[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
Hi. Macht euch nicht verrückt.Verstehe nicht, warum noch etliche User auf Offset bei modernen S1155 CPus herumreiten.
Ist quasi ein Relikt aus S775-Zeiten, wo es im IDLE noch derbe Entlastung für CPU und Leistungsaufnahme gab.
Durch die serielle Anbindung von CPU und Controllunit ist das Schnee von gestern.
Du hast praktisch nur noch gaaanz geringe Verluste an den wenigen Spawa-Bausteinen, mit deinen 1,1V s 0,89V(geschätzt unter 0,5W).
Beispiel: Bei meinem GD55 liegen 1 Watt zwischen 1,3V und 0,96V Idle-Spannung.
Das ist aber wenig. Ich hatte ca. 5W Differenz bei meinem GD55 gemessen. Das entspricht 10%, die ich gerne mitnehmen würde.
Dein Board macht mit dem Ivy 4,4Ghz. Ist doch genial, mit dem günstigen Board.
Im Laberthread/OC-Thread "eiern" User mit gerade noch machbaren 4,5Ghz und 150-200 Euro-Boards rum.
Da hast Du recht. Anscheinend sind aber viele Bastler der Meinung 100Phasen und 30 USB3 Anschlüsse zu brauchen...
@X909
Da sagen meine Messungen etwas anderes. Ich kopiere die ganzen Werte aus dem Z77-Thread.
Erst einmal das Asus P8P67V, das vorher drin war.
So, fertig mit der Messerei. Ich habe zuerst die Optimized Defaults geladen, die AI Suite 1.02.12 war installiert und aktiv. Spannungen laut CPU-Z 1.60, Prime 26.6 zum Auslasten. Es wurde der ganze PC gemessen, also inklusive Wasserkühlung, vier Lüftern, GTX480, etc. CPU ist ein 2500K. Die Werte von V und W springen natürlich, insbesondere bei der Einstellung Phase Optimised, ich habe versucht, einen vernünftigen Mittelwert zu finden. Der Youtubekanal war übrigens von einem gewissen ralleh85, angezeigt mit Firefox 11 und deaktivierter Hardwarebeschleunigung. Die 480 ist gemoddet mit P8 und P12 auf 0.825V, lief bei den Videos immer im P8 mit 405/324Mhz.
Mit installierter AI Suite
Idle - 0.976V - 77W
Youtube - 0.960V - 87W
P95 1T - 1.208V - 103W
P95 4T - 1.192V - 138W
Mit installierter AI Suite, Phase Optimised
Idle - 0.960V - 73W
Youtube - 0.960V - 82W
P95 1T - 1.208V - 100W
P95 4T - 1.200V - 138W
Deinstallierte AI Suite, alles von Asus gelöscht, Asus-Dienste entfernt, Standard
Idle - 0.896V - 77W
Youtube - 0.880V - 87W
P95 1T - 1.152V - 100W
P95 4T - 1.136V - 130W (?)
Deinstallierte AI Suite, alles von Asus gelöscht, Asus-Dienste entfernt, Phase Optimised
Idle - 0.920V - 73W
Youtube - 0.904V - 82W
P95 1T - 1.152V - 97W
P95 4T - 1.136V - 131W
Alles Standard, alle Software von Asus entfernt, vCore im BIOS auf 1.30V
Idle - 1.240V - 80W
Ich verstehe nicht jeden Wert, aber jede Zahl ist überprüft. Um 6.00 klingelt der Wecker, bis dahin könnt ihr noch etwas anregen, wenn ich es in zehn Minuten umsetzen kann, werde ich es tun.
Jetzt der Umbau auf das Z77-GD65.
Endlich läuft wieder -fast- alles. Here are the results from the MSI mainboard: (MSI Z77A-GD65)
Insgesamt springt die Anzeige ziemlich wild, noch mehr als bei Asus mit optimierter Phase.
Idle - 67W
YT - 74W
P95 1T - 91W
P95 4T - 127W
Noch einmal mit dem BIOS 10.5.
Sachen gibt es. Da es mittlerweile mit 10.5 ein neues BIOS gibt, habe ich zuerst die normalen Messungen wiederholt.
