21:23:49 T:2228 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:23:49 T:2228 NOTICE: -----------------------------------------------------------------------
21:23:49 T:2228 NOTICE: Starting Kodi (14.2 Git:20150326-7cc53a9). Platform: Windows NT x86 32-bit
21:23:49 T:2228 NOTICE: Using Release Kodi x32 build
21:23:49 T:2228 NOTICE: Kodi compiled Mar 26 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
21:23:49 T:2228 NOTICE: Running on ASUS All Series with Windows 8.1, kernel: Windows NT x86 64-bit version 6.3
21:23:49 T:2228 NOTICE: Host CPU: Intel(R) Core(TM) i3-4330 CPU @ 3.50GHz, 4 cores available
21:23:49 T:2228 NOTICE: Desktop Resolution: 1920x1080 32Bit at 59Hz
21:23:49 T:2228 NOTICE: Running with restricted rights
21:23:49 T:2228 NOTICE: Aero is enabled
21:23:49 T:2228 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
21:23:49 T:2228 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
21:23:49 T:2228 NOTICE: special://masterprofile/ is mapped to: C:\Users\Dennis\AppData\Roaming\Kodi\userdata
21:23:49 T:2228 NOTICE: special://home/ is mapped to: C:\Users\Dennis\AppData\Roaming\Kodi\
21:23:49 T:2228 NOTICE: special://temp/ is mapped to: C:\Users\Dennis\AppData\Roaming\Kodi\cache
21:23:49 T:2228 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
21:23:49 T:2228 NOTICE: Local hostname: HTPC
21:23:49 T:2228 NOTICE: Log File is located: C:\Users\Dennis\AppData\Roaming\Kodi\kodi.log
21:23:49 T:2228 NOTICE: load settings...
21:23:49 T:2228 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
21:23:49 T:2228 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
21:23:49 T:2228 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
21:23:49 T:2228 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:23:49 T:2228 NOTICE: Default DVD Player: dvdplayer
21:23:49 T:2228 NOTICE: Default Video Player: dvdplayer
21:23:49 T:2228 NOTICE: Default Audio Player: paplayer
21:23:49 T:2228 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:23:49 T:2228 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
21:23:49 T:2228 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:23:49 T:2228 NOTICE: Loaded playercorefactory configuration
21:23:49 T:2228 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:23:49 T:2228 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:23:49 T:3848 NOTICE: Thread ActiveAE start, auto delete: false
21:23:49 T:4064 NOTICE: Thread AESink start, auto delete: false
21:23:49 T:3848 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "TX-NR616 (2- High Definition Audio-Gerät)" seems to be not supported.
21:23:49 T:3848 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "TX-NR616 (2- High Definition Audio-Gerät)" seems to be not supported.
21:23:49 T:3848 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "TX-NR616 (2- High Definition Audio-Gerät)" seems to be not supported.
21:23:49 T:3848 NOTICE: Found 2 Lists of Devices
21:23:49 T:3848 NOTICE: Enumerated DIRECTSOUND devices:
21:23:49 T:3848 NOTICE: Device 1
21:23:49 T:3848 NOTICE: m_deviceName : {17DF9084-5E0D-41FE-8B27-E43E74F7DF86}
21:23:49 T:3848 NOTICE: m_displayName : Speakers - Lautsprecher (Realtek High Definition Audio)
21:23:49 T:3848 NOTICE: m_displayNameExtra: DIRECTSOUND: Lautsprecher (Realtek High Definition Audio)
21:23:49 T:3848 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:23:49 T:3848 NOTICE: m_channels : FL,FR
21:23:49 T:3848 NOTICE: m_sampleRates : 48000
21:23:49 T:3848 NOTICE: m_dataFormats : AE_FMT_FLOAT
21:23:49 T:3848 NOTICE: Device 2
21:23:49 T:3848 NOTICE: m_deviceName : {B188DC80-9546-4A5E-B40B-B62186B7090D}
21:23:49 T:3848 NOTICE: m_displayName : HDMI - TX-NR616 (2- High Definition Audio-Gerät)
21:23:49 T:3848 NOTICE: m_displayNameExtra: DIRECTSOUND: TX-NR616 (2- High Definition Audio-Gerät)
21:23:49 T:3848 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
21:23:49 T:3848 NOTICE: m_channels : FL,FR,FC,BL,BR,SL,SR,LFE
21:23:49 T:3848 NOTICE: m_sampleRates : 44100
21:23:49 T:3848 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
21:23:49 T:3848 NOTICE: Device 3
21:23:49 T:3848 NOTICE: m_deviceName : default
21:23:49 T:3848 NOTICE: m_displayName : default
21:23:49 T:3848 NOTICE: Enumerated WASAPI devices:
21:23:49 T:3848 NOTICE: m_displayNameExtra: WASAPI: Lautsprecher (Realtek High Definition Audio)
21:23:49 T:3848 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
21:23:49 T:3848 NOTICE: m_sampleRates : 192000,96000,48000,44100
21:23:49 T:3848 NOTICE: m_dataFormats : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
21:23:49 T:3848 NOTICE: m_displayNameExtra: WASAPI: TX-NR616 (2- High Definition Audio-Gerät)
21:23:49 T:3848 NOTICE: m_sampleRates : 192000,176400,96000,88200,48000,44100,32000
21:23:49 T:3848 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
21:23:49 T:2228 NOTICE: Running database version Addons16
21:23:49 T:2228 NOTICE: ADDONS: Using repository repository.xbmc.org
21:23:49 T:3944 NOTICE: Thread RemoteControl start, auto delete: false
21:23:49 T:1944 NOTICE: Thread PeripBusCEC start, auto delete: false
21:23:49 T:964 NOTICE: Thread PeripBusUSB start, auto delete: false
21:23:49 T:2228 NOTICE: Found screen: Digital Flat Panel (1024x768 60Hz) on Intel(R) HD Graphics 4600, adapter 0.
21:23:49 T:2228 NOTICE: Primary mode: 1920x1080@ 59.94 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 23.98 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 24.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 25.00 - Full Screen
21:23:49 T:2228 NOTICE: Previous line repeats 2 times.
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 29.97 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 30.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 50.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 59.94 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x200@ 60.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 23.98 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 24.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 25.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 29.97 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 30.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 50.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 59.94 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 320x240@ 60.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 23.98 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 24.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 25.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 29.97 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 30.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 50.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 59.94 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 400x300@ 60.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 23.98 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 24.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 25.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 29.97 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 30.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 50.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 59.94 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 512x384@ 60.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 23.98 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 24.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 25.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 29.97 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 30.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 50.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 59.94 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x400@ 60.00 - Full Screen
21:23:49 T:2228 NOTICE: Additional mode: 640x480@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Previous line repeats 2 times.
