[Sammelthread] Gigabyte Z97X-SOC Force
--- GIGABYTE Z97 OC Microsite ---
GIGABYTE Z97X-SOC Force
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- GIGABYTE Z97X-SOC Force @ hwbot ---
Spezifikationen
Model numberGA-Z97X-SOC FORCE
EAN4719331812232
Form factorATX (305x244mm)
CPULGA1150
ChipsetIntel® Z97
MemoryNumber of slots: 4
Channels: Dual
Corresponding standard: DDR3
3300 (OC) / 3200 (OC) / 3100 (OC) / 3000 (OC) / 2933 (OC) / 2800 (OC) / 2666 (OC) / 2600 (OC)
2500 (OC) / 2400 (OC) / 2200 (OC) / 2133 (OC) / 2000 (OC) / 1866 (OC) / 1800 (OC) / 1600 / 1333
Built-in graphicsD-sub (1920x1200 @ 60Hz)
DVI-D (1920x1200 @ 60Hz)
HDMI 1.4a (4096x2160 @ 24Hz, 2560x1600 @ 60Hz)
DisplayPort 1.2 (4096x2160 @ 24Hz, 3840x2160 @ 60Hz)
Expansion slot4x PCI Express x16 (2x16, 1x8, 2x4 Lanes)
1x PCI Express x1
2x PCI
Multi-GPU4-Way AMD CrossFire, 2-Way NVIDIA SLI
Storage1x SATA Express*
6x SATA 6Gb/s (RAID 0/1/5/10 support)
*SATA Express and SATA3_4/5 Port shared
Audio7.1 Channel Realtek HD Audio (ALC1150)
LAN1x Qualcomm Atheros Killer E2201 (Gigabit Ethernet)
Interface6x USB3.0 (4x Backpanel, 2x Internal)
8x USB2.0 (4x Backpanel, 4x Internal)
Internal connector1x 24-pin ATX main power
1x 8-pin ATX 12V power
1x 4-pin ATX 12V power
1x OC PEG power
1x SATA Express
6x SATA 6Gb/s
1x CPU fan header
1x water cooling fan header (CPU_OPT)
6x system fan headers
1x front panel header
1x front panel audio header
1x S/PDIF Out header
1x USB 3.0 / 2.0 header
1x USB 2.0 / 1.1 header
2x USB 2.0 / 1.1 ports
1x serial port header
1x Clear CMOS jumper
1x power button
1x reset button
1x Clear CMOS button
1x Gear button
1x OC Turbo button
1x OC Tag button
1x OC Trigger switch
1x CPU BCLK Down button
1x CPU BCLK Up button
1x CPU Ratio Down button
1x CPU Ratio Up button
1x Memory Safe button
1x Settings Lock button
1x Direct to BIOS button
1x OC DIMM switch
1x OC PCIe switch
1x OC Ignition button
1 Clear Battery button
2x BIOS switches
1x onboard voltage measurement module
Back panel4 x USB 2.0 / 1.1 ports
4x USB 3.0 / 2.0 ports
1x optical S / PDIF Out connector
1x D-Sub port
1x DVI-D port
1x HDMI port
1x DisplayPort
1x PS/2 keyboard & mouse port
1x RJ-45 port
6x audio jacks (Center / Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In, Line Out, Mic In)
BIOS2x 128 Mbit flash
AMI UEFI BIOS
Support for DualBIOS
PnP 1.0a, DMI 2.7, WfM 2.0, SM BIOS 2.7, ACPI 5.0
Supported OSWindows 7 / 8 / 8.1
AccessoriesUser manual
Installation guidebook
I/O shield
Driver disk
4x SATA cable
OC brace
V-probes
2x SLI bridge
BIOS
1) Bilder
2) Spannungen
CPU Vcore0.500V bis 1.800V
-0.300V bis +0.400V
in 1 mV Schritten (Override)
in 1mV Schritten (Offset)
CPU VRIN External Override1.000V bis 2.400Vin 10mV Schritten
CPU Graphics Voltage0.500V bis 1.800V
-0.300V bis +0.400V
in 1mV Schritten (Override)
CPU RING Voltage0.800V bis 1.800V
-0.300V bis +0.400V
CPU System Agent Voltage-0.300V bis +0.400Vals Offset in 1mV Schritten
CPU I/O Analog Voltage-0.300V bis +0,400Vals Offset in 1mV Schritten
CPU I/O Digital Voltage-0.300V bis +0,400Vals Offset in 1mV Schritten
DRAM Voltage1.160V bis 2.100Vin 20mV Schritten
DRAM Termination0.325 bis 1.939Vin 3mV Schritten
PCH Core0.650 bis 1.300Vin 5mV Schritten
PCH I/O1.050V bis 1.900Vin 5mV Schritten
3) BIOS Downloads - Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
  • F3 (Initial Release)
  • F4 (Changes: Enhanced OC & Memory Compatibility)
  • F5 (Changes: CPU Microcode Update)
  • F6 (Changes: G3258 Overclocking, Improve SSD Performance)
  • F7e (Changes: Beta, Support future NVMe SSD drive)
  • F7 (Changes: CPU Microcode Update, Achtung: Es ist anschließend kein Downgrade mehr möglich!)
