[Sammelthread] MSI 890FXA GD-70 (890fx)
MSI 890FX GD-70 Sammelthread
________________________________________________
Technische Daten
________________________________________________​
* Hersteller: MSI
* CPU-Sockel: Sockel AM3
* Formfaktor: ATX
* Mainboard Chipsatz: AMD 890FX (RD890)
* System-Bus (FSB / HT / QPI / DMI): 5.2 GT/s HT
* Grafikkarten Bus: PCI Express 2.0
* Arbeitsspeicher Typ: DDR3-SDRAM 1866MHz (PC3-15000)
* Anzahl der S-ATA Anschlüsse: 7
* Onboard Audiokanäle: 7.1
* Netzwerk Schnittstellen 2x
* Multi-GPU Unterstützung: CrossFire, CrossFireX
* Passive Kühlung: Ja
Weiter Informationen
Superb Stability: Military Class Components
OC Genie: Easy Overclocking Technology
Unlock CPU Core: Unlock hidden CPU core and potential
DrMOS: Best power efficiency
Support USB 3.0 AND SATA 6Gb/s
Lossless 24bit/192kHz HD Audio
CPU
• 64bit AMD® Phenom II X6/X4/X3/X2, Athlon II X4/X3/X2 and Sempron CPU.
Please refer to CPU Support for compatible CPU; the above description is for reference only.
140W Support
* Supports AMD high performance 140W CPUs
* Reserve the ability for future CPU upgrade
* To fully release the power of AMD CPUs
Hyper Transport Bus
• HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
• AMD® 890FX and SB850 Chipset
Main Memory
• Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600*/1800*/2133* (OC) SDRAM, 16GB Max
Slots
• 4 PCI Express 2.0 slots with x16 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI EXpress 2.0 slot (PCI_E4) with x4 operation (PCI Express Bus SPEC V2.0 compliant)
• 1 PCI Express 2.0 x1 slot
• 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board IDE
• One IDE port by JMicron® JMB363
- Supports Ultra DMA 66/100/133 mode
- Supports PIO, Bus Master operation mode
- Can connect up to two IDE devices
On-Board SATA
• 6 SATA III (1~6) ports by AMD® SB850
- Supports storage and data transfers at up to 6Gb/s
• 1 SATA II (SATA7) port by JMicron® JMB363
• 1 eSATA II / USB Combo port by JMicron® JMB363
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB850
Audio
• Chipset integrated by Realtek® ALC889/ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Realtek PCI-E GbLAN controller 8111DL
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
• VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 3 x USB 2.0 connectors
- 6 x Serial ATA III connectors
- 1 x Serial ATA II connector
- 2 x IEEE1394 connectors
- 1 x ATA133 HD connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Dial button
- 1 x OC Dial knob
- 1 x Green Power button
- 1 x Debug LED button
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 5 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 1 x eSATA / USB 2.0 Combo port
- 2 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
• 24.5cm(L) x 30.5cm(W) ATX Form Factor
Mounting
• 9 mounting holes.
Testberichte/Reviews/Homepage:
MSI-TV
MSI Review
Homepage MSI
Heise.de: (zurzeit ab ca. 148€ zuhaben.
http://preisvergleich.hardwareluxx.de/a527581.html
Bilder.
Bitte Verschieben.
Kann im Sammelthread keinen Beitrag schreiben.
Danke:bigok:
ich hab nu auf den äußeren 2 Bänken 2 ma 4 gig corsair ram mit 1333 1T un 9-9-9-25.
läuft wie immer stabil und es gibt niks zu meckern.
Im Glad.greezz vom seltsam
Danke GA ich warte iMO auf mein Phanteks Kühler, dann werde ich mal sehen welcher Ram dann noch passt. Corsair hatte ich aber auch im Auge.
Der ram ist nicht hoeher als ram ohne hs, sollte also auch unter den kuehlkoerper bzw luefter des clu kuehlers passen (was er bei mir tut)
@seltasam: mal ram auf 1600 mit cl9 versucht ? Packt doch fast jeder ram und bringt performance
Sent from my iPhone 4 using Hardwareluxx app
Jo Thrawn,danke für den hinweis auf den 6kerner.Bei meiner neuen Baustelle mit dem 990ziger mobo werde ich den Ernsthaft in Betracht ziehen.
Meine jetzige Hardware is so geil am Rennen das ich niks mehr daran ändere.
Wirklichen Schubkraftzuwachs habe ich nur durch den wechsel von HDD auf SSD bemerkt.
Wenn ich da an Socket A und mein hobby die sanduhr anstarren denke wird mir jetzt noch schlecht.
Win7 und ne SSD ist einfach nur schön))))
Dazu hab ich nun Win xp-x64 auf der WD-Caviar .
im verry glad.greezz vom hardwarejunkie
PS.mein case für den neuen rechner is der knüller.
Siehe mal die page von Origen AE und das case S21T....
ich denke da wird sich das 990 Pudelwohl fühlen)
Freue mich jetz schon wie ein Schneekönig))
Muss mir das case zuhause mal anschauen, hab bei nem kumpel das sabertooth 990fx verbaut, kann ich nur empfehlen, x6 auf 4,2 ghz is kein prob
Nochma zum x6, der ramcontroler bei denen wurde deutlich verbessert, hoher takt und cl1 usw ist kein prob, leider werden die teile immer teurer
Irgendwie läuft es nicht so rund, wenn ich die Vengeance Ram auf default 1600mhz ( 9-9-9-27 1.5V ) stell, bekomm ich irgendwann einen BSOD, ganz spontan so nach 20-30Min bei kaum intensiven Speicherzugriffen.
Hab jetzt die letzte Biosversion drauf, 960T läuft default mit 4 Kernen.
Auf meinem Ex 890FXA früher hatte ich XMS3 auch 1600er mit 8-8-8-20 1.65V laufen ohne Probleme, waren 2x2Gb Riegel. Aber das war 2009 mit einem X6 1090T.
Jetzt ist natürlich der Spekulatius riesengroß, Bios oder Ram
Warum wechselst von nem 1090T auf nen 960T ?
Hatte auch auf bulli gehofft und wurde extrem enttauescht..
Pildriver wird da auch nix mehr retten. Habe das sys vor allem noch weil das mobo so genial ist, aber naechstes jahr kommt def ein dickes update mit haswell I7, ssd, neues netzteil usw