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 25.00i - Full Screen
21:23:50 T:2228 NOTICE: Previous line repeats 1 times.
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1152x864@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x600@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1400x1050@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 23.98 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 24.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 25.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 29.97 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 30.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 50.00 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
21:23:50 T:2228 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
21:23:51 T:2228 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
21:23:51 T:2228 NOTICE: Checking resolution 16
21:23:51 T:2228 ERROR: Window Translator: Can't find window tv
21:23:51 T:2228 ERROR: Previous line repeats 3 times.
21:23:51 T:2228 NOTICE: Running database version Addons16
21:23:51 T:2228 NOTICE: Running database version ViewModes6
21:23:51 T:2228 NOTICE: Running database version Textures13
21:23:51 T:2228 NOTICE: Running database version MyMusic48
21:23:51 T:2228 NOTICE: Running database version MyVideos90
21:23:51 T:2228 NOTICE: Running database version TV26
21:23:51 T:2228 NOTICE: Running database version Epg8
21:23:51 T:2228 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
21:23:51 T:2228 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
21:23:51 T:2228 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
21:23:51 T:2228 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
21:23:51 T:4964 NOTICE: Thread LanguageInvoker start, auto delete: false
21:23:51 T:2728 NOTICE: Thread JobWorker start, auto delete: true
21:23:51 T:2228 NOTICE: initialize done
21:23:51 T:2728 NOTICE: PVRManager - starting up
21:23:51 T:1728 NOTICE: Thread PVRManager start, auto delete: false
21:23:51 T:4736 NOTICE: Thread PVRClient start, auto delete: false
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::Open - VU+ Addon Configuration options
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::Open - Hostname: '192.168.178.141'
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::Open - WebPort: '80'
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::Open - StreamPort: '8001'
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::Open Use HTTPS: 'false'
21:23:51 T:2228 NOTICE: Running the application...
21:23:51 T:2944 NOTICE: Thread FileCache start, auto delete: false
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::GetDeviceInfo - DeviceInfo
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::GetDeviceInfo - E2EnigmaVersion: 2015-06-17
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::GetDeviceInfo - E2ImageVersion: 5.0.0
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::GetDeviceInfo - E2WebIfVersion: OWIF 0.4.6
21:23:51 T:4736 NOTICE: AddOnLog: VU+ / Enigma2 Client: Vu::GetDeviceInfo - E2DeviceName: Quad Plus
21:23:51 T:1496 NOTICE: Thread FileCache start, auto delete: false
21:23:51 T:2228 NOTICE: ES: Starting event server
21:23:51 T:2804 NOTICE: Thread EventServer start, auto delete: false
21:23:51 T:3556 NOTICE: Thread TCPServer start, auto delete: false
21:23:51 T:2804 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
21:23:51 T:2804 NOTICE: UDP: Listening on port 9777
21:23:51 T:4964 NOTICE: -->Python Interpreter Initialized<--
21:23:51 T:4900 NOTICE: Thread FileCache start, auto delete: false
21:23:52 T:1728 NOTICE: Previous line repeats 17 times.
21:23:52 T:1728 ERROR: AddOnLog: VU+ / Enigma2 Client: Vu::GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
21:23:52 T:1396 NOTICE: Thread PVRGUIInfo start, auto delete: false
21:23:53 T:1728 NOTICE: EPG::CEpgContainer::Start - EPG thread started
21:23:53 T:2740 NOTICE: Thread EPGUpdater start, auto delete: false
21:23:53 T:716 NOTICE: Thread FileCache start, auto delete: false
21:24:06 T:2632 NOTICE: Previous line repeats 55 times.
21:24:06 T:2632 NOTICE: Thread BackgroundLoader start, auto delete: false
21:24:06 T:1664 NOTICE: Thread FileCache start, auto delete: false
21:24:11 T:4352 NOTICE: Previous line repeats 15 times.
21:24:11 T:4352 NOTICE: Thread BackgroundLoader start, auto delete: false
21:24:11 T:1616 NOTICE: Thread FileCache start, auto delete: false
21:24:13 T:2480 NOTICE: Previous line repeats 7 times.
21:24:13 T:2480 NOTICE: Thread BackgroundLoader start, auto delete: false
21:24:13 T:4996 NOTICE: Thread FileCache start, auto delete: false
21:24:19 T:4372 NOTICE: Previous line repeats 45 times.
21:24:19 T:4372 NOTICE: Thread BackgroundLoader start, auto delete: false
21:24:19 T:992 NOTICE: Thread FileCache start, auto delete: false
21:24:20 T:4840 NOTICE: Previous line repeats 8 times.
21:24:20 T:4840 NOTICE: Thread JobWorker start, auto delete: true
21:24:20 T:3472 NOTICE: Thread FileCache start, auto delete: false
21:24:21 T:3420 NOTICE: Previous line repeats 8 times.
21:24:21 T:3420 NOTICE: Thread JobWorker start, auto delete: true
21:24:21 T:2568 NOTICE: Thread FileCache start, auto delete: false
21:24:22 T:4632 NOTICE: Previous line repeats 12 times.
21:24:22 T:4632 NOTICE: Thread JobWorker start, auto delete: true
21:24:30 T:4840 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/script.module.youtube.dl/icon.png
21:24:30 T:2728 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/script.ace.extrapack/icon.png
21:24:32 T:3420 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/service.libraryautoupdate/icon.png
21:24:49 T:4840 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/helix/script.artworkorganizer/fanart.jpg
21:24:51 T:4632 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.advanced.wol/icon.png
21:25:06 T:2228 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:25:06 T:2228 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:25:06 T:2228 ERROR: XFILE::CFileCache::Open - failed to open source <http://mirrors.kodi.tv/addons/helix/script.keymap/script.keymap-1.0.9.zip.md5>
21:25:14 T:4008 NOTICE: Thread FileCache start, auto delete: false
21:25:16 T:2728 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
21:25:26 T:1552 NOTICE: Thread BackgroundLoader start, auto delete: false
21:25:33 T:2504 NOTICE: Thread LanguageInvoker start, auto delete: false
21:25:33 T:2504 NOTICE: -->Python Interpreter Initialized<--
21:25:40 T:4840 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/helix/script.artworkorganizer/icon.png
21:25:51 T:4840 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.audio.profiles/icon.png
21:26:01 T:4840 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/helix/script.xbmcbackup/icon.png
21:26:03 T:1880 NOTICE: Thread BackgroundLoader start, auto delete: false
21:26:12 T:4116 NOTICE: Previous line repeats 2 times.
