• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] J&W 790GX Extreme (AMD 790GX)
J&W 790GX Extreme
Spezifikationen
unterstützte Prozessoren
• Sockel AM2+/AM2 for AMD Phenom™FX / AMD Phenom™ / AMD Athlon™ 64 FX / AMD Athlon™ 64 X2 / AMD Athlon™ 64 / AMD Sempron™ Prozessoren (Unterstützung bis 140W TDP Prozessoren.)
Chipsatz
• AMD® 790GX + SB750 (Built in Radeon™ HD 3300 Graphics, DirectX® 10 Ready, with 128MB DDR3 side-port memory onboard)
• Marvell® 10/100/1000 Mbps Ethernet Controller
• Super I/O: Winbond W83627EHG chip
• Realtek ALC 888 HD Audio Codec
• 8M bit flash ROM
HyperTransport™
• HyperTransport™ 3.0/1.0, 5200/2000 MT/s
Memory
• Dual Channel DDR2 1066/800/667/533 support (DDR2 1066 support is dependent on CPU)
• Max Kapazität: 8 GB
• DIMM slots: 4
Interne I/O Anschlüsse
• 1 x 24-pin ATX power connector
• 1 x 8-pin ATX 12V power connector (compatible with 4-pin connector)
• 1 x floppy connector
• 1 x IDE connector (for 2 PATA devices)
• 6 x SATA 3Gb/s connectors (Support RAID 0,1,0+1,5)
• 1 x CPU fan connector
• 2 x system fan connectors
• 1 x front panel connector
• 1 x front audio connector
• 3 x USB 2.0 header for additional 6 USB 2.0 ports (by cables)
• 1 x buzzer connector
• 1 x IR connector
• 1 x COM connector
• 1 x CD-IN connector
• 1 x SPDIF In/Out header
Erweiterungs- Slots
• 3 x PCI-E x16 slots
• 1 x PCI-E x1 slot
• 2 x PCI slots
Anschlüsse hinten I/O
• 1 x PS/2 Keyboard port
• 1 x PS/2 Mouse port
• 1 x HDMI port
• 1 x S/PDIF In port (coaxial)
• 1 x S/PDIF Out port (optical)
• 1 x DVI port
• 1 x VGA port
• 1 x eSATA port
• 4 x USB 2.0 ports
• 1 x RJ45 GigaLAN port
• 6 x Audio ports (Line In / Line Out / MIC In / Rear Speaker Out / Center-Subwoofer Speaker Out / Side Speaker Out)
Form Faktor
• ATX
• 304.8mm x 245mm
H/W Monitoring
• Winbond W83627DHG
• System health status auto-detect and reported by BIOS
BIOS
• 8Mbit flash ROM, Award BIOS
Bundle Software
• Treiber- und Utility CD/DVD
Besonderheiten
• 100% Solid Capacitors, Debug LED onboard.
Links und Downloads
Bios - http://www.jwele.com/motherboard_detail.php?147#_bios
Treiber - http://www.jwele.com/motherboard_detail.php?147#_driver
Manual - http://www.jwele.com/motherboard_detail.php?147#_manual
Utilities - http://www.jwele.com/motherboard_detail.php?147#_util
Hier kann man das Board kaufen - http://www.jwele.de/
Ram Kompatibilität : Läuft
4gb Kit 2x 2gb OCZ Flex EX 9600 ( Mr.Wifi )
2gb Kit Crucial Ballistix Tracer - Sollen laut Aussagen eines Users sehr gut laufen :)
4GBCrucial Ballistix Tracer DIMM PC2-6400U CL4-4-4-12 ( Octa )
4gb TRANSCEND AxeRAM (TX1066QLU-4GK) Laufen sehr gut 600mhz @ 2,16v. ( Chubaka )
4gb Kit A-DATA XPG G Series DIMM PC2-6400U CL5-5-5-15 Laufen sehr gut ( Daniel N )
Man kann sagen dass das Board sehr gut für Ram OC geeignet ist, meldungen über nichtlaufenden Speicher gab es bis jetzt keine ;)
Kühler Kompatibilität :
Passt nicht
Scythe Kama Kama Cross ( Kollidiert mit Northbridge Kühler durch ausladenen Halteklammern, evtl. muss man mit Gewalt oder anders improvisieren )
Passt
IFX 14 ( niedrige Ram HS sind Pflicht wenn man Dualchannel benutzen möchte, weiterhin wird der erste Ram Slot von einem Lüfter blockiert oder man platziert ihn zwischen den Kühlblöcken des IFX und oder einen hinten ziehend )
Zerotherm FZ 120 ( gleiches Problem wie IFX )
Hexa Tabelle um die Multiplikatoren bzw. Vcore unter Pstates im Bios einzustellen ( Thx an Chubaka )
Interessantes über das Board :
http://www.xtremesystems.org/forums/showthread.php?t=191428
Die folgenden Screens zeigen was Monteboy ( AF ) an OC mit diesem Board erreicht hat ;)
http://www.hwbot.org/result.do?resultId=808042
Die 4GHz SM Tool stable von Chubaka ( 0849DPAW !!! )
4.1Ghz Primestable von Chubaka ( 0850 DPMW )
Bios Pics : Thx an Octa und CBOT
Hallo Leute, wenn jemand dieses Board nicht mehr behalten will, kann sich an mich wenden, ich werde den dann sehr gerne käuflich erwerben...
