also ich habs im terminal eingegeben (/usr/bin/ffmpeg).
das ergebniss ist diese liste, aber kein ffmpeg programm das startet.
neo@neo-desktop:~$ /usr/bin/ffmpeg
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-gpl --enable-pp --enable-pthreads --enable-vorbis --enable-libogg --enable-a52 --enable-dts --enable-libgsm --enable-dc1394 --disable-debug --enable-shared --prefix=/usr
libavutil version: 0d.49.0.0
libavcodec version: 0d.51.11.0
libavformat version: 0d.50.5.0
built on Jan 28 2007 22:48:38, gcc: 4.1.2 20070106 (prerelease) (Ubuntu 4.1.1-21ubuntu7)
usage: ffmpeg [[infile options] -i infile]... {[outfile options] outfile}...
Hyper fast Audio and Video encoder
Main options:
-L show license
-h show help
-version show version
-formats show available formats, codecs, protocols, ...
-f fmt force format
-img img_fmt force image format
-i filename input file name
-y overwrite output files
-t duration set the recording time
-fs limit_size set the limit file size
-ss time_off set the start time offset
-itsoffset time_off set the input ts offset
-title string set the title
-timestamp time set the timestamp
-author string set the author
-copyright string set the copyright
-comment string set the comment
-v verbose control amount of logging
-target type specify target file type ("vcd", "svcd", "dvd", "dv", "dv50", "pal-vcd", "ntsc-svcd", ...)
-dframes number set the number of data frames to record
-scodec codec force subtitle codec ('copy' to copy stream)
-newsubtitle add a new subtitle stream to the current output stream
-slang code set the ISO 639 language code (3 letters) of the current subtitle stream
Video options:
-b bitrate set video bitrate (in kbit/s)
-vframes number set the number of video frames to record
-r rate set frame rate (Hz value, fraction or abbreviation)
-s size set frame size (WxH or abbreviation)
-aspect aspect set aspect ratio (4:3, 16:9 or 1.3333, 1.7777)
-croptop size set top crop band size (in pixels)
-cropbottom size set bottom crop band size (in pixels)
-cropleft size set left crop band size (in pixels)
-cropright size set right crop band size (in pixels)
-padtop size set top pad band size (in pixels)
-padbottom size set bottom pad band size (in pixels)
-padleft size set left pad band size (in pixels)
-padright size set right pad band size (in pixels)
-padcolor color set color of pad bands (Hex 000000 thru FFFFFF)
-vn disable video
-bt tolerance set video bitrate tolerance (in kbit/s)
-maxrate bitrate set max video bitrate tolerance (in kbit/s)
-minrate bitrate set min video bitrate tolerance (in kbit/s)
-bufsize size set ratecontrol buffer size (in kByte)
-vcodec codec force video codec ('copy' to copy stream)
-sameq use same video quality as source (implies VBR)
-pass n select the pass number (1 or 2)
-passlogfile file select two pass log file name
-newvideo add a new video stream to the current output stream
Advanced Video options:
-pix_fmt format set pixel format
-g gop_size set the group of picture size
-intra use only intra frames
-vdt n discard threshold
-qscale q use fixed video quantiser scale (VBR)
-qmin q min video quantiser scale (VBR)
-qmax q max video quantiser scale (VBR)
-lmin lambda min video lagrange factor (VBR)
-lmax lambda max video lagrange factor (VBR)
-mblmin q min macroblock quantiser scale (VBR)
-mblmax q max macroblock quantiser scale (VBR)
-qdiff q max difference between the quantiser scale (VBR)
-qblur blur video quantiser scale blur (VBR)
-qsquish squish how to keep quantiser between qmin and qmax (0 = clip, 1 = use differentiable function)
-qcomp compression video quantiser scale compression (VBR)
-rc_init_cplx complexity initial complexity for 1-pass encoding
-b_qfactor factor qp factor between p and b frames
-i_qfactor factor qp factor between p and i frames
-b_qoffset offset qp offset between p and b frames
-i_qoffset offset qp offset between p and i frames
-ibias bias intra quant bias
-pbias bias inter quant bias
