[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
MSI hat eine neue Final 10.6 für das GD65 herausgebracht. Das angegebene Changelog ist ziemlich kurz, da aber alle Fixes der ganzen Betas drin sind, ist dies nur ein Auszug der Änderungen. Vielleicht wird Notnagel im MSI Forum noch eine komplette Liste posten.
- Update CPU Micro Code.
- Update SMI flash module.
- Update M-Flash module for ME update.
- Improved memory compatibility.
- Support Corsair K90 gaming keyboard.
Download
ich brauche mal Hilfe. Ich benutze einen I5 2390T auf einem MSi z77MA-G45, letztes Bios ist geflasht, Win7 64 bit, alle Treiber, nichts verändert an den Energieeinstellungen...
Jetzt sollte dieser Dualcore mit HT 3 Taktstufe fahren können: 2,7/3,1/3.5 Je nach Auslastung auf den Kernen.
Wenn ich diese jetzt simuliere mit Prime kommt die Cpu immer auf 3,1. Egal ob 25%, 50%, 75%, 100%, Auslastung....
Mein zweiter Rechner ein 3770k auf einem Asus z68 schafft das genauso wie es soll.
Habt ihr eine Idee welche Bios Einstellung auf dem Msi für dieses Fehlverhalten zuständig ist?
Mit prime bekommst du wahrscheinlich auch nicht den schnellsten Turbo State. Denn wenn man nur zwei worker startet, werden trotzdem alle Kerne ausgelastet.
Die 3,5 bekommst du also nur, wenn zwei Kerne ausgelastet werden. Man könnte das vielleicht auch simulieren, indem du mit nur zwei Kernen bootest (sollte sich im UEFI einstellen lassen).
Doch Hibble bekomme ich... Siehe da:
Ein Worker in Prime
Ich habe ein Z77A-G45 + I7 3770.
@Prime: Alle 8 Threads = 3,7 GHz für alle Kerne.
1 Thread = Der Takt springt zwischen 3,7 / 3,8 /3,9 GHZ / Multi: 37/38/39
Ich vermute, dass der eine Thread von Windows zwischen einem echten Kern und dem "HT-Kern" springt.
Pinne ich den Prime Thread fest im Task Manager an einen Kern (z.B. CPU0), dann bleibt der Takt festgenagelt auf 3,9 GHZ.
Also an sich ist das Verhalten ja richtig.
Aber warum ich mich hier mal einklinke, ggf. hat jemand eine Idee:
Seit Jahren ziehe ich fast alle Treiber im Regelfall von den Chipherstellern, da diese im Regelfall (sofern vorhanden) am aktuellsten sind.
Bei Z77A-G45 bietet MSI z.T. Treiberversionen an (neuere Versions Nummer + Datum) als Intel selbst (US+deutsche Seite).
Wie kommen die zu den Treiber ? Betas sind es nicht, da WHQL zertifiziert.
Schöne Grüße
Adam
mal an alle GD55 Besitzer. Ist die Lüftersteuerung zu gebrauchen? Will meinen Lüfter vom Cpukühler mit 500rpm laufen lassen, dazu kommen nochmal 2 Lüfter fürs Case, die ich ebenfalls mit 500rpm laufen lassen möcht. Wenns dann entsprechend wärmer wird, sollen die dann auf maximal 800rpm hochdrehen.
ich kann nur fürs G45 sprechen: meinen PWM-Lüfter (die neuen Noiseblocker) kann ich per Speedfan auf 0% (oder 10%?) regeln, dann dreht er mit ~450-550upm. Weiter runter habe ich mit PWM-Regelung noch keinen Lüfter bekommen. Die 3pin-Lüfter kann ich über Speedfan sogar anhalten.
Speedfan will ich aber net nutzen, das soll das Board fein selbst machen ;)
selber schuld ;) :d da kann ich dir keine Auskunft geben, nutze immer SF
Das niedrigste was man bei den 3 pin Lüftern im UEFI einstellen kann, ist 50 %. Alternativ kann man den auch auf Auto stellen, dann sollte der wahrscheinlich nach der Temperatur gehen (wie weit der dann nach unten geht, kann ich nicht sagen, denke aber bis 50 %).