Mal sehen, ob der wirklich besser als DFI DK 790FXB ist..
Ich glaube niemand wird dieses (HAMMER-)Board freiwillig wieder hergeben!
Hab heute bei dem JWele angerufen. Er zweifelt es stark an, dass die diese Woche noch neue Boards bekommen.
im forum hab ich gelesen das einige vorsichtshalber die cpu-nb spannung leicht erhöhen da sie ihren ram mit ner spannung von 2,1 - 2,2 volt betreiben
frage im bios gibt es ja nur ne nb spannung und ne nb2 spannung ist die nb2 spannung die so genannte cpu-nb spannung?
und auf was sollte man dann die spannung erhöhen
@Proteus, im Bios ist es die K10NB Spannung und ich hab die auf 1,375v@3000MHz. Kannst aber bis 1,450v. gehen ist kein Problem.
@Proteus, die ist für die North Bridge :d
Die CPU NB ist für den L3 Cache zuständig, wenn du den um einen Schritt erhöhst entspricht das in etwa 100MHz mehr CPU Takt.
lol :d es gibt ja einmal im die NB Voltage Control und dann die NB2 Voltage Control hab mir schon fast gedacht dass das schon mit der northbridge zu tun hat^^ nur die 2 hat mich irritiert also die tatsache das es ne 2. nb voltage control gibt verwirrt mich
Ihr habt da echt nen schönes Board, falls jemand seins loswerden will, sagt bescheid :)
Zwei Sachen würden mich noch interessieren:
-Kann man die CPU-NB Spannung unabhängig von der CPU-NB VID erhöhen?
-Gibt's nen Bild wo man das Board ohne Mosfetkühler sieht, oder weiß zufällig jemand wieviele Fets das Teil pro Phase hat?
Danke für die Hilfe ;)
hab mal bios shots gemacht...
Ich ändere nur die FID...
Übersicht und Voltages
Voltages
CPUZ
Muss dazu sagen das ich immer noch die Beta verwende, bei der Offiziellen Version fehlt zb. ECC Mode, Dual Bios und die Sideport Memory Einstellung...
Zu den Mosfetkühlern kann ich dir leider nichts sagen.
Wenn du im Bios die K10 CPUNB Voltage veränderst und in K10stat nachguckst, steht die dann auf dem Standard Wert oder auf dem, den du eingestellt hast?
Ja, wie auf dem Bild im K10P-States zu sehen, ist auf Standard...
wenn du allerdings die CPU VID im K10P-States auf Auto lässt und die Prozessor Voltage auch dann fährt er glatt mit 1,544v. hoch :shot:
Also wenn jemand gar nichts einstellt, fährt er mit 1,54V? xD
Aber coole Sache das mit der CPU-NB, dann kann man auch bei non BEs die Spannung erhöhen. Das geht bei den wenigsten Boards.
Hallo zusammen,
ich bin auf der Suche nach einem sehr guten 790GX Board. Habe hier schon ein wenig mitgelesen und habe einen guten ersten Eindruck gegenüber diesem Brett. Einige Fragen sind allerdings noch offen:
  • Wie ist der Support (BIOS etc.)
  • Wo liegen die Schwächen?
  • Wo liegen die besonderen Stärken
  • Wo ist der Stromverbrauch einzuordnen (mit IGP)
  • Ist der Soundchip "akzeptabel" (ja ich weiß, schwer zu bewerten)?
  • Werden die beiden Sys-Fans PWM geregelt durchs Board?
  • Was kann über den IR-Connector gesteuert werden?
  • Was ist ein Buzzer-Connector?:confused:
  • Benutzt zufällig wer einen Scythe Shuriken? Passt der optimal?
  • Würdet ihr das Brett nochmal kaufen :d?