21:26:12 T:4116 NOTICE: Thread JobWorker start, auto delete: true
21:26:17 T:4840 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:26:17 T:4840 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:26:27 T:4840 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.cinema.experience/icon.png
21:26:29 T:4048 NOTICE: Thread FileCache start, auto delete: false
21:26:29 T:2228 NOTICE: DVDPlayer: Opening: pvr://channels/tv/Alle Kanäle/0.pvr
21:26:29 T:2228 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
21:26:29 T:4568 NOTICE: Thread DVDPlayer start, auto delete: false
21:26:29 T:4568 NOTICE: Creating InputStream
21:26:30 T:4020 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 NOTICE: Previous line repeats 2 times.
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Television' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Television'
21:26:30 T:2032 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VOX' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VOX'
21:26:30 T:5108 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1'
21:26:30 T:5052 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben'
21:26:30 T:2732 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL2' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL2'
21:26:30 T:2764 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'DMAX' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'DMAX'
21:26:30 T:3464 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'kabel eins' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'kabel eins'
21:26:30 T:3504 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben MAXX' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben MAXX'
21:26:30 T:4856 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 Gold' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 Gold'
21:26:30 T:4408 NOTICE: Thread FileCache start, auto delete: false
21:26:30 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ANIXE SD' from client '1': server error
21:26:30 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ANIXE SD'
21:26:30 T:3756 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 NOTICE: Previous line repeats 2 times.
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTLNITRO' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTLNITRO'
21:26:31 T:340 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'n-tv' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'n-tv'
21:26:31 T:1412 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'N24' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'N24'
21:26:31 T:300 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ORF1 HD' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ORF1 HD'
21:26:31 T:708 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ATV HD' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ATV HD'
21:26:31 T:1948 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ATV2' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ATV2'
21:26:31 T:4760 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PULS 4 Austria' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PULS 4 Austria'
21:26:31 T:4636 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Nickelodeon' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Nickelodeon'
21:26:31 T:2752 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Comedy Central Nederland' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Comedy Central Nederland'
21:26:31 T:1648 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SUPER RTL' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SUPER RTL'
21:26:31 T:1808 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Boomerang' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Boomerang'
21:26:31 T:3120 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Animax' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Animax'
21:26:31 T:1548 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Nicktoons (S)' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Nicktoons (S)'
21:26:31 T:4528 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Cartoon Network (S)' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Cartoon Network (S)'
21:26:31 T:4176 NOTICE: Thread FileCache start, auto delete: false
21:26:31 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney XD' from client '1': server error
21:26:31 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney XD'
21:26:32 T:4524 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 NOTICE: Previous line repeats 1 times.
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SPORT1' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SPORT1'
21:26:32 T:804 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Eurosport Deutschland' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Eurosport Deutschland'
21:26:32 T:4568 NOTICE: Creating Demuxer
21:26:32 T:848 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MELODIE TV' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MELODIE TV'
21:26:32 T:3272 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Comedy Central / VIVA AT' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Comedy Central / VIVA AT'
21:26:32 T:2316 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Comedy Central/VIVA' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Comedy Central/VIVA'
21:26:32 T:748 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VIVA Polska.' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VIVA Polska.'
21:26:32 T:3740 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VIVA Polska..' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VIVA Polska..'
21:26:32 T:2992 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:4568 NOTICE: Opening stream: 2 source: 256
21:26:32 T:4568 NOTICE: Creating video codec with codec id: 28
21:26:32 T:4568 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
21:26:32 T:4568 NOTICE: Creating video thread
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VIVA Polska' from client '1': server error
21:26:32 T:4568 NOTICE: Opening stream: 7 source: 256
21:26:32 T:1564 NOTICE: Thread DVDPlayerVideo start, auto delete: false
21:26:32 T:1564 NOTICE: running thread: video_thread
21:26:32 T:4568 NOTICE: Finding audio codec for: 86019
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VIVA Polska'
21:26:32 T:4568 NOTICE: Creating audio thread
21:26:32 T:4568 NOTICE: Opening stream: 6 source: 256
21:26:32 T:4556 NOTICE: Thread DVDPlayerAudio start, auto delete: false
21:26:32 T:4568 NOTICE: Opening stream: 5 source: 256
21:26:32 T:4556 NOTICE: running thread: CDVDPlayerAudio::Process()
21:26:32 T:4568 NOTICE: CDVDMessageQueue(teletext)::WaitUntilEmpty
21:26:32 T:4568 WARNING: CDVDMessageQueue(teletext)::Put MSGQ_NOT_INITIALIZED
21:26:32 T:4568 NOTICE: waiting for teletext data thread to exit
21:26:32 T:4568 NOTICE: Creating teletext data thread
21:26:32 T:3720 NOTICE: Thread DVDTeletextData start, auto delete: false
21:26:32 T:3720 NOTICE: running thread: CDVDTeletextData
21:26:32 T:1564 NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
21:26:32 T:4556 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
21:26:32 T:1564 NOTICE: DXVA::CDecoder::Close - closing decoder
21:26:32 T:1564 NOTICE: fps: 0.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
21:26:32 T:1564 NOTICE: D3D: rendering method forced to DXVA processor
21:26:32 T:2228 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
21:26:32 T:2708 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VOX Music TV' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VOX Music TV'
21:26:32 T:1408 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'gotv' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'gotv'
21:26:32 T:3248 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Music Box Russia' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Music Box Russia'
21:26:32 T:4952 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PMC' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PMC'
21:26:32 T:1332 NOTICE: Thread FileCache start, auto delete: false
21:26:32 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nex1' from client '1': server error
21:26:32 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nex1'
21:26:33 T:3148 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Shanson TV' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Shanson TV'
21:26:33 T:2424 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'iMovie' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'iMovie'
21:26:33 T:104 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Mjuzik TV' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Mjuzik TV'
21:26:33 T:612 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TV Disco' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TV Disco'
21:26:33 T:3864 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:1172 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:4444 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 NOTICE: Previous line repeats 1 times.
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Music 24' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Music 24'
21:26:33 T:716 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV ROCKS' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV ROCKS'
21:26:33 T:1888 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Hits' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Hits'
21:26:33 T:3624 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Dance' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Dance'
21:26:33 T:1404 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1'
21:26:33 T:4468 NOTICE: Thread FileCache start, auto delete: false
21:26:33 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1 Classic' from client '1': server error
21:26:33 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1 Classic'
21:26:34 T:3920 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD'
21:26:34 T:564 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Deluxe Music HD' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Deluxe Music HD'
21:26:34 T:1456 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1 Classic.' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1 Classic.'
21:26:34 T:3136 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1.' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1.'
21:26:34 T:4028 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1'
21:26:34 T:3516 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:4832 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Hits.' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Hits.'