Mit dem neuen BIOS 10.6 ist mir heute nach dem MS-Patchtag ein interessantes Phänomen aufgefallen. Der warme Neustart dauert ewig. Die einzelnen Meldungen des BIOS über die Debug LEDs wie C6, B4, etc. stehen jeweils einige Sekunden still. Insgesamt dauert es locker 20-30 Sekunden (geschätzt, gefühlt war es eher noch länger), bis das BIOS komplett initialisiert ist. Beim Kaltstart ist bisher kein solches Problem vorgekommen, sonst fahre ich den PC nur hoch und runter. Ich werde das einmal beobachten, hat noch jemand solch ein Verhalten beim GD65 beobachtet?
Also, ich habe keine Probleme mit der neuen final.
Hast du auch die neue ME geflasht?
Die aktuell finale Version. Man beachte auch die ME-Version:
Hier die vorherige Version:
Klar, die ME habe ich bereits vor der neuen Final aktualisiert. Der Hänger ist auch nicht erneut aufgetreten, obwohl er sich beim Patchday zweimal identisch zeigte. Aber so oft brauche ich den Warmstart sowieso nicht, als dass mich dies besonders berühren würde.
Edit: Jetzt habe ich die Ursache gefunden. Hängt mein Streichelfon noch per USB zum Laden am PC braucht das BIOS ewig. Andere USB-Geräte wie MP3-Player oder USB-Stick rufen diese Verzögerung nicht hervor.
Oh man, mit dem neuen Bios kann man die OC Profile nicht weiter benutzen. Hatte da noch ein paar wichtige Profile, deshalb mach ich jetzt erst mal wieder das alte drauf.
Weiß eigentlich jemand was die ME ist?
Man kann sehr wohl OC Profile anlegen und diese auch laden! Bei mir funktioniert das einwandfrei.
Was du meinst, ist wohl, dass die zuvor angelegten Profile beim Update gelöscht werden. Das ist Tatsache. sollte längst bekannt sein.
Wer vor dem Update kein Backup der Einstellungen gemacht hat oder wenigstens einen Screenshot, ist selbst schuld...
Jetzt die alte Version drauf zu machen, macht auch keinen Sinn. Das stellt die zuvor angelegten Profile nicht wieder her!
D.h. so oder so "neu einstellen". ;)
---------- Post added at 19:44 ---------- Previous post was at 19:38 ----------
Die ME ist eine Firmware für den Chip(satz) und wird gelegentlich von Intel aktualisiert.
Ein UEFI/BIOS ist meist an eine entsprechende ME Version angepasst (optimiert).
Nein, ich meine doch, dass ich die Profile nicht mehr laden kann, weil bestimmte Optionen fürs OCen dazugekommen sind. Da kommt das UEFI nicht mit zurecht und verweigert das Laden der Profile.
Die Profile werden beim Flash nicht gelöscht. Sicherheitshalber habe ich die aber auch kopiert.
Ich bin vom 1.5er aufs 1.6er umgestiegen. Nur so als Info für die, die noch flashen wollen. Die Profile muss man sich also irgendwie als Screenshots abspeichern und dann neu anlegen!
Wenn man alles richtig gemacht hat und auch den C-Mos-Reset nach dem Update macht, sollten die Profiele weg sein. ;)
C-MOS Reset habe ich nicht gemacht. Durch so etwas verschwinden die Profile aber auch nicht. Warum sollte man das überhaupt tun, es werden doch sowieso die defaults geladen?!
Bei mir wurde jedenfalls die richtige Bios Version angezeigt und ME war nach erneutem Flash auch aktualisiert.
Kann mir hier jemand etwas zum Idle-Stromverbrauch der Z77 Boards von MSI sagen bei Übertaktung sagen. Bei meinem jetztigen P55-GD65 hat MSI ja leider irgendwann das APS abgeschaltet sobald man übertaktet und daduch erhöhte sich der Idle-Verbrauch enorm. Wie sieht das bei den Z77-Boards von MSI aus?
Ist genauso. Schau mal die Beiträge #269 und #280 an.
Bei mir sind es 3 W Unterschied, ob APS an oder aus ist.
Also, APS greift dann nicht mehr, aber scheinbar schnellt der Verbrauch dennoch nicht in die Höhe.
