MSI 990FXA-GD80
Preis
MSI 990FXA-GD80 - Hardwareluxx - Preisvergleich
Spezifikationen
CPU
- 64bit AMD® Phenom II X8/X6/X4/X3/X2
- Athlon II X4/X3/X2
- Sempron CPU in AM3 / AM3+ package
Hyper Transport Bus
- HyperTransport 3.0 supporting speed up to 5200MT/s
Chipset
- Northbridge AMD® 990FX
- Southbridge AMD® SB950
BIOS/UEFI
- Click BIOS mit UEFI System
Main Memory
- Supports four unbuffered DIMM of 1.5 Volt DDR3 800/1066/1333/1600/1800*/2133* (OC) DRAM
- 32GB Max
Slots
- 4 PCI Express 2.0 x16 slots
- 2 PCI Express 2.0 x1 slots
- 1 PCI slot, support 3.3V/ 5V PCI bus Interface.
On-Board SATA
- 6 SATA III (1~6) ports by AMD® SB950
- Supports storage and data transfers at up to 6Gb/s
RAID Function
- SATA III 1~6 support RAID 0, 1, 5, 10 mode by AMD® SB950
- MSI Reminder: • The RAID setup floppy disk is optional depending on the districts. You can download the files from the website to make the setup disk.
USB 3.0
- 2 USB 3.0 ports by NEC® D720200
Audio
- Chipset integrated by Realtek® ALC892
- True Blu-ray Audio Support
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
- Realtek PCI-E GbLAN controller 8111E
- Integrated Fast Ethernet MAC and PHY in single chip
- Supports 10Mb/s, 100Mb/s and 1000Mb/s
- Compliance with PCI-Express Bus specification v1.0a
IEEE1394 / FireWire
- VIA® VT6315N chipset
- Supports up to two 1394 ports. (pinheader x2)
- Transfer rate is up to 400Mbps.
Internal I/O Connectors
- 1 x ATX 24-pin power connector
- 1 x ATX 8-pin 12V CPU power connector
- CPU x 1 / System x 4 FAN connectors
- 1 x Front panel audio connector
- 1 x Front panel connector
- 1 x Chassis intrusion switch connector
- 2 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 6 x Serial ATA III connectors
- 1 x IEEE1394 connector
- 1 x Serial port connector
- 1 x Power button
- 1 x Reset button
- 1 x OC Genie button
- 1 x Debug LED display
- 1 x Clear CMOS jumper
- 1 x SPDIF-out connector
- 1 x TPM module connector
Back Panel I/O Ports
- 1 x PS/2 Keyboard port
- 1 x PS/2 Mouse port
- 1 x Claer CMOS button
- 1 x Coaxial SPDIF-out
- 1 x Optical SPDIF-out
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports (blue)
- 2 x eSATA / USB 2.0 Combo ports
- 1 x RJ45 LAN Jacks
- 1 x 6 in 1 audio jack
Dimension
- 30.5cm x 24.4cm (Länge x Breite)
- ATX Form Factor
Bilder
Eigene Bilder
BIOS ( Screenshots sind aus der Version 11.4 )
Reviews
overclockingstation.de
legitreviews ( *English* )
Hardwareheaven ( Zusammen mit dem ASUS Crosshair V Formula *Englisch* )
MSI 990FXA-GD80 Premium Gaming Motherboard Unboxing & First Look Linus Tech Tips ( Youtube *Englisch* )
Downloads
MSI - BIOS
MSI - Treiber
MSI - Utilities
MSI - Manuals
BIOS-Changelogs
- 11.6
- - Update CPU AGESA code.
- - Add buzzer beep warning message with memory unplugged.
- - Improved memory compatibility.
- - Improved gaming mouse compatibility.
- 11.5
- - Update memory module.
- - Update RAID ROM version.
- - Update USB module.
- - Enhance CPU smart fan function.
- 11.4
- - Update CPU module.
- 11.2
- - Update NB module.
- 11.1
Kompatibilität
Kompatible Kühler:
- Corsair H70
OC-Werte
Sonstiges
So wie es aussieht, gibt es zurzeit ( Stand 15.10.2011 ) noch ein paar Probleme bezüglich diverser Eingabegeräte ( Logitech, Razer, Roccat ). Im BIOS sind die Mausbewegungen invertiert. Ein kommendes BIOS-Update soll aber schon in Planung sein. ( [/COLOR]"]Soll mit der offiziellen Version 11.6 der Vergangenheit angehören[/COLOR] )
FAQ - Frequently Asked Questions
Frage: Irgendwie sieht das BIOS nicht nach UEFI aus. Warum?
Antwort:Es ist durchaus ein UEFI-Bios, nur besteht es in den ersten Versionen nur aus einer "textähnlichen" UEFI-Version mit Maus-Unterstützung.
In der Version 11.4 wurde es komplett überarbeitet und besitzt jetzt eine komplette grafische UEFI-Umgebung *Link*
*Danke an Phantomias88*