21:26:34 T:4160 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Hits' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Hits'
21:26:34 T:2336 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV'
21:26:34 T:1720 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:3288 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Classic' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Classic'
21:26:34 T:4704 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Dance' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Dance'
21:26:34 T:2296 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Music' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Music'
21:26:34 T:3844 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV ROCKS.' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV ROCKS.'
21:26:34 T:4104 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Rocks' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Rocks'
21:26:34 T:4964 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:5104 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Polska.' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Polska.'
21:26:34 T:4340 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Polska' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Polska'
21:26:34 T:5016 NOTICE: Thread FileCache start, auto delete: false
21:26:34 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD Austria' from client '1': server error
21:26:34 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD Austria'
21:26:35 T:1380 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV BASE HD' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV BASE HD'
21:26:35 T:4560 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV PULSE HD' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV PULSE HD'
21:26:35 T:1992 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV IDOL HD' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV IDOL HD'
21:26:35 T:2396 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD'
21:26:35 T:3520 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2080 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Live HD' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Live HD'
21:26:35 T:2380 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:3108 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MCM' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MCM'
21:26:35 T:3796 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RFM TV' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RFM TV'
21:26:35 T:292 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:336 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MCM TOP' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MCM TOP'
21:26:35 T:1892 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:5040 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel '40 TV' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table '40 TV'
21:26:35 T:4992 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MEGA' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MEGA'
21:26:35 T:2832 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MAD T.V' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MAD T.V'
21:26:35 T:3152 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova MAD MUSIC My Rock' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova MAD MUSIC My Rock'
21:26:35 T:820 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova MAD MUSIC Greek' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova MAD MUSIC Greek'
21:26:35 T:3324 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova 3D' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova 3D'
21:26:35 T:2780 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova Mad Music My Rock Cy' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova Mad Music My Rock Cy'
21:26:35 T:320 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova 3D Cy' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova 3D Cy'
21:26:35 T:3892 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova Mad Music Seasonal Cy' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova Mad Music Seasonal Cy'
21:26:35 T:4720 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:3368 NOTICE: Thread FileCache start, auto delete: false
21:26:35 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TF1' from client '1': server error
21:26:35 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TF1'
21:26:35 T:652 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NRJ HITS' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NRJ HITS'
21:26:36 T:3264 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC PLAYER' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'M6 MUSIC PLAYER'
21:26:36 T:4252 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'M6 MUSIC'
21:26:36 T:3476 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:1672 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC HD' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'M6 MUSIC HD'
21:26:36 T:5096 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Syfy' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Syfy'
21:26:36 T:2700 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel '13th Street' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table '13th Street'
21:26:36 T:2372 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Discovery Channel' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Discovery Channel'
21:26:36 T:1044 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NatGeo Wild' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NatGeo Wild'
21:26:36 T:4948 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'National Geographic' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'National Geographic'
21:26:36 T:1976 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 NOTICE: Previous line repeats 2 times.
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Fox Serie' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Fox Serie'
21:26:36 T:3524 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TNT Serie' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TNT Serie'
21:26:36 T:2632 NOTICE: Thread FileCache start, auto delete: false
21:26:36 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Motorvision TV' from client '1': server error
21:26:36 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Motorvision TV'
21:26:37 T:1664 NOTICE: Thread FileCache start, auto delete: false
21:26:37 T:2740 NOTICE: Previous line repeats 1 times.
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney XD' from client '1': server error
21:26:37 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney XD'
21:26:37 T:3132 NOTICE: Thread FileCache start, auto delete: false
21:26:37 T:2740 NOTICE: Previous line repeats 3 times.
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Crime' from client '1': server error
21:26:37 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Crime'
21:26:37 T:1028 NOTICE: Thread FileCache start, auto delete: false
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Passion' from client '1': server error
21:26:37 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Passion'
21:26:37 T:3500 NOTICE: Thread FileCache start, auto delete: false
21:26:37 T:2740 NOTICE: Previous line repeats 2 times.
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Animax' from client '1': server error
21:26:37 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Animax'
21:26:37 T:1296 NOTICE: Thread FileCache start, auto delete: false
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Living' from client '1': server error
21:26:37 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Living'
21:26:37 T:1180 NOTICE: Thread FileCache start, auto delete: false
21:26:37 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1 Classic' from client '1': server error
21:26:37 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1 Classic'
21:26:38 T:3900 NOTICE: Thread FileCache start, auto delete: false
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Cartoon Network (S)' from client '1': server error
21:26:38 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Cartoon Network (S)'
21:26:38 T:996 NOTICE: Thread FileCache start, auto delete: false
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Boomerang' from client '1': server error
21:26:38 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Boomerang'
21:26:38 T:1812 NOTICE: Thread FileCache start, auto delete: false
21:26:38 T:2740 NOTICE: Previous line repeats 3 times.
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'A&E' from client '1': server error
21:26:38 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'A&E'
21:26:38 T:4180 NOTICE: Thread FileCache start, auto delete: false
21:26:38 T:2740 NOTICE: Previous line repeats 1 times.
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 emotions' from client '1': server error
21:26:38 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 emotions'
21:26:38 T:4292 NOTICE: Thread FileCache start, auto delete: false
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'kabel eins classics' from client '1': server error
21:26:38 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'kabel eins classics'
21:26:38 T:2800 NOTICE: Thread FileCache start, auto delete: false
21:26:38 T:2740 NOTICE: Previous line repeats 2 times.
21:26:38 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Cinema+1' from client '1': server error
21:26:38 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Cinema+1'
21:26:39 T:1040 NOTICE: Thread FileCache start, auto delete: false
21:26:39 T:2740 NOTICE: Previous line repeats 5 times.
21:26:39 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:39 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Action' from client '1': server error
21:26:39 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Action'
21:26:39 T:2376 NOTICE: Thread FileCache start, auto delete: false
21:26:39 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Atlantic' from client '1': server error
21:26:39 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Atlantic'
21:26:39 T:3352 NOTICE: Thread FileCache start, auto delete: false
21:26:40 T:2740 NOTICE: Previous line repeats 4 times.
21:26:40 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:40 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NatGeo HD' from client '1': server error
21:26:40 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NatGeo HD'
21:26:40 T:4112 NOTICE: Thread FileCache start, auto delete: false
21:26:40 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Atlantic HD' from client '1': server error
21:26:40 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Atlantic HD'
21:26:40 T:4640 NOTICE: Thread FileCache start, auto delete: false
21:26:40 T:2740 NOTICE: Previous line repeats 1 times.