Schei***. Seit dem Updaten kann ich nicht mehr OCen. Immer wenn ich einen Wert über 34er Multi einstelle, läuft die CPU nur mit 34.
Wenn ich untertakte, nimmt er den Wert an..
Spannung wird z.B. auch angenommen, nur der Multi nicht. Ich werde echt verrückt mit dem Board -.-
Ich hab schon alles probiert: Bios Reset, Multi per Control Center verstellt, overspeed protection aus, 1.5er wie 1.6er Bios ausprobiert.
Die ME Version lässt sich aber nicht zurückflashen, oder? Ich hoffe ihr könnt mir helfen.
PS: Wenn ich übertakte, steht zwar im UEFI der richtige Takt, in Windows dann aber nicht. Der Takt wird wohl auch deswegen nicht angenommen, denn wenn ich übertakte startet der PC nicht komplett neu, sondern die Lüfter bleiben an und der PC bootet neu.
Bei meinem 3 GHz Profil, das auch funktioniert, ist alles normal (PC schaltet sich beim Übernehmen der neuen Werte ab und startet neu).
Nächster toller Bug, den ich gefunden habe: Immer wenn ich was in OC-Profil 2 oder 3 speichere, ist das Profil nach einem Neustart verschwunden :mad:
Ich bekomm meinen 3570k ohne Spannungserhöhung wohl nicht auf 4.5 GHz. :(
Hat jemand grad den Link zum OC-Thread parat? :wink:
das is doch normal, ohne erhöhung über 4,2ghz wäre schon abnormal...
überprüfe mal deine lastspannung mit cpu-z
dein mobo hat bestimmt die spannung selbst erhöht weils auf auto is
Hi
Ich benötige mal eine eine Auskunft von euch MSI Cracks.
Hab mir einacktete G45 für mein neues Modd-System zugelegt, und möchte den OC Genie Jumper ( JTURBO1 )
über einen externen Schalter ansteuern ( Schliesser ?)
Handbuch,Internet + MSI Website liefern wie immer keine Ergebnisse.
Frage: Wenn ich Jumper1 und Jumper3 vom Jturbo1 Brücke übertacktet er dann mit dem OC Genie oder hab ich nur einen Kurzschluss?
einen sonnigen Sonntag weiterhin
Ich hab jetzt endlich den Übeltäter bei mir gefunden. Die Option "Power technology" muss auf Custom und nicht disabled sein.
Das Board ist so verbuggt, das ist echt schlimm. Mit dem neuen Bios wurde jetzt wohl alles noch viel schlimmer :[
Danke für den Hinweis, zur automatischen Spannungserhöhung!:hail:
Ich habe schließlich direkt in Windows, schrittweise mit dem "ControlCenter", übertaktet.
Dabei habe ich die CPU-Spannung auf Auto gelassen, um zu sehen wie weit sie hoch geht, wenn ich den Multi ehrhöhe:
Angefangen bei 4,2 GHz, da diese selbst ohne Spannungserhöhung laufen.
4,3 GHz:
4,4 GHz:
4,5 GHz 1,176V stellt ControlCenter automatisch ein.
Schließlich habe ich im UEFI die 1,1700V eingestellt. Unter Last fällt die Spannung dann auf 1,16V. Vielleicht lässt sich das noch optimieren, aber die angestrebten 4,5 habe ich mit relativ wenig Aufwand erreicht. (Wirklich praktisch das ControlCenter.) :angel:
Ein Test mit dem Multi 46 und Spannung auf AUTO lässt aber Prime sofot abstürzen.
Anschließend habe ich die Spannung auf den "24/7-Max.-Wert: 1,2V" eingestellt und den Multi auf 46 gesetzt.
-> Leider stürzt hier wieder Prime ab. Aber es kommt kein BSOD.
Der Turbo ist übrigens aus (lasst ihr ihn auch aus, oder ist das egal?).
Wie geht Ihr vor, wenn ihr über die 4,5 GHz übertaktet?
Das er bei Multi 45 austeigt liegt an der Option zum überschreiben.
Wenn schon OC dann mit Turbo, ist einfach schöner was den Stromverbrauch angeht.
Pll Overwrite oder so heißt die. Dann gehen normalerweise Multis über 45. Einfach auf Enabled setzen und dann müsste 46+ gehen.