  • F8 (Changes: Enhanced 5th Gen Core Processors/Broadwell Support)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr, Garantieverlust!)
News & Reviews
HARDWARELUXX Review Gigabyte GA-Z97X-SOC Force im Test
Hardwareluxx News: Gigabyte zeigt Intel Z97-Mainboards
Hardwareluxx News: Computex 2014: Gigabyte zeigt das GA-Z97X-SOC Force LN2
International Reviews
00) Gamezoom
01) Hartware.net
02) Tweakpc
03) Awardfabrik
04) ProClockers
05) OMF
06) Pclab.pl (Vergleichstest, 34 Modelle)
07) shahrsakhtafzar
08) Hardware Asylum
09) EasyCOM (ua)
10) Benchmark.rs
11) ocaholic
12) PC Perspective
13) PCaxe
14) pctuning.tyden.cz
15) Hardware.Info United Kingdom (Vergleichstest, 19 Modelle)
16) PC Ekspert
17) Legit Reviews
18) Benchit
19) HotHardware (Vergleichstest, 5 Modelle)
20) AnandTech
21) Z97 Motherboard LN2 Roundup @ Hardware.Info United Kingdom
ASRock Z97 OC Formula
ASUS Maximus VII Gene
MSI Z97 XPower AC
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.​
Nützliche Links & Tips (im Forum & im WWW)
1) Hardwareluxx
2) WWW (international)
3) Tips & Tricks
  • Das Verhalten der Stromsparmechanismen beim Übertakten (vom Z87X-OC):
  • Power-Off Dead Syndrom (Rechner lässt sich plötzlich nicht mehr einschalten)
    Wie ich dem Problem entgegne:
    Man kann das Board wieder zum Leben erwecken, indem man mit einer Litze das Netzteil manuell startet, während der Hauptstecker auf dem Mainboard sitzt. Das System läuft an, startet dann nochmal neu und danach geht es auch schon wieder in Windows.
    Alternativ: Das Board stromlos machen, die Batterie entfernen und das Board entladen (lassen, ca ~ 5 Minuten Wartezeit genügen).
emissary42 schrieb:
Falls noch jemand das Bild von der Verpackung als Wallpaper haben möchte:
Ist nur abfotografiert, sieht aber halbwegs original aus.
Ist eingetragen. Da man ja vom F7 nicht mehr downgraden kann, brauchen wir nun auch noch ein neues X-BIOS^^
Hatte heute auch Power-Off Dead mit 5Stb und GND Brücken lief es wieder an und bleibt jetzt auch wieder an.
Gibt es da irgendwas schon was von Gigabyte zu? Habe mein ganzes Netzteil passend in dieses Orange Schwarz gesleevte und möchte jetzt ungerne das Board austauschen allerdings ist das ein Bug den ich nicht hinnehmen möchte. Vom Strom nehmen hilft nicht Habe mein PC nachts immer komplett vom Strom
Jetzt mein Netzteil neu zu Sleeven und Board zu tauschen möcht ich ungern.
Ich hatte Gigabyte angeschrieben, den war das Problem aber nicht bekannt. Da ich es mit meinem Z97X-SOC Force selbst nicht nachstellen konnte, müsste sich deswegen mal ein Betroffener an Hamburg wenden und genauere Angaben machen (Forum, Email oder Hotline).
Werde ich den mal Schreiben.
Muss ja daran Liegen das ich den Komplett vom Strom nehme Nachts.
Denn es leuchtete Nicht mal die STB leuchte vom Board nach dem ich wieder Strom eingeschaltet habe.