21:26:40 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Syfy HD' from client '1': server error
21:26:40 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Syfy HD'
21:26:40 T:2808 NOTICE: Thread FileCache start, auto delete: false
21:26:40 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel '13th Street HD' from client '1': server error
21:26:40 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table '13th Street HD'
21:26:40 T:4956 NOTICE: Thread FileCache start, auto delete: false
21:26:40 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Universal HD' from client '1': server error
21:26:40 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Universal HD'
21:26:41 T:2480 NOTICE: Thread FileCache start, auto delete: false
21:26:41 T:2740 NOTICE: Previous line repeats 1 times.
21:26:41 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:41 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TNT Glitz HD' from client '1': server error
21:26:41 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TNT Glitz HD'
21:26:41 T:1644 NOTICE: Thread FileCache start, auto delete: false
21:26:41 T:2740 NOTICE: Previous line repeats 2 times.
21:26:41 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'E! Entertainm. HD' from client '1': server error
21:26:41 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'E! Entertainm. HD'
21:26:41 T:2724 NOTICE: Thread FileCache start, auto delete: false
21:26:41 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney Channel HD' from client '1': server error
21:26:41 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney Channel HD'
21:26:41 T:2976 NOTICE: Thread FileCache start, auto delete: false
21:26:41 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Fox HD' from client '1': server error
21:26:41 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Fox HD'
21:26:42 T:5004 NOTICE: Thread FileCache start, auto delete: false
21:26:42 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:42 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Cinema+1 HD' from client '1': server error
21:26:42 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Cinema+1 HD'
21:26:42 T:1160 NOTICE: Thread FileCache start, auto delete: false
21:26:42 T:2740 NOTICE: Previous line repeats 1 times.
21:26:42 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Deluxe Music HD' from client '1': server error
21:26:42 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Deluxe Music HD'
21:26:42 T:660 NOTICE: Thread FileCache start, auto delete: false
21:26:42 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sportdigital' from client '1': server error
21:26:42 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sportdigital'
21:26:42 T:1776 NOTICE: Thread FileCache start, auto delete: false
21:26:42 T:2740 NOTICE: Previous line repeats 2 times.
21:26:42 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Sport 1' from client '1': server error
21:26:42 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Sport 1'
21:26:42 T:3004 NOTICE: Thread FileCache start, auto delete: false
21:26:43 T:2228 NOTICE: Previous line repeats 8 times.
21:26:43 T:2228 NOTICE: CDVDPlayer::CloseFile()
21:26:43 T:2228 NOTICE: DVDPlayer: waiting for threads to exit
21:26:43 T:3636 NOTICE: Thread FileCache start, auto delete: false
21:26:43 T:4568 NOTICE: CDVDPlayer::OnExit()
21:26:43 T:4568 NOTICE: Closing stream player 1
21:26:43 T:4568 NOTICE: Waiting for audio thread to exit
21:26:43 T:4556 NOTICE: thread end: CDVDPlayerAudio::OnExit()
21:26:43 T:4568 NOTICE: Closing audio device
21:26:43 T:4568 NOTICE: Deleting audio codec
21:26:43 T:4568 NOTICE: Closing stream player 2
21:26:43 T:4568 NOTICE: waiting for video thread to exit
21:26:43 T:3208 NOTICE: Thread FileCache start, auto delete: false
21:26:43 T:1564 NOTICE: Previous line repeats 1 times.
21:26:43 T:1564 NOTICE: thread end: video_thread
21:26:43 T:4568 NOTICE: deleting video codec
21:26:43 T:4568 NOTICE: DXVA::CDecoder::Close - closing decoder
21:26:43 T:4568 NOTICE: DXVA::Close - closing decoder context
21:26:43 T:4568 NOTICE: Closing stream player 3
21:26:43 T:4568 NOTICE: Closing stream player 4
21:26:43 T:4568 NOTICE: waiting for teletext data thread to exit
21:26:43 T:3720 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
21:26:43 T:3720 NOTICE: thread end: data_thread
21:26:43 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:43 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SPORT1 HD' from client '1': server error
21:26:43 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SPORT1 HD'
21:26:43 T:2228 NOTICE: DVDPlayer: finished waiting
21:26:43 T:4100 NOTICE: Thread FileCache start, auto delete: false
21:26:43 T:2056 NOTICE: Thread FileCache start, auto delete: false
21:26:44 T:2740 NOTICE: Previous line repeats 12 times.
21:26:44 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:44 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Bundesliga 1' from client '1': server error
21:26:44 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Bundesliga 1'
21:26:44 T:3176 NOTICE: Thread FileCache start, auto delete: false
21:26:45 T:2740 NOTICE: Previous line repeats 10 times.
21:26:45 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:45 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Bundesliga HD 1' from client '1': server error
21:26:45 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Bundesliga HD 1'
21:26:45 T:4428 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 NOTICE: Previous line repeats 9 times.
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 HD'
21:26:46 T:5080 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 Gold HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 Gold HD'
21:26:46 T:5064 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben HD'
21:26:46 T:3192 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben MAXX HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben MAXX HD'
21:26:46 T:3472 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL HD'
21:26:46 T:3972 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTLII HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTLII HD'
21:26:46 T:3304 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SUPER RTL HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SUPER RTL HD'
21:26:46 T:2356 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTLNITRO HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTLNITRO HD'
21:26:46 T:4344 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VOX HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VOX HD'
21:26:46 T:4412 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'kabel eins HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'kabel eins HD'
21:26:46 T:4236 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SIXX HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SIXX HD'
21:26:46 T:3652 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TLC HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TLC HD'
21:26:46 T:4392 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NICKELODEON HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NICKELODEON HD'
21:26:46 T:596 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney Channel HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney Channel HD'
21:26:46 T:5116 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'n-tv HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'n-tv HD'
21:26:46 T:2568 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SPORT1 HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SPORT1 HD'
21:26:46 T:2536 NOTICE: Thread FileCache start, auto delete: false
21:26:46 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'N24 HD' from client '1': server error
21:26:46 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'N24 HD'
21:26:47 T:4884 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TELE 5 HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TELE 5 HD'
21:26:47 T:4656 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'DMAX HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'DMAX HD'
21:26:47 T:4764 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'sonnenklar.TV HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'sonnenklar.TV HD'
21:26:47 T:1908 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Deluxe Music HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Deluxe Music HD'
21:26:47 T:5036 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD'
21:26:47 T:2420 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 NOTICE: Previous line repeats 1 times.
