[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
Hi
Ich habe mir das GD55 geholt und bin damit auch sehr zu Frieden.Bis auf die Lüftersteuerung.
Ich lasse meine Lüfter immer Automatisch über Speedfan regeln aber leider bekomme ich das bei dem Board nicht hin.Manuell einstellen geht aber komischer weiße.
Hat noch jemand das Problem.Es ist der CPU und der Sys1 Anschluss.
lass es doch automatisch von der mobosteuerung steuern, kannste ja nen temp wert eingeben den die dann hält, und einen min lüfterwert, sprich ist die cpu unter z.b. 60 grad belbit der lüfter immer bei 40%, zumindest geht das so beim G43 und ist sehr gut gelöst, speedfan ist da unnötig
auf meinen G45 gehts, anfangs hatte ich da aber auch Probleme, weiss aber nicht mehr genau, was schief lief.
Kann dir ja mal meine Konfig screenshotten, heute Abend evtl. falls ich dazukomme
Hi
die Mobo steuerung macht mir zu viel Unfug.
@ Patric_ das währe super wenn du das machen könntest.
Tante Edit:
hat sich erledigt seit Heute gibt es eine neu Speedfan Version und da geht es.
THX
okok!
ich hatte 4.47 beta2 am Laufen
Hab jetzt seit ein paar Tagen das GD65. Ein sehr gute Platine (7751 Version 2.1)! :angel:
Ich würde gerne wissen, ob man Network Genie auch mit dem GD65 nutzen kann.
Das Board hat einen Intel-LAN Chip aber die Beschreibung beim Network Genie sagt:
Hardware:
MSI mainboard with Realtek LAN chip (8111E or newer).
Software specifications:
Realtek LAN driver
Heißt das jetzt nur Realtek oder auch andere Chips?
Hat jemand die Software am laufen (mit dem GD65)?
Ist sie zu empfehlen?
Nein, geht nur bei einem mit Realtek. Hab die Software auch mal versehentlich installiert :d
Tag :)
bin derzeit auch am überlegen mir ein GD65 / GD55 oder G45 zu kaufen.
kann mir jemand sagen was vor und Nachteile der einzelnen Boards sind ?
LG
Ich schreib einfach mal, was die größeren Boards jeweils besser machen:
G45 -> GD55:
-Intel, statt Realtek LAN Adapter (muss aber nicht besser sein, manche hier meinen auch, dass die Intel Probleme machen können?)
-Lucid Virtu MVP (äähm Moment, auf der Herstellerseite steht Virtu jetzt auch beim 45er)
-Auf dem Board gibts Knöpfe für Restart usw. (hauptsächlich für OCer interessant)
-SLI (kann aber auch nachgepatcht werden beim 45er)
GD55 -> GD65:
-3x PCIe 3.0
-besserer Audio Chip
-Firewire
-2x zusätzlich Sata 3 (bringt aber nicht viel mehr als Sata 2)
-Dual BIOS
-post anzeige
-Spannungspunkte zum Messen
Sollte ich was vergessen haben, bitte nachtragen.
Aber insgesamt fallen die Änderungen recht klein aus. Wenn du nicht sehr stark übertakten möchtest, reicht das 45er würde ich sagen.
die spannungsversorgung dürfte bei den gd modellen auch besser sein.
Hey,
danke euch erst einmal, hab noch eine frage hierzu:
hat dies einen Grund ? es sind doch 2 x SATA3 Ports?
http://www.hardwareluxx.de/communit...i-vs-sata-iii-vs-marvell-sata-iii-845761.html
Die Zusatz-Chips sind meist nicht besser, als die Chipsatz-SATA2-Ports. Da kommt es evtl. auf Deine speziellen Anforderungen an.
Leider verrätst Du ja nicht, was Dein Rechner eigentlich können soll. Deshalb kann man Dir eigentlich auch keine Empfehlung geben.
