The following errors occur with Bios 1903 or newer. All errors have been reproduced and confirmed by several users.
* While overclocking, a memory frequency higher than 400-450Mhz is not possible. This occurs independent of processor- and memory type, as well of memory timing, voltage etc.
I don't know the reason. Maybe an internal timing is to fast.
* C&Q problem - With enabled fan control, only the cpu multiplicator, but not the voltage is decreased.
* C6Q only works works with a multiplicator below 19.
* x4-organised memory modules cause an error message [bankinterleave], that has to be confirmed by pressing F1, but run normal without further problems. I'd apprediate the possibility to set the [Bank Interleave] not only to auto and disabled, but also to enabled. (Yes, i know, auto are enabled, but it don´t work correctly with x4 organised memory modules)
We also have problems with the displayed cpu frequency while booting. For example, when using a Phemom II 965 and booting with 10x300 fails, in the "fail safe" mode 5100Mhz is displayed (default multiplicator * custom reference frequency). But this is only displayed incorrect, everything works fine.
Extra wishes:
* No volt core limitation, independent of cpu version.
* No Vdimm limitation (2,8v or more)
* The lastest RAID ROM in the BIOS release.
* Wake on Keyboard via USB, if possible
* Drive strength options in bios (DFI have it!)
* Additional possibility to fix the CPU-NB-Voltage, that isn't decreased by C&Q. This is needed if you need a high Vdimm while using C&Q. When C&Q decreases the VCore and the CPU-NB voltage and you use a high Vdimm, it will kill your IMC (Phenom I)
[...]@August:
Welche CPU hast du im Einsatz, bei der C&Q die Spannung bei aktivierter Lüftersteuerung nicht senkt?
Dito. Das Volt-Problem bei CnQ + Lüfterprofil is auch immer noch drin.
Hallo Leute,
ich weiß nicht ob die Frage schon fiel, aber bei meinem Phenom (siehe Sig) senkt sich die Spannung auf einmal nicht mehr, der Takt jedoch schon.
Weiß da jemand genaueres?
Wheity hat dann einfach nur zurück bekommen das sie "C&Q and correlative function", was auch immer mit letzterem genau gemeint ist, getestet hätten und kein Problem gefunden wurde. Anbei waren 2 Screen wo man sah das ein Phenom X4 9750 korrekt hoch/runter taktete.
Das wars. Auf den Rest gingen die nicht einmal ein.![]()