Habs mal wieder nicht ausgehalten und auch dieses Board bestellt :fresse:
Schauen wir mal was das Board kann :bigok:
Bis auf dem bug der erst einmal bei mir war ist es für mich das beste Intel board was ich bisher hatte. Zuletzt war ich so zufrieden bei den DFIs boards :d
Es gibt schon ein paar Dinge, die man noch verbessern könnte*, aber grundsätzlich hat Gigabyte beim Z97X-SOC Force Vieles richtig gemacht. Das Z87X-OC war aber auch schon eine hervorragende Grundlage und ist in paar Punkten sogar das bessere der beiden Modelle.
*z.B.
- die Lüftersteuerung
- feinere Vdimm-Kontrolle
- ein zweiter Front USB3 Header (gern auch abgewinkelt)
- weg mit VGA und DVI
- eine USB BIOS Flashback Entsprechung
- Intel statt Killer NIC
Intel statt Killer NIC ist bei mir der größte Kritikpunkt. Aber auch so bin ich mittlerweile mehr als zufrieden! :)
Da man wahlweise auch einen Qualcomm Standardtreiber für den Atheros AR8161 verwenden kann, finde ich den Punkt nicht so dramatisch.
*z.B.
habe gerade eben(und die nächste 5 Stunden) die Möglichkeit Gigabyte Z97X-SOC Force Board gegen Gigabyte GA-Z87X-OC Force zu tauschen bzw. auswählen.
meinst Du wäre die Gigabyte GA-Z87X-OC Force bessere Wahl?
Besser wofür? Allgemein nein, wenn dir das Z87X-OC Force nicht irgendetwas bietet, was dem Z97X-SOC Force fehlt.
Willkommen im Club :wink:
Aber wirklich ein 4790 oder doch ein 4790K? =)
Das Mainboard ist hier, bis jetzt alles gut :coolblue:
Verpackung selber, das Aussehen, Qualität verbaute Teile, Position allen Komponenten, also das gesamte Eindruck ist 1A.
Einbau tue ich morgen genau wie Overclock meine 4790K Cpu, kann im Moment nur sagen- eins von beiden geht spätestens Übermorgen in unser Marktplatz.
Das beste bleibt hier :love: entweder Gigabyte Z97X-SOC Force oder ASUS ROG Maximus VII Hero.
MfG
swdtechnik
Na dann viel Spaß :fresse2:
Scheiß ROG Bretter... :d
Naja, zu Z77 Zeiten war ich mit meinem Maximus V Extreme ganz zufrieden*. Die VIer Modelle hatten ja leider diesen fiesen Uhrzeit-Bug und von den VIIern interessierte mich eigentlich nur das Impact.
*Edit: behalten habe ich dann doch das Z77X-UP5 TH :d
Hallo. 1 Tag das Board drin und schon das erste Problem.
Der PC ist Heute schon 2 mal abgeschmiert ohne bluescren einfach sie ausgegangen und wieder neu gestarte.
liegt es am Bis F3 hab einen normalen intel 4790 drin weil es gibt ja schon F7 Bios
Update mal, das F3 ist ja antik und die frühen Releases haben die 4790K mit Spannungen gut angegrillt. Welche Stopcodes hatten deine BSODs?
Hatte kein bluescren keine Fehlermeldung von win.
Was ist eigendlich GTL2.0
Soll ich F6 oder F7 nehmen?
Wie mache ich den Flash am besten
Wenn ich GTL2 installiere und starte stürzt der PC ab, das war gestern mit F3
Hab jetzt F6 drauf.Soll ich GTL nochmal versuchen?
Hast du die Chipsatztreiber und ME Software bereits installiert? Damit würde ich anfangen.
Erstelle nachdem du mit den Standardtreibern durch bist am Besten auch erst mal manuell einen Wiederherstellungspunkt.
Das blöde ist, ich habe beide ROG, S Brettern hier
Formula VII Sleep Dog Edition und Hero VII
Mit Hero bin eigentlich zufrieden aber mag immer wieder was neues und darum habe ich nun
SOC FORCE gekauft. Zurzeit fehlt mir sehr schwer zu entscheiden welches Board ich los werden muss Hero oder SOC FORCE.
Beides sind gut, komisch ist nur das SOC FORCE für 4.8 GHz nur 1.204 V braucht und Hero 1.217 !!!
Bis jetzt war immer anders, zumindest bei mir....
P.S. habe drei PC ;)