Dabei liegen die Werte tendenziell eher noch einmal ein Watt unter der letzten Messung, wobei man für die Idle und Teillasten eigentlich den PC eine Stunde laufen lassen und danach den Gesamtverbrauch ablesen müsste. Die Sprünge sind schon recht stark. Für die OC-Liste taugen die Werte natürlich nicht, dafür müsste Prime länger laufen.
Idle 0.960/0.968V 66W, springt von 65 bis 67W
Youtube 0.968V 73W , 72-75W
Prime 1 Thread 85W, 82-90W
Prime 4 Threads 127W, 126-127W
Danach mit ClickBIOS II die CPU vCore auf 1.300V fest eingestellt, leider muss man danach neu booten, also eher sinnloses Feature.
Dummerweise zeigt mir jetzt mein Messgerät bei Prime 11-14W, im Idle 1-2W an, was ich durchaus bezweifle. Mal sehen, was sich da noch machen lässt.
Und noch einmal wiederholt, nachdem das Messgerät komplett vom Netz war und sich der Controller darin entladen konnte.
@Low
Denke nicht, dass bei meiner Messung ein Problem existiert. Wenn, dann zieht es sich durch alle Läufe, auch bereits beim Asus P67. Noch einmal die Werte ohne Tools.
Idle - 0.896V - 77W
Idle - 0.920V - 73W
Idle - 1.240V - 80W
MSI Z77A-GD65
Idle - 67W
YT - 74W
P95 1T - 91W
P95 4T - 127W
Verschoben ins Sammelthread Unterforum :wink:
Sehr ausführlicher Testbericht @ Dr. Unblutig.
Richtig. Genau das meinte ich. Es wird sich zu viel verrückt gemacht @ VOffset.
Wie ich sehe ist unser Board(GD55) immer noch sparsamer in allen Testphasen, ob IDLE,LAST,Teillast.
Warum also 100e Versuche mit IDLE-Spannungen austesten, bis Stabilität passt, wenns auch einfacher geht.
Gestern ein G43 bestellt inkl 3570k. Bin gespannt.
Nachdem die letzten Boards alle immer zwischen 150 und 200€ gekostet haben bin ich gespannt wie das G43 ist.
Hi leute,
hab ne Frage... habe auch das MSI Z77A-G43... nur die frage die ich habe ist... ich habe ne MSI GTX 560 Ti.. kann ichd ie auch ohne probleme auf den pci 3.0 slot verbauen? oder sollte ich doch eher den 2.0 nehmen?...
und wie schalte ich die intelgrafik aus?... hab gemerkt, dass ich beim zocken ab und zu mal ganz kurz pixelfehler bekomme.. und dachte das liegt evtl. daran.. und kennt ihr evtl. nen guten guide.. wo alles was man im bios so einstellen kann erklärt wird... das handbuch ist ja mal völlig falsch.... mit rechtschreibfehler und total sinnlose sätze stehen da zum teil drinne.. -.-
Danke im Vorraus
lg
Hawke
Habe das G43 in 2 neuen pcs fuer freunde verbaut und bin sehr begeistert (45W im idle mit 3770k und 3570k).
Bootet sauschnell, schnelles und gut aufgeteiltes uefi, super p/l verhaeltnis, spawakuehler
Wie findet ihr es ?
@hawke: du kannsts in den 3.0 slot stecken und auch im bios auf 3.0 stellen.
Die grafikfehler liegen an deine graka, die hd4000 hat damit nix zu tub
Sent from my iPhone 4 using Hardwareluxx app
Nabend, hier noch ein´ für die RAM-Liste
Bild: primeuswue7xb.jpg - abload.de
Hyper X T1, wird sauber gemäss Datenblatt erkannt und eingestellt.
Also bei mir war infolge irgendwelcher Treiberkonflikte mit der OnboardGPU (und wohl auch nicht mehr ganz taufrischem Systems) eine Windows Neuinstallation fällig. Aber mit im Bios deaktivierter IGD.
Nachtrag, irgendwie fehlt bei meinem G45 jegliche Möglichkeit im Bios die Vcore oder Vdimm manuell festzulegen. Wäre zwar vorhanden bleibt aber ausgegraut. Wollte ich mit nem Lukü-System nur mässig übertakten würde mir das mächtig auf den S... gehen.
So, bin inzwischen auch weitergekommen.
