[Sammelthread] Mining Hardware und Software Smalltalk-Thread (Kein Handel oder Fragen zum Steuerrecht!)
Die TON rewards sind aber auch heftig am schwanken.. Hatte die letzten tage auch wieder 0,38-0,4 pro GH am tag.. seit paar stunden liegt das bei 0,17 :LOL:
In den letzten 4h sogar nur 0,1476. Das wird sich wohl nicht mehr lange rentieren. Naja ist auch egal. Ab März halte ich die Hitze in meinem Büro vermutlich eh nicht mehr aus.
hat länger gehalten als ich dachte, aber es kennt nur eine Richtung. ^^
Screenshot 2022-02-15 at 11-54-55 The Open Network Mining-Rechner - Darkcoin ⛏️ minerstat.png
wielange ist TON eigentlich noch minebar? Es hieß ja afaik 6 Monate nur. Finde allerdings auf die schnelle nix darüber.
TON FAQ:
FAQ​
General​
Is TON PoS or PoW network?​
TON Blockchain uses the Proof-of-Stake consensus and mining is not required to generate new blocks.
So how come there is Proof-of-Work in TON?​
Well, the reason is that the initial issue of 5bn TON Coins was transferred to ad hoc Proof-of-Work Giver smart contracts. Mining is used to obtain TON Coins from this smart contract.
How many coins are left for mining?​
The most actual information is available on tonmine.xyz, see bleed graphs. PoW Giver contracts have their limits and will dry out once users mine all available TON Coins.
How many coins have been mined already?​
As of August 2021, about 4.9BN TON Coins have been mined.
Who has mined those coins?​
Coins have been mined to over 70'000 wallets, owners of those wallets are not known.
Is it difficult to start mining?​
Not at all, all you need is adequate hardware and to follow steps outlined in quick start section.
Is there another way to mine?​
Yes, there is a 3rd party app TON Miner Bot
Where can I see mining statistics?​
tonmine.xyz
How many miners are out there?​
We cannot say this, all we know is total hashrate of all miners on the network. There are however graphs on tonmine.xyz that attempt to estimate quantity of machines of certan type needed to provide aproximate total hashrate.
Do i need TON coins to start mining?​
No, you do not, anyone can start mining without owning a single TON Coin
I mine for hours, why my wallet total does not increase, not even by 1 TON?​
TONs are mined in blocks of 100, you either guess a block and receive 100 TON or receive nothing. please see basics
I mine for days and I see no results, why?​
Did you check your current Income estimates? If field Est. 24h chance to mine a block is less then 100% then you need to be patient. Also please do note that a 50% chance to mine a block within 24h does not automatically mean that you will mine one within 2 days, 50% applies to each day individually.
Are there mining pools?​
No, As of now there are no implementations of mining pools, everyone mines for himself.
Which giver should I mine?​
It does not really matter which giver you choose, difficulty tends to fluctuate on each giver, so current easiest giver on tonmine.xyz might become most complex within an hour, same applies in opposite direction.
thxx
Puh, ich glaube im Hochsommer hätte ich mir auch echt was überlegen müssen... Da kommt schon massiv wärme zusammen obwohl "nur" 700W mehr verbraucht wird
thxx
Ich glaube bis zum Sommer hat sich das Thema schon lange von alleine erledigt.
Neue Lolminer Version
lolMiner 1.45
Repository: Lolliedieb/lolMiner-releases · Tag: 1.45 · Commit: ede3f48 · Released by: Lolliedieb
lolMiner 1.45​
(hold on while we prepare the Windows builds)
Changes​
  • Added Ethash + Alephium dual mining mode analogous to existing Ethash + Ton mode. Use --dualmode ALEPHDUAL to use it. Supported GPUs: Nvidia Turing & Ampere generation, AMD Polaris (RX 400, 500), Navi and Big Navi generations.
  • Stratum connections will now have an increasing timeout (steps of 5 seconds) when reconnecting plus a small random time of 1 second in order to not overload the target pool in case of recovering from a network outtake.
  • lolMiner API now has new page /gui, which allows you to watch your rig mining in a web browser. Navigate to http://:/gui in your brower doing so.