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Redlight' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Redlight'
21:26:47 T:460 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'EXOTICA TV' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'EXOTICA TV'
21:26:47 T:2280 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT 5' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT 5'
21:26:47 T:3936 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT 6' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT 6'
21:26:47 T:4572 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT 7' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT 7'
21:26:47 T:5092 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT HQ' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT HQ'
21:26:47 T:5000 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT HD'
21:26:47 T:4668 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PINK O TV' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PINK O TV'
21:26:47 T:3552 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Dorcel TV' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Dorcel TV'
21:26:47 T:3676 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Brazzers TV' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Brazzers TV'
21:26:47 T:3964 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Hustler TV' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Hustler TV'
21:26:47 T:4684 NOTICE: Thread FileCache start, auto delete: false
21:26:47 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Hustler HD' from client '1': server error
21:26:47 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Hustler HD'
21:26:47 T:3924 NOTICE: Thread FileCache start, auto delete: false
21:26:48 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:26:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PRIVATE TV' from client '1': server error
21:26:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PRIVATE TV'
21:26:48 T:1508 NOTICE: Thread FileCache start, auto delete: false
21:26:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Daring tv! 133' from client '1': server error
21:26:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Daring tv! 133'
21:26:48 T:2920 NOTICE: Thread FileCache start, auto delete: false
21:26:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Redlight HD' from client '1': server error
21:26:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Redlight HD'
21:27:13 T:4632 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.facebook.media/icon.png
21:27:36 T:4632 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/helix/script.globalsearch/icon.png
21:27:46 T:4632 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/plugin.program.HyperSpin/icon.png
21:27:56 T:4632 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/script.ircchat/icon.png
21:28:10 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/helix/script.filecleaner/icon.png
21:28:20 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/helix/script.xbmc.debug.log/icon.png
21:28:32 T:2312 NOTICE: Thread FileCache start, auto delete: false
21:28:32 T:1728 NOTICE: Previous line repeats 1 times.
21:28:32 T:1728 ERROR: AddOnLog: VU+ / Enigma2 Client: Vu::GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
21:29:10 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:29:10 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:29:20 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/plugin.program.mceremote/icon.png
21:29:30 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:29:30 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:29:51 T:4116 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/script.moviequiz/icon.png
21:30:24 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/screensaver.randomtrailers/icon.png
21:30:35 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.games.rom.collection.browser/icon.png
21:30:37 T:4796 NOTICE: Thread FileCache start, auto delete: false
21:30:37 T:1728 NOTICE: Previous line repeats 1 times.
21:30:37 T:1728 ERROR: AddOnLog: VU+ / Enigma2 Client: Vu::GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
21:31:14 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:31:14 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:31:14 T:3756 NOTICE: Thread JobWorker start, auto delete: true
21:31:34 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.rss.editor/icon.png
21:31:48 T:3272 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Television' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Television'
21:31:48 T:2316 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VOX' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VOX'
21:31:48 T:748 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1'
21:31:48 T:3740 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben'
21:31:48 T:2992 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL2' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL2'
21:31:48 T:4128 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'DMAX' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'DMAX'
21:31:48 T:4192 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'kabel eins' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'kabel eins'
21:31:48 T:4464 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben MAXX' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben MAXX'
21:31:48 T:808 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 Gold' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 Gold'
21:31:48 T:2428 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ANIXE SD' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ANIXE SD'
21:31:48 T:5076 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTLNITRO' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTLNITRO'
21:31:48 T:1076 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'n-tv' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'n-tv'
21:31:48 T:4804 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'N24' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'N24'
21:31:48 T:4988 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ORF1 HD' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ORF1 HD'
21:31:48 T:3752 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ATV HD' from client '1': server error
21:31:48 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ATV HD'
21:31:48 T:2940 NOTICE: Thread FileCache start, auto delete: false
21:31:48 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ATV2' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ATV2'
21:31:49 T:2708 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PULS 4 Austria' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PULS 4 Austria'
21:31:49 T:2208 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Nickelodeon' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Nickelodeon'
21:31:49 T:1408 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Comedy Central Nederland' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Comedy Central Nederland'
21:31:49 T:3248 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SUPER RTL' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SUPER RTL'
21:31:49 T:4952 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Boomerang' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Boomerang'
21:31:49 T:1332 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Animax' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Animax'
21:31:49 T:3148 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Nicktoons (S)' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Nicktoons (S)'
21:31:49 T:2424 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Cartoon Network (S)' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Cartoon Network (S)'
21:31:49 T:104 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney XD' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney XD'
21:31:49 T:612 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SPORT1' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SPORT1'
21:31:49 T:3864 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Eurosport Deutschland' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Eurosport Deutschland'
21:31:49 T:1172 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MELODIE TV' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MELODIE TV'
21:31:49 T:3064 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Comedy Central / VIVA AT' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Comedy Central / VIVA AT'
21:31:49 T:4444 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Comedy Central/VIVA' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Comedy Central/VIVA'
21:31:49 T:1108 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VIVA Polska.' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VIVA Polska.'
21:31:49 T:716 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VIVA Polska..' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VIVA Polska..'
21:31:49 T:1888 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VIVA Polska' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VIVA Polska'
21:31:49 T:3624 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VOX Music TV' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VOX Music TV'
21:31:49 T:1404 NOTICE: Thread FileCache start, auto delete: false
21:31:49 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'gotv' from client '1': server error
21:31:49 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'gotv'
21:31:49 T:4468 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Music Box Russia' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Music Box Russia'
21:31:50 T:3920 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PMC' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PMC'
21:31:50 T:1960 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nex1' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nex1'
21:31:50 T:564 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Shanson TV' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Shanson TV'
21:31:50 T:1456 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'iMovie' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'iMovie'
21:31:50 T:3136 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Mjuzik TV' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Mjuzik TV'
21:31:50 T:4028 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TV Disco' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TV Disco'
21:31:50 T:3516 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:4832 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:1528 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Music 24' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Music 24'
21:31:50 T:4160 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV ROCKS' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV ROCKS'
21:31:50 T:2336 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Hits' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Hits'
21:31:50 T:1720 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Dance' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Dance'
21:31:50 T:3288 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1'
21:31:50 T:4704 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1 Classic' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1 Classic'
21:31:50 T:2296 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD'
21:31:50 T:3844 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Deluxe Music HD' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Deluxe Music HD'
21:31:50 T:4104 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1 Classic.' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1 Classic.'
21:31:50 T:4964 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1.' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1.'
21:31:50 T:5104 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:4340 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:5016 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Hits.' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Hits.'
21:31:50 T:1380 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:4560 NOTICE: Thread FileCache start, auto delete: false
21:31:50 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV' from client '1': server error
21:31:50 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV'
21:31:51 T:1992 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV'
21:31:51 T:2396 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Classic' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Classic'
21:31:51 T:2080 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Dance' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Dance'
21:31:51 T:2380 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Music' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Music'
21:31:51 T:3108 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV ROCKS.' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV ROCKS.'
