / Athlon™ 64 / Sempron™ processors
Interne I/O Anschlüsse
1. 1 24-pin ATX power connector
2. 1 4-pin ATX 12V power connector
3. 1 floppy connector
4. 1 IDE connector
5. 4 SATA 3Gb/s connector
6. 1 CPU fan header
7. 1 system fan header
8. 1 front panel header
9. 1 front audio header r
10. 1 CD In connector
11. 1 SPDIF In/Out header
12. 1 TV Out header
13. 2 IEEE 1394a header
14. 3 USB 2.0/1.1 header for additional 6 USB 2.0/1.1 ports by cables
15. 1 Parallel port header
16. 1 Serial port header
17. 1 Power LED header
18. 1 Chassis Intrusion header
Rear Panel I/O
1. 1 PS/2 keyboard port
2. 1 PS/2 mouse port
3. 1 D-Sub port
4. 1 DVI-D port
5. 1 HDMI port
6. 1 Optical SPDIF Out port
7. 1 IEEE 1394a port
8. 4 USB 2.0/1.1 port
9. 1 RJ-45 LAN port
10. 6 audio jacks (Line In / Line Out / MIC In/Surround Speaker Out (Rear Speaker Out)/Center/Subwoofer Speaker Out/Side Speaker Out)
Erweiterungs Steckplätze
1. 1 PCI Express x 16 slot
2. 1 PCI Express x 4 slot
3. 2 PCI slot
H/W Monitoring
1. System voltage detection
2. CPU / System temperature detection
3. CPU / System fan speed detection
4. CPU / System warning temperature
5. CPU fan failure warning
6. Supports CPU Smart Fan function
Other Features
1. Supports @BIOS
2. Supports Download Center
3. Supports Q-Flash
4. Supports EasyTune (only supports Hardware Monitor function)
5. Supports Xpress Install
6. Supports Xpress Recovery2
7. Supports Xpress BIOS Rescue
Arbeitsspeicher
1. 4 DDR2 DIMM memory slots (supports up to 16GB memory)
2. Supports dual channel DDR2 800/667/533/400 DIMMs
3. Supports 1.8V DDR2 DIMMs
Power
1. ATX power connector and ATX 12V connector
1.2 Ausstattung
- 1x IDE Kabel
- 1x Floppy Kabel
- 2x SATA Kabel
- 1x Slotblende (1x S-Video, 1x Y/Pr/Pb)
- 1x I/O Shield
- 1x Treiber CD Vista
- 1x Treiber CD XP
- 1x Mainboard Handbuch
2. Hilfen
2.1 FAQ - Frequently Asked Questions
Kommen noch.
2.2 Speicher Kompatiblitätsliste
->Speicher Kompatiblitätsliste
-> Falls Speicher die nicht in der Liste stehen und funktionieren bzw. nicht funktionieren stehen sie hier.
- ...Bisher noch keine Einträge...
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
->BIOS
->Treiber
->Bedienungsanleitung
3.2 Reviews
->motherboards.org
->techgage.com
3.3 Geizhals Link
->Geizhals.at
Ich bin offen für Verbesserungsvorschläge.
2 - SPDIF connector
Noch mehr Bilder
1.1 Spezifikationen
Spezifikationen
Form Factor
BIOS
Chipsatz
Prozessor
4. 1 IDE connector
6. 1 CPU fan header
12. 1 TV Out header
Rear Panel I/O
3. 1 D-Sub port
4. 1 DVI-D port
5. 1 HDMI port
9. 1 RJ-45 LAN port
3. 2 PCI slot
H/W Monitoring
Other Features
1. Supports @BIOS
3. Supports Q-Flash
Arbeitsspeicher
Power
1.2 Ausstattung
- 1x IDE Kabel
- 1x Floppy Kabel
- 2x SATA Kabel
- 1x I/O Shield
- 1x Treiber CD XP
2. Hilfen
Kommen noch.
->BIOS
->Treiber
3.2 Reviews
->motherboards.org
->techgage.com
3.3 Geizhals Link
->Geizhals.at