Ich weiß es sind viele Fragen, aber ich würde mich freuen wenn ihr mir sie beantwortet :hail: Ist eben nicht einfach mit der Brettauswahl wenn man zimperlich ist :fresse:
Bedankt :d!
Ich beantworte mal das, was mir spontan einfällt bzw. was ich weiss :d.
Nja...ich muss jetzt hier die Zeile vollbekommen! :shot::shot:
    -Gut! Gut, beim Bios hats ein wenig gedauert. Aber durch Connections erhielt man ja die Beta!
    -Fehlertechnisch 1A, wird sofort von DE nach China geschickt. Die checken dann den Fehler ab und geben Hilfestellung!
    -Keine Lüftersteuerung! Kein richtiges Multizeugs und so im Bios.
    -(sehr einfallsreich!) hat nicht jeder :d
    -Gutes OC.
    -Gutes Layout.
    -Sieht fein aus!
    -Ist sehr stabil (technisch gesehen!)
    -kA
    -Ja, habe zum Beweis noch eine SB-Xtreme Gamer
    -Nein
    -kA
    -kA
    -Gib die Größe, dann mess ich.
    -Jop
Bedankt :d!
Hi octa!
Danke für deine Hilfe :wink:.
Hat das Brett keine CPU-Lüftersteuerung :confused:
Was bedeutet: Kein richtiges Multizeugs und so im Bios
Kann ich etwa den Multi nicht frei wählen???
Maße vom Shuriken gebe ich morgen durch, muß jetzt dringend ins Bett :-[
Chubaka octa könnt ihr das Board mit den DFI vergleichen? Welche ist wohl stärker? Ich schreibe jetzt ein FAQ mit Phenom II MB Rating, also wiß ich nicht welche dann an Ersten stelle liegen wurde.
DFI 790FXB habe ich jetzt, aber möchte auch J&W dazu holen.
Außer dem, was ist über J&W P45 Ultra und X48 Extreme bekannt? Ich möchte die gans gerne in Sortiment nehmen, aber finde gar keine richtige iNFO...
hol dir auf jeden noch ein DFI UT, ein Jetway HA07 ultra und ein Gigabyte DQ6 dazu! die dürfen da nicht fehlen!
so Geld wurde überwiesen, mal schauen wann das Board kommt. :bigok:
http://81.169.162.205/Lifestylebase-p540h4s6-LSB-TEST-JW-X48D2-E.html
das!
Wiedermal ein gutes Board das gut aussieht!
Ist eine Lüftersteuerung denn vorgesehen bzw. geplant?
Nja...ich habe sie gefragt! Im Bios gibt es eine LW, die funktioniert bei mir aber nicht!
Hi octa!
Also...wie genannt, die LW geht bei mir nicht.
Mit Multizeugs, das geht nur über Hexa, ->Bilder von Chubaka weiter oben!
Also nicht,
"Hey mal kurz Multi 17 einstellen und die Spannung anheben"
Man muss da vorher erst die Hexa wissen!
Das meine ich.
Also nicht so 0815 im Bios :P
MfG
octa Danke, bin gar kein Fan von gutem Aussehen, viel mehr aber von 600+ FSB-Takt - davon ist nichts zu sehen, bleibt wohl nur das eine - kaufen und selber testen.
Ich gehe über den Toslink Ausgang in den AVR, analog über Kopfhörer ( Sennheiser ) ist der Sound OK, aber nicht vergleichbar mit ner Soundkarte. Digital hingegen kein Unterschied zur XFI Xtreme Music die ich vorher drinn hatte. Mit dem neuen Bios ist im Realtek nun auch ein digitaler Audio in verfügbar ( Coax Eingang ).
2 fragen:
1. Passt der Alpenföhn Brocken oder Groß Clockner drauf?
2. MSi DKA790GX Platinum oder das hier? :>
Grüße!
2 fragen:
Grüße!
1. Gib die Größen und es wird gemessen!
2.Tja...das MSI ist eigtl. nur eine "teure Version" des DKA790GX!
Heißt 100 Euro. Jetzt entscheidest du, welches Board besser ist!
(JW 124 Euro).
MfG
Abmessungen (BxHxT):
Brocken: 126 mm x 157 mm x 104 mm
Groß Clockner: 125 mm x 157 mm x 110 mm
(laut alternate)
da ich ne vdimm von 2,1 volt habe wollte ich die K10NB spannung auf 1,4 volt anheben damit der imc nicht abkratzt
nun frage ich mich ob bei aktivierten c&q die K10NB spannung auch herabgesetzt wird oder ist diese unberührt vom c&q
wieweit kann man die nb spannung ohne größere gefahr anheben