Alles auf default gesetzt, RAM 1333/cl9, und dann dieses "Control Center" mit "Intel ME Treiber" installiert.
Versucht ein Profil abzuspeichern > Rechner fährt runter, lässt sich nicht mehr starten:coolblue:
Was ist der intel ME treiber genau ?
Hab den nie installiert, funktioniert hat trotzdem alles..
Ihr scheint euch ja gut mit den MSI boards auszukennen :d ich blick da noch net ganz durch.. wie kann man denn die voltzahl verringern? hab gesehen, dass man nur erhöhen kann in nem dropdown menu... aba selber ne ziffer eintippen geht net irgendwie :/ hab einen i5 3570k wollte den mal untervolten und dabei den max. takt rausholen.... scheint aber leider net zu gehen -.-
@X909
Danke für die interessanten Werte. Das entscheidende ist aber nicht dabei: Ein Vergleich (selbes Board) mit niedriger Last (irgendwas bei dem die CPU noch nicht auf maximalen Takt geht, z.B. Video-Decoding OHNE dass die GPU die ganze Arbeit macht) und einmal mit funktionierendem EIST sowei einmal mit festgepinnter VCore. Wenn man mit Prime misst, taktet die CPU voll hoch - dann machts natürlich keinen Unterschied ob die Spannungssenkung bei EIST funktioniert.
Das sind natürlich Betriebszustände, die den Standard-User weniger interessieren. Wenn der Rechner aber 24/7 läuft und 1-2-Kerne laufend mit sehr geringer Last aktiv sind, macht das schon etwas aus. Auch wenns nur um 5W geht.
Und was ist mit der Messung Youtube-Video abspielen ohne GPU-Beschleunigung? Die ist bei mir im FF ausgeschaltet. Definiert Teillast herzustellen ist schon nicht ganz simpel, aber sie zu messen ist wahrlich schwierig. Die Werte springen oft locker 10W hin und her. Um da absolut belastbare Ergebnisse zu haben, wird man den über mindestens eine Stunde laufen lassen müssen mit Angabe des Gesamtenergieverbrauchs. Wenn man sich da nicht mit Stoppuhr daneben setzen will, braucht es doch etwas teureres Equipment.
Richtig toll wie ich mit meinen fragen hier konsequent ignoriert werde..
Hallo Leute
Wie sieht es eigentlich mit der OCbarkeit und dem P/L Verhältnis des GD45 aus? Verspricht das Millitary Class wirklich Qualität oder ist das nur wieder ein Fake
Frage zum MSI Z77A-GD55:
Wenn beim Start/Neustart noch ein USB3.0 Stick (Lexar Triton JumpDrive 16GB) an irgendnem USB3.0 Port steckt bleibt POST bei B4 hängen - zieh ich den ab gehts sofort weiter.
Gibts ne Lösung ?
hier noch paar Verbrauchsdaten mit minimaler Hardware:
MB: MSI Z77A-GD65
CPU: i7-3770 + NOCTUA NH-C14
NT: LC-7300
RAM: 16GB Corsair (2xCML8GX3M2A1600C9)
SSD: Samsung 830 128GB
Display´s: internes Display (HTPC) + angeschlossener Touch (USB), extern HDMI
Testinstallation: Windows 7 (ausbalanciert)
BIOS: unverändert
Windows IDLE: 23,7 W
Windows IDLE + Diplays aus: 21,8 W
auch die dicken CPU´s idlen recht gut, da brauchts keinen "S" oder "T" ;)
Dazu könnte ich jetzt was sagen wenn mein Mobo starten würde.
Hab aber nur nen Cursor oben links auf dem Monitor und die LEDs an Maus und Tastatur(USB) bleiben dunkel.
edit: cmos clear durchgeführt, alles überflüssige abgehängt, nur einen RAM-Riegel eingesteckt, CPU und Graka ausgetauscht.
Die Lüfter laufen und sonst rein garnix mehr.
Moin!
Wollte mir jetzt auch das GD65 kaufen, habe gelesen das es bei dem Asus Maximus V Gene probleme mit der Erkennung von ssds gibt.Wie sieht es denn bei dem msi aus, wollte eine Samsung 830 128gb verbauen.
gruß
Danke habe ich wohl überlesen ;)
Bin ich mal gespannt, ob mein Speetport W701v auch Probleme mit dem Intel DP67BG lan chip hat.
