[Sammelthread] Gigabyte Z97X-SOC Force
--- GIGABYTE Z97 OC Microsite ---
GIGABYTE Z97X-SOC Force
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- GIGABYTE Z97X-SOC Force @ hwbot ---
Spezifikationen
Model numberGA-Z97X-SOC FORCE
EAN4719331812232
Form factorATX (305x244mm)
CPULGA1150
ChipsetIntel® Z97
MemoryNumber of slots: 4
Channels: Dual
Corresponding standard: DDR3
3300 (OC) / 3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC)
2500 (OC) / 2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333
Built-in graphicsD-sub (1920x1200 @ 60Hz)
DVI-D (1920x1200 @ 60Hz)
HDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz)
DisplayPort 1.2 (4096x2160 @ 24Hz, 3840x2160 @ 60Hz)
Expansion slot4x PCI Express x16 (2x16, 1x8, 2x4 Lanes)
1x PCI Express x1
2x PCI
Multi-GPU4-Way AMD CrossFire, 2-Way NVIDIA SLI
Storage1x SATA Express*
6x SATA 6Gb/s (RAID 0/1/5/10 support)
*SATA Express and SATA3_4/5 Port shared
Audio7.1 Channel Realtek HD Audio (ALC1150)
LAN1x Qualcomm Atheros Killer E2201 (Gigabit Ethernet)
Interface6x USB3.0 (4x Backpanel, 2x Internal)
8x USB2.0 (4x Backpanel, 4x Internal)
Internal connector1x 24-pin ATX main power
1x 8-pin ATX 12V power
1x 4-pin ATX 12V power
1x OC PEG power
1x SATA Express
6x SATA 6Gb/s
1x CPU fan header
1x water cooling fan header (CPU_OPT)
6x system fan headers
1x front panel header
1x front panel audio header
1x S/PDIF Out header
1x USB 3.0 / 2.0 header
1x USB 2.0 / 1.1 header
2x USB 2.0 / 1.1 ports
1x serial port header
1x Clear CMOS jumper
1x power button
1x reset button
1x Clear CMOS button
1x Gear button
1x OC Turbo button
1x OC Tag button
1x OC Trigger switch
1x CPU BCLK Down button
1x CPU BCLK Up button
1x CPU Ratio Down button
1x CPU Ratio Up button
1x Memory Safe button
1x Settings Lock button
1x Direct to BIOS button
1x OC DIMM switch
1x OC PCIe switch
1x OC Ignition button
1 Clear Battery button
2x BIOS switches
1x onboard voltage measurement module
Back panel4 x USB 2.0 / 1.1 ports
4x USB 3.0 / 2.0 ports
1x optical S / PDIF Out connector
1x D-Sub port
1x DVI-D port
1x HDMI port
1x DisplayPort
1x PS/2 keyboard & mouse port
1x RJ-45 port
6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In)
BIOS2x 128 Mbit flash
AMI UEFI BIOS
Support for DualBIOS
PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0
Supported OSWindows 7 / 8 / 8.1
AccessoriesUser manual
Installation guidebook
I/O shield
Driver disk
4x SATA cable
OC brace
V-probes
2x SLI bridge
BIOS
1) Bilder
2) Spannungen
CPU Vcore0.500V bis 1.800V
-0.300V bis +0.400V
in 1 mV Schritten (Override)
in 1mV Schritten (Offset)
CPU VRIN External Override1.000V bis 2.400Vin 10mV Schritten
CPU Graphics Voltage0.500V bis 1.800V
-0.300V bis +0.400V
in 1mV Schritten (Override)
CPU RING Voltage0.800V bis 1.800V
-0.300V bis +0.400V
CPU System Agent Voltage-0.300V bis +0.400Vals Offset in 1mV Schritten
CPU I/O Analog Voltage-0.300V bis +0,400Vals Offset in 1mV Schritten
CPU I/O Digital Voltage-0.300V bis +0,400Vals Offset in 1mV Schritten
DRAM Voltage1.160V bis 2.100Vin 20mV Schritten
DRAM Termination0.325 bis 1.939Vin 3mV Schritten
PCH Core0.650 bis 1.300Vin 5mV Schritten
PCH I/O1.050V bis 1.900Vin 5mV Schritten
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
  • F3 (Initial Release)
  • F4 (Changes: Enhanced OC & Memory Compatibility)
  • F5 (Changes: CPU Microcode Update)
  • F6 (Changes: G3258 Overclocking, Improve SSD Performance)
  • F7e (Changes: Beta, Support future NVMe SSD drive)
  • F7 (Changes: CPU Microcode Update, Achtung: Es ist anschließend kein Downgrade mehr möglich!)
  • F8 (Changes: Enhanced 5th Gen Core Processors/Broadwell Support)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr, Garantieverlust!)