-rc_eq equation set rate control equation
-rc_override override rate control override for specific intervals
-me method set motion estimation method
-me_threshold motion estimaton threshold
-mb_threshold macroblock threshold
-bf frames use 'frames' B frames
-preme pre motion estimation
-bug param workaround not auto detected encoder bugs
-strict strictness how strictly to follow the standards
-deinterlace deinterlace pictures
-psnr calculate PSNR of compressed frames
-vstats dump video coding statistics to file
-vhook module insert video processing module
-intra_matrix matrix specify intra matrix coeffs
-inter_matrix matrix specify inter matrix coeffs
-top top=1/bottom=0/auto=-1 field first
-sc_threshold threshold scene change threshold
-me_range range limit motion vectors range (1023 for DivX player)
-dc precision intra_dc_precision
-mepc factor (1.0 = 256) motion estimation bitrate penalty compensation
-vtag fourcc/tag force video tag/fourcc
-skip_threshold threshold frame skip threshold
-skip_factor factor frame skip factor
-skip_exp exponent frame skip exponent
-genpts generate pts
-qphist show QP histogram
-vbsf bitstream filter
Audio options:
-aframes number set the number of audio frames to record
-ab bitrate set audio bitrate (in kbit/s)
-aq quality set audio quality (codec-specific)
-ar rate set audio sampling rate (in Hz)
-ac channels set number of audio channels
-an disable audio
-acodec codec force audio codec ('copy' to copy stream)
-vol volume change audio volume (256=normal)
-newaudio add a new audio stream to the current output stream
-alang code set the ISO 639 language code (3 letters) of the current audio stream
Advanced Audio options:
-atag fourcc/tag force audio tag/fourcc
-absf bitstream filter
Subtitle options:
Audio/Video grab options:
-vd device set video grab device
-vc channel set video grab channel (DV1394 only)
-tvstd standard set television standard (NTSC, PAL (SECAM))
-ad device set audio device
-grab format request grabbing using
-gd device set grab device
Advanced options:
-map file:stream[:syncfile:syncstream] set input stream mapping
-map_meta_data outfile:infile set meta data information of outfile from infile
-benchmark add timings for benchmarking
-dump dump each input packet
-hex when dumping packets, also dump the payload
-re read input at native frame rate
-loop_input loop (current only works with images)
-loop_output number of times to loop output in formats that support looping (0 loops forever)
-threads count thread count
-vsync video sync method
-async audio sync method
-vglobal video global header storage type
-copyts copy timestamps
-shortest finish encoding within shortest input
-dts_delta_threshold timestamp discontinuity delta threshold
-ps size set packet size in bits
-error rate error rate
-muxrate rate set mux rate
-packetsize size set packet size
-muxdelay seconds set the maximum demux-decode delay
-muxpreload seconds set the initial demux-decode delay
AVCodecContext AVOptions:
-bit_rate <int> E.VA.
-bit_rate_tolerance <int> E.V..
-flags <flags> EDVA.
-mv4 E.V.. use four motion vector by macroblock (mpeg4)
-obmc E.V.. use overlapped block motion compensation (h263+)
-qpel E.V.. use 1/4 pel motion compensation
-loop E.V.. use loop filter
-gmc E.V.. use gmc
-mv0 E.V.. always try a mb with mv=<0,0>
-part E.V.. use data partitioning
-gray EDV.. only decode/encode grayscale
-psnr E.V.. error[?] variables will be set during encoding
-naq E.V.. normalize adaptive quantization
-ildct E.V.. use interlaced dct
-low_delay .DV.. force low delay
-alt E.V.. enable alternate scantable (mpeg2/mpeg4)
-trell E.V.. use trellis quantization
-bitexact EDVAS use only bitexact stuff (except (i)dct)
-aic E.V.. h263 advanced intra coding / mpeg4 ac prediction
-umv E.V.. use unlimited motion vectors
-cbp E.V.. use rate distortion optimization for cbp
-qprd E.V.. use rate distortion optimization for qp selection
-aiv E.V.. h263 alternative inter vlc
-slice E.V..
