na ein bischen schon...
http://www.anandtech.com/mb/showdoc.aspx?i=2273
Gigabyte K8NXP-9 Specifications
CPU Interface Socket 939 Athlon 64
Chipset nVidia nForce 4 Ultra (Single-Chip)
Bus Speeds 200MHz to 400MHz*
PCI Express Speeds None in Pre-Release BIOS*
Core Voltage 0.8V to 1.7V in 0.025V increments
CPU Clock Multiplier 6x-25x in 1X increments*
HyperTransport Frequency 1000MHz (1GHz)
HyperTransport Multiplier 1X, 2X, 3X, 4X, 5X
DRAM Voltage 2.5V to 3.1V in 0.1V increments*
HyperTransport Voltage Normal, + 0.1V, +0.2V, +0.3V
Memory Slots Four 184-pin DDR DIMM Slots
Dual-Channel Configuration
Regular Unbuffered Memory to 4GB Total
Expansion Slots 1 x16 PCIe Slot
2 x1 PCIe Slots
3 PCI Slots
Onboard SATA/SATA RAID 8 SATA Drive Total
4 SATA 300 Drives by nForce4
(RAID 0, 1, 0+1, JBOD)
Can be combined with IDE drives in RAID
4 SATA 150 Drives by Sil3114CT176
Onboard IDE/IDE RAID Two Standard ATA133/100/66 (4 drives)
Drives may be as IDE RAID or combined with nF4 SATA drives in a RAID Array
Onboard USB 2.0/IEEE-1394 10 USB 2.0 ports supported by nForce4
2 Firewire 1394B by TI 46A9C3W
Onboard LAN Dual Gigabit LAN
On-chip Gigabit LAN by nF4/Cicada 8201 PHY
PCI Express Gigabit LAN by Marvel 88E8053
Wireless LAN PCI 802.11b/g Wireless LAN Card Included
Onboard Audio AC '97 2.3 8-Channel by Realtek ALC850
BIOS Revision Award GA-K8NXP-9 M01 11/02/2004
Gruß jandelely