  • Added experimental (at the moment a bit slow) Ethash kernels for new AMD BC-250 APUs
  • In dual mining the algorithm that mined a share will now be shown in command line output
  • --ton-mode 6 stratum mode will now obey the prefix send to it on the first bytes of the nonce (request from other pools that want to use this scheme)
  • Startup time of dual mining on non-LHR cards is now reduced to 30 seconds after DAG build
  • Removed --ton-mode 2 from automatic detection (you still can request it explicitly) - ton-pool.com will instead use mode 1 for existing and mode 6 for upcoming new stratum servers.
Fixes​
  • Fixed multiple stratum bugs - mostly crash fixes when running web socket based connections
Ich habe ein Rig von TON wieder runtergenommen, nachdem die
thxx
Ich habe ein Rig von TON runtergenommen...
ton-pool empfiehlt aktuell noch auf 1.43 zu bleiben. im telegram channel von denen is ne news diesbezüglich
Deine Werte habe ich über 24h nicht ansatzweise erreichen können.
Aktueller 24h Stand ist bei mir 0,235/GHs
Same, bin seit den letzten 10 stunden auch "nur" bei 0,22.. Mir kommt es auch so vor als würde Nachts der Profit deutlich mehr sein.. zumindest bin ich immer amused wenn ich morgens einen /balance check mache :LOL:
Jap, ich dachte schon, dass ich mir das einbilde :d
Ich teste jetzt 1.45 mit Ton-Pool.
Hab mit ddu Nvidia Treiber nochmal neu, Afterburner neue Version, Chipsatztreiber aktuell. Auslagerungsdatei auch erhöht. Mal gucken ob es jetzt besser läuft. Unter Windows weiterhin. Hive vom Stick ginge natürlich auch, aber da kann der Rechner ja nicht weiterminen wenn ich zocke..
Denk an die neue ton Pool Adresse die du nehmen musst - @tixomixo hatte die news ja schon angesprochen.
Ist der Ton Server gerade abgestürzt?
Hier die Erklärung:
Let us clarify the situation here. lolMiner 1.45 has new features in ton-mode 6 that are required to work with our new endpoints, and thanks to @Lolliedieb for that. However, it also dropped support for ton-mode 2. When running it against the original endpoint https://next.ton-pool.com, it sends a query every second, and we are not prepared to handle so many requests from our miners. Therefore, we do not allow using lolMiner 1.45 with https://next.ton-pool.com, and it will stop working in the future. The new endpoint is not well-tested and we cannot guarantee that it will work flawlessly. However, for miners who want to try it out, please use wss://eu1.stratum.ton-pool.com/stratum as the argument to --pool option. Right now, we recommend staying at lolMiner 1.43 before we get the new endpoint tested out. Once we get the new endpoint working, there may be more endpoints to come. Thanks for your support!
Mädels hat hier jemand einen Ledger ?:d hätte paar fragen und würde nicht gerne den Thread spammen deshalb wenn möglich den post-liken , dann schreib ich euch ne PM ( sind nur 1-2 fragen :d )
Da es hier zuletzt 2 mal schmorgebratene PCIe-Kabel/Stecker gab: Woran erkennt man ordentliche Qualität bei z.B. 8pin auf dual 6+2pin Y-Adaptern - am 18AWG Aufdruck? Sieht für mich alles nach dem gleichen gelb-schwarzen China-Standard-Kram aus.
Was ist mit dem ton-pool los, mining läuft, aber webseite und telegram scheint nicht erreichbar zu sein.
Zu viele Leute die ohne zu lesen LolMiner 1.45 installieren und dann den Pool abschießen. Wenn Du als SW - Entwickler Software raus gibst, wo die anderen über die Konfig nachdenken müssen, dann werden Sie es falsch machen ... ist immer so.
Ist jetzt wieder Online. Ich schau mir das jetzt noch ein paar Tage an und dann hör ich auf. Ich habe heute Nacht grade mal 1 TON gemacht bei 15,5GH. Bei den Rewards gerade und die Stromkosten bei Pool-Absturz sind es Imho nicht wert.
merkwürdig. ich hab von der downtime garnix mitbekommen. alles lief wie immer. habe auch über Nacht 4,5 TON gemacht (von 20 - 7Uhr).
ETH+ALPH ist jetzt auch nicht so zu verachten
