This time my case to mod is a classic. Powermac G5. One of the most popular and ,one of the most modded beauttiful case ever made. As robustness , ı can say it is a PANZER.
someone showed his love like ...
Some prefer to use such
Powermac G5 is one oft most modded case. but most of them, changed outlook of the case
My goals for this Project were to preserve the look of the case at outside ;and fit my PC s hardware including a full ATX MB. And watercooling.
I will to mod at two stages
First the mod on the case and and convert it for an ATX (BTX) MB …
Thenn as second mod this case for Watercooling… with acrylic tubing and alphacool capecora passive rads 642+142= 742
To use an ATX mainboard at this case, the back panel must be changed.
İf we wannt to adapt the case to new motherboard. We must change
At the back panel, the fans must be moved off center, to make a new I/O. and a larger room
for 7 slots
There are a lot of mods, one of them is ,
to make a half mask as Ben Katz did.
Link: BuildIts: How to Fit Your PC in a Power Mac G5 Case
and mount them to thecase
Or we can use a MB tray with backpanel as gibsonc did.
Link : Powermac G5 Case mod - Mods and Overclocking - InsanelyMac Forum
And cut the case, to make a space
And mount it
But I wannt to make a new back panel complett. With new fan holes , I/O and slots.
I wannt to use the original fangrill as well.
Drawn at corel... but ı musst make nearly 3000 circles with 3mm Radius..
And sent to water jet for cutting….
OTHER WORKLOGS
Worklog http://www.hardwareluxx.de/community/f143/12-angry-men-spider-web-case-900-d-1080606.html
Worklog http://www.hardwareluxx.de/community/f143/playdoh-silverstone-tj-07-acrylic-pipe-1012476.html
Worklog http://www.hardwareluxx.de/communit...w-edition-acrylic-tubing-upgrade-1027807.html
Worklog http://www.hardwareluxx.de/community/f143/corsair-900-d-watercooled-mmt-case-997564.html
Worklog http://www.hardwareluxx.de/community/f143/jumbo-case-997157.html
Worklog http://www.hardwareluxx.de/community/f143/transformer-case-996669.html
Worklog http://www.hardwareluxx.de/community/f143/how-make-bench-case-old-atx-1-a-1032451.html
Worklog http://www.hardwareluxx.de/community/f143/4-way-hdd-switcher-1033308.html
Worklog http://www.hardwareluxx.de/community/f143/self-made-cosmos-ii-clear-panel-1034027.html#post22531803
Worklog http://www.hardwareluxx.de/communit...-watercooled-copper-acrylic-pipe-1028332.html
for 7 slots
And mount it
OTHER WORKLOGS