21:31:51 T:3796 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Rocks' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Rocks'
21:31:51 T:292 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:336 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Polska.' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Polska.'
21:31:51 T:1892 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Polska' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Polska'
21:31:51 T:5040 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD Austria' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD Austria'
21:31:51 T:4992 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV BASE HD' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV BASE HD'
21:31:51 T:2832 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV PULSE HD' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV PULSE HD'
21:31:51 T:3152 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV IDOL HD' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV IDOL HD'
21:31:51 T:820 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD'
21:31:51 T:3324 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2780 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV Live HD' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV Live HD'
21:31:51 T:320 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:3892 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MCM' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MCM'
21:31:51 T:4720 NOTICE: Thread FileCache start, auto delete: false
21:31:51 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RFM TV' from client '1': server error
21:31:51 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RFM TV'
21:31:51 T:3368 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:652 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MCM TOP' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MCM TOP'
21:31:52 T:3264 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:4252 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel '40 TV' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table '40 TV'
21:31:52 T:3476 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MEGA' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MEGA'
21:31:52 T:1672 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MAD T.V' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MAD T.V'
21:31:52 T:5096 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova MAD MUSIC My Rock' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova MAD MUSIC My Rock'
21:31:52 T:2700 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova MAD MUSIC Greek' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova MAD MUSIC Greek'
21:31:52 T:2372 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova 3D' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova 3D'
21:31:52 T:1044 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova Mad Music My Rock Cy' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova Mad Music My Rock Cy'
21:31:52 T:4948 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova 3D Cy' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova 3D Cy'
21:31:52 T:1976 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'nova Mad Music Seasonal Cy' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'nova Mad Music Seasonal Cy'
21:31:52 T:3688 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:4420 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TF1' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TF1'
21:31:52 T:3524 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NRJ HITS' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NRJ HITS'
21:31:52 T:2632 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC PLAYER' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'M6 MUSIC PLAYER'
21:31:52 T:1664 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'M6 MUSIC'
21:31:52 T:4424 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:3132 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'M6 MUSIC HD' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'M6 MUSIC HD'
21:31:52 T:856 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Syfy' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Syfy'
21:31:52 T:4376 NOTICE: Thread FileCache start, auto delete: false
21:31:52 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel '13th Street' from client '1': server error
21:31:52 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table '13th Street'
21:31:53 T:392 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Discovery Channel' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Discovery Channel'
21:31:53 T:1028 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NatGeo Wild' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NatGeo Wild'
21:31:53 T:3500 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'National Geographic' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'National Geographic'
21:31:53 T:4852 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Fox Serie' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Fox Serie'
21:31:53 T:3228 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TNT Serie' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TNT Serie'
21:31:53 T:1296 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Motorvision TV' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Motorvision TV'
21:31:53 T:1180 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney XD' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney XD'
21:31:53 T:3900 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Crime' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Crime'
21:31:53 T:996 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Passion' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Passion'
21:31:53 T:1812 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Animax' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Animax'
21:31:53 T:1560 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL Living' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL Living'
21:31:53 T:3220 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VH1 Classic' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VH1 Classic'
21:31:53 T:4920 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Cartoon Network (S)' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Cartoon Network (S)'
21:31:53 T:4180 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Boomerang' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Boomerang'
21:31:53 T:76 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'A&E' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'A&E'
21:31:53 T:4292 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 emotions' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 emotions'
21:31:53 T:2800 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'kabel eins classics' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'kabel eins classics'
21:31:53 T:3172 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Cinema+1' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Cinema+1'
21:31:53 T:4212 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Action' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Action'
21:31:53 T:1040 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Atlantic' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Atlantic'
21:31:53 T:3672 NOTICE: Thread FileCache start, auto delete: false
21:31:53 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NatGeo HD' from client '1': server error
21:31:53 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NatGeo HD'
21:31:54 T:3692 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Atlantic HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Atlantic HD'
21:31:54 T:4268 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Syfy HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Syfy HD'
21:31:54 T:4228 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel '13th Street HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table '13th Street HD'
21:31:54 T:1004 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Universal HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Universal HD'
21:31:54 T:2376 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TNT Glitz HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TNT Glitz HD'
21:31:54 T:3352 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'E! Entertainm. HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'E! Entertainm. HD'
21:31:54 T:4452 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney Channel HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney Channel HD'
21:31:54 T:5048 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Fox HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Fox HD'
21:31:54 T:1516 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Cinema+1 HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Cinema+1 HD'
21:31:54 T:4152 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Deluxe Music HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Deluxe Music HD'
21:31:54 T:4112 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sportdigital' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sportdigital'
21:31:54 T:4352 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Sport 1' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Sport 1'
21:31:54 T:1616 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SPORT1 HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SPORT1 HD'
21:31:54 T:3976 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Bundesliga 1' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Bundesliga 1'
21:31:54 T:3184 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Sky Bundesliga HD 1' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Sky Bundesliga HD 1'
21:31:54 T:4640 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 HD'
21:31:54 T:4108 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SAT.1 Gold HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SAT.1 Gold HD'
21:31:54 T:2368 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben HD'
21:31:54 T:4932 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'ProSieben MAXX HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'ProSieben MAXX HD'
21:31:54 T:2808 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTL HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTL HD'
21:31:54 T:4956 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTLII HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTLII HD'
21:31:54 T:1800 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SUPER RTL HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SUPER RTL HD'
21:31:54 T:2480 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'RTLNITRO HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'RTLNITRO HD'
21:31:54 T:4996 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'VOX HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'VOX HD'
21:31:54 T:1644 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'kabel eins HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'kabel eins HD'
21:31:54 T:3764 NOTICE: Thread FileCache start, auto delete: false
21:31:54 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SIXX HD' from client '1': server error
21:31:54 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SIXX HD'
21:31:55 T:1512 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TLC HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TLC HD'
21:31:55 T:2724 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'NICKELODEON HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'NICKELODEON HD'
21:31:55 T:1268 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Disney Channel HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Disney Channel HD'
21:31:55 T:4200 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'n-tv HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'n-tv HD'
21:31:55 T:2976 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SPORT1 HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SPORT1 HD'
21:31:55 T:2416 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'N24 HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'N24 HD'
21:31:55 T:5004 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'TELE 5 HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'TELE 5 HD'
21:31:55 T:1160 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'DMAX HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'DMAX HD'
21:31:55 T:3276 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'sonnenklar.TV HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'sonnenklar.TV HD'
21:31:55 T:660 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Deluxe Music HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Deluxe Music HD'
21:31:55 T:3888 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'MTV HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'MTV HD'
21:31:55 T:1776 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Redlight' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Redlight'
21:31:55 T:2196 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'EXOTICA TV' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'EXOTICA TV'
21:31:55 T:3204 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT 5' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT 5'
21:31:55 T:3004 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT 6' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT 6'
21:31:55 T:3044 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT 7' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT 7'
21:31:55 T:2736 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT HQ' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT HQ'
21:31:55 T:1936 NOTICE: Thread FileCache start, auto delete: false
21:31:55 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'SCT HD' from client '1': server error
21:31:55 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'SCT HD'
21:31:56 T:4448 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClient::GetEPGForChannel - addon 'Quad Plus:192.168.178.141' returned an error: server error
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PINK O TV' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PINK O TV'
21:31:56 T:4984 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Dorcel TV' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Dorcel TV'
21:31:56 T:5012 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Brazzers TV' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Brazzers TV'
21:31:56 T:1012 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Hustler TV' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Hustler TV'
21:31:56 T:4564 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Hustler HD' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Hustler HD'
21:31:56 T:3636 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'PRIVATE TV' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'PRIVATE TV'
21:31:56 T:4556 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Daring tv! 133' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Daring tv! 133'
21:31:56 T:3332 NOTICE: Thread FileCache start, auto delete: false
21:31:56 T:2740 ERROR: PVR - PVR::CPVRClients::GetEPGForChannel - cannot get EPG for channel 'Redlight HD' from client '1': server error
21:31:56 T:2740 ERROR: EPG - EPG::CEpg::Update - failed to update table 'Redlight HD'
21:32:29 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:32:29 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:32:29 T:1564 NOTICE: Thread JobWorker start, auto delete: true
21:32:39 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/helix/script.speedfaninfo/icon.png
21:32:42 T:2460 NOTICE: Thread FileCache start, auto delete: false
21:32:42 T:1728 NOTICE: Previous line repeats 1 times.