News & Reviews
HARDWARELUXX Review Gigabyte GA-Z97X-SOC Force im Test
Hardwareluxx News: Gigabyte zeigt Intel Z97-Mainboards
Hardwareluxx News: Computex 2014: Gigabyte zeigt das GA-Z97X-SOC Force LN2
International Reviews
00) Gamezoom
01) Hartware.net
02) Tweakpc
03) Awardfabrik
04) ProClockers
05) OMF
06) Pclab.pl (Vergleichstest, 34 Modelle)
07) shahrsakhtafzar
08) Hardware Asylum
09) EasyCOM (ua)
10) Benchmark.rs
11) ocaholic
12) PC Perspective
13) PCaxe
14) pctuning.tyden.cz
15) Hardware.Info United Kingdom (Vergleichstest, 19 Modelle)
16) PC Ekspert
17) Legit Reviews
18) Benchit
19) HotHardware (Vergleichstest, 5 Modelle)
20) AnandTech
21) Z97 Motherboard LN2 Roundup @ Hardware.Info United Kingdom
ASRock Z97 OC Formula
ASUS Maximus VII Gene
MSI Z97 XPower AC
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tips (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • Das Verhalten der Stromsparmechanismen beim Übertakten (vom Z87X-OC):
  • Power-Off Dead Syndrom (Rechner lässt sich plötzlich nicht mehr einschalten)
    Wie ich dem Problem entgegne:
    Man kann das Board wieder zum Leben erwecken, indem man mit einer Litze das Netzteil manuell startet, während der Hauptstecker auf dem Mainboard sitzt. Das System läuft an, startet dann nochmal neu und danach geht es auch schon wieder in Windows.
    Alternativ: Das Board stromlos machen, die Batterie entfernen und das Board entladen (lassen, ca ~ 5 Minuten Wartezeit genügen).
emissary42 schrieb:
Falls noch jemand das Bild von der Verpackung als Wallpaper haben möchte:
Ist nur abfotografiert, sieht aber halbwegs original aus.
Das Board mal komplett vom Strom trennen und die Batterie raus nehmen schadet sicher nicht, zumindest wenn es sonst keinen Mucks mehr macht. Sonst mal im offenen Tischaufbau systematisch die relevanten Funktionen abhaken, wie CBat, Ignition usw.
Naja also icrack ist zumindest der vierte Fall aus dem Forum. Bei der geringen Anzahl an Besitzern des Bords hier ist das schon auffällig. Als ich mein defektes verschenkt habe, hätten sich noch zwei andere gemeldet, die das selbe Problem haben ...
Und Gigabyte macht da garnichts, ohne Rechnung null Chance. Und das bei einem 180€ board... Echt schwach
Wenn sich die vier (?) Leute mal absprechen und ihre Boards noch da haben, könnte man da ja mal nachforschen - wenn da von offizieller Seite nichts passiert, dann halt wir hier unter uns. Irgendwas muss es damit ja auf sich haben. Mir ist zumindest noch nie ein Board im ausgeschalteten Zustand komplett verstorben, in über 20 Jahren o_O
Der beschenkte hat ja jetzt zwei mit den selben Symptomen bzw defekten. Er wollte mal schauen und sich dann melden
Er kann sich auch gern mal bei mir melden, falls ich helfen kann.
Also ich schicke meins ein, da Garantie. Versuche dann herauszufinden, was da das Problem ist... Vielleicht kann ich euch ja was gutes mit ner Fehlerbeschreibung geben. Vermute aber, aufgrund des geringen Alters, dass es einfach direkt ausgetauscht wird. Mal sehen, ich melde mich hier definitiv weiterhin!
Nicht bei Mindfactory ;-)
...jeder eingetragener Händler kann direkt eine RMA bei Gigabyte einleiten. Auch die Rechnungskopie wird nicht benötigt, da dieses über die S/N geschied. Also, wenn es sich nicht um Grauimporte handelt, sollte es mit der RMA auch keine Probleme geben. Ansonsten kann ich das auch gegen eine Aufwandspauschale abwickeln.
Ach scheiße, das sagst du mir jetzt :heul:
Mindfactory hat mir soeben bestätigt, nachdem das Mainboard keine 2h da war, dass ohne weitere Prüfung das SoC auf Kulanz ab Lager getauscht wird... Böh
Bei einem der beiden Boards von HardwareFreaky soll einer der Spannungswandler für die CPU durch gewesen sein, das andere ist ohne sichtbare Beschädigung. Leider hat er keine Bilder gemacht, so bleibt das Ganze erst mal ein Mysterium (auch weil ein Wandler im CPU-VRM eher nicht im ausgeschalteten Zustand durchbrennt).
Weiß jemand, wie man es schafft, dass die USB Anschlüsse stromlos werden im StandBy? Bei mir läuft externe Fesplatte, DVB-T Stick etc. immer.
Habe da schon alles durch (Erp im Bios, in Windows sämtliche Einstellungen im Geräte Manager sowie Energieoptionen). Der Strom bleibt immer an.
Guten Morgen,
wenn im BIOS ErP = [Enabled], müssen die USB-Anschlüsse stromlos sein. Ansonsten ist es ein Bug im BIOS.