-ilme E.V.. interlaced motion estimation
-scan_offset E.V.. will reserve space for svcd scan offset user data
-cgop E.V.. closed gop
-fast E.V.. allow non spec compliant speedup tricks
-sgop E.V.. strictly enforce gop size
-noout E.V.. skip bitstream encoding
-local_header E.V.. place global headers at every keyframe instead of in extradata
-me_method <int> E.V..
-gop_size <int> E.V..
-cutoff <int> E..A. set cutoff bandwidth
-frame_size <int> E..A.
-qcompress <float> E.V..
-qblur <float> E.V..
-qmin <int> E.V..
-qmax <int> E.V..
-max_qdiff <int> E.V..
-max_b_frames <int> E.V..
-b_quant_factor <float> E.V..
-rc_strategy <int> E.V..
-b_strategy <int> E.V..
-hurry_up <int> .DV..
-bugs <int> .DV..
-autodetect .DV..
-old_msmpeg4 .DV..
-xvid_ilace .DV..
-ump4 .DV..
-no_padding .DV..
-amv .DV..
-ac_vlc .DV..
-qpel_chroma .DV..
-std_qpel .DV..
-qpel_chroma2 .DV..
-direct_blocksize .DV..
-edge .DV..
-hpel_chroma .DV..
-dc_clip .DV..
-ms .DV..
-lelim <int> E.V.. single coefficient elimination threshold for luminance (negative values also consider dc coefficient)
-celim <int> E.V.. single coefficient elimination threshold for chrominance (negative values also consider dc coefficient)
-strict <int> E.V..
-very E.V..
-strict E.V..
-normal E.V..
-inofficial E.V..
-experimental E.V..
-b_quant_offset <float> E.V..
-er <int> .DV..
-careful .DV..
-compliant .DV..
-aggressive .DV..
-very_aggressive .DV..
-mpeg_quant <int> E.V..
-rc_qsquish <float> E.V..
-rc_qmod_amp <float> E.V..
-rc_qmod_freq <int> E.V..
-rc_eq <string> E.V..
-rc_max_rate <int> E.V..
-rc_min_rate <int> E.V..
-rc_buffer_size <int> E.V..
-rc_buf_aggressivity <float> E.V..
-i_quant_factor <float> E.V..
-i_quant_offset <float> E.V..
-rc_initial_cplx <float> E.V..
-dct <int> E.V..
-auto E.V..
-fastint E.V..
-int E.V..
-mmx E.V..
-mlib E.V..
-altivec E.V..
-faan E.V..
-lumi_mask <float> E.V.. lumimasking
-tcplx_mask <float> E.V.. temporal complexity masking
-scplx_mask <float> E.V.. spatial complexity masking
-p_mask <float> E.V.. inter masking
-dark_mask <float> E.V.. darkness masking
-idct <int> EDV..
-auto EDV..
-int EDV..
-simple EDV..
-simplemmx EDV..
-libmpeg2mmx EDV..
-ps2 EDV..
-mlib EDV..
-arm EDV..
-altivec EDV..
-sh4 EDV..
-simplearm EDV..
-h264 EDV..
-vp3 EDV..
-ipp EDV..
-xvidmmx EDV..
-ec <flags> .DV..
-guess_mvs .DV..
-deblock .DV..
-pred <int> E.V.. prediction method
-left E.V..
-plane E.V..
-median E.V..
-aspect <rational> E.V..
-debug <flags> EDVAS print specific debug info
-pict .DV..
-rc E.V..
-bitstream .DV..
-mb_type .DV..
-qp .DV..
-mv .DV..
-dct_coeff .DV..
-skip .DV..
-startcode .DV..
-pts .DV..