21:32:42 T:1728 ERROR: AddOnLog: VU+ / Enigma2 Client: Vu::GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
21:33:06 T:4116 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/helix/script.toolbox/icon.png
21:33:26 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:33:26 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:33:48 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:33:48 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:33:58 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.transmission/icon.png
21:34:08 T:4116 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/script.tvguide/icon.png
21:34:19 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/script.tvrage.com/icon.png
21:34:30 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/helix/script.tvshowtime/icon.png
21:34:41 T:4116 ERROR: CCurlFile::Stat - Failed: Couldn't connect to server(7) for
http://mirrors.kodi.tv/addons/gotham/plugin.program.utorrent/icon.png
21:34:47 T:888 NOTICE: Thread FileCache start, auto delete: false
21:34:47 T:1728 NOTICE: Previous line repeats 1 times.
21:34:47 T:1728 ERROR: AddOnLog: VU+ / Enigma2 Client: Vu::GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
21:34:51 T:4116 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/plugin.program.video.node.editor/icon.png
21:35:01 T:4116 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
21:35:01 T:4116 ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
21:35:06 T:3848 NOTICE: Found 2 Lists of Devices
21:35:06 T:3848 NOTICE: Enumerated DIRECTSOUND devices:
21:35:06 T:3848 NOTICE: Device 1
21:35:06 T:3848 NOTICE: m_deviceName : {6C26BA7D-F0B2-4225-B422-8168C5261E45}
21:35:06 T:3848 NOTICE: m_displayName : Network Device - Remoteaudio
21:35:06 T:3848 NOTICE: m_displayNameExtra: DIRECTSOUND: Remoteaudio
21:35:06 T:3848 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:35:06 T:3848 NOTICE: m_channels : FL,FR
21:35:06 T:3848 NOTICE: m_sampleRates : 44100
21:35:06 T:3848 NOTICE: m_dataFormats : AE_FMT_FLOAT
21:35:06 T:3848 NOTICE: Device 2
21:35:06 T:3848 NOTICE: m_deviceName : default
21:35:06 T:3848 NOTICE: m_displayName : default
21:35:06 T:3848 NOTICE: Enumerated WASAPI devices:
21:35:06 T:3848 NOTICE: m_displayNameExtra: WASAPI: Remoteaudio
21:35:08 T:3848 NOTICE: Found 2 Lists of Devices
21:35:08 T:3848 NOTICE: Enumerated DIRECTSOUND devices:
21:35:08 T:3848 NOTICE: Device 1
21:35:08 T:3848 NOTICE: m_deviceName : {6C26BA7D-F0B2-4225-B422-8168C5261E45}
21:35:08 T:3848 NOTICE: m_displayName : Network Device - Remoteaudio
21:35:08 T:3848 NOTICE: m_displayNameExtra: DIRECTSOUND: Remoteaudio
21:35:08 T:3848 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:35:08 T:3848 NOTICE: m_channels : FL,FR
21:35:08 T:3848 NOTICE: m_sampleRates : 44100
21:35:08 T:3848 NOTICE: m_dataFormats : AE_FMT_FLOAT
21:35:08 T:3848 NOTICE: Device 2
21:35:08 T:3848 NOTICE: m_deviceName : default
21:35:08 T:3848 NOTICE: m_displayName : default
21:35:08 T:3848 NOTICE: Enumerated WASAPI devices:
21:35:08 T:3848 NOTICE: m_displayNameExtra: WASAPI: Remoteaudio
21:35:11 T:4116 ERROR: CCurlFile::Stat - Failed: Timeout was reached(28) for
http://mirrors.kodi.tv/addons/gotham/script.videoextras/icon.png
21:35:12 T:2228 NOTICE: Storing total System Uptime
21:35:12 T:2228 NOTICE: Saving settings
21:35:12 T:2228 NOTICE: stop all
21:35:12 T:2228 NOTICE: stop player
21:35:12 T:2228 NOTICE: PVRManager - stopping
21:35:17 T:2228 NOTICE: ES: Stopping event server
21:35:18 T:2804 NOTICE: ES: UDP Event server stopped
21:35:18 T:2228 NOTICE: stop sap announcement listener
21:35:18 T:2228 NOTICE: clean cached files!
21:35:18 T:2228 NOTICE: unload skin
21:35:18 T:2228 ERROR: CWinSystemWin32::ChangeResolution : ChangeDisplaySettingsEx failed with -2
21:35:18 T:2228 NOTICE: stopped
21:35:18 T:2228 NOTICE: destroy
21:35:18 T:2228 NOTICE: closing down remote control service
21:35:18 T:2228 NOTICE: unload sections
21:35:18 T:2228 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:35:18 T:2228 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
21:35:18 T:2228 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
21:35:18 T:2228 NOTICE: application stopped...
21:35:18 T:2228 ERROR: dllFreeLibrary - Invalid hModule specified