Das SoC ist ausgetauscht, Rechner läuft wieder :)
Sorry für die miese Bildqualität.
ich brauche echt hilfe beim OC :d
stelle 1,25V ein und 4,5 ghz -> absturz
1,265V laufen die 4,5ghz aber CPU-z liesst bist zu 1,35V aus und die CPU temp liegt bei 80°C (wakü temp auf 23°C und als kühle kryos delrin)
spannung erhöht über overdrive. also erst "voltage setting" auf normal und dann bei "voltage override" +0,165V
hast recht. wenn ich also die vcore einstelle, sollte die spannung ja in idle abgesenkt werden. cpu-z zeigt das nicht an (aber ist ja im wernersen tut auch so erklärt). muss mir wohl nen multimeter besorgen
mein 4670k braucht für 4.2ghz schon stolze 1,275V
Solange du EIST und die C-States nicht deaktivierst wird die Vcore abgesenkt. Du brauchst dir deswegen auch nicht gleich ein MM kaufen, -afaik- liest z.B. HWInfo das korrekt aus.
leider zeigt hwinfo auch nur die eingestellte vcore an. aber ich hab gerade mein messgerät dran (brennenstuhl pm 231 oder so) und es zeigt 70w in idle an.
also alles ok für 4670k, 780ti, HDD, SSD, aquastream XT @ 60hz (12V*0,4A) und insgesamt gut 5-10w lüfter (3x NB PK2@ 35%; 2x PL2 @ 35%)
eventuell kommt morgen mein neues spielzeug, mal sehen was da raus kommt (4790k pretested - 4,8ghz @ 1,22V :d)
Ich kann den Verbrauch ehrlich gesagt nicht einschätzen, aber ohne Graka und Waku kam ich problemlos unter 30W @ Idle.
Naja man muss ja auch dazu sagen, dass ein Bq p10 750w verbaut ist. Dieses hat bei 10% Auslastung ja bekanntlich nicht die beste Effizienz. Dazu sagen wir mal 10-20w gpu, 6w Pumpe und 5w Lüfter... Da wären wir schon bei 55-60w
Achja, eine phoebus ist auch noch verbaut. Dafür sind 70w dann meiner Meinung nach Spitze (hatte ich ohne wakü mit dem e9 450w auch ...)
Ja, das sollte dann in etwa passen.
So, dann will ich mich mal einklinken.
Bei mir zeigt das Board jetzt auch das Power-Off Dead Syndrom, also das es sich der Rechner nicht mehr einschalten lässt.
Ich hatte auch zunächst das Netzteil in Verdacht, aber es liegt am Board, da ich das Netzteil manuell starten konnte.
Leider habe ich das Board bei ebay Kleinanzeigen ergattert (125€) im Wissen, dass es von Amazon.uk vertrieben worden war. Bisher hatte ich aber noch nie ein Board welches kaputt gegangen ist.
Power-Off Dead Syndrom: Rechner lässt sich nicht mehr einschalten.
Das hört sich nachvollziehbarer an, als die Geschichte, dass die betroffenen Boards tatsächlich im ausgeschalteten Zustand Schäden am VRM davon getragen hätten. Offenbar ist nur ein gewisser Teil der Logik des Boards dann scheintot z.B. Frontpanelanschlüsse, Power-Schalter, ... Alternativ zum Brücken des Netzteils könnte es dann eventuell auch reichen, das Board vom Strom zu trennen und zu entladen? Das müsste mal jemand testen, bei dem das Phänomen auftritt. Vielleicht finden sich im laufe der Zeit auch noch einfachere Lösungen dafür. Das wichtigste ist für die Betroffenen ja erst mal, dass er weiß, das sein Board noch "lebt".
Ich werde deinen Quote auch in den ersten Beitrag einfügen, also Danke schon mal :wink:
Also stromlos hatte ich das Board schon mal gemacht, allerdings ohne die Batterie zu entfernen. Wollte mir bislang meine BIOS Einstellungen nicht zerschießen, weil ich wusste, dass ich das Profil nicht gesichert hatte.
Wenn das Phänomen wieder auftritt, werde ich mal die Stromstecker abziehen und die Batterie entfernen. CMOS Clear hat in jedem Fall nicht gereicht..
Bei mir hatte das Brücken des NTs nicht geholfen. Genauso CMOS Reset, BIOS Batterie entfernen (mehrere Minuten), etc.
Die Frage ist natürlich auch, wenn die Logik vom Board nur Scheintot ist - müsste es für die Techniker dann nicht ein leichtes sein dieses wieder in Gang zu setzen? Ich habe allerdings definitiv ein neues erhalten. Das alte wurde nicht reanimiert..
Ich wüsste mal gerne was genau zu diesem Fehler führt.
Hoffe nun darauf, dass mein neues den Fehler niemals an den Tag legt :d
BIOS F7 ist final! Falls noch nicht aufgefallen :)