Bei mir läuft der Intel Lan mit den Speedport W700V einwandfrei ;)
Hab aber nur nen blinkenden Cursor oben links auf dem Monitor und die LEDs an Maus und Tastatur(USB) bleiben dunkel.
Es ist mir ein Rätsel, warum man in einem Technikforum Fragen stellt, die in zwei Minuten mit Google zu beantworten sind. Das ist der Treiber für die Intel Management Engine, damit kannst du bei MSI z.B. im Control Center die Einstellungen der Hardware ändern. Nutzt du solche Funktionen nicht, brauchst du ihn nicht zu installieren. Im abgesicherten Modus sollte er nicht geladen werden, dann kannst du ihn deinstallieren. Wichtig ist, dass Treiber und Firmware zusammenpassen. Der aktuelle Treiber funktioniert nur mit dem aktuellen BIOS. Im BIOS selbst siehst du auf der Startseite die Version.
Ich habe bei meinem GD65 auch eine SSD im Einsatz. Würde mich aber wundern, wenn Asus wirklich Probleme damit hätte. Dürfte ein Einzelphänomen sein.
Bei Au-Ja! - Startseite und aktuelle Meldungen im Test zum Asus Board stand nur, das sie am Anschluss des ASMedia ASM1061 eine Crucial M4 64GB nicht zum laufen gebracht haben.Hatte mich nur interessiert, ob vielleicht auch andere in der Hinsicht Probleme hatten, habe mir das Board jetzt bestellt hatte sonst eigentlich immer nur Asus aber das Msi macht einen soliden Eindruck.
Ist das richtig, dass nur die größeren GD65 und GD80 Modelle die Virtu MVP -Unterstützung haben?
Oder gibts diese auch schon beim GD55?
Das stimmt, einer der Unterschiede zwischen GD55 und GD65 ist die Virtu-Lizenz. Die kleineren Modelle wie das G45 haben dann auch nur noch die Unterstützung für Crossfire und nicht mehr für SLI.
@The_Jack
Wobei man eine SSD sowieso immer am schnellsten Anschluss betreiben sollte und das sind die Intel-SATAs. Insofern ist es ziemlich egal, wenn an dem ASMedia etwas nicht läuft.
Mir ist es ein Rätsel warum es überhaupt hardwareforen gibt wenn man doch alles googlen kann ?... Evtl weil google überhaupt erst die antworten in genau solchen foren findet ?
Naja ist überflüssig der Treiber, sonst wäre er bei den wichtigen sachen auf der mobo cd gewesen, 2 systeme gebaut und dei funzen 1a ohne das teil^^
btw war das nicht die einzige frage
Ja, da geb ich Dir Recht. Es ist nicht ganz simpel so etwas zu messen. Man kann den Rechner eigentlich nur mal einen Tag mit dem üblichen Workload laufen lassen und den Gesamtverbrauch in (Kilo)Wattstunden messen. Aber auch da hat man Ungenauigkeiten. HD-Video-Wiedergabe wäre nicht schlecht. Youtube erzeugt bei mir fast keine Last...
haben die MSIs eigentlich ähnliche Probleme mit Sandys wie die aktuellen Gigabyte Z77? Ich hab das UD3H und könnte es 3mal am Tag zum Fenster rauswerfen, weil der Bock nicht hochfahren will. Geht kurz an, geht dann wieder aus. Geht dann wieder kurz an .... etc, also ein richtig tolles Festplattenmassaker. Muss man kplt vom Strom trennen, dann klappt es meistens. Ansonsten 14h primestable etc. Und ich bin nicht der einzige, mindestens die Hälfte im Sammelthread haben die Probs mit Sandys.
Gibts solchen Murks auch mit den MSIs? Mist, ja gibts
Es ist halt bitter, dass MSI für Boards mit einer vergleichsweisen schlechten Ausstattung solche Apothekerpreise verlangt ...
Eher gab's ;) Hat sich dann mit einem BIOS-Update beheben lassen, siehe hier.
Ich schwanke derzeit auch zwischen einem GA UD3H und einem MSI GD55, preislich nehmen die sich ja nichts und mir reicht eigentlich die Ausstattung des GD55...hmm, mal sehn, was es letzten Endes wird.