-er .DV..
-mmco .DV..
-bugs .DV..
-vis_qp .DV..
-vis_mb_type .DV..
-vismv <int> .DV.. visualize motion vectors
-pf .DV..
-bf .DV..
-bb .DV..
-mb_qmin <int> E.V..
-mb_qmax <int> E.V..
-cmp <int> E.V.. full pel me compare function
-subcmp <int> E.V.. sub pel me compare function
-mbcmp <int> E.V.. macroblock compare function
-ildctcmp <int> E.V.. interlaced dct compare function
-dia_size <int> E.V..
-last_pred <int> E.V..
-preme <int> E.V..
-precmp <int> E.V.. pre motion estimation compare function
-sad E.V..
-sse E.V..
-satd E.V..
-dct E.V..
-psnr E.V..
-bit E.V..
-rd E.V..
-zero E.V..
-vsad E.V..
-vsse E.V..
-nsse E.V..
-w53 E.V..
-w97 E.V..
-dctmax E.V..
-chroma E.V..
-pre_dia_size <int> E.V..
-subq <int> E.V.. sub pel motion estimation quality
-me_range <int> E.V..
-ibias <int> E.V..
-pbias <int> E.V..
-coder <int> E.V..
-vlc E.V.. variable length coder / huffman coder
-ac E.V.. arithmetic coder
-context <int> E.V.. context model
-mbd <int> E.V..
-simple E.V..
-bits E.V..
-rd E.V..
-sc_threshold <int> E.V..
-lmin <int> E.V.. min lagrange factor
-lmax <int> E.V.. max lagrange factor
-nr <int> E.V.. noise reduction
-rc_init_occupancy <int> E.V..
-inter_threshold <int> E.V..
-flags2 <flags> EDVA.
-antialias <int> .DV..
-auto .DV..
-fastint .DV..
-int .DV..
-float .DV..
-qns <int> E.V.. quantizer noise shaping
-thread_count <int> EDV..
-dc <int> E.V..
-nssew <int> E.V.. nsse weight
-skip_top <int> .DV..
-skip_bottom <int> .DV..
-profile <int> E.VA.
-unknown E.VA.
-level <int> E.VA.
-unknown E.VA.
-lowres <int> .DV..
-frame_skip_threshold <int> E.V..
-frame_skip_factor <int> E.V..
-frame_skip_exp <int> E.V..
-skipcmp <int> E.V.. frame skip compare function
-border_mask <float> E.V..
-mb_lmin <int> E.V..
-mb_lmax <int> E.V..
-me_penalty_compensation <int> E.V..
-bidir_refine <int> E.V..
-brd_scale <int> E.V..
-crf <int> E.V..
-cqp <int> E.V..
-keyint_min <int> E.V..
-refs <int> E.V..
-chromaoffset <int> E.V..
-bframebias <int> E.V..
-trellis <int> E.VA.
-directpred <int> E.V..
-bpyramid E.V..
-wpred E.V..
-mixed_refs E.V..
-8x8dct E.V..
-fastpskip E.V..
-aud E.V..
-brdo E.V..
-complexityblur <float> E.V..
-deblockalpha <int> E.V..
-deblockbeta <int> E.V..
-partitions <flags> E.V..
-parti4x4 E.V..
-parti8x8 E.V..
-partp4x4 E.V..
-partp8x8 E.V..
-partb8x8 E.V..
-sc_factor <int> E.V..
-mv0_threshold <int> E.V..
-ivlc E.V.. intra vlc table
-b_sensitivity <int> E.V..
-compression_level <int> E.VA.
-use_lpc <int> E..A.
-lpc_coeff_precision <int> E..A.
-min_prediction_order <int> E..A.
-max_prediction_order <int> E..A.
-prediction_order_method <int> E..A.
-min_partition_order <int> E..A.
-max_partition_order <int> E..A.
neo@neo-desktop:~$
was nun, ich wollte eigentlich das ffmpeg programm starten/ ausführen?