Die bessere Stromversorgung des GD65 wird z.B. (IMHO) erst ab Wasserkühlung (oder SubZero) und 4,8GHz aufwärts wichtig. Wenn Du gar nicht Übertakten willst, ist die Stromversorgung komplett unwichtig.
Die sind aber per Zusatzchip betrieben, sodass die Geschwindigkeit kaum schneller gegenüber Sata 2 ist.
auch wenn durch den hohen aufpreis sicher kein sehr starker grund, aber der stromverbrauch sollte auch etwas besser sein dadurch.
Ich hatte mein GD55 gegen das GD65 eines Freundes mit der selben Hardware getestet - das GD55 war im idle sparsamer.
Steht auch irgendwo hier im Thread.
Leider hatten wir kein G45 zum Vergleichen... da hätte man gesehen, ob Dr.MOS2 nur Marketing ist, oder die GD-Boards wirklich sparsamer sind.
ja, hatte deine werte gesehen.
denke es macht für den aufpreis zu wenig aus.
ich werd nächsten oder übernächsten Monat noch mal den Versuch wagen und mir nochmal ein GD55 kaufen :d
werde es wohl diese woche noch bestellen :d
ne, diesen Monat wurde bei mir genug bestellt. Das langt erstmal :d
Weiß eigentlich jemand was es mit dieser Phasen-LED auf sich hat? Bei mir leuchten im Windows-idle immer alle. Greift die Stromsparfunktion dann gar nicht oder ist das bei euch allen so?
Ich hab bei mir alle Stromsparfeatures aktiviert und die Vcore auf 0,82 gesenkt ;)
BTW: Mein Kühler kann auf die Kompatibilitätsliste gesetzt werden.
des funzt nur, wenn du alles auf auto hast, so war mir das in Erinnerung. Sobald du irgend ne Änderung selbst vor nimmst, greift des nimmer.
Weil ich jetzt mal wissen wollte, was die Phasenabschaltung wirklich bringt, habe ich es gerade mal ausprobiert. Meine Messwerte wurden mit Default Einstellungen gemacht:
Auto V: 72 W
manuell eingestellte Spannung: 75 W
Undervolting @ 0,81 V: 74 W (hier habe ich die laut UEFI effizientesten Einstellungen gewählt)
Die Phasenabschaltung bringt dann doch ein kleines bisschen was. Trotzdem ist das ganze sehr schlecht umgesetzt, weil mir der kleinsten Änderungen im OC-Menu funktioniert die Phasenabschaltung schon nicht mehr (ich habe im Haupt-OC-Menu alles auf auto gehabt und nur bei den sonder Features natürlich das bestmögliche zum Stromsparen ausgewählt). Für Leute, die ihre UEFI Einstellung also gerne anpassen, was wohl auch die Zielgruppe von den teuren Boards ist, ist das ganze echt eine Sauerei.
Das mit dem fehlenden Offset wusste ich ja schon davor, aber dass dann die ganzen Stromsparfeatures gar nicht greifen, obwohl man das eingestellt hat, ist schon wirklich schwach.
Ob jetzt andere Boards vielleicht nicht viel effizienter sind, wenn man die richtig einstellt, wäre eine interessante Frage?
Meine Messwerte wurden alle bei 3 GHz gemacht:
Dann hast du am Multiplikator herum gespielt, klappt auch da nicht mehr mit der dynamischen Phasenschaltung ;)
Alles was mit dem CPU Takt oder einer Spannung zusammenhängt deaktiviert beim ändern die Funktion,
so schön sich diese Funktion in der MSI Werbemaschinerie macht so nutzlos ist sie auch gleichzeitig bei der aktuellen Implantation für 99% der Käuferschicht weil man sie schlichtweg nicht nutzen kann!
Wenn es läuft hat man unter Last beim Spielen eine schöne Lichtorgel und genau unter solch wechselhaften Lasten müsste man auch die Funktion testen meiner Meinung nach.
